MULTILAYER CERAMIC CHIP CAPACITORS
CKG Series
Commercial Grade
MEGACAP Type
Type:
CKG32K [EIA CC1210]
CKG45K [EIA CC1812]
CKG45N [EIA CC1812]
CKG57K [EIA CC2220]
CKG57N [EIA CC2220]
Issue date:
Oct 2015
20151024 / mlcc_commercial_megacap_en
REMINDERS
Please read before using this product
SAFETY REMINDERS
REMINDERS
1.
If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage,
you must contact our company’s sales window.
2.
We may modify products or discontinue production of a product listed in this catalog without prior notification.
3.
We provide “Delivery Specification” that explain precautions for the specifications and safety of each product
listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers
that use one of these products.
4.
If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according
to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export
permission in harmony with this law.
5.
Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our
company.
6.
We are not responsible for problems that occur related to the intellectual property rights or other rights of our
company or a third party when you use a product listed in this catalog. We do not grant license of these rights.
7.
This catalog only applies to products purchased through our company or one of our company’s official agencies.
This catalog does not apply to products that are purchased through other third parties.
Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging
specification detail. This new catalog number should be referenced on all catalog orders going forward, and
is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will
differ from the item description (internal control number) on the product label. Contact your local TDK Sales
representative for more information.
(Example)
Catalog Issued date
Catalog Number
Item Description (On Delivery Label)
Prior to January 2013
C1608C0G1E103J
C1608C0G1E103JT000N
January 2013 and Later
C1608C0G1E103J080AA
C1608C0G1E103JT000N
Page 1
CKG Series
MEGACAP Type
Type: CKG32K [EIA CC1210], CKG45K [EIA CC1812],
CKG45N [EIA CC1812], CKG57K [EIA CC2220], CKG57N [EIA CC2220]
Adopts a double-stacked structure that realizes twice as much
capacitance as that of the existing products without changing the
capacitor footprint.
Lower ESR and ESL than Al caps.
Capable of absorbing thermal and mechanical stress.
Improved vibration performance.
Features
Design
Structure
No.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
Catalog Number
Construction
MATERIAL
Class 1 Class 2
Ceramic Dielectric CaZrO3 BaTiO3
Internal Electrode
Nickel (Ni)
Copper (Cu)
Termination
Nickel (Ni)
Tin (Sn)
Metal Cap Joint High Temp Solder
Metal Cap
42 Alloy
NAME
Applications
Smoothing circuits
DC-DC converters
LED, HID applications
Temperature variable applications
Piezoelectric-effect countermeasure
Shape &
Dimensions
L
W
T
E
Single Type
Stacked Type
Body Length
Body Width
Body Height
Metal Terminal Width
L
W
T
E
Body Length
Body Width
Body Height
CKG 57 N X7S 1C 107 M 500 J H
Series Name
Dimensions L x W (mm)
Code
32
45
57
Length
3.60 ± 0.30
5.00 ± 0.50
6.00 ± 0.50
Width
2.60 ± 0.30
3.50 ± 0.50
5.00 ± 0.50
Metal Terminal
0.80 ± 0.15
1.10 ± 0.30
1.60 ± 0.30
Structure
Code
K
N
Description
Single Type
Stacked Type
Temperature Characteristics
Temperature
Characteristics
C0G
X5R
X7R
X7S
X7T
Temperature Coefficient or
Capacitance Change
0 ± 30ppm/°C
± 15%
± 15%
± 22%
+ 22/-33%
Temperature
Range
-55 to +125°C
-55 to +85°C
-55 to +125°C
-55 to +125°C
-55 to +125°C
Rated Voltage (DC)
Code
1C
1E
1H
2A
2E
2W
2J
Voltage (DC)
16V
25V
50V
100V
250V
450V
630V
Nominal Capacitance (pF)
The capacitance is expressed in three digit codes and in units of pico
Farads (pF). The first and second digits identify the first and second
significant figures of the capacitance. The third digit identifies the
multiplier. R designates a decimal point.
