CLLE1AX7S0G225M050AC
    TDK(东电化)
    2.2 µF ±20% 4V 陶瓷电容器 X7S 0805(2012 公制)
CLLE1AX7S0G225M050AC 数据手册
MULTILAYER CERAMIC CHIP CAPACITORS CLL Series Commercial Grade Ultra Low Inductance Type: CLLC1A [EIA CC0603] CLLE1A [EIA CC0805] CLLG1A [EIA CC1206] lssue date: Dec 2014 20141224 / mlcc_commercial_uli_en MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item according to the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire export permission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Catalog Number Item Description (On Delivery Label) Prior to January 2013 C1608C0G1E103J C1608C0G1E103JT000N January 2013 and Later C1608C0G1E103J080AA C1608C0G1E103JT000N Page 1 20141224 / mlcc_commercial_uli_en MULTILAYER CERAMIC CHIP CAPACITORS CLL Series Ultra Low Inductance Type: CLLC1A [EIA CC0603], CLLE1A [EIA CC0805], CLLG1A [EIA CC1206] Features • Features a unique internal structure that cancels magnetic fields to reduce equivalent series inductance. • Eight side terminal electrodes in one capacitor. • Small and low profile design enables undersurface mounting for semiconductor packages. Shape & Dimensions L W T C P Applications • Decoupling CPU power line • High speed digital IC, decoupling • GPU, CPU - Design Structure Body Length Body Width Body Height Terminal Width Terminal Spacing + Catalog Number Construction - + + - + Internal Electrode Terminations CLL • E1A • X7S • 0G • 685 • M • 050 • A • C Series Name Dimensions L x W (mm) Code C1A E1A G1A Length 1.60 ± 0.10 2.00 ± 0.15 3.20 ± 0.15 Width 0.80 ± 0.10 1.25 ± 0.15 1.60 ± 0.15 Temperature Characteristics Temperature Characteristics X6S X7R X7S Capacitance Change ±22% ±15% ±22% Temperature Range -55 to +105°C -55 to +125°C -55 to +125°C Rated Voltage (DC) Code 0G 0J 1A Voltage (DC) 4.0V 6.3V 10V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Capacitance Tolerance Code M Tolerance ± 20% ([5 S) S) S) Q) ȝ) Nominal Thickness Code 050 055 085 Thickness 0.50 mm 0.55 mm 0.85 mm Packaging Style Code A Style 178 mm Reel, 4 mm Pitch Special Reserved Code Code C Description TDK Internal Code Page 2 • All specifications are subject to change without notice. 20141224 / mlcc_commercial_uli_en MULTILAYER CERAMIC CHIP CAPACITORS CLLC1A(1608) [EIA CC0603] Capacitance Range Chart Capacitance Range Chart Temperature Characteristics: X6S (± 22%), X7R (±15%), X7S (± 22%) Rated Voltage: 4V (0G) Capacitance (pF) 47,000 100,000 330,000 470,000 680,000 1,000,000 2,200,000 4,700,000 Code 473 104 334 474 684 105 225 475 Tolerance X6S X7R X7S 0G (4V) 0G (4V) 0G (4V) M: ± 20% CLLE1A(2012) [EIA CC0805] Capacitance Range Chart Capacitance Range Chart Temperature Characteristics: X7R (±15%), X7S (± 22%) Rated Voltage: 10V (1A), 6.3V (0J), 4V (0G) Capacitance (pF) 47,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 4,700,000 6,800,000 X7R Code 473 104 154 224 334 474 684 105 155 225 475 685 Tolerance 1A (10V) 0J (6.3V) X7S 0G (4V) 1A (10V) 0J (6.3V) 0G (4V) M: ± 20% CLLG1A(3216) [EIA CC1206] Capacitance Range Chart Capacitance Range Chart Temperature Characteristics: X7R (±15%), Rated Voltage: 10V (1A), 6.3V (0J) Capacitance (pF) 1,000,000 2,200,000 X7R Code 105 225 Tolerance 1A (10V) 0J (6.3V) M: ± 20% Standard Thickness 0.50 mm 0.85 mm Page 3 • All specifications are subject to change without notice. 