CLF6045T-331M-CA
CLF6045T-331M-CA
    TDK(东电化)
    Nonstandard
    FIXED IND 330UH 440MA 1.164 OHM
CLF6045T-331M-CA 数据手册
1 of 3 Creation Date :June 18 2014 CLF6045T-331M-CA Applications Automotive Grade Feature Wire Wound Magnetic Shield Ferrite Core AEC-Q200 Series CLF-CA Series / CLF6045-CA Type Status PROD Size Length(L) 6.20mm +/-0.20mm Width(W) 5.90mm +/-0.20mm Thickness(T) 4.50mm +/-0.30mm Recommended Land Pattern (A) 1.70mm Nom. Recommended Land Pattern (B) 3.60mm Nom. Recommended Land Pattern (C) 2.20mm Nom. Electrical Characteristics Inductance 330uH +/-20% at 100kHz Rated Current (L Change) [Typ.] 350mA (10% Down) Rated Current (Temperature Rise) [Typ.] 440mA (30degC Rise) DC Resistance [Nom.] 970mΩ DC Resistance [Max.] 1.164Ω Other Operating Temp. Range (Including Self-Temp. Rise) -40 to 105degC Soldering Method Reflow, Iron Soldering AEC Q200 Yes Packing Blister (Plastic)Taping [330mm Reel] Package Quantity 1000Pcs Min. Weight 0.6g •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 2 of 3 Creation Date :June 18 2014 CLF6045T-331M-CA CLF6045T-331M-CA CLF6045T-331M-CA CLF6045T-331M-CA CLF6045T-331M-CA •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved 3 of 3 Creation Date :June 18 2014 CLF6045T-331M-CA CLF6045T-331M-CA(Amb. Temp. = 20degc) CLF6045T-331M-CA(Amb. Temp. = 20degc) •This PDF document was created based on the data listed on the TDK Corporation website. •All specifications are subject to change without notice. Copyright(c) TDK Corporation. All rights reserved CLF6045T-331M-CA(DC = 0A) CLF6045T-331M-CA(DC = 0.175A)
CLF6045T-331M-CA 价格&库存
很抱歉,暂时无法提供与“CLF6045T-331M-CA”相匹配的价格&库存,您可以联系我们找货
