CLF5030NIT-3R3N-D
CLF5030NIT-3R3N-D
    TDK(东电化)
    SMD,5.3x5mm
    固定电感器 Nonstandard 3.3µH ±30% 2.6A 52mΩ
CLF5030NIT-3R3N-D 数据手册
I N D U C T O R S Inductors for power circuits Wound ferrite CLF-NI-D series (for automotive) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 CLF5030NI-D type FEATURES Magnetic shield type wound inductor for power circuits. It can be used at a wide temperature range. –55 to +150°C (including self-temperature rise) 1 to 470µH, wide E-6 series lineup allows for various usages. Operating temperature range: –55 to +150°C (including self-temperature rise) Compliant with AEC-Q200 APPLICATION Automotive-related equipment (ECM, airbags, headlights, electronic power steering, meters, ABS, other) Application guides: Automotive (xEV) PART NUMBER CONSTRUCTION CLF5030NI T Series name Packaging style - 1R0 N Inductance (µH) Inductance tolerance - D Internal code CHARACTERISTICS SPECIFICATION TABLE L Measuring frequency DC resistance Rated current* Isat (µH) Tolerance (kHz) (Ω ) (A)max. (A)typ. 1.0 ±30% 100 0.019 5.00 6.00 1.5 ±30% 100 0.023 3.69 5.20 2.2 ±30% 100 0.030 3.42 4.53 3.3 ±30% 100 0.040 2.70 3.60 4.7 ±30% 100 0.060 2.43 3.18 6.8 ±30% 100 0.075 2.07 2.58 10 ±20% 100 0.095 1.60 2.15 15 ±20% 100 0.140 1.30 1.75 22 ±20% 100 0.200 1.10 1.42 33 ±20% 100 0.310 0.94 1.20 47 ±20% 100 0.435 0.75 1.00 68 ±20% 100 0.530 0.68 0.86 100 ±20% 100 0.880 0.56 0.68 150 ±20% 100 1.290 0.44 0.57 220 ±20% 100 2.530 0.38 0.46 330 ±20% 100 3.400 0.29 0.39 470 ±20% 100 4.400 0.24 0.31  Rated current: smaller value of either Isat or Itemp. Isat: When based on the inductance change rate (30% below the nominal value) Itemp: When based on the temperature increase (temperature increase of 40°C by self heating) Part No. Itemp (A)typ. 3.70 3.40 3.10 2.60 2.10 1.85 1.70 1.40 1.20 0.88 0.68 0.59 0.40 0.32 0.28 0.20 0.17 CLF5030NIT-1R0N-D CLF5030NIT-1R5N-D CLF5030NIT-2R2N-D CLF5030NIT-3R3N-D CLF5030NIT-4R7N-D CLF5030NIT-6R8N-D CLF5030NIT-100M-D CLF5030NIT-150M-D CLF5030NIT-220M-D CLF5030NIT-330M-D CLF5030NIT-470M-D CLF5030NIT-680M-D CLF5030NIT-101M-D CLF5030NIT-151M-D CLF5030NIT-221M-D CLF5030NIT-331M-D CLF5030NIT-471M-D Measurement equipment Measurement item Product No. L 4285A DC resistance AN-114N Rated current Isat 4285A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies ADEX Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/5) 20200706 inductor_automotive_power_clf5030ni-d_en.fm I N D U C T O R S CLF5030NI-D type L FREQUENCY CHARACTERISTICS 10000 1000 471 331 221 151 Inductance(µH) 100 101 680 470 330 220 150 10 100 6R8 4R7 3R3 2R2 1 1R5 1R0 0.1 10 100 1000 Frequency(kHz) 10000 100000 Measurement equipment Product No. Manufacturer 4294A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/5) 20200706 inductor_automotive_power_clf5030ni-d_en.fm I N D U C T O R S CLF5030NI-D type INDUCTANCE VS. DC BIAS CHARACTERISTICS 1000 471 331 221 151 100 101 680 470 330 Inductance(µH) 220 150 10 100 6R8 4R7 3R3 2R2 1R5 1 0.1 1R0 0 1 2 3 DC current(A) 4 5 6 Measurement equipment