CS70-B2GA101KYNS
CS70-B2GA101KYNS
    TDK(东电化)
    Radial
    贴片电容(MLCC) 径向 100pF ±10% 250V B
CS70-B2GA101KYNS 数据手册
Mid-high Voltage Ceramic Capacitors Disk type with lead Safety standard approved CS series Issue date: October 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/3) Mid-high Voltage Ceramic Capacitors(Disk with Lead) Safety Standard Approved CS Series Conformity to RoHS Directive BASIC INSULATION TYPE/Operating temperature range: –25 to +105°C(UL standard: –25 to +85°C) CLASS 2 HIGH DIELECTRIC PRODUCT IDENTIFICATION FEATURES • Flame-resistant reinforced outer insulation prevents fires, electrical shock, and other potential hazards. • Compliant with the safety standards of 11 countries. • It has a withstand voltage of AC.2600V • This product is compatible with halogen-free external resin coating (we recommend halogen-free products as standard). CS 11 -E 2GA 222 M Y N S A (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (1) Type (2) Shape (3) Capacitance temperature characteristics (4) Rated voltage (5) Nominal capacitance (6) Capacitance tolerance (7) Class (8) Lead type (9) Safety standard (10) Halogen-free compatible product CAPACITANCE TEMPERATURE CHARACTERISTICS AND TOLERANCE Test temperature range –25 to +85°C –25 to +85°C –25 to +85°C Temperature characteristics B(±10%) E(+20, –55%) F(+30, –80%) Capacitance tolerance K(±10%) M(±20%) M(±20%) CAPACITANCE AND DIMENSIONS Part No. Halogen-free product Current product CS70-B2GA101KY†∗SA CS70-B2GA151KY†SA CS70-B2GA221KY†SA CS85-B2GA331KY†SA CS85-B2GA471KY†SA CS95-B2GA681KY†SA CS10-B2GA102KY†SA CS80-E2GA102MY†SA CS90-E2GA152MY†SA CS11-E2GA222MY†SA CS13-E2GA332MY†SA CS14-E2GA392MY†SA CS15-E2GA472MY†SA CS12-F2GA472MY†SA CS17-F2GA103MY†SA CS70-B2GA101KY†∗S CS70-B2GA151KY†S CS70-B2GA221KY†S CS85-B2GA331KY†S CS85-B2GA471KY†S CS95-B2GA681KY†S CS10-B2GA102KY†S CS80-E2GA102MY†S CS90-E2GA152MY†S CS11-E2GA222MY†S CS13-E2GA332MY†S CS14-E2GA392MY†S CS15-E2GA472MY†S CS12-F2GA472MY†S CS17-F2GA103MY†S ∗ Capacitance temperature characteristics B(±10%) E(+20, –55%) F(+30, –80%) Dimensions(mm) Capacitance (pF) Capacitance tolerance D max. T max. F d Taping dimensions 100 150 220 330 470 680 1,000 1,000 1,500 2,200 3,300 3,900 4,700 4,700 10,000 K(±10%) K(±10%) K(±10%) K(±10%) K(±10%) K(±10%) K(±10%) M(±20%) M(±20%) M(±20%) M(±20%) M(±20%) M(±20%) M(±20%) M(±20%) 7.0 7.0 7.0 8.5 8.5 9.5 10.0 8.0 9.0 10.5 12.5 13.5 14.5 12.0 16.5 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 0.6±0.05 V2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V2 V3 V2 — 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.0 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 7.5±1.5 10±2 † : Lead shape symbol LIST OF STANDARD LEAD SHAPES The lead type is indicated by the letter which is the 15th character of the product name. Example) TDK Product Name: CS11-E2GA222MYNSA N: Lead type (Vertical kink, Short) Dimensions in mm Short lead Symbol G Symbol N T D D T 4max. 4max. D Taping Symbol V F F d 5±1 25min. 16+1.5 –0.5 Vertical kink T 4max. Long lead d • We recommend using a vertical kink type. • For bulk products, we recommend a short lead type with the symbol N. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 005-03 / 20111003 / e4b3_cs.fm (2/3) HALOGEN-FREE PRODUCT MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. Sub-class of safety performance 6. TDK’s logogram 7. Date code ∗ ∗ Marking examples CS 222(2200pF) M(±20%) (AC.250V) 250V X1Y2 CS222M 250 X1Y2 15 15 (2011.5)∗ (Marking position is reference.) Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). The expression has become simplified due to a revision in the standards. INTERNATIONALLY CERTIFIED STATUS / IEC60384-14 EN60384-14 Approved Safety standard BSI VDE SEV SEMKO NEMKO DEMKO FIMKO IMQ SAA UL Standard No. of IEC IEC 60065 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60065 — Temperature Insulation characteristics sub-class Standard No. BS EN 60065 BS EN60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 EN 60384-14 AS3250 UL 1414 Rated voltage Eac(V) Approval report No. Japan Taiwan Xiamen B, E, F X1, Y2 250 KM37103 KM37103 KM37103 B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F X1, Y2 X1, Y2 X1, Y2 X1, Y2 X1, Y2 X1, Y2 X1, Y2 — (X, Y) 250 250 250 250 250 250 250 400 250 40029781 10.0120 912461 P09211677 315269-01 FI 25553 V3692 CS6268 E37861 2278972 (LR 35801) CQC10001051610 40029781 10.0120 912461 P09211677 315269-01 FI 25553 V3692 CS6268 E37861 2278972 (LR 35801) CQC10001051637 40029781 10.0120 912461 P09211677 315269-01 FI 25553 V3692 CS6268 E37861 2278972 (LR 35801) CQC03001004815 CSA IEC 60384-14 CAN/CSA-E60384-14 B, E, F (X, Y) 250 CQC IEC 60384-14 GB-T 14472-1998 B, E, F X1, Y2 250 • Certificate numbers shall be changed owing to the revisions of the related standards. CURRENT PRODUCT MARKINGS Item 1. Series 2. Nominal capacitance 3. Capacitance tolerance 4. Rated voltage Eac 5. Withstand voltage Eac 6. Sub-class of safety performance 7. TDK’s logogram 8. Date code 9. Regulatory body safety standards compliance markings BSI (U.K.) ∗ BSI SEV (Switzerland) SEMKO (Sweden) UL (U.S.A.) VDE (Germany) CSA (Canada) TJ508 Marking examples CS 222(2200pF) M(±20%) (AC.250V) 250V X1Y2 Back Front CS222M BSI 250V X1Y2 TJ508 15 15 (2011.5)∗ (Marking position of the monogram is reference.) FIMKO (Finland) NEMKO (Norway) DEMKO (Denmark) IMQ (Italy) Year and month of production: last digit of year + month denoted by 1, 2, 3, 4, 5, 6, 7, 8, 9, O (October), N (November), or D (December). INTERNATIONALLY CERTIFIED STATUS / IEC60384-14 EN60384-14 Approved Safety standard BSI VDE SEV SEMKO NEMKO DEMKO FIMKO IMQ SAA UL CSA Standard No. of IEC IEC 60065 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60384-14 IEC 60065 — — Standard No. BS EN 60065 BS EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 EN60384-14 AS3250 UL 1414 CSA C22.2 No.0 & No.1 Temperature characteristics Insulation sub-class Rated voltage Eac(V) Approval report No. Japan Taiwan Xiamen B, E, F X1, Y2 250 226494 226494 226494 B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F B, E, F X1, Y2 X1, Y2 X1, Y2 X1, Y2 X1, Y2 X1, Y2 X1, Y2 — (X, Y) (X, Y) 250 250 250 250 250 250 250 400 250 250 138559 09.0962 915556 P09211507 315179-01 FI 25453 V3692 6268 E37861 LR35801 138560 09.0962 915556 P09211507 315179-01 FI 25453 V3692 6268 E37861 LR65972 122006 09.0962 915394 P08209309 314664-02 FI 24306A1 V3692 6268 E37861 LR65972 • Certificate numbers shall be changed owing to the revisions of the related standards. • All specifications are subject to change without notice. 005-03 / 20111003 / e4b3_cs.fm (3/3) TAPING DIMEMSIONS VERTICAL KINK LEAD TYPE D P T P2 D ∆h T P2 ∆h H0 S W0 W L W1 L W0 W P0 D0 ød P1 F D0 ød t t P0 C H0 H1 S H0 W2 C A H0 H1 W1 P1 F ∆h A ∆h W2 P V3 V1, V2 Item Symbol Dimensions(mm) V1 V2 V3 Remarks Body diameter D Depends on the specification of each product. Body thickness T Depends on the specification of each product. Lead-wire diameter ød 0.6±0.05 0.6±0.05 0.6±0.05 Pitch of component P 12.7±1.0 15.0±1.0 30.0±1.0 Including the slant of body Feed hole pitch P0 12.7±0.3 15.0±0.3 15.0±0.3 Excepting the tape splicing part Feed hole center to lead P1 3.85±0.7 3.75±0.7 3.75±0.7 Feed hole center to component center P2 6.35±1.3 7.5±1.3 7.5±1.3 Lead-to lead distance F 5+0.8, –0.2 7.5±0.8 7.5±0.8 Measuring point is bottom kink Component alignment ∆h 0±2.0 0±2.0 0±2.0 Including the slanting body due to bending lead-wire Tape width W 18.0+1.0, –0.5 18.0+1.0, –0.5 18.0+1.0, –0.5 Adhesive tape width W0 11.5min. 11.5min. 11.5min. Hole position W1 9.0±0.5 9.0±0.5 9.0±0.5 Adhesive tape position W2 3.0max. 3.0max. 3.0max. Bottom of kink from tape center H0 16.0+1.5, –0.5 16.0+1.5, –0.5 16.0+1.5, –0.5 Height of body from tape center H1 46.0max. 46.0max. 46.0max. 1.0max. 1.0max. 1.0max. Lead-wire protrusion Feed hole diameter D0 4.0±0.2 4.0±0.2 4.0±0.2 Total tape thickness t 0.6±0.3 0.6±0.3 0.6±0.3 Length of snipped lead L 11.0max. 11.0max. 11.0max. Coating on lead C 4.0max. 4.0max. 4.0max. Height of kink A 4.0max. 4.0max. 4.0max. Spring action S 2.0max. 2.0max. 2.0max. Adhesive tape do not stick out the tape Do not including adhesive tape Measuring point is bottom kink • For more information about products with other capacitance or other data, please contact us. • All specifications are subject to change without notice. 005-03 / 20111003 / e4b3_cs.fm
CS70-B2GA101KYNS 价格&库存
很抱歉,暂时无法提供与“CS70-B2GA101KYNS”相匹配的价格&库存,您可以联系我们找货
