Mid-high Voltage Ceramic Capacitors
Disk type with lead
Safety standard approved
CS series
Issue date:
October 2011
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/3)
Mid-high Voltage Ceramic Capacitors(Disk with Lead)
Safety Standard Approved CS Series
BASIC INSULATION TYPE/Operating temperature range: –25 to +105°C(UL standard: –25 to +85°C)
CLASS 2 HIGH DIELECTRIC
PRODUCT IDENTIFICATION
FEATURES
• Flame-resistant reinforced outer insulation prevents fires, electrical shock, and other potential hazards.
• Compliant with the safety standards of 11 countries.
• It has a withstand voltage of AC.2600V
• This product is compatible with halogen-free external resin
coating (we recommend halogen-free products as standard).
CS 11 -E 2GA 222 M Y N S A
(1) (2) (3) (4) (5) (6) (7) (8) (9) (10)
(1) Type
(2) Shape
(3) Capacitance temperature characteristics
(4) Rated voltage
(5) Nominal capacitance
(6) Capacitance tolerance
(7) Class
(8) Lead type
(9) Safety standard
(10) Halogen-free compatible product
CAPACITANCE TEMPERATURE CHARACTERISTICS
AND TOLERANCE
Test temperature
range
–25 to +85°C
–25 to +85°C
–25 to +85°C
Temperature characteristics
B(±10%)
E(+20, –55%)
F(+30, –80%)
Capacitance
tolerance
K(±10%)
M(±20%)
M(±20%)
CAPACITANCE AND DIMENSIONS
Part No.
Halogen-free product
Current product
CS70-B2GA101KY∗SA
CS70-B2GA151KYSA
CS70-B2GA221KYSA
CS85-B2GA331KYSA
CS85-B2GA471KYSA
CS95-B2GA681KYSA
CS10-B2GA102KYSA
CS80-E2GA102MYSA
CS90-E2GA152MYSA
CS11-E2GA222MYSA
CS13-E2GA332MYSA
CS14-E2GA392MYSA
CS15-E2GA472MYSA
CS12-F2GA472MYSA
CS17-F2GA103MYSA
CS70-B2GA101KY∗S
CS70-B2GA151KYS
CS70-B2GA221KYS
CS85-B2GA331KYS
CS85-B2GA471KYS
CS95-B2GA681KYS
CS10-B2GA102KYS
CS80-E2GA102MYS
CS90-E2GA152MYS
CS11-E2GA222MYS
CS13-E2GA332MYS
CS14-E2GA392MYS
CS15-E2GA472MYS
CS12-F2GA472MYS
CS17-F2GA103MYS
Capacitance
temperature
characteristics
B(±10%)
E(+20, –55%)
F(+30, –80%)
Dimensions(mm)
Capacitance
(pF)
Capacitance
tolerance
D max. T max. F
d
Taping
dimensions
100
150
220
330
470
680
1,000
1,000
1,500
2,200
3,300
3,900
4,700
4,700
10,000
K(±10%)
K(±10%)
K(±10%)
K(±10%)
K(±10%)
K(±10%)
K(±10%)
M(±20%)
M(±20%)
M(±20%)
M(±20%)
M(±20%)
M(±20%)
M(±20%)
M(±20%)
7.0
7.0
7.0
8.5
8.5
9.5
10.0
8.0
9.0
10.5
12.5
13.5
14.5
12.0
16.5
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
0.6±0.05
V2
V2
V2
V2
V2
V2
V2
V2
V2
V2
V2
V2
V3
V2
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.0
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
7.5±1.5
10±2
: Lead shape symbol
LIST OF STANDARD LEAD SHAPES
The lead type is indicated by the letter which is the 15th character of the product name.
Example) TDK Product Name: CS11-E2GA222MYNSA
N: Lead type (Vertical kink, Short)
Dimensions in mm
Short lead
Symbol G
Symbol N
T
D
D
T
4max.
4max.
D
Taping
Symbol V
F
F
d
5±1
25min.
16+1.5
–0.5
Vertical kink
T
4max.
Long lead
d
• We recommend using a vertical kink type.
• For bulk products, we recommend a short lead type with the symbol N.
005-03 / 20111003 / e4b3_cs.fm
(2/3)
HALOGEN-FREE PRODUCT
MARKINGS
Item
1. Series
2. Nominal capacitance
3. Capacitance tolerance
4. Rated voltage Eac
5. Sub-class of safety performance
6. TDK’s logogram
7. Date code
Marking examples
CS
222(2200pF)
M(±20%)
(AC.250V)
250V
X1Y2
CS222M
250
X1Y2
15
15 (2011.5)∗
(Marking position is reference.)
Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December).
The expression has become simplified due to a revision in the standards.
INTERNATIONALLY CERTIFIED STATUS / IEC60384-14 EN60384-14 Approved
Safety
standard
BSI
VDE
SEV
SEMKO
NEMKO
DEMKO
FIMKO
IMQ
SAA
UL
Standard No.
of IEC
IEC 60065
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60065
Temperature
Insulation
characteristics sub-class
Standard No.
BS EN 60065
BS EN60384-14
EN 60384-14
EN 60384-14
EN 60384-14
EN 60384-14
EN 60384-14
EN 60384-14
EN 60384-14
AS3250
UL 1414
Rated voltage
Eac(V)
Approval report No.