Ex. 105 = 1,000,000pF = 1,000nF = ȝ) = 100,000,000pF = 100,000nF = ȝ)
Capacitance Tolerance
Code
J
K
M
Tolerance
± 5%
± 10%
± 20%
Nominal Thickness
Code
290
335
500
Thickness
2.90mm
3.35mm
5.00mm
Packaging Style
Code
A
J
Style
178mm Reel, 4mm Pitch
330mm Reel, 8mm Pitch
Special Reserved Code
Code
H
Description
MEGACAP (Std)
Page 2
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
Capacitance
Range Chart
CKG32K [EIA CC1210]
Capacitance Range Chart
Temperature Characteristics: C0G (0 ± 30ppm/℃), X7R (± 15%), X7S (± 22%), X7T (+ 22/-33%)
Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A), 50V (1H), 25V (1E)
C0G
Capacitance
(pF)
Code
22,000
33,000
47,000
68,000
100,000
150,000
220,000
330,000
470,000
1,000,000
2,200,000
3,300,000
4,700,000
6,800,000
10,000,000
223
333
473
683
104
154
224
334
474
105
225
335
475
685
106
Tolerance
X7R
X7S
2J
2W
2E
2A
2J
2E
2A
1H
(630V) (450V) (250V) (100V) (630V) (250V) (100V) (50V)
X7T
1E
2A
1H
2J
2W
2E
(25V) (100V) (50V) (630V) (450V) (250V)
C0G ;
J : ±5%
X7R, X7S
X7T ;
K : ± 10%
M : ± 20%
Standard Thickness
3.35 mm
Capacitance
Range Chart
CKG45K [EIA CC1812]
Temperature Characteristics: X7R (± 15%), X7S (± 22%), X7T (+ 22/-33%)
Rated Voltage: 630V (2J), 450V (2W), 250V (2E), 100V (2A), 50V (1H), 25V (1E), 16V (1C)
X7R
Capacitance
(pF)
Code
100,000
150,000
220,000
330,000
470,000
680,000
1,000,000
1,500,000
2,200,000
3,300,000
4,700,000
10,000,000
22,000,000
104
154
224
334
474
684
105
155
225
335
475
106
226
Tolerance
X7S
2J
2E
2A
1H
1E
(25V)
1C
2A
1H
(16V) (100V) (50V)
X7T
1C
2J
2W
2E
(16V) (630V) (450V) (250V)
K: ± 10%
M: ± 20%
M: ± 20%
Standard Thickness
2.90 mm
Page 3
Capacitance
Range Chart
CKG57K [EIA CC2220]
Capacitance
(pF)
X7R
Code
224
220,000
334
330,000
474
470,000
684
680,000
105
1,000,000
155
1,500,000
225
2,200,000
335
3,300,000
475
4,700,000
685
6,800,000
106
10,000,000
156
15,000,000
226
22,000,000
476
47,000,000
Standard Thickness
Tolerance
2J
(630V)
2E
(250V)
2A
(100V)
X7S
1H
(50V)
1E
(25V)
1C
(16V)
2A
(100V)
1H
(50V)
X7T
1C
(16V)
2J
(630V)
2W
(450V)
2E
(250V)
K: ± 10%
M: ± 20%
M: ± 20%
3.35 mm
Page 4
Capacitance
Range Chart
CKG45N [EIA CC1812]
Temperature Characteristics: X5R (± 15%), X7R (± 15%), X7S (± 22%), X7T (+ 22/-33%)
X5R
Capacitance
(pF)
Code
220,000
470,000
1,000,000
2,200,000
3,300,000
4,700,000
6,800,000
10,000,000
22,000,000
47,000,000
224
474
105
225
335
475
685
106
226
476
Tolerance
1H
(50V)
Code
330,000
470,000
680,000
1,000,000
1,500,000
2,200,000