20141224 / mlcc_commercial_uli_en MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics: X6S (-55 to +105ºC, ±22%) Capacitance Size Thickness (mm) Capacitance Tolerance 4.7 μF 1608 0.50 ± 0.05 ± 20% Catalog Number Rated Voltage Edc: 10V Rated Voltage Edc: 6.3V Rated Voltage Edc: 4.0V CLLC1AX6S0G475M050AC Rated Voltage Edc: 6.3V Rated Voltage Edc: 4.0V CLLE1AX7R0G473M050AC CLLC1AX7R0G104M050AC Class 2 (Temperature Stable) Temperature Characteristics: X7R (-55 to +125ºC, ±15%) Capacitance Size 47 nF 2012 1608 100 nF 150 nF 220 nF 330 nF 470 nF 680 nF 1 μF 1.5 μF 2.2 μF 2012 2012 2012 2012 2012 2012 2012 3216 2012 3216 Thickness (mm) Capacitance Tolerance 0.50 ± 0.05 0.50 ± 0.05 0.50 +0.05/-0.10 0.50 ± 0.05 0.50 +0.05/-0.10 0.50 +0.05/-0.10 0.50 +0.05/-0.10 0.50 +0.05/-0.10 0.50 +0.05/-0.10 0.85 ± 0.10 0.85 ± 0.10 0.85 ± 0.10 0.85 ± 0.10 ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% Catalog Number Rated Voltage Edc: 10V CLLE1AX7R1A104M050AC CLLE1AX7R0G104M050AC CLLE1AX7R1A154M050AC CLLE1AX7R1A224M050AC CLLE1AX7R1A334M050AC CLLE1AX7R0J474M050AC CLLE1AX7R0J684M050AC CLLE1AX7R0J105M085AC CLLE1AX7R0G105M085AC CLLG1AX7R1A105M085AC CLLE1AX7R0J155M085AC CLLG1AX7R0J225M085AC Class 2 (Temperature Stable) Temperature Characteristics: X7S (-55 to +125ºC, ±22%) Capacitance 47 nF 100 nF 150 nF 220 nF 330 nF 470 nF 680 nF 1 μF 1.5 μF Size 1608 2012 1608 2012 2012 2012 1608 2012 1608 2012 1608 2012 1608 2012 2012 1608 2.2 μF 2012 4.7 μF 2012 6.8 μF 2012 Thickness (mm) Capacitance Tolerance 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 ± 0.05 0.50 +0.05/-0.10 0.50 ± 0.05 0.50 +0.05/-0.10 0.50 ± 0.05 0.50 +0.05/-0.10 0.50 ± 0.05 0.50 +0.05/-0.10 0.50 +0.05/-0.10 0.50 +0.05/-0.10 0.85 ± 0.10 0.50 ± 0.05 0.50 +0.05/-0.10 0.85 ± 0.10 0.50 ± 0.05 0.85 ± 0.10 0.50 ± 0.05 ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% ± 20% Catalog Number Rated Voltage Edc: 10V Rated Voltage Edc: 6.3V Rated Voltage Edc: 4.0V CLLC1AX7S0G473M050AC CLLE1AX7S0G473M050AC CLLC1AX7S0G104M050AC CLLE1AX7S0G104M050AC CLLE1AX7S1A154M050AC CLLE1AX7S1A224M050AC CLLC1AX7S0G334M050AC CLLE1AX7S1A334M050AC CLLC1AX7S0G474M050AC CLLE1AX7S0J474M050AC CLLC1AX7S0G684M050AC CLLE1AX7S0J684M050AC CLLC1AX7S0G105M050AC CLLE1AX7S0G105M050AC CLLE1AX7S0G155M050AC CLLE1AX7S0J155M085AC CLLC1AX7S0G225M050AC CLLE1AX7S0G225M050AC CLLE1AX7S0G225M085AC CLLE1AX7S0G475M050AC CLLE1AX7S0G475M085AC CLLE1AX7S0G685M050AC Page 4 • All specifications are subject to change without notice. 20141224 / mlcc_commercial_uli_en
物料型号: - CLLC1A [EIA CC0603] - CLLE1A [EIA CC0805] - CLLG1A [EIA CC1206]
器件简介: - 这些电容器具有超低电感特性,适用于高速数字IC、CPU、GPU的去耦。 - 采用八侧端电极设计,小型化低轮廓设计,可实现半导体封装的底部安装。
引脚分配: - 八侧端电极设计。
参数特性: - 具有独特的内部结构,可抵消磁场,降低等效串联电感。 - 温度特性包括X6S(-55至+105°C,±22%)、X7R(-55至+125°C,±15%)、X7S(-55至+125°C,±22%)。 - 额定电压包括4.0V、6.3V、10V。 - 电容公差为±20%。
功能详解: - 电容器具有超低电感特性,适用于高速信号线路的去耦。
应用信息: - 用于CPU电源线路去耦、高速数字IC去耦、GPU、CPU等。
封装信息: - 提供了详细的尺寸信息和封装样式代码。
CLLE1AX7S0G225M050AC 价格&库存
很抱歉,暂时无法提供与“CLLE1AX7S0G225M050AC”相匹配的价格&库存,您可以联系我们找货