Product No. Manufacturer 4285A+42841A+42842C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/5) 20200706 inductor_automotive_power_clf5030ni-d_en.fm I N D U C T O R S CLF5030NI-D type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 5.3±0.2 2 1.8±0.1 5.0±0.2 2.0±0.5 1.6±0.1 (0.1) 2.7±0.3 ø100 (2.1) 1.6±0.1 (1.0) Dimensions in mm ø13.0±0.5 13.5 ø21.0±0.8 17.5 ø330 Dimensions in mm 4.0±0.1 Sprocket hole 2.0 B Dimensions in mm 12.0±0.3 2.0 2.0±0.1 5.5±0.1 2.0 2.0 1.5 +0.1 –0 0.4 1.75±0.1 TAPE DIMENSIONS RECOMMENDED LAND PATTERN K Cavity A 8.0±0.1 Dimensions in mm Type CLF5030NI-D RECOMMENDED REFLOW PROFILE Preheating Soldering Peak PACKAGE QUANTITY 245°C Package quantity Temperature 230°C 230°C 180°C 5s 150°C 60 to 120s Natural cooling A 5.7 B 5.4 K 3.6 2000 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –55 to +150 °C –55 to +150 °C 0.24 g  Operating temperature range includes self-temperature rise.  The storage temperature range is for after the assembly. 10 to 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/5) 20200706 inductor_automotive_power_clf5030ni-d_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. Do not use products that have received any excessive mechanical shock such as by being dropped. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Do not expose the products to magnets or magnetic fields. The performance of the product may deteriorate if coating materials are used, thus please assess the situation beforehand by taking this factor into consideration. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification, while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (5/5) 20200706 inductor_automotive_power_clf5030ni-d_en.fm
CLF5030NIT-3R3N-D
1. 物料型号:文档描述了TDK的CLF5030NI-D系列电感器,这些电感器适用于汽车电源电路。
2. 器件简介:电感器是磁屏蔽型,能在-55至+150°C的宽温度范围内工作,符合AEC-Q200标准,并且是无卤、无铅、符合RoHS标准的。
3. 引脚分配:文档中没有提供具体的引脚分配图,但提到了电感器的封装风格和尺寸。
4. 参数特性:提供了详细的电感值、公差、测量频率、直流电阻、额定电流等参数,以及不同型号的电感器的特定参数。
5. 功能详解:文档提供了电感器的频率特性和直流偏置特性的图表,展示了不同直流电流下的电感值变化。
6. 应用信息:适用于汽车相关设备,如发动机控制模块、安全气囊、前大灯、电子助力转向、仪表、防抱死制动系统等。
7. 封装信息:提供了电感器的外形尺寸、推荐焊盘图案、胶带尺寸和回流焊接曲线。
8. 安全提醒:强调了在使用这些产品前需要请求交付规格,并注意安全设计警告。
9. 存储条件:建议存储期限不超过12个月,并遵循特定的存储条件。
10. 使用限制:明确了产品不适用于需要更高安全或可靠性水平的特定应用,如航空航天、医疗设备、核能相关设备等。
CLF5030NIT-3R3N-D 价格&库存
很抱歉,暂时无法提供与“CLF5030NIT-3R3N-D”相匹配的价格&库存,您可以联系我们找货
CLF5030NIT-3R3N-D
  • 1+4.31930
  • 10+3.63100
  • 30+3.23510
  • 100+2.83760
  • 500+2.65790
  • 1000+2.53800
库存:1913
CLF5030NIT-3R3N-D
  • 2000+3.458442000+0.44748
CLF5030NIT-3R3N-D
    • 1+5.16500
    • 10+5.04857
    • 30+4.97448
    • 100+4.88981
    库存:39
    CLF5030NIT-3R3N-D
    • 1+6.869091+0.88878
    • 10+5.6539510+0.73156
    • 25+5.2315825+0.67691
    • 50+4.9338250+0.63838
    • 100+4.65117100+0.60181
    • 250+4.30254250+0.55670
    • 500+4.05683500+0.52491
    • 1000+3.825291000+0.49495
    库存:2934
    CLF5030NIT-3R3N-D
    • 2000+3.504092000+0.45339
    • 4000+3.304594000+0.42758
    • 6000+3.193306000+0.41318
    • 10000+3.0585910000+0.39575
    • 14000+2.9730714000+0.38468
    • 20000+2.9724720000+0.38461
    库存:2934