6,800,000
10,000,000
47,000,000
334
474
684
105
155
225
685
106
476
1E
(25V)
1C
(16V)
M : ± 20%
X7S
Capacitance
(pF)
X7R
1C
2J
2E
2A
1H
(16V) (630V) (250V) (100V) (50V)
Tolerance
2A
1H
(100V) (50V)
X7T
1C
2J
2W
2E
M : ± 20%
Standard Thickness
5.00 mm
Page 5
Capacitance
Range Chart
CKG57N [EIA CC2220]
X5R
Capacitance
(pF)
Code
470,000
1,000,000
2,200,000
4,700,000
10,000,000
22,000,000
33,000,000
47,000,000
100,000,000
474
105
225
475
106
226
336
476
107
Tolerance
2A
1H
(100V) (50V)
1E
(25V)
X7R
1C
2J
2E
2A
1H
Code
680,000
1,000,000
1,500,000
2,200,000
3,300,000
22,000,000
47,000,000
100,000,000
684
105
155
225
335
226
476
107
1C
(16V)
M : ± 20%
X7S
Capacitance
(pF)
1E
(25V)
Tolerance
2A
1H
(100V) (50V)
1E
(25V)
X7T
1C
2J
2W
2E
M : ± 20%
Standard Thickness
5.00 mm
Page 6
Capacitance
Range Table
Class 1 (Temperature Compensating)
Temperature Characteristics: C0G (-55 to +125ºC, ± 30ppm/ºC)
Capacitance
Size
Thickness
(mm)
Capacitance
Tolerance
22nF
33nF
47nF
68nF
3225
3225
3225
3225
3.35 ± 0.10
3.35 ± 0.10
3.35 ± 0.10
3.35 ± 0.10
± 5%
± 5%
± 5%
± 5%
Catalog Number
Rated Voltage Edc: 630V
Rated Voltage Edc: 450V
Rated Voltage Edc: 250V
CKG32KC0G2J223J335AH CKG32KC0G2W223J335AH
CKG32KC0G2J333J335AH CKG32KC0G2W333J335AH CKG32KC0G2E333J335AH
CKG32KC0G2E473J335AH
Rated Voltage Edc: 100V
CKG32KC0G2A683J335AH
Class 2 (Temperature Stable)
Temperature Characteristics: X5R (-55 to +85ºC, ±15%)
Capacitance
10 μF
22 μF
47 μF
100 μF
Size
Thickness
(mm)
Capacitance
Tolerance
4532
5750
5750
4532
5750
5750
5.00 ± 0.50
5.00 ± 0.50
5.00 ± 0.50
5.00 ± 0.50
5.00 ± 0.50
5.00 ± 0.50
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
Catalog Number
Rated Voltage Edc: 50V
CKG45NX5R1H106M500JH
Rated Voltage Edc: 25V
Rated Voltage Edc: 16V
CKG57NX5R2A106M500JH
CKG57NX5R1H226M500JH
CKG45NX5R1C476M500JH
CKG57NX5R1E476M500JH
CKG57NX5R1C107M500JH
Temperature Characteristics: X7R (-55 to +125ºC, ±15%)
Capacitance
47 nF
Size
Thickness
(mm)
3225
3.35 ± 0.10
3225
3.35 ± 0.10
4532
2.90 ± 0.10
3225
3.35 ± 0.10
100 nF
220 nF
4532
2.90 ± 0.10
5.00 ± 0.50
470 nF
5750
3.35 ± 0.15
3225
3.35 ± 0.10
4532
2.90 ± 0.10
5.00 ± 0.50
5750
3.35 ± 0.15
5.00 ± 0.50
3225
1 μF
4532
3.35 ± 0.10
2.90 ± 0.10
5.00 ± 0.50
5750
3.35 ± 0.15
5.00 ± 0.50
1.5 μF
2.2 μF
4532
2.90 ± 0.10
3225
3.35 ± 0.10
4532
2.90 ± 0.10
5.00 ± 0.50
5750
3.35 ± 0.15
5.00 ± 0.50
Capacitance
Tolerance
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
Catalog Number
CKG32KX7R2J473K335AH
CKG32KX7R2J473M335AH
