CKG57KX7R1E476M335JJ
    TDK(东电化)
    SMD,6x5mm
    贴片电容(MLCC) 非标准 47µF ±20% 25V X7R
CKG57KX7R1E476M335JJ 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS October 2022 MULTILAYER CERAMIC CHIP CAPACITORS Automotive grade, MEGACAP type CKG series Single type CKG32K CKG45K CKG57K [3.6x2.6 mm] [5.0x3.5 mm] [6.0x5.0 mm] Stacked type CKG45N [5.0x3.5 mm] CKG57N [6.0x5.0 mm] * Dimensions are typical values. (2/10) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS 1. The products listed in this specification are intended for use in automotive applications under normal operation and usage conditions. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (excepting Pharmaceutical Affairs Law classification Class1,2) (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 2. 3. 4. 5. 6. 7. In addition, although the products listed in this specification are intended for use in automotive applications as described above, they are not prohibited to use in general electronic equipment, whose performance and/or quality doesn’t require a more stringent level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property. Therefore, the description of this caution will be applied, when the products are used in general electronic equipment under a normal operation and usage conditions. We may modify products or discontinue production of a product listed in this catalog without prior notification. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog issued date Prior to January 2013 January 2013 and later Catalog number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item description (on delivery label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20221012 / mlcc_automotive_megacap_en.fm (3/10) MULTILAYER CERAMIC CHIP CAPACITORS CKG series RoHS MEGACAP type REACH SVHC-Free Cl Br Pb Halogen Free Lead Free Type: CKG32K [3.6x2.6 mm], CKG45K [5.0x3.5 mm], CKG57K [6.0x5.0 mm], CKG45N [5.0x3.5 mm], CKG57N [6.0x5.0 mm] ■ SERIES OVERVIEW CKG series is a product which metal frames are attached to the terminal electrodes of MLCC. It is also referred to as MEGACAP. Because the metal frame relieves mechanical stress and thermal shock, CKG series is an extremely reliable product. In addition, the stacked type is effective in mounting area reduction because twice capacitance functions by the stacked structure. ■ FEATURES ■ APPLICATIONS • Metal frames relieve mechanical stress and thermal shock. • Stacked type has twice the capacitance in the same area. • C0G type having excellent stable temperature and DC-bias characteristics is also available. • Mounting on aluminum board is possible. • AEC-Q200 compliant. • X7x products: Smoothing and decoupling applications requiring high capacitance • C0G products: LC resonant circuits of OBC and wireless power transfer, etc. ■ SHAPE & DIMENSIONS Single type T T E L W T E Product length Product width Product thickness Metal-frame width W L W L Stacked type E L W T E Type L W CKG32K 3.60±0.30 2.60±0.30 CKG45K 5.00±0.50 3.50±0.50 CKG57K 6.00±0.50 5.00±0.50 CKG45N 5.00±0.50 3.50±0.50 CKG57N 6.00±0.50 5.00±0.50 Dimensional tolerances are typical values. T 3.35±0.10 2.90±0.10 3.35±0.15 5.00±0.50 5.00±0.50 Dimensions in mm E 0.80±0.15 1.10±0.30 1.60±0.30 1.10±0.30 1.60±0.30 Product length Product width Product thickness Metal-frame width Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm (4/10) MULTILAYER CERAMIC CHIP CAPACITORS ■ CATALOG NUMBER CONSTRUCTION CKG 57 N X7R 1V 107 M 500 J J (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (1) Series (2) Dimensions L x W (mm) Code 32 45 57 Length 3.60 5.00 6.00 Width 2.60 3.50 5.00 Metal-frame width 0.80 1.10 1.60 (3) Structure Code K N Type Single Stacked Temperature coefficient or capacitance change 0±30ppm/°C ±15% ±15% ±22% +22, –33% (5) Rated voltage (DC) Code 1C 1E 1V 1H 2A 2E 2W 2J 3A Voltage (DC) 16V 25V 35V 50V 100V 250V 450V 630V 1000V (Example)0R5 = 0.5pF 101 = 100pF 225 =2,200,000pF = 2.2µF (7) Capacitance tolerance Code J K M (4) Temperature characteristics Temperature characteristics C0G X5R X7R X7S X7T (6) Nominal capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Tolerance ± 5% ± 10% ± 20% Temperature range –55 to +125°C –55 to +85°C –55 to +125°C –55 to +125°C –55 to +125°C (8) Thickness Code 290 335 500 Thickness 2.90 mm 3.35 mm 5.00 mm (9) Packaging style Code A J Style 178mm reel, 4mm pitch 330mm reel, 8mm pitch (10) Special reserved code Code J Description MEGACAP (with metal frame) Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm (5/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 CKG32K [3.6x2.6 mm], Single type C0G 3A (1kV) 2J (630V) 2W (450V) 2E (250V) 2A (100V) 102 122 152 182 222 272 332 392 472 562 682 822 103 153 223 333 473 683 Standard thickness  3.35 mm Background gray: These products are not recommended for new designs. ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Capacitance range chart Capacitance (pF) 33,000 47,000 68,000 Code CKG45K [5.0x3.5 mm], Single type C0G 2J (630V) 2W (450V) 2E (250V) 333 473 683 Standard thickness  2.90 mm ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm (6/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) 68,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 47,000,000 Code CKG57K [6.0x5.0 mm], Single type C0G X7R X7S X7T 2J 2E 2J 2E 2A 1H 1V 1E 1C 2A 1H 1C 2J 2W 2E (630V) (250V) (630V) (250V) (100V) (50V) (35V) (25V) (16V) (100V) (50V) (16V) (630V) (450V) (250V) 683 154 224 334 474 684 105 155 225 335 475 685 106 156 226 476 Standard thickness  3.35 mm ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Capacitance range chart Capacitance (pF) 66,000 94,000 140,000 Code CKG45N [5.0x3.5 mm], Stacked type C0G 2J (630V) 2W (450V) 2E (250V) 663 943 144 Standard thickness  5.00 mm ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm (7/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range chart Capacitance (pF) Code 140,000 300,000 470,000 1,000,000 2,200,000 4,700,000 10,000,000 22,000,000 33,000,000 47,000,000 100,000,000 144 304 474 105 225 475 106 226 336 476 107 Capacitance (pF) Code 680,000 1,000,000 1,500,000 2,200,000 3,300,000 22,000,000 47,000,000 100,000,000 684 105 155 225 335 226 476 107 CKG57N [6.0x5.0 mm], Stacked type C0G X5R 2J 2E 2A 1H (630V) (250V) (100V) (50V) 1E (25V) X7R 1C 2J 2E 2A 1H (16V) (630V) (250V) (100V) (50V) X7S 2A 1H (100V) (50V) 1E (25V) 1V (35V) 1E (25V) 1C (16V) X7T 1C 2J 2W 2E (16V) (630V) (450V) (250V) Standard thickness 5.00 mm Background gray: This product is not recommended for new designs. ■For details such as the catalog numbers, please refer to the capacitance range table on page 8 and after. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm (8/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Capacitance 1nF 1.2nF 1.5nF 1.8nF 2.2nF 2.7nF 3.3nF 3.9nF 4.7nF 5.6nF 6.8nF 8.2nF 10nF 15nF 22nF 33nF 47nF 66nF 68nF 94nF 140nF 150nF 300nF Dimensions Thickness Capacitance (mm) (mm) tolerance 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 3.6x2.6 5.0x3.5 3.6x2.6 5.0x3.5 5.0x3.5 3.6x2.6 5.0x3.5 6.0x5.0 5.0x3.5 5.0x3.5 6.0x5.0 6.0x5.0 6.0x5.0 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 3.35±0.10 2.90±0.10 3.35±0.10 2.90±0.10 5.00±0.50 3.35±0.10 2.90±0.10 3.35±0.15 5.00±0.50 5.00±0.50 5.00±0.50 3.35±0.15 5.00±0.50 ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±5% ±10% ±10% ±5% ±5% Temperature characteristic: C0G (–55 to +125°C, 0±30ppm/°C) Catalog number Rated voltage Edc: 1kV Rated voltage Edc: 630V Rated voltage Edc: 450V Rated voltage Edc: 250V Rated voltage Edc: 100V CKG32KC0G3A102J335AJ CKG32KC0G3A122J335AJ CKG32KC0G3A152J335AJ CKG32KC0G3A182J335AJ CKG32KC0G3A222J335AJ CKG32KC0G3A272J335AJ CKG32KC0G3A332J335AJ CKG32KC0G3A392J335AJ CKG32KC0G3A472J335AJ CKG32KC0G3A562J335AJ CKG32KC0G3A682J335AJ CKG32KC0G3A822J335AJ CKG32KC0G3A103J335AJ CKG32KC0G3A153J335AJ CKG32KC0G3A223J335AJ CKG32KC0G2J223J335AJ CKG32KC0G2W223J335AJ CKG32KC0G2J333J335AJ CKG32KC0G2W333J335AJ CKG32KC0G2E333J335AJ CKG45KC0G2J333J290JJ CKG32KC0G2E473J335AJ CKG45KC0G2W473J290JJ CKG45NC0G2J663J500JJ CKG32KC0G2A683J335AJ CKG45KC0G2E683J290JJ CKG57KC0G2J683J335JJ CKG45NC0G2W943J500JJ CKG45NC0G2E144K500JJ CKG57NC0G2J144K500JJ CKG57KC0G2E154J335JJ CKG57NC0G2E304J500JJ ■ Gray items: These products are not recommended for new designs. Click the part numbers for details. Capacitance range table Temperature characteristic: X5R (–55 to +85°C, ±15%)   Capacitance Dimensions (mm) Thickness (mm) Capacitance tolerance Catalog number Rated voltage Edc: 100V 10µF 22µF 47µF 100µF 6.0x5.0 6.0x5.0 6.0x5.0 6.0x5.0 5.00±0.50 5.00±0.50 5.00±0.50 5.00±0.50 ±20% ±20% ±20% ±20% CKG57NX5R2A106M500JJ Rated voltage Edc: 50V Rated voltage Edc: 25V Rated voltage Edc: 16V CKG57NX5R1H226M500JJ CKG57NX5R1E476M500JJ CKG57NX5R1C107M500JJ ■ Gray item: This product is not recommended for new designs. Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm (9/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Temperature characteristic: X7R (–55 to +125°C, ±15%)   Capacitance Dimensions (mm) 220nF 6.0x5.0 470nF 6.0x5.0 Thickness Capacitance (mm) tolerance 3.35±0.15 3.35±0.15 5.00±0.50 1µF 6.0x5.0 3.35±0.15 5.00±0.50 2.2µF 6.0x5.0 3.35±0.15 5.00±0.50 3.3µF 6.0x5.0 4.7µF 6.0x5.0 10µF 6.0x5.0 3.35±0.15 3.35±0.15 5.00±0.50 5.00±0.50 ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±20% ±20% Catalog number Rated voltage Edc: 630V Rated voltage Edc: 250V Rated voltage Edc: 100V CKG57KX7R2J224K335JJ CKG57KX7R2J224M335JJ CKG57KX7R2E474K335JJ CKG57KX7R2E474M335JJ CKG57NX7R2J474M500JJ CKG57KX7R2E105K335JJ CKG57KX7R2A105K335JJ CKG57KX7R2E105M335JJ CKG57KX7R2A105M335JJ CKG57NX7R2E105M500JJ CKG57KX7R2A225K335JJ CKG57KX7R2A225M335JJ CKG57NX7R2E225M500JJ CKG57NX7R2A225M500JJ CKG57KX7R2A335K335JJ CKG57KX7R2A335M335JJ CKG57KX7R2A475K335JJ CKG57KX7R2A475M335JJ CKG57NX7R2A475M500JJ CKG57NX7R2A106M500JJ Click the part numbers for details. Capacitance 4.7µF Dimensions (mm) 