CLF10040T-470M-CA
CLF10040T-470M-CA
    TDK(东电化)
    固定电感器 Nonstandard 47µH ±20% 1.3A 150mΩ
CLF10040T-470M-CA 数据手册
1 of 3 Creation Date :December 29 2015 CLF10040T-470M-CA Applications Automotive Grade Feature Wire Wound Magnetic Shield Ferrite Core AEC-Q200 Series CLF-CA Series / CLF10040-CA Type Status Production Size Length(L) 10.00mm +/-0.30mm Width(W) 9.70mm +/-0.30mm Thickness(T) 3.80mm +/-0.30mm Recommended Land Pattern (A) 2.50mm Nom. Recommended Land Pattern (B) 5.60mm Nom. Recommended Land Pattern (C) 3.20mm Nom. Electrical Characteristics Inductance 47uH +/-20% at 100kHz Rated Current (L Change) [Typ.] 1.9A (10% Down) Rated Current (Temperature Rise) [Typ.] 1.3A (30degC Rise) DC Resistance [Nom.] 125mΩ DC Resistance [Max.] 150mΩ Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 105degC Soldering Method Reflow, Iron Soldering AEC Q200 Yes Packing Blister (Plastic)Taping [330mm Reel] Package Quantity 800Pcs Min. Weight 1.3g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :December 29 2015 CLF10040T-470M-CA CLF10040T-470M-CA CLF10040T-470M-CA CLF10040T-470M-CA CLF10040T-470M-CA •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :December 29 2015 CLF10040T-470M-CA CLF10040T-470M-CA(Amb. Temp. = 20degc) CLF10040T-470M-CA(Amb. Temp. = 20degc) •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved CLF10040T-470M-CA(DC = 0A) CLF10040T-470M-CA(DC = 0.65A)
CLF10040T-470M-CA 价格&库存
很抱歉,暂时无法提供与“CLF10040T-470M-CA”相匹配的价格&库存,您可以联系我们找货