CKG32KX7R2E104K335AH
CKG32KX7R2E104M335AH
CKG45KX7R2J104K290JH
CKG45KX7R2J104M290JH
CKG32KX7R2E224K335AH
CKG32KX7R2E224M335AH
CKG45KX7R2E224K290JH
CKG45KX7R2E224M290JH
CKG45NX7R2J224M500JH
CKG57KX7R2J224K335JH
CKG57KX7R2J224M335JH
CKG32KX7R2A474K335AH
CKG32KX7R2A474M335AH
CKG45KX7R2E474K290JH
CKG45KX7R2E474M290JH
CKG45NX7R2E474M500JH
CKG57KX7R2E474K335JH
CKG57KX7R2E474M335JH
CKG57NX7R2J474M500JH
CKG32KX7R2A105K335AH CKG32KX7R1H105K335AH
CKG32KX7R2A105M335AH CKG32KX7R1H105M335AH
CKG45KX7R2A105K290JH
CKG45KX7R2A105M290JH
CKG45NX7R2E105M500JH
CKG57KX7R2E105K335JH
CKG57KX7R2E105M335JH
CKG57NX7R2E105M500JH
CKG57KX7R2A105K335JH
CKG57KX7R2A105M335JH
CKG45KX7R1H155K290JH
CKG45KX7R1H155M290JH
CKG57NX7R2E225M500JH
CKG32KX7R2A225K335AH
CKG32KX7R2A225M335AH
CKG45KX7R2A225K290JH
CKG45KX7R2A225M290JH
CKG45NX7R2A225M500JH
CKG57KX7R2A225K335JH
CKG57KX7R2A225M335JH
CKG57NX7R2A225M500JH
Page 7
Capacitance
Range Table
Capacitance
Size
4532
5750
3.35 ± 0.15
3225
3.35 ± 0.10
4532
10 μF
5.00 ± 0.50
5.00 ± 0.50
3225
3.35 ± 0.10
4532
2.90 ± 0.10
5.00 ± 0.50
5750
4532
22 μF
5750
33 μF
3.35 ± 0.15
4532
5750
15 μF
2.90 ± 0.10
5.00 ± 0.50
5750
6.8 μF
2.90 ± 0.10
5.00 ± 0.50
3.3 μF
4.7 μF
Thickness
(mm)
5750
3.35 ± 0.15
5.00 ± 0.50
3.35 ± 0.15
2.90 ± 0.10
5.00 ± 0.50
3.35 ± 0.15
5.00 ± 0.50
5.00 ± 0.50
Capacitance
Tolerance
± 10%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
Catalog Number
CKG45KX7R1H335K290JH
CKG45KX7R1H335M290JH
CKG45NX7R1H335M500JH
CKG57KX7R2A335K335JH
CKG57KX7R2A335M335JH
CKG32KX7R1E475K335AH
CKG32KX7R1E475M335AH
CKG45KX7R1E475K290JH
CKG45KX7R1E475M290JH
CKG45NX7R2A475M500JH
CKG57KX7R2A475K335JH CKG57KX7R1H475K335JH
CKG57KX7R2A475M335JH CKG57KX7R1H475M335JH
CKG57NX7R2A475M500JH
CKG45NX7R1H685M500JH
CKG32KX7R1E106K335AH
CKG32KX7R1E106M335AH
CKG45KX7R1C106K290JH
CKG45KX7R1C106M290JH
CKG45NX7R1E106M500JH
CKG57KX7R1E106K335JH
CKG57KX7R1E106M335JH
CKG57NX7R2A106M500JH CKG57NX7R1H106M500JH
CKG57KX7R1C156M335JH
CKG45KX7R1C226M290JH
CKG45NX7R1C226M500JH
CKG57KX7R1E226M335JH
CKG57NX7R1E226M500JH
CKG57NX7R1C336M500JH
Temperature Characteristics: X7S (-55 to +125ºC, ±22%)
Capacitance
Size
Thickness
(mm)
3225
3.35 ± 0.10
4532
2.90 ± 0.10
3225
3.35 ± 0.10
4532
2.90 ± 0.10
3225
3.35 ± 0.10
4532
5.00 ± 0.50
5750
3.35 ± 0.15
3225
3.35 ± 0.10
4532
5.00 ± 0.50
5750
3.35 ± 0.15
5750
4532
5750
4532
3.35 ± 0.15
2.90 ± 0.10
5.00 ± 0.50
5.00 ± 0.50
3.35 ± 0.15
5.00 ± 0.50
5.00 ± 0.50
3.3 μF
4.7 μF
6.8 μF
10 μF
15 μF
22 μF
47 μF
100 μF
5750
5750
