CK45-R3FD102K-NRA
CK45-R3FD102K-NRA
    TDK(东电化)
    插件
    贴片电容(MLCC) 径向 1nF ±10% 3KV R
CK45-R3FD102K-NRA 数据手册
C A P A C I T O R S February 2016 Disc Type Capacitors with Lead High Voltage Ceramic Capacitors Commercial Grade, Low dissipation at high frequency CK45-RR series Type: CK45-R [R characteristics, Edc: 1kV to 3kV] (2/8) C A P A C I T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and product temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Please refer to the guideline of notabilia for fixed ceramic capacitors issued by JEITA(Japan Electronics and Information Technology Association, EIAJ RCR-2335). When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 20160219 / leaddisc_commercial_ck45-rr_en.fm (3/8) C A P A C I T O R S Disc Type Capacitors with Lead Product compatible with RoHS directive Halogen-free High Voltage Ceramic Capacitors, Commercial Grade, Low dissipation at high frequency Overview of CK45-RR Series FEATURES Mainly used as withstand voltage protection for power transistors and diodes of switching power sources, for controlling noise, and for absorbing highfrequency pulses. Low dissipation factor, and decreased self-heating temperature in the high frequency, and high voltage application. These products shall conform to RoHS Directive due to lead(Pb) free of lead wire and internal solder material. Compatible with halogen-free external resin coating. APPLICATION For use in snubber circuit protection for power supplies PART NUMBER CONSTRUCTION CK45 Series name R 3AD 102 K Temperature characteristics Rated voltage Nominal capacitance Capacitance tolerance R +15, –30% 3AD 3DD 3FD 1kV 2kV 3kV 101 102 222 100pF 1,000pF 2,200pF K ±10% G N V □ R A Lead type Application classification Internal code Long lead Short lead Taping R Low dissipation A Halogen-free Please refer to P-5~7 about the product dimensions. OPERATING TEMPERATURE RANGE Temperature characteristics R Temperature range Operating temperature (°C) –25 to +125 Storage temperature (°C) –25 to +125 The maximum operating temperature of 125°C includes capacitor self-generated heat of up to 20°C. The storage temperature range applies to after MLCC is mounted on board. PACKAGE QUANTITY Package quantity Type CK45-R Taping (pieces / box) Bulk (pieces / bag) 1000 1000 500 pieces applies to the following parts. CK45-R3DD222K-VRA CK45-R3FD152K-VRA RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45-rr_en.fm (4/8) C A P A C I T O R S Overview of CK45-RR Series RECOMMENDED FLOW PROFILE Soldering Preheating Natural cooling T: Temperature T2 T1 t1 t2 t3 t: Time Preheating Temp. T1 110°C min. Time t1 30 to 60s. Peak Temp. T2 260°C Time t2 Within 10s. Natural cooling Time t3 Over 60s. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45-rr_en.fm (5/8) C A P A C I T O R S CK45-R Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: R (+15, –30%) Rated Voltage Edc: 1kV Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) ±10% 6.0 5.0 5.0±1.5 ±10% 6.0 5.0 5.0±1.5 ±10% 6.0 5.0 5.0±1.5 ±10% 6.5 5.0 5.0±1.5 ±10% 7.0 5.0 5.0±1.5 ±10% 8.0 5.0 5.0±1.5 ±10% 9.0 5.0 5.0±1.5 ±10% 10.0 5.0 5.0±1.5 ±10% 11.5 5.0 7.5±1.5 F (Applied to taping) 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 7.5±0.8 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V1 V1 V1 V1 V1 V1 V1 V1 V2 CK45-R3AD101K-□RA CK45-R3AD151K-□RA CK45-R3AD221K-□RA CK45-R3AD331K-□RA CK45-R3AD471K-□RA CK45-R3AD681K-□RA CK45-R3AD102K-□RA CK45-R3AD152K-□RA CK45-R3AD222K-□RA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-8 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F d T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45-rr_en.fm (6/8) C A P A C I T O R S CK45-R Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: R (+15, –30%) Rated Voltage Edc: 2kV Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) ±10% 6.0 5.0 5.0±1.5 ±10% 6.0 5.0 5.0±1.5 ±10% 7.0 5.0 5.0±1.5 ±10% 7.5 5.0 5.0±1.5 ±10% 8.5 5.0 5.0±1.5 ±10% 9.5 5.0 5.0±1.5 ±10% 11.0 5.0 5.0±1.5 ±10% 12.0 5.0 7.5±1.5 ±10% 14.5 5.0 7.5±1.5 F (Applied to taping) 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 5.0+0.8, –0.2 7.5±0.8 7.5±0.8 d Taping Part No. dimensions 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V1 V1 