CKCL44X7R1H102M085AA
    TDK(东电化)
    0805(2012公制)
    排容 0805 4 1nF ±20% 2.00 x 1.25mm 50V
CKCL44X7R1H102M085AA 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS CKC Series Commercial Grade 4 in 1 Array Type: CKCL44 [EIA CC0805] CKCA43 [EIA CC1206] Issue date: January 2013 002-01 / 20130219 / mlcc_commercial_4array_en MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice : Effective January 2013, TDK will use a new catalog part number which adds product thickness and packaging specification detail. This new part number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the TDK catalog part number will differ from the TDK item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date TDK Part Number (In Catalog) TDK Item Description (On Delivery Label) Prior to January 2013 C1608C0G1E103J C1608C0G1E103JT000N January 2013 and Later C1608C0G1E103J080AA C1608C0G1E103JT000N Page 1 002-01 / 20130219 / mlcc_commercial_4array_en MULTILAYER CERAMIC CHIP CAPACITORS CKC Series 4in1 Array Capacitors Type: CKCL44 [EIA CC0805], CKCA43 [EIA CC1206] Features Applications • Multiple capacitors are fitted in a single product, contributing to reduced installation costs. • The electrostatic capacity range and shape are designed to meet the demands of the cellular phone market. • Unique electrode construction reduces crosstalk. Shape & Dimensions L W T C P PC Board Pattern Body Length Body Width Body Height Terminal Width Terminal Spacing • • • • • • Cellular telephone interface Interface cable circuit PC and peripherals CPU bus line High frequency circuit Noise bypass circuit CKCL44 CKCA43 Dimensions in mm Part Number Construction CKC • A43 • X5R • 0J • 105 • M • 100 • A • A Series Name Dimensions L x W (mm) Code L44 A43 Length 2.00 ± 0.15 3.20 ± 0.20 Width 1.25 ± 0.15 1.60 ± 0.15 Temperature Characteristics Temperature Characteristics C0G CH JB X5R X7R Capacitance Change 0±30 ppm/°C 0±60 ppm/°C ±10% ±15% ±15% Temperature Range -55 to +125°C -25 to +85°C -25 to +85°C -55 to +85°C -55 to +125°C Rated Voltage (DC) Code 0J 1A 1C 1E 1H Voltage (DC) 6.3V 10V 16V 25V 50V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Ex. 0R2 = 0.2pF; 103 = 10,000pF; 105 = 1,000,000pF = 1,000nF = 1μF Nominal Thickness Code 085 100 Thickness 0.85 mm 1.00 mm Capacitance Tolerance Code F K M Tolerance ± 1pF ± 10% ± 20% Packaging Style Code A Style 178” Reel, 4mm Pitch Special Reserved Code Code A Description TDK Internal Code Page 2 • All specifications are subject to change without notice. 002-01 / 20130219 / mlcc_commercial_4array_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CKCL44(C2012) [EIA CC0805] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), JB (± 10%), X5R (± 15%), X7R (± 15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance (pF) 10 15 22 33 47 68 100 150 220 470 1,000 2,200 4,700 10,000 22,000 47,000 100,000 Capacitance (pF) 220 470 1,000 2,200 4,700 10,000 22,000 47,000 100,000 Code 100 150 220 330 470 680 101 151 221 471 102 222 472 103 223 473 104 Tolerance C0G CH 1H (50V) 1H (50V) 1H (50V) 1E (25V) JB 1H (50V) 1E (25V) 1C (16V) 1A (10V) 0J 1A (10V) (6.3V) 1H (50V) F: ± 1pF K: ± 10% X5R Code 221 471 102 222 472 103 223 473 104 0J (6.3V) Tolerance 1C (16V) X7R 1E (25V) 1C (16V) M: ± 20% Standard Thickness 0.85 mm Page 3 • All specifications are subject to change without notice. 