Capacitance
Tolerance
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
± 20%
Catalog Number
CKG32KX7S2A335K335AH
CKG32KX7S2A335M335AH
CKG45KX7S2A335K290JH
CKG45KX7S2A335M290JH
CKG32KX7S2A475K335AH CKG32KX7S1H475K335AH
CKG32KX7S2A475M335AH CKG32KX7S1H475M335AH
CKG45KX7S2A475K290JH CKG45KX7S1H475K290JH
CKG45KX7S2A475M290JH CKG45KX7S1H475M290JH
CKG32KX7S1H685K335AH
CKG32KX7S1H685M335AH
CKG45NX7S2A685M500JH
CKG57KX7S2A685K335JH
CKG57KX7S2A685M335JH
CKG32KX7S1H106K335AH
CKG32KX7S1H106M335AH
CKG45NX7S2A106M500JH CKG45NX7S1H106M500JH
CKG57KX7S2A106K335JH CKG57KX7S1H106K335JH
CKG57KX7S2A106M335JH CKG57KX7S1H106M335JH
CKG57KX7S2A156M335JH
CKG45KX7S1C226M290JH
CKG57NX7S2A226M500JH
CKG57NX7S1H226M500JH
CKG45NX7S1C476M500JH
CKG57KX7S1C476M335JH
CKG57NX7S1E476M500JH
CKG57NX7S1C107M500JH
Page 8
Capacitance
Range Table
Temperature Characteristics: X7T (-55 to +125ºC, +22/-33%)
Capacitance
100 nF
Size
Thickness
(mm)
3225
3.35 ± 0.10
3225
3.35 ± 0.10
4532
2.90 ± 0.10
3225
3.35 ± 0.10
4532
2.90 ± 0.10
3225
3.35 ± 0.10
150 nF
220 nF
330 nF
4532
2.90 ± 0.10
5.00 ± 0.50
5750
4532
470 nF
3.35 ± 0.15
2.90 ± 0.10
5.00 ± 0.50
5750
4532
3.35 ± 0.15
2.90 ± 0.10
5.00 ± 0.50
680 nF
5750
3.35 ± 0.15
5.00 ± 0.50
4532
5.00 ± 0.50
1 μF
5750
4532
1.5 μF
5750
4532
2.2 μF
3.3 μF
2.90 ± 0.10
5750
5750
3.35 ± 0.15
5.00 ± 0.50
5.00 ± 0.50
3.35 ± 0.15
5.00 ± 0.50
5.00 ± 0.50
3.35 ± 0.15
5.00 ± 0.50
5.00 ± 0.50
Capacitance
Tolerance
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 10%
± 20%
± 20%
± 20%
± 10%
± 20%
± 20%
± 20%
± 10%
± 20%
± 20%
± 20%
Catalog Number
CKG32KX7T2J104K335AH
CKG32KX7T2J104M335AH
CKG32KX7T2J154K335AH
CKG32KX7T2J154M335AH
CKG45KX7T2J154K290JH
CKG45KX7T2J154M290JH
CKG32KX7T2W224K335AH
CKG32KX7T2W224M335AH
CKG45KX7T2J224K290JH
CKG45KX7T2J224M290JH
CKG32KX7T2E334K335AH
CKG32KX7T2E334M335AH
CKG45KX7T2W334K290JH
CKG45KX7T2W334M290JH
CKG45NX7T2J334M500JH
CKG57KX7T2J334K335JH
CKG57KX7T2J334M335JH
CKG45KX7T2W474K290JH
CKG45KX7T2W474M290JH
CKG45NX7T2J474M500JH
CKG57KX7T2J474K335JH
CKG57KX7T2J474M335JH
CKG45KX7T2E684K290JH
CKG45KX7T2E684M290JH
CKG45NX7T2W684M500JH
CKG57KX7T2W684K335JH
CKG57KX7T2W684M335JH
CKG57NX7T2J684M500JH
CKG45KX7T2E105K290JH
CKG45KX7T2E105M290JH
CKG45NX7T2W105M500JH
CKG57KX7T2W105K335JH
CKG57KX7T2W105M335JH
CKG57NX7T2J105M500JH
CKG45NX7T2E155M500JH
CKG57KX7T2E155K335JH
CKG57KX7T2E155M335JH
CKG57NX7T2W155M500JH
CKG45NX7T2E225M500JH
CKG57KX7T2E225K335JH
CKG57KX7T2E225M335JH
CKG57NX7T2W225M500JH
CKG57NX7T2E335M500JH
Page 9
