CKCL44X5R0J104M085AA 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS
CKC Series
Commercial Grade
4 in 1 Array
Type:
CKCL44 [EIA CC0805]
CKCA43 [EIA CC1206]
Issue date:
Dec 2014
20141219 / mlcc_commercial_4array_en
REMINDERS
Please read before using this product
SAFETY REMINDERS
REMINDERS
1.
If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage,
you must contact our company’s sales window.
2.
We may modify products or discontinue production of a product listed in this catalog without prior notification.
3.
We provide “Delivery Specification” that explain precautions for the specifications and safety of each product
listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers
that use one of these products.
4.
If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according
to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export
permission in harmony with this law.
5.
Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our
company.
6.
We are not responsible for problems that occur related to the intellectual property rights or other rights of our
company or a third party when you use a product listed in this catalog. We do not grant license of these rights.
7.
This catalog only applies to products purchased through our company or one of our company’s official agencies.
This catalog does not apply to products that are purchased through other third parties.
Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging
specification detail. This new catalog number should be referenced on all catalog orders going forward, and
is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will
differ from the item description (internal control number) on the product label. Contact your local TDK Sales
representative for more information.
(Example)
Catalog Issued date
Catalog Number
Item Description (On Delivery Label)
Prior to January 2013
C1608C0G1E103J
C1608C0G1E103JT000N
January 2013 and Later
C1608C0G1E103J080AA
C1608C0G1E103JT000N
Page 1
CKC Series
4in1 Array Capacitors
Type: CKCL44 [EIA CC0805], CKCA43 [EIA CC1206]
Applications
• Multiple capacitors are fitted in a single product, contributing to reduced installation costs.
• The electrostatic capacity range and shape are designed to
meet the demands of the cellular phone market.
• Unique electrode construction reduces crosstalk.
L
W
T
C
P
PC Board
Pattern
Body Length
Body Width
Body Height
Terminal Width
Terminal Spacing
Cellular telephone interface
Interface cable circuit
PC and peripherals
CPU bus line
High frequency circuit
Noise bypass circuit
CKCL44
CKCA43
0.4
0.25
0.6 0.55
Shape &
Dimensions
0.8-1.0 0.6-0.7
Features
Dimensions in mm
Catalog Number
Construction
CKC • A43 • X5R • 0J • 105 • M • 100 • A • A
Series Name
Dimensions L x W (mm)
Code
L44
A43
Length
2.00 ± 0.15
3.20 ± 0.20
Width
1.25 ± 0.15
1.60 ± 0.15
Temperature Characteristics
Temperature
Characteristics
C0G
CH
JB
X5R
X7R
Temperature Coefficient or
Capacitance Change
0±30 ppm/°C
0±60 ppm/°C
±10%
±15%
±15%
Temperature
Range
-55 to +125°C
-25 to +85°C
-25 to +85°C
-55 to +85°C
-55 to +125°C
Rated Voltage (DC)
Code
0J
1A
1C
1E
1H
Voltage (DC)
6.3V
10V
16V
25V
50V
Nominal Capacitance (pF)
The capacitance is expressed in three digit codes and in units of pico
Farads (pF). The first and second digits identify the first and second
significant figures of the capacitance. The third digit identifies the
multiplier. R designates a decimal point.
([5 S) S) S) Q) ȝ)
Capacitance Tolerance
Code
F
K
M
Tolerance
± 1pF
± 10%
± 20%
Nominal Thickness
Code
085
100
Thickness
0.85 mm
1.00 mm
Packaging Style
Code
A
Style
178 mm Reel, 4 mm Pitch
Special Reserved Code
Code
A
Description
TDK Internal Code
Page 2
• All specifications are subject to change without notice.
