CLF10040T-680M-CA
CLF10040T-680M-CA
    TDK(东电化)
    固定电感器 Nonstandard 68µH ±20% 1.1A 216mΩ
CLF10040T-680M-CA 数据手册
1 of 3 Creation Date :December 29 2015 CLF10040T-680M-CA Applications Automotive Grade Feature Wire Wound Magnetic Shield Ferrite Core AEC-Q200 Series CLF-CA Series / CLF10040-CA Type Status Production Size Length(L) 10.00mm +/-0.30mm Width(W) 9.70mm +/-0.30mm Thickness(T) 3.80mm +/-0.30mm Recommended Land Pattern (A) 2.50mm Nom. Recommended Land Pattern (B) 5.60mm Nom. Recommended Land Pattern (C) 3.20mm Nom. Electrical Characteristics Inductance 68uH +/-20% at 100kHz Rated Current (L Change) [Typ.] 1.6A (10% Down) Rated Current (Temperature Rise) [Typ.] 1.1A (30degC Rise) DC Resistance [Nom.] 180mΩ DC Resistance [Max.] 216mΩ Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 105degC Soldering Method Reflow, Iron Soldering AEC Q200 Yes Packing Blister (Plastic)Taping [330mm Reel] Package Quantity 800Pcs Min. Weight 1.3g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :December 29 2015 CLF10040T-680M-CA CLF10040T-680M-CA CLF10040T-680M-CA CLF10040T-680M-CA CLF10040T-680M-CA •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :December 29 2015 CLF10040T-680M-CA CLF10040T-680M-CA(Amb. Temp. = 20degc) CLF10040T-680M-CA(Amb. Temp. = 20degc) •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved CLF10040T-680M-CA(DC = 0A) CLF10040T-680M-CA(DC = 0.55A)
CLF10040T-680M-CA
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:该器件共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考引脚图。
4. 参数特性:工作电压为2.0V至3.6V,工作频率可达72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(如UART、SPI、I2C)等模块的详细功能描述。
6. 应用信息:适用于工业控制、医疗设备、消费电子等多种应用场景。
7. 封装信息:采用LQFP48封装,尺寸为7x7mm。
CLF10040T-680M-CA 价格&库存
很抱歉,暂时无法提供与“CLF10040T-680M-CA”相匹配的价格&库存,您可以联系我们找货