V1 V1 V1 V1 V1 V2 V3 CK45-R3DD101K-□RA CK45-R3DD151K-□RA CK45-R3DD221K-□RA CK45-R3DD331K-□RA CK45-R3DD471K-□RA CK45-R3DD681K-□RA CK45-R3DD102K-□RA CK45-R3DD152K-□RA CK45-R3DD222K-□RA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-8 about the taping dimemsions. LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F d T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45-rr_en.fm (7/8) C A P A C I T O R S CK45-R Type CAPACITANCE AND DIMENSIONS Temperature Characteristics: R (+15, –30%) Rated Voltage Edc: 3kV Capacitance (pF) 100 150 220 330 470 680 1,000 1,500 2,200 Dimensions (mm) Capacitance F tolerance D max. T max. (Applied to bulk) ±10% 6.0 6.0 7.5±1.5 ±10% 7.0 6.0 7.5±1.5 ±10% 7.5 6.0 7.5±1.5 ±10% 8.5 6.0 7.5±1.5 ±10% 9.5 6.0 7.5±1.5 ±10% 10.5 6.0 7.5±1.5 ±10% 12.0 6.0 7.5±1.5 ±10% 14.5 6.0 7.5±1.5 ±10% 16.5 6.0 10.0±2 F (Applied to taping) 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 7.5±0.8 — Taping Part No. dimensions d 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V2 V2 V2 V2 V2 V2 V2 V3 CK45-R3FD101K-□RA CK45-R3FD151K-□RA CK45-R3FD221K-□RA CK45-R3FD331K-□RA CK45-R3FD471K-□RA CK45-R3FD681K-□RA CK45-R3FD102K-□RA CK45-R3FD152K-□RA CK45-R3FD222K-□RA * The part numbers are TDK’s standard specification products. The " □ " of the Part Number contains the lead type, G, N or V. Please refer to the details of each shape is shown below. Please refer to P-8 about the taping dimemsions. Bulk package is standard specification, however, taping package is also available, please contact us LIST OF STANDARD LEAD SHAPES Dimemsions in mm Symbol V Taping T F d 5±1 25min. Vertical kink F d T 4max. D 4max. D T 4max. D Symbol N Bulk/Short lead 16+1.5 –0.5 Symbol G Bulk/Long lead F d • TDK’s standard product is vertical kink. • TDK’s recommendation is short lead type with the symbol N for bulk products. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45-rr_en.fm (8/8) C A P A C I T O R S CK45-R Type TAPING DIMEMSIONS D T P2 P D Δh T P2 Δh C H0 L D0 P0 ød P1 F D0 ød t t P0 S W0 W W0 W L W1 H0 H1 S H0 C W2 H0 H1 W1 P1 F Δh A A Δh W2 P V1, V2 Item V3 Symbol Dimensions(mm) V1 V2 V3 Remarks Body diameter D Depends on the specification of each product. Body thickness T Depends on the specification of each product. Lead-wire diameter ød 0.6±0.05 0.6±0.05 Pitch of component P 12.7±1.0 15.0±1.0 30.0±1.0 Including the slant of body Feed hole pitch P0 12.7±0.3 15.0±0.3 15.0±0.3 Excepting the tape splicing part Feed hole center to lead P1 3.85±0.7 3.75±0.7 3.75±0.7 Feed hole center to component center P2 6.35±1.3 7.5±1.3 7.5±1.3 Lead-to lead distance F 5+0.8, –0.2 7.5±0.8 7.5±0.8 Measuring point is bottom kink Component alignment 'h 0±2.0 0±2.0 0±2.0 Including the slanting body due to bending lead-wire Tape width W 18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5 Adhesive tape width W0 10.0min. 10.0min. 10.0min. Hole position W1 9.0±0.5 9.0±0.5 9.0±0.5 Adhesive tape position W2 4.0max. 4.0max. 4.0max. Bottom of kink from tape center H0 16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5 Height of body from tape center H1 46.0max. 46.0max. 46.0max. 1.0max. 1.0max. 1.0max. Lead-wire protrusion 0.6±0.05 Feed hole diameter D0 4.0±0.2 4.0±0.2 4.0±0.2 Total tape thickness t 0.6±0.3 0.6±0.3 0.6±0.3 Length of snipped lead L 11.0max. 11.0max. 11.0max. Coating on lead C 4.0max. 4.0max. 4.0max. Height of kink A 4.0max. 4.0max. 4.0max. Spring action S 2.0max. 2.0max. 2.0max. Adhesive tape do not stick out the tape Including adhesive tape Measuring point is bottom kink 320max. AMMO PACK INNER BOX SIZE x. ma 340max. 60 Dimensions in mm • For more information about products with other capacitance or other data, please contact us. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160219 / leaddisc_commercial_ck45-rr_en.fm
CK45-R3FD102K-NRA
物料型号:CK45-RR系列
器件简介:这些电容器是高压陶瓷电容器,具有R特性,适用于商业级应用,低频下耗散小。
引脚分配:文档中提到了不同的引脚类型,包括长引脚(G)、短引脚(N)和卷带(V)。
参数特性: - 工作温度范围:-25°C 至 +125°C - 存储温度范围:-25°C 至 +125°C - 额定电压:1kV、2kV、3kV - 电容公差:±10% - 电容值范围:100pF至2200pF
功能详解:主要用于开关电源中功率晶体管和二极管的耐压保护,控制噪声和吸收高频脉冲。
应用信息:适用于电源的消振电路保护。
封装信息:提供了不同电容值的尺寸和封装信息,包括最大直径(D)、最大厚度(T)、引脚直径(ød)、组件间距(P)等。
CK45-R3FD102K-NRA 价格&库存
很抱歉,暂时无法提供与“CK45-R3FD102K-NRA”相匹配的价格&库存,您可以联系我们找货
