CLF12555T-101M-CA
CLF12555T-101M-CA
    TDK(东电化)
    IND-2P_12.5X12.1MM_SM
    固定电感器 Nonstandard 100µH ±20% 1.3A 228mΩ
CLF12555T-101M-CA 数据手册
1 of 3 Creation Date :December 29 2015 CLF12555T-101M-CA Applications Automotive Grade Feature Wire Wound Magnetic Shield Ferrite Core AEC-Q200 Series CLF-CA Series / CLF12555-CA Type Status Production Size Length(L) 12.50mm +/-0.30mm Width(W) 12.10mm +0.30/-0.20mm Thickness(T) 5.50mm +/-0.35mm Recommended Land Pattern (A) 2.70mm Nom. Recommended Land Pattern (B) 8.30mm Nom. Recommended Land Pattern (C) 3.20mm Nom. Electrical Characteristics Inductance 100uH +/-20% at 100kHz Rated Current (L Change) [Typ.] 2.1A (10% Down) Rated Current (Temperature Rise) [Typ.] 1.3A (30degC Rise) DC Resistance [Nom.] 190mΩ DC Resistance [Max.] 228mΩ Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 105degC Soldering Method Reflow, Iron Soldering AEC Q200 Yes Packing Blister (Plastic)Taping [330mm Reel] Package Quantity 500Pcs Min. Weight 3g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :December 29 2015 CLF12555T-101M-CA CLF12555T-101M-CA CLF12555T-101M-CA CLF12555T-101M-CA CLF12555T-101M-CA •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :December 29 2015 CLF12555T-101M-CA DC Bias Characteristic no data available CLF12555T-101M-CA(DC = 0A) Temperature Rise by DC no data available •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved CLF12555T-101M-CA(DC = 0.65A)
CLF12555T-101M-CA 价格&库存
很抱歉,暂时无法提供与“CLF12555T-101M-CA”相匹配的价格&库存,您可以联系我们找货