Capacitance
Range Chart
CKCL44(C2012) [EIA CC0805]
Capacitance Range Chart
Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), JB (± 10%), X5R (± 15%), X7R (± 15%)
Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J)
Capacitance
(pF)
10
15
22
33
47
68
100
150
220
470
1,000
2,200
4,700
10,000
22,000
47,000
100,000
Capacitance
(pF)
220
470
1,000
2,200
4,700
10,000
22,000
47,000
100,000
Code
100
150
220
330
470
680
101
151
221
471
102
222
472
103
223
473
104
Tolerance
C0G
CH
1H
(50V)
1H
(50V)
1H
(50V)
1E
(25V)
JB
1H
(50V)
1E
(25V)
1C
(16V)
1A
(10V)
0J
1A
(10V) (6.3V)
1H
(50V)
F: ± 1pF
K: ± 10%
X5R
Code
221
471
102
222
472
103
223
473
104
0J
(6.3V)
Tolerance
1C
(16V)
X7R
1E
(25V)
1C
(16V)
M: ± 20%
Standard Thickness
0.85 mm
Page 3
Capacitance
Range Chart
CKCA43(C3216) [EIA CC1206]
Capacitance
(pF)
10
15
22
33
47
68
100
150
220
330
470
680
1,000
Capacitance
(pF)
470
1,000
2,200
4,700
10,000
22,000
47,000
100,000
1,000,000
Code
100
150
220
330
470
680
101
151
221
331
471
681
102
Tolerance
C0G
CH
1H
(50V)
1H
(50V)
1H
(50V)
1E
(25V)
F: ± 1pF
K: ± 10%
JB
Code
471
102
222
472
103
223
473
104
105
Tolerance
1C
(16V)
X5R
1H
0J
(6.3V) (50V)
1E
(25V)
1C
(16V)
X7R
1H
0J
(6.3V) (50V)
1E
(25V)
1C
(16V)
M: ± 20%
Standard Thickness
1.00 mm
Page 4
Capacitance
Range Table
Class 1 (Temperature Compensating)
Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC)
Capacitance
10 pF
15 pF
22 pF
33 pF
47 pF
68 pF
100 pF
150 pF
220 pF
330 pF
470 pF
680 pF
1 nF
Size
Thickness
(mm)
Capacitance
Tolerance
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
3216
3216
3216
3216
3216
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.10
1.00 ± 0.15
1.00 ± 0.10
1.00 ± 0.15
1.00 ± 0.10
1.00 ± 0.15
± 1%
± 1%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
Catalog Number
Rated Voltage Edc: 50V
CKCL44C0G1H100F085AA
CKCA43C0G1H100F100AA
CKCL44C0G1H150K085AA
CKCA43C0G1H150K100AA
CKCL44C0G1H220K085AA
CKCA43C0G1H220K100AA
CKCL44C0G1H330K085AA
CKCA43C0G1H330K100AA
CKCL44C0G1H470K085AA
CKCA43C0G1H470K100AA
CKCL44C0G1H680K085AA
CKCA43C0G1H680K100AA
CKCL44C0G1H101K085AA
CKCA43C0G1H101K100AA
CKCL44C0G1H151K085AA
CKCA43C0G1H151K100AA
CKCA43C0G1H221K100AA
CKCA43C0G1H331K100AA
CKCA43C0G1H471K100AA
CKCA43C0G1H681K100AA
CKCA43C0G1H102K100AA
Rated Voltage Edc: 25V
Rated Voltage Edc: 16V
Rated Voltage Edc: 10V
Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC)
Capacitance
10 pF
15 pF
22 pF
33 pF
47 pF
68 pF
100 pF
150 pF
220 pF
330 pF
470 pF
680 pF
1 nF
Size
Thickness
(mm)
Capacitance
Tolerance
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
3216
3216
3216
3216
3216
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.10
0.85 ± 0.15
1.00 ± 0.10
1.00 ± 0.10
1.00 ± 0.10
1.00 ± 0.10
1.00 ± 0.10
1.00 ± 0.10
± 1%
± 1%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
± 10%
Catalog Number
CKCL44CH1H100F085AA
CKCA43CH1H100F100AA
CKCL44CH1H150K085AA
CKCA43CH1H150K100AA