002-01 / 20130219 / mlcc_commercial_4array_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart CKCA43(C3216) [EIA CC1206] Capacitance Range Chart Temperature Characteristics: C0G (0 ± 30ppm/ºC), CH (0 ± 60ppm/ºC), JB (± 10%), X5R (± 15%), X7R (± 15%) Rated Voltage: 50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance (pF) 10 15 22 33 47 68 100 150 220 330 470 680 1,000 Capacitance (pF) 470 1,000 2,200 4,700 10,000 22,000 47,000 100,000 1,000,000 Code 100 150 220 330 470 680 101 151 221 331 471 681 102 Tolerance C0G CH 1H (50V) 1H (50V) 1H (50V) 1E (25V) F: ± 1pF K: ± 10% JB Code 471 102 222 472 103 223 473 104 105 Tolerance 1C (16V) X5R 1H 0J (6.3V) (50V) 1E (25V) 1C (16V) X7R 1H 0J (6.3V) (50V) 1E (25V) 1C (16V) M: ± 20% Standard Thickness 1.00 mm Page 4 • All specifications are subject to change without notice. 002-01 / 20130219 / mlcc_commercial_4array_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating) Temperature Characteristics: C0G (-55 to +125ºC, 0±30 ppm/ºC) Capacitance 10 pF 15 pF 22 pF 33 pF 47 pF 68 pF 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1 nF Size Thickness (mm) Capacitance Tolerance 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 3216 3216 3216 3216 3216 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.10 1.00 ± 0.15 1.00 ± 0.10 1.00 ± 0.15 1.00 ± 0.10 1.00 ± 0.15 ± 1% ± 1% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% TDK Part Number Rated Voltage Edc: 50V CKCL44C0G1H100F085AA CKCA43C0G1H100F100AA CKCL44C0G1H150K085AA CKCA43C0G1H150K100AA CKCL44C0G1H220K085AA CKCA43C0G1H220K100AA CKCL44C0G1H330K085AA CKCA43C0G1H330K100AA CKCL44C0G1H470K085AA CKCA43C0G1H470K100AA CKCL44C0G1H680K085AA CKCA43C0G1H680K100AA CKCL44C0G1H101K085AA CKCA43C0G1H101K100AA CKCL44C0G1H151K085AA CKCA43C0G1H151K100AA CKCA43C0G1H221K100AA CKCA43C0G1H331K100AA CKCA43C0G1H471K100AA CKCA43C0G1H681K100AA CKCA43C0G1H102K100AA Rated Voltage Edc: 25V Rated Voltage Edc: 16V Rated Voltage Edc: 10V Class 1 (Temperature Compensating) Temperature Characteristics: CH (-25 to +85ºC, 0±60 ppm/ºC) Capacitance 10 pF 15 pF 22 pF 33 pF 47 pF 68 pF 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1 nF Size Thickness (mm) Capacitance Tolerance 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 3216 3216 3216 3216 3216 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.10 0.85 ± 0.15 1.00 ± 0.10 1.00 ± 0.10 1.00 ± 0.10 1.00 ± 0.10 1.00 ± 0.10 1.00 ± 0.10 ± 1% ± 1% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% ± 10% TDK Part Number Rated Voltage Edc: 50V CKCL44CH1H100F085AA CKCA43CH1H100F100AA CKCL44CH1H150K085AA CKCA43CH1H150K100AA CKCL44CH1H220K085AA CKCA43CH1H220K100AA CKCL44CH1H330K085AA CKCA43CH1H330K100AA CKCL44CH1H470K085AA CKCA43CH1H470K100AA CKCL44CH1H680K085AA CKCA43CH1H680K100AA CKCL44CH1H101K085AA CKCA43CH1H101K100AA CKCL44CH1H151K085AA CKCA43CH1H151K100AA CKCA43CH1H221K100AA CKCA43CH1H331K100AA CKCA43CH1H471K100AA CKCA43CH1H681K100AA CKCA43CH1H102K100AA Rated Voltage Edc: 25V Rated Voltage Edc: 16V Rated Voltage Edc: 10V Page 5 • All specifications are subject to change without notice. 