Japan
Taiwan
Xiamen
B, E, F
X1, Y2
250
KM37103
KM37103
KM37103
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
X1, Y2
X1, Y2
X1, Y2
X1, Y2
X1, Y2
X1, Y2
X1, Y2
(X, Y)
250
250
250
250
250
250
250
400
250
40029781
10.0120
912461
P09211677
315269-01
FI 25553
V3692
CS6268
E37861
2278972
(LR 35801)
CQC10001051610
40029781
10.0120
912461
P09211677
315269-01
FI 25553
V3692
CS6268
E37861
2278972
(LR 35801)
CQC10001051637
40029781
10.0120
912461
P09211677
315269-01
FI 25553
V3692
CS6268
E37861
2278972
(LR 35801)
CQC03001004815
CSA
IEC 60384-14 CAN/CSA-E60384-14
B, E, F
(X, Y)
250
CQC
IEC 60384-14 GB-T 14472-1998
B, E, F
X1, Y2
250
• Certificate numbers shall be changed owing to the revisions of the related standards.
CURRENT PRODUCT
MARKINGS
Item
1. Series
5. Withstand voltage Eac
6. Sub-class of safety performance
7. TDK’s logogram
8. Date code
9. Regulatory body safety standards compliance markings
BSI
(U.K.)
BSI
SEV
(Switzerland)
SEMKO
(Sweden)
UL
(U.S.A.)
VDE
(Germany)
CSA
(Canada)
TJ508
Marking examples
CS
222(2200pF)
M(±20%)
(AC.250V)
250V
X1Y2
Back
Front
CS222M
BSI
250V
X1Y2
TJ508
15
15 (2011.5)∗
(Marking position of the monogram is reference.)
FIMKO
(Finland)
NEMKO
(Norway)
DEMKO
(Denmark)
IMQ
(Italy)
Safety
standard
BSI
VDE
SEV
SEMKO
NEMKO
DEMKO
FIMKO
IMQ
SAA
UL
CSA
Standard No.
of IEC
IEC 60065
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60384-14
IEC 60065
Standard No.
BS EN 60065
BS EN60384-14
EN60384-14
EN60384-14
EN60384-14
EN60384-14
EN60384-14
EN60384-14
EN60384-14
AS3250
UL 1414
CSA C22.2 No.0 & No.1
Temperature
characteristics
Insulation
sub-class
Rated voltage
Eac(V)
Approval report No.
Japan
Taiwan
Xiamen
B, E, F
X1, Y2
250
226494
226494
226494
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
B, E, F
X1, Y2
X1, Y2
X1, Y2
X1, Y2
X1, Y2
X1, Y2
X1, Y2
(X, Y)
(X, Y)
250
250
250
250
250
250
250
400
250
250
138559
09.0962
915556
P09211507
315179-01
FI 25453
V3692
6268
E37861
LR35801
138560
09.0962
915556
P09211507
315179-01
FI 25453
V3692
6268
E37861
LR65972
122006
09.0962
915394
P08209309
314664-02
FI 24306A1
V3692
6268
E37861
LR65972
(3/3)
TAPING DIMEMSIONS
VERTICAL KINK LEAD TYPE
D
P
T
P2
D
∆h
T
P2
∆h
H0
S
W0
W
L
W1
L
W0
W
P0
D0
ød
P1 F
D0
ød
t
t
P0
C
H0
H1
S
H0
W2
C
A
H0
H1
W1
P1 F
∆h
A
∆h
W2
P
V3
V1, V2
Item
Symbol
Dimensions(mm)
V1
V2
V3
Remarks
Body diameter
D
Depends on the specification of each product.
Body thickness
T
Lead-wire diameter
ød
0.6±0.05
0.6±0.05
0.6±0.05
Pitch of component
P
12.7±1.0
15.0±1.0
30.0±1.0
Including the slant of body
Feed hole pitch
P0
12.7±0.3
15.0±0.3
15.0±0.3
Excepting the tape splicing part
Feed hole center to lead
P1
3.85±0.7
3.75±0.7
3.75±0.7
Feed hole center to component
center
P2
6.35±1.3
7.5±1.3
7.5±1.3
Lead-to lead distance
F
5+0.8, –0.2
7.5±0.8
7.5±0.8
Measuring point is bottom kink
Component alignment
∆h
0±2.0
0±2.0
0±2.0
Including the slanting body due to bending lead-wire
Tape width
W
18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5
Adhesive tape width
W0
11.5min.
11.5min.
11.5min.
Hole position
W1
9.0±0.5
9.0±0.5
9.0±0.5
Adhesive tape position
W2
3.0max.
3.0max.
3.0max.
Bottom of kink from tape center
H0
16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5
Height of body from tape center
H1
46.0max.
46.0max.
46.0max.
1.0max.
1.0max.
1.0max.
Lead-wire protrusion
Feed hole diameter
D0
4.0±0.2
4.0±0.2
4.0±0.2
Total tape thickness
t
0.6±0.3
0.6±0.3
0.6±0.3
Length of snipped lead
L
11.0max.
11.0max.
11.0max.
Coating on lead
C
4.0max.
4.0max.
4.0max.
Height of kink
A
4.0max.
4.0max.
4.0max.
Spring action
S
2.0max.
2.0max.
2.0max.
Adhesive tape do not stick out the tape
Do not including adhesive tape
• For more information about products with other capacitance or other data, please contact us.
