CLLE1AX7S0G225M/0.95
    TDK(东电化)
    2.2 µF ±20% 4V 陶瓷电容器 X7S 0805(2012 公制)
CLLE1AX7S0G225M/0.95 数据手册
CLL Series Ultra Low Inductance Capacitors Type: CLLC1A CLLE1A Issue date: April 2011 TDK MLCC US Catalog Version B11 REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. 2. 3. 4. 5. 6. 7. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. We may modify products or discontinue production of a product listed in this catalog without prior notification. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. TDK MLCC US Catalog Page 230 Version B11 CLL Series Ultra Low Inductance Capacitors Type: CLLC1A (C1608), CLLE1A (C2012) Features • Features a unique internal structure that cancels magnetic fields to reduce equivalent series inductance • Eight side terminal electrodes in one capacitor Structure Applications • Decoupling CPU power line • High speed digital IC/decoupling • GPU/CPU Shape & Dimensions ULI Chip Size C1608 C2012 FLIP STD C1632 C2012 Cap. 1µF 1µF 1µF 1µF W.V. 0G (4V) 0G (4V) 1A (10V) 1A (10V) ESL 65pH 70pH 180pH 850pH Dimensions in mm L W T C P Body Length Body Width Body Height Terminal Width Terminal Spacing Part Number Construction CLLC1A X7R 0J 105 M T XXXX Internal Codes Series Name Case Code CLLC1A CLLE1A Length 1.60 ± 0.10 2.00 ± 0.15 Width 0.80 ± 0.10 1.25 ± 0.15 Packaging Style Capacitance Change ± 15% ± 22% Temperature Range -55 to +125ºC -55 to +125ºC Tolerance Code M Tolerance ± 20% Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Rated Voltage (DC) Voltage Code 0G 0J 1A Style Tape & Reel Capacitance Tolerance Temperature Characteristic Temperature Characteristics X7R X7S Packaging Code T Voltage (DC) 4V 6.3V 10V Capacitance Code 0R5 010 102 105 TDK MLCC US Catalog Page 231 Capacitance 0.5pF 1pF 1,000pF (1nF) 1,000,000pF (1µF) Version B11 Capacitance Range Chart CLLC1A [EIA CC0603] Capacitance Range Chart Temperature Characteristics: X7S (± 22) Rated Voltage: 4V (0G) Capacitance (pF) 330,000 470,000 680,000 1,000,000 X7S Cap Code 334 474 684 105 Tolerance 0G (4V) M: ± 20% Standard Thickness 0.50 mm Capacitance Range Table CLLC1A [EIA CC0603] Class 2 (Temperature Stable) Temperature Characteristics: X7S (-55 to +125ºC, ±22%) TDK Part Number Temperature Rated (Ordering Code) Characteristics Voltage Capacitance (pF) Capacitance Tolerance Thickness (mm) CLLC1AX7S0G334M X7S 4V 330,000 ± 20% 0.50 ± 0.10 CLLC1AX7S0G474M X7S 4V 470,000 ± 20% 0.50 ± 0.10 CLLC1AX7S0G684M X7S 4V 680,000 ± 20% 0.50 ± 0.10 CLLC1AX7S0G105M X7S 4V 1,000,000 ± 20% 0.50 ± 0.10 TDK MLCC US Catalog Page 232 Version B11 Capacitance Range Chart CLLE1A [EIA CC0805] Capacitance Range Chart Temperature Characteristics: X7R (± 15%), X7S (± 22) Rated Voltage: 10V (1A), 6.3V (0J), 4V (0G) Capacitance (pF) 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 4,700,000 X7R Cap Code 104 154 224 334 474 684 105 155 225 475 Tolerance 1A (10V) X7S 0J (6.3V) 0G (4V) M: ± 20% Standard Thickness 0.50 mm 0.85 mm Capacitance Range Table CLLE1A [EIA CC0805] Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%), X7S (-55 to +125ºC, ±22%) TDK Part Number Temperature Rated Capacitance Capacitance (Ordering Code) Characteristics Voltage (pF) Tolerance Thickness (mm) CLLE1AX7R1A104M X7R 10V 100,000 ± 20% 0.50 ± 0.10 CLLE1AX7R1A154M X7R 10V 150,000 ± 20% 0.50 ± 0.10 CLLE1AX7R1A224M X7R 10V 220,000 ± 20% 0.50 ± 0.10 CLLE1AX7R1A334M X7R 10V 330,000 ± 20% 0.50 ± 0.10 CLLE1AX7R0J474M X7R 6.3V 470,000 ± 20% 0.50 ± 0.10 CLLE1AX7R0J684M X7R 6.3V 680,000 ± 20% 0.50 ± 0.10 CLLE1AX7R0J105M X7R 6.3V 1,000,000 ± 20% 0.85 ± 0.10 CLLE1AX7R0J155M X7R 6.3V 1,500,000 ± 20% 0.85 ± 0.10 CLLE1AX7S0G105M X7S 4V 1,000,000 ± 20% 0.50 ± 0.10 CLLE1AX7S0G155M X7S 4V 1,500,000 ± 20% 0.50 ± 0.10 CLLE1AX7S0G225M/0.50 X7S 4V 2,200,000 ± 20% 0.50 ± 0.10 CLLE1AX7S0G225M/0.85 X7S 4V 2,200,000 ± 20% 0.85 ± 0.10 CLLE1AX7S0G475M X7S 4V 4,700,000 ± 20% 0.85 ± 0.10 TDK MLCC US Catalog Page 233 Version B11 General Specifications CLL Series – ULI Capacitors No. Item Performance Test or Inspection Method 1 External Appearance No defects which may affect performance. Inspect with magnifying glass (3×). 