CKCL44CH1H220K085AA
CKCA43CH1H220K100AA
CKCL44CH1H330K085AA
CKCA43CH1H330K100AA
CKCL44CH1H470K085AA
CKCA43CH1H470K100AA
CKCL44CH1H680K085AA
CKCA43CH1H680K100AA
CKCL44CH1H101K085AA
CKCA43CH1H101K100AA
CKCL44CH1H151K085AA
CKCA43CH1H151K100AA
CKCA43CH1H221K100AA
CKCA43CH1H331K100AA
CKCA43CH1H471K100AA
CKCA43CH1H681K100AA
CKCA43CH1H102K100AA
Page 5
Capacitance
Range Table
Class 2 (Temperature Stable)
Temperature Characteristics: JB (-25 to +85ºC, ±10%)
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
220 pF
470 pF
100 nF
2012
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
3216
0.85 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
1.00 ± 0.15
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
100 nF
1 μF
2012
3216
0.85 ± 0.15
1.00 ± 0.15
± 20%
± 20%
1 nF
2.2 nF
4.7 nF
10 nF
22 nF
47 nF
Catalog Number
CKCL44JB1H221M085AA
CKCL44JB1H471M085AA
CKCA43JB1H471M100AA
CKCL44JB1H102M085AA
CKCA43JB1H102M100AA
CKCL44JB1H222M085AA
CKCA43JB1H222M100AA
CKCL44JB1H472M085AA
CKCA43JB1H472M100AA
CKCL44JB1E103M085AA
CKCA43JB1H103M100AA
CKCL44JB1C223M085AA
CKCA43JB1H223M100AA
CKCL44JB1A473M085AA
CKCA43JB1E473M100AA
CKCA43JB1C104M100AA
Catalog Number
Rated Voltage Edc: 6.3V
CKCL44JB0J104M085AA
CKCA43JB0J105M100AA
Temperature Characteristics: X5R (-55 to +85ºC, ±15%)
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
220 pF
1 μF
2012
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
3216
0.85 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
0.85 ± 0.15
1.00 ± 0.15
1.00 ± 0.15
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
100 nF
1 μF
2012
3216
0.85 ± 0.15
1.00 ± 0.15
± 20%
± 20%
470 pF
1 nF
2.2 nF
4.7 nF
10 nF
22 nF
47 nF
100 nF
Catalog Number
CKCL44X5R1H221M085AA
CKCL44X5R1H471M085AA
CKCA43X5R1H471M100AA
CKCL44X5R1H102M085AA
CKCA43X5R1H102M100AA
CKCL44X5R1H222M085AA
CKCA43X5R1H222M100AA
CKCL44X5R1H472M085AA
CKCA43X5R1H472M100AA
CKCL44X5R1E103M085AA
CKCA43X5R1H103M100AA
CKCL44X5R1C223M085AA
CKCA43X5R1H223M100AA
CKCL44X5R1A473M085AA
CKCA43X5R1E473M100AA
CKCA43X5R1C104M100AA
Catalog Number
CKCA43X5R0J105M100AA
Page 6
Capacitance
Range Table
Temperature Characteristics: X7R (-55 to +125ºC, ±15%)
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
220 pF
2012
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
2012
3216
3216
3216
0.85 ± 0.15
0.85 ± 0.15
1.00 ± 0.30
0.85 ± 0.15
1.00 ± 0.30
0.85 ± 0.15
1.00 ± 0.30
0.85 ± 0.15
1.00 ± 0.30
0.85 ± 0.15
1.00 ± 0.30
0.85 ± 0.15
1.00 ± 0.30
1.00 ± 0.30
1.00 ± 0.30
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
470 pF
1 nF
2.2 nF
4.7 nF
10 nF
22 nF
47 nF
100 nF
Catalog Number
CKCL44X7R1H221M085AA
CKCL44X7R1H471M085AA
CKCA43X7R1H471M100AA
CKCL44X7R1H102M085AA
CKCA43X7R1H102M100AA
CKCL44X7R1H222M085AA
CKCA43X7R1H222M100AA
CKCL44X7R1H472M085AA
CKCA43X7R1H472M100AA
CKCL44X7R1E103M085AA
CKCA43X7R1H103M100AA
CKCL44X7R1C223M085AA
CKCA43X7R1H223M100AA
CKCA43X7R1E473M100AA
CKCA43X7R1C104M100AA
Page 7