6.0x5.0 10µF 6.0x5.0 15µF 6.0x5.0 22µF 6.0x5.0 33µF 6.0x5.0 47µF 6.0x5.0 100µF 6.0x5.0 Thickness Capacitance (mm) tolerance 3.35±0.15 3.35±0.15 5.00±0.50 3.35±0.15 3.35±0.15 5.00±0.50 5.00±0.50 3.35±0.15 5.00±0.50 5.00±0.50 ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog number Rated voltage Edc: 50V Rated voltage Edc: 35V Rated voltage Edc: 25V Rated voltage Edc: 16V CKG57KX7R1H475K335JJ CKG57KX7R1H475M335JJ CKG57KX7R1E106K335JJ CKG57KX7R1E106M335JJ CKG57NX7R1H106M500JJ CKG57KX7R1C156M335JJ CKG57KX7R1H226M335JJ CKG57KX7R1E226M335JJ CKG57NX7R1E226M500JJ CKG57NX7R1C336M500JJ CKG57KX7R1V476M335JJ CKG57KX7R1E476M335JJ CKG57NX7R1V107M500JJ CKG57NX7R1E107M500JJ CKG57NX7R1H476M500JJ Click the part numbers for details. Capacitance range table Temperature characteristic: X7S (–55 to +125°C, ±22%)   Capacitance Dimensions (mm) Thickness Capacitance (mm) tolerance 6.8µF 6.0x5.0 3.35±0.15 10µF 6.0x5.0 3.35±0.15 15µF 22µF 6.0x5.0 6.0x5.0 47µF 6.0x5.0 100µF 6.0x5.0 3.35±0.15 5.00±0.50 3.35±0.15 5.00±0.50 5.00±0.50 ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% Catalog number Rated voltage Edc: 100V Rated voltage Edc: 50V Rated voltage Edc: 25V Rated voltage Edc: 16V CKG57KX7S2A685K335JJ CKG57KX7S2A685M335JJ CKG57KX7S2A106K335JJ CKG57KX7S1H106K335JJ CKG57KX7S2A106M335JJ CKG57KX7S1H106M335JJ CKG57KX7S2A156M335JJ CKG57NX7S2A226M500JJ CKG57NX7S1H226M500JJ CKG57KX7S1C476M335JJ CKG57NX7S1E476M500JJ CKG57NX7S1C107M500JJ Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm (10/10) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance range table Temperature characteristic: X7T (–55 to +125°C, +22, –33%)   Capacitance Dimensions (mm) Thickness (mm) 330nF 6.0x5.0 3.35±0.15 470nF 6.0x5.0 3.35±0.15 680nF 6.0x5.0 3.35±0.15 5.00±0.50 1µF 6.0x5.0 3.35±0.15 5.00±0.50 1.5µF 6.0x5.0 3.35±0.15 5.00±0.50 2.2µF 6.0x5.0 3.3µF 6.0x5.0 3.35±0.15 5.00±0.50 5.00±0.50 Capacitance tolerance Catalog number Rated voltage Edc: 630V ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±20% ±10% ±20% ±20% ±10% ±20% ±20% ±20% CKG57KX7T2J334K335JJ Rated voltage Edc: 450V Rated voltage Edc: 250V CKG57KX7T2J334M335JJ CKG57KX7T2J474K335JJ CKG57KX7T2J474M335JJ CKG57KX7T2W684K335JJ CKG57KX7T2W684M335JJ CKG57NX7T2J684M500JJ CKG57KX7T2W105K335JJ CKG57KX7T2W105M335JJ CKG57NX7T2J105M500JJ CKG57KX7T2E155K335JJ CKG57KX7T2E155M335JJ CKG57NX7T2W155M500JJ CKG57KX7T2E225K335JJ CKG57KX7T2E225M335JJ CKG57NX7T2W225M500JJ CKG57NX7T2E335M500JJ Click the part numbers for details. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20221012 / mlcc_automotive_megacap_en.fm
物料型号:文档列出了多种型号,包括CKG32K、CKG45K、CKG57K(单层型)和CKG45N、CKG57N(堆叠型)。
器件简介:这些产品是带有金属框架的MLCC,也称为MEGACAP。金属框架可以缓解机械应力和热冲击,使CKG系列产品极为可靠。堆叠型由于其结构,在相同面积内具有双倍电容。
引脚分配:文档中未明确提供引脚分配信息,但提到了产品宽度、产品长度、产品厚度和金属框架宽度。
参数特性:包括温度特性、额定电压、标称电容值、电容公差、厚度和包装风格等。
功能详解:文档中提到了金属框架缓解机械应力和热冲击、堆叠型具有相同面积内双倍电容、C0G类型具有出色的温度和直流偏置特性、可在铝板上安装、符合AEC-Q200标准等特点。
应用信息:文档中提到了X7x产品适用于需要高电容的平滑和去耦应用,C0G产品适用于OBC的LC谐振电路和无线能量传输等。
封装信息:提供了不同型号的尺寸和封装细节,例如CKG32K的尺寸为3.60mm x 2.60mm,金属框架宽度为0.80mm。
CKG57KX7R1E476M335JJ 价格&库存
很抱歉,暂时无法提供与“CKG57KX7R1E476M335JJ”相匹配的价格&库存,您可以联系我们找货
  • 1000+33.144961000+4.30053
  • 2000+32.284522000+4.18889
库存:6001
  • 1+65.783101+8.53531
  • 10+48.6937810+6.31798
  • 50+41.8793850+5.43382
  • 100+39.77100100+5.16026
  • 500+36.20065500+4.69701
库存:6001
