CLF10040T-330M-CA
CLF10040T-330M-CA
    TDK(东电化)
    FIXED IND 33UH 1.7A 96 MOHM SMD
CLF10040T-330M-CA 数据手册
1 of 3 Creation Date :December 29 2015 CLF10040T-330M-CA Applications Automotive Grade Feature Wire Wound Magnetic Shield Ferrite Core AEC-Q200 Series CLF-CA Series / CLF10040-CA Type Status Production Size Length(L) 10.00mm +/-0.30mm Width(W) 9.70mm +/-0.30mm Thickness(T) 3.80mm +/-0.30mm Recommended Land Pattern (A) 2.50mm Nom. Recommended Land Pattern (B) 5.60mm Nom. Recommended Land Pattern (C) 3.20mm Nom. Electrical Characteristics Inductance 33uH +/-20% at 100kHz Rated Current (L Change) [Typ.] 2.2A (10% Down) Rated Current (Temperature Rise) [Typ.] 1.7A (30degC Rise) DC Resistance [Nom.] 80mΩ DC Resistance [Max.] 96mΩ Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 105degC Soldering Method Reflow, Iron Soldering AEC Q200 Yes Packing Blister (Plastic)Taping [330mm Reel] Package Quantity 800Pcs Min. Weight 1.3g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :December 29 2015 CLF10040T-330M-CA CLF10040T-330M-CA CLF10040T-330M-CA CLF10040T-330M-CA CLF10040T-330M-CA •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :December 29 2015 CLF10040T-330M-CA CLF10040T-330M-CA(Amb. Temp. = 20degc) CLF10040T-330M-CA(Amb. Temp. = 20degc) •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved CLF10040T-330M-CA(DC = 0A) CLF10040T-330M-CA(DC = 0.85A)
CLF10040T-330M-CA
物料型号:CLF10040T-330M-CA
器件简介:该电感器是汽车级产品,采用线绕方式,带有磁屏蔽的铁氧体核心,符合AEC-Q200标准。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性: - 尺寸:长度10.00mm±0.30mm,宽度9.70mm±0.30mm,厚度3.80mm±0.30mm - 推荐焊盘图案尺寸:A为2.50mm,B为5.60mm,C为3.20mm - 电感值:33uH±20%(在100kHz时) - 额定电流(电感变化):典型值为2.2A(下降10%) - 额定电流(温升):典型值为1.7A(温升30°C) - 直流电阻:典型值为80mΩ,最大值为96mΩ
功能详解:文档中未提供详细的功能解释。
应用信息:适用于汽车级应用。
封装信息: - 工作温度范围:-40至105°C(包括自温升) - 焊接方法:回流焊,烙铁焊接 - 符合AECQ200标准 - 包装:吸塑(塑料)胶带[330mm卷装] - 包装数量:最小800件 - 重量:1.3g
CLF10040T-330M-CA 价格&库存
很抱歉,暂时无法提供与“CLF10040T-330M-CA”相匹配的价格&库存,您可以联系我们找货
CLF10040T-330M-CA
  • 1+9.340991+1.21262
  • 10+7.6538610+0.99360
  • 25+7.0778525+0.91882
  • 50+6.6729050+0.86625
  • 100+6.29063100+0.81663
  • 250+5.81992250+0.75552
库存:509