002-01 / 20130219 / mlcc_commercial_4array_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: JB (-25 to +85ºC, ±10%) Capacitance Size Thickness (mm) Capacitance Tolerance 220 pF 470 pF 100 nF 2012 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 3216 0.85 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 1.00 ± 0.15 ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% Capacitance Size Thickness (mm) Capacitance Tolerance 100 nF 1 μF 2012 3216 0.85 ± 0.15 1.00 ± 0.15 ± 20% ± 20% 1 nF 2.2 nF 4.7 nF 10 nF 22 nF 47 nF TDK Part Number Rated Voltage Edc: 50V CKCL44JB1H221M085AA CKCL44JB1H471M085AA CKCA43JB1H471M100AA CKCL44JB1H102M085AA CKCA43JB1H102M100AA CKCL44JB1H222M085AA CKCA43JB1H222M100AA CKCL44JB1H472M085AA CKCA43JB1H472M100AA Rated Voltage Edc: 25V Rated Voltage Edc: 16V Rated Voltage Edc: 10V CKCL44JB1E103M085AA CKCA43JB1H103M100AA CKCL44JB1C223M085AA CKCA43JB1H223M100AA CKCL44JB1A473M085AA CKCA43JB1E473M100AA CKCA43JB1C104M100AA TDK Part Number Rated Voltage Edc: 6.3V CKCL44JB0J104M085AA CKCA43JB0J105M100AA Class 2 (Temperature Stable) Temperature Characteristics: X5R (-55 to +85ºC, ±15%) Capacitance Size Thickness (mm) Capacitance Tolerance 220 pF 1 μF 2012 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 3216 0.85 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 0.85 ± 0.15 1.00 ± 0.15 1.00 ± 0.15 ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% Capacitance Size Thickness (mm) Capacitance Tolerance 100 nF 1 μF 2012 3216 0.85 ± 0.15 1.00 ± 0.15 ± 20% ± 20% 470 pF 1 nF 2.2 nF 4.7 nF 10 nF 22 nF 47 nF 100 nF TDK Part Number Rated Voltage Edc: 50V CKCL44X5R1H221M085AA CKCL44X5R1H471M085AA CKCA43X5R1H471M100AA CKCL44X5R1H102M085AA CKCA43X5R1H102M100AA CKCL44X5R1H222M085AA CKCA43X5R1H222M100AA CKCL44X5R1H472M085AA CKCA43X5R1H472M100AA Rated Voltage Edc: 25V Rated Voltage Edc: 16V Rated Voltage Edc: 10V CKCL44X5R1E103M085AA CKCA43X5R1H103M100AA CKCL44X5R1C223M085AA CKCA43X5R1H223M100AA CKCL44X5R1A473M085AA CKCA43X5R1E473M100AA CKCA43X5R1C104M100AA TDK Part Number Rated Voltage Edc: 6.3V CKCL44X5R0J104M085AA CKCA43X5R0J105M100AA Page 6 • All specifications are subject to change without notice. 002-01 / 20130219 / mlcc_commercial_4array_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size Thickness (mm) Capacitance Tolerance 220 pF 2012 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 2012 3216 3216 3216 0.85 ± 0.15 0.85 ± 0.15 1.00 ± 0.30 0.85 ± 0.15 1.00 ± 0.30 0.85 ± 0.15 1.00 ± 0.30 0.85 ± 0.15 1.00 ± 0.30 0.85 ± 0.15 1.00 ± 0.30 0.85 ± 0.15 1.00 ± 0.30 1.00 ± 0.30 1.00 ± 0.30 ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% 470 pF 1 nF 2.2 nF 4.7 nF 10 nF 22 nF 47 nF 100 nF TDK Part Number Rated Voltage Edc: 50V CKCL44X7R1H221M085AA CKCL44X7R1H471M085AA CKCA43X7R1H471M100AA CKCL44X7R1H102M085AA CKCA43X7R1H102M100AA CKCL44X7R1H222M085AA CKCA43X7R1H222M100AA CKCL44X7R1H472M085AA CKCA43X7R1H472M100AA Rated Voltage Edc: 25V Rated Voltage Edc: 16V Rated Voltage Edc: 10V CKCL44X7R1E103M085AA CKCA43X7R1H103M100AA CKCL44X7R1C223M085AA CKCA43X7R1H223M100AA CKCA43X7R1E473M100AA CKCA43X7R1C104M100AA Page 7 • All specifications are subject to change without notice. 002-01 / 20130219 / mlcc_commercial_4array_en
CKCL44X7R1H102M085AA 价格&库存
很抱歉,暂时无法提供与“CKCL44X7R1H102M085AA”相匹配的价格&库存,您可以联系我们找货