2 Insulation Resistance 100MΩ•μF min. Apply rated voltage for 60s. Measure 8 terminal electrodes at the same time. 3 Voltage Proof Withstand test voltage without insulation breakdown or other damage. 2.5 times rated voltage (DC) shall be applied for 1 to 5s. Charge / discharge current shall not exceed 50mA. Measure 8 terminal electrodes at the same time. 4 Capacitance Within the specified tolerance at 1000hrs age (Per IEC-384-9). Measuring Frequency 1kHz±10% Withstanding Voltage Measuring voltage 10V 1.0 ± 0.2 Vrms ≤ 6.3V 0.5 ± 0.2 Vrms Measure 8 terminal electrodes at the same time. 5 6 7 Dissipation Factor (Class 2) Temperature Characteristics of Capacitance (Class 2) Robustness of Terminations T.C. D.F. X7R X7S 0.10 max. See No.4 in this table for measuring condition. Capacitance Change (%) Capacitance shall be measured by the steps shown in the following table after thermal equilibrium is obtained for each step. ∆C be calculated ref. STEP 3 reading No DC Voltage Applied X7R: ± 15% X7S: ± 22% Step No sign of termination coming off, breakage of ceramic, or other abnormal signs. Temperature (ºC) 1 Reference temp. ± 2 2 Min. operating temp. ± 2 3 Reference temp. ± 2 4 Max. operating temp. ± 2 Reflow solder the capacitor on P.C. board (shown in Appendix 1 and 2) and apply a pushing force of 2N for 10±1s. 2N Capacitor 8 Solderability All terminations shall exhibit a continuous solder coating free from defects for a minimum of 75% of the surface area of any individual termination. Anomalies other than dewetting, non-wetting, and pin holes are not cause for rejection. Ceramic surface of A sections shall not be exposed due to melting or shifting of termination material. P.C. Board Completely soak both terminations in solder at 235±5°C for 2±0.5s. Solder : H63A (JIS Z 3282) Flux : Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. A section TDK MLCC US Catalog Page 234 Version B11 General Specifications CLL Series – ULI Capacitors No. Item 9 Resistance to solder heat External appearance Capacitance Performance No cracks are allowed and terminations shall be covered at least 60% with new solder Characteristics X7R X7S 10 Change from the value before test ± 7.5 % D.F. (Class 2) Meet the initial spec. Insulation Resistance Meet the initial spec. Capacitance X7R X7S D.F. (Class 2) Capacitance Change from the value before test ± 7.5 % Vibrate the capacitor with amplitude of1.5mm P-P sweeping the frequencies from 10Hz to 55Hz and back to 10Hz in about 1 minute. Repeat this for 2h each in 3 perpendicular directions (6h in total). Meet the initial spec. Reflow solder the capacitors on a P.C. board (shown in Appendix 1 and 2) before testing. No mechanical damage. Characteristics X7R X7S Change from the value before test ± 7.5 % D.F. (Class 2) Meet the initial spec. Insulation Resistance Meet the initial spec. Voltage Proof No insulation breakdown or other damage. TDK MLCC US Catalog Flux : Isopropyl alcohol (JIS K 8839) Rosin (JIS K 5902) 25% solid solution. Reflow solder the capacitor on a P.C. board (shown in Appendix 1 and 2) before testing. Temperature cycle External appearance Preheating condition Temp. : 150±10ºC Time : 1 to 2min. Leave the capacitor in ambient conditions for 24±2h before measurement. No mechanical damage. Characteristics Completely soak both terminations in solder at 260±5ºC for 5±1s. Solder : H63A (JIS Z 3282) Vibration External appearance 11 Test or Inspection Method Page 235 Expose the capacitor in the condition step1 through step 4, and repeat 5 times consecutively. Leave the capacitor in ambient conditions for 24±2h before measurement. Step Temperature (ºC) Time (min.) 1 Min. operating temp. ±3 30 ± 3 2 Reference Temp. 2–5 3 Max. operating temp. ± 2 30 ± 2 4 Reference Temp. 2-5 Version B11 General Specifications CLL Series – ULI Capacitors No. Item 12 Moisture Resistance (Steady State) External appearance Performance Reflow solder the capacitor on P.C. board (shown in Appendix 1 and 2) before testing. No mechanical damage. Capacitance Characteristics X7R X7S 13 Test or Inspection Method Change from the value before test ± 12.5 % D.F. (Class 2) Characteristics: X7R: 200% of initial spec. max. X7S: 200% of initial spec. max. Insulation Resistance 10MΩ·μF min. Moisture Resistance External appearance Capacitance X7R X7S Leave the capacitor in ambient condition for 24±2h before measurement. Reflow solder the capacitors on P.C. board (shown in Appendix 1 and 2) before testing. No mechanical damage. Characteristics Leave at temperature 40±2ºC and 90 to 95%RH for 500 +24,0h. Change from the value before test Apply the rated voltage at temperature 40±2ºC and 90 to 95%RH for 500 +24,0h. Charge/discharge current shall not exceed 50mA. Leave the capacitor in ambient conditions for 48±4h before measurement. ± 12.5 % D.F. (Class 2) Characteristics X7R: 200% of initial spec. max. X7S: 200% of initial spec. max. Voltage conditioning: Voltage treat the capacitors under testing temperature and voltage for 1 hour. Insulation Resistance 5MΩ·μF min. Leave the capacitors in ambient condition for 24±2h before measurement. Use this measurement for initial value. 14 Life External appearance Capacitance Reflow solder the capacitor on P.C. board (shown in Appendix 1 and 2) before testing. No mechanical damage. Characteristics X7R X7S Apply 1 x rated voltage at 125±2ºC for 1,000 +48, 0h. Change from the value before test ± 15 % D.F. (Class 2) Characteristics X7R: 200% of initial spec. max. X7S: 200% of initial spec. max. Insulation Resistance 10MΩ·μF min. TDK MLCC US Catalog Charge/discharge current shall not exceed 50mA. Leave the capacitors in ambient condition for 24±2h before measurement. Voltage conditioning: Voltage treat the capacitor under testing temperature and voltage for 1 hour. Leave the capacitor in ambient conditions for 48±4h before measurement. Use this measurement for initial value. Page 236 Version B11 General Specifications CLL Series – ULI Capacitors Appendix - 1 P.C. Board for reliability test Applied for CLLC1A 50.0 50.0 41.25 41.25 4.0 3.0 1.5 2.5 20.0 2.0 10.0 7.0 20.0 18.0 15.0 4.0 7.0 5.0 5.0 10.0 20.0 19.0 Unit: mm Material: Glass Epoxy ( As per JIS C6484 GE4 ) P.C. Board thickness: 0.8mm 1.1 0.8 0.4 pitch Copper ( thickness 0.035mm ) Solder resist 0.6 1.1 0.8 0.6 0.4 0.08 1.2 0.76 0.725 0.725 0.76 0.32 0.25 1.2 0.19 TDK MLCC US Catalog Page 237 Version B11 General Specifications CLL Series – ULI Capacitors Appendix - 2 P.C. Board for reliability test Applied for CLLE1A 50.0 50.0 41.25 41.25 4.0 3.0 1.5 2.5 20.0 10.0 7.0 4.0 5.0 5.0 7.0 15.0 2.0 19.0 18.0 10.0 20.0 20.0 Unit: mm 1.5 Material: Glass Epoxy ( As per JIS C6484 GE4) 1.1 P.C. Board thickness: 1.6mm 0.85 0.5 pitch Copper ( thickness 0.035mm ) Solder resist 1.5 1.1 0.85 0.7 8.3 1.05 0.4 1.05 0.9 0.1 0.9 0.3 8.3 0.4 TDK MLCC US Catalog Page 238 Version B11 Soldering Information CLL Series – ULI Capacitors • Recommended Soldering Land Pattern • Recommended Soldering Profile Reflow Soldering P A Preheating 300 B 0 Temp (ºC) Temp (ºC) Peak Temp D C Manual soldering (Solder iron) Soldering Natural cooling ∆T ∆T Preheating 0 Over 60 sec. Peak Temp time Reflow Soldering Unit: mm CLLC1A (C1608/CC0603) CLLE1A (C2012/CC0805) A 0.25 0.3 Type Symbol B 0.4 0.3 ~ 0.6 C 1.2 1.3 ~ 1.8 D 0.4 0.5 ~ 0.8 P 0.4 0.5 Recommended soldering duration Temp./ Dura. Reflow Soldering Peak temp (°C) Duration (sec.) Sn-Pb Solder 230 max. 20 max. Lead-Free Solder 260 max. 10 max. Solder Recommended solder compositions Sn-37Pb (Sn-Pb solder) Sn-3.0Ag-0.5Cu (Lead Free Solder) • Recommended Solder Amount Excessive solder 3sec. (As short as possible) Preheating Condition Higher tensile force on the chip capacitor may cause cracking. Soldering Temp. (ºC) Reflow soldering ∆T ≤ 150 Manual soldering ∆T ≤ 150 Maximum amount Adequate solder Insufficient solder TDK MLCC US Catalog Minimum amount Small solder fillet may cause contact failure or failure to hold the chip capacitor to the P.C. board. Page 239 Version B11 Packaging Information CLL Series – ULI Capacitors • Carrier Tape Configuration Blank Blank Chips 160mm min. 160mm min. Leader Drawing direction 400mm min. • Peel Back Force (Top Tape) Direction & angle of pull force Top cover tape Carrier tape 0~15° • Carrier tape shall be flexible enough to be wound around a minimum radius of 30mm with components in tape. • The missing of components shall be less than 0.1% • Components shall not stick to the cover tape. • The cover tape shall not protrude beyond the edges of the carrier tape and shall not cover the sprocket holes. Direction of pull force • Chip Quantity Per Reel and Structure of Reel Top cover tape Pitch hole Cavity (Chip insert) Plastic carrier tape Series Taping Material CLLC1A CLLE1A Plastic TDK MLCC US Catalog Chip quantity (pcs.) φ178mm (7”) reel φ330mm (13”) reel 4,000 10,000 4,000 10,000 Page 240 Version B11 Additional Information CLL Series – ULI Capacitors • Inside Structure & Material System A’ No. NAME MATERIAL (1) Ceramic Dielectric BaTiO3 (2) Internal Electrode Nickel (Ni) Class 2 B’ (3) (4) B Copper (Cu) Termination (5) A 3 4 Nickel (Ni) Tin (Sn) 5 2 1 • Equivalent Circuit • Environmental Information TDK Corporation established internal product environmental assurance standards that include the six hazardous substances banned by the EU RoHS Directive1 enforced on July 1, 2006 along with additional substances independently banned by TDK and has successfully completed making general purpose electronic components conform to the RoHS Directive2. + 1) 3) 5) 7) - 2) 4) 6) 8) 8 terminals are connected and measured at the same time. 1. Abbreviation for Restriction on Hazardous Substances, which refers to the regulation EU Directive 2002/95/EC on hazardous substances by the European Union (EU) effective from July 1, 2006. The Directive bans the use of six specific hazardous substances in electric and electronic devices and products handled within the EU. The six substances are lead, mercury, cadmium, hexavalent chromium, PBB (polybrominated biphenyls), and PBDE (polybrominated diphenyl ethers). 2. This means that, in conformity with the EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • Shape & Dimensions L T W P Case Code Series JIS EIA CLLC1A C1608 CC0603 CLLE1A C2012 CC0805 TDK MLCC US Catalog C L 1.60 2.00 Dimensions (mm) W T P 0.80 0.55 max. 0.40 1.25 0.95 max. 0.50 C 0.25 0.25 Page 241 For REACH (SVHC : 15 substances according to ECHA / October 2008) : All TDK MLCC do not contain these 15 substances. For European Directive 2000/53/CE and 2005/673/CE : Cadmium, Hexavalent Chromium, Mercury, Lead are not contained in all TDK MLCC. For European Directive 2003/11/CE : Pentabromodiphenylether, Octabromodiphenyl-ether are not contained in all TDK MLCC. Version B11
CLLE1AX7S0G225M/0.95 价格&库存
很抱歉,暂时无法提供与“CLLE1AX7S0G225M/0.95”相匹配的价格&库存,您可以联系我们找货
