I N D U C T O R S
June 2017
Inductors for Power Circuits
Wound Ferrite
CLF Series
CLF7045 Type
CLF7045
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
May 18, 2017
Last Purchase Order Date
Mar. 29, 2019
Last Shipment Date
Sep. 30, 2019
Please refer to our Web site about replacement information.
(2/9)
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 30°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
Th
e
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20170612 / inductor_commercial_power_clf7045_en.fm
(3/9)
I N D U C T O R S
Product compatible with RoHS directive
Compatible with lead-free solders
Wound Ferrite
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Overview of CLF7045 type
FEATURES
Magnetic shield type wound inductor for power circuits.
Wide E-6 Series lineup allows for various usages.
APPLICATION
Thin-screen TVs, LCDs, AV equipment, STBs, LED lights, industrial equipment
PART NUMBER CONSTRUCTION
CLF
Series name
7045
L×W×H Dimensions
(mm)
7045
7.2×6.9×4.5
T
Packaging style
T
Taping
1R5
N
Inductance
(µH)
1R0
1.0
100
10
101
100
Inductance
tolerance
M
±20%
N
±30%
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Package quantity
Individual weight
(g)
0.8
Th
e
Operating
Storage
Type
temperature
temperature
(pieces/reel)
(°C)
(°C)
CLF7045
–40 to +105
–40 to +105
1000
Operating temperature range includes self-temperature rise.
The Storage temperature range is for after the circuit board is mounted.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/9)
I N D U C T O R S
CLF7045 type
RECOMMENDED REFLOW PROFILE
Soldering
Natural
cooling
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Preheating
Peak
T: Temperature
T4
T3
T2
T1
t1
T3
t3
t2
t: Time
Time
t1
60 to 120s
Soldering
Temp.
Time
T3
t2
230°C
30s
Peak
Temp.
T4
250°C
Time
t3
5s
Th
e
Preheating
Temp.
T1
T2
150°C
180°C
(5/9)
I N D U C T O R S
CLF7045 Type
SHAPE & DIMENSIONS
2.0±0.1
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
6.9±0.2
7.2±0.2
100
(4.8)
1.2±0.15
Dimensions in mm
2.2
RECOMMENDED LAND PATTERN
1.7
4.4
1.7
Dimensions in mm
Th
e
4.5±0.3
(0.1)
1.2±0.15
(6/9)
I N D U C T O R S
CLF7045 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Measuring frequency
(µH)
1.0
1.5
2.2
3.3
4.7
6.8
10
15
22
33
47
68
100
150
220
330
470
DC resistance
Rated current
Part No.
9.6m±30%
11.0m±30%
14.6m±30%
16.4m±30%
20m±30%
27m±30%
38m±20%
51m±20%
69m±20%
0.11±20%
0.15±20%
0.21±20%
0.33±20%
0.48±20%
0.66±20%
1.03±20%
1.42±20%
Idc1
(A)
8.9
7.3
5.5
5.0
4.1
3.3
2.7
2.3
1.9
1.55
1.30
1.10
0.90
0.67
0.62
0.49
0.43
CLF7045T-1R0N
CLF7045T-1R5N
CLF7045T-2R2N
CLF7045T-3R3N
CLF7045T-4R7N
CLF7045T-6R8N
CLF7045T-100M
CLF7045T-150M
CLF7045T-220M
CLF7045T-330M
CLF7045T-470M
CLF7045T-680M
CLF7045T-101M
CLF7045T-151M
CLF7045T-221M
CLF7045T-331M
CLF7045T-471M
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L
Tolerance
±30%
±30%
±30%
±30%
±30%
±30%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
(kHz)
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
100
Idc2
(A)
5.2
4.9
4.3
4.1
3.6
3.0
2.5
2.1
1.8
1.40
1.20
0.95
0.75
0.61
0.52
0.42
0.37
Rated current: smaller value of either Idc1 or Idc2.
Idc1: When based on the inductance change rate (10% below the initial value)
Idc2: When based on the temperature increase (Temperature increase of 30°C)
Manufacturer
Keysight Technologies
Panasonic
Th
e
○ Measurement equipment
Measurement item
Product No.
L
4285A
DC resistance
VP-2941A
Rated current Idc1
4285A+42841A+42842C
* Equivalent measurement equipment may be used.
(7/9)
I N D U C T O R S
CLF7045 Type
10000
1000
471M
331M
221M
151M
100
101M
Inductance(µH)
680M
470M
330M
220M
150M
10
100M
6R8N
4R7N
3R3N
2R2N
1
1R5N
1R0N
100
1000
Frequency(kHz)
10000
100000
Th
e
0.1
10
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
L FREQUENCY CHARACTERISTICS GRAPH
Product No.
Manufacturer
4294A
(8/9)
I N D U C T O R S
CLF7045 type
1000
471M
331M
221M
151M
100
101M
680M
470M
330M
Inductance(µH)
220M
150M
10
100M
6R8N
4R7N
3R3N
2R2N
1R5N
1
1
DC current(A)
10
Th
e
0.1
0.1
1R0N
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH
Product No.
Manufacturer
4285A+42841A+42842C
(9/9)
I N D U C T O R S
CLF7045 type
PACKAGING STYLE
REEL DIMENSIONS
E
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
2.0±0.5
Type
CLF7045
A
ø330
W1
16.4
W2
22.4
N
ø50
E
2
N
* These values are typical values.
(1.0)
ø13.0±0.5
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
P0
K
P1
t
A
A
7.5
B
7.5
øD0
1.5+0.1/–0
E
1.75±0.1
F
7.5±0.1
Dimensions in mm
P0
P1
P2
W
4.0±0.1 12.0±0.1 2.0±0.1 16.0±0.3
K
4.9
t
0.4
Th
e
Type
CLF7045
B
W
F
E
øD0
很抱歉,暂时无法提供与“CLF7045T-100M”相匹配的价格&库存,您可以联系我们找货
