CSS500-12
CSS500-12
    TDK(东电化)
    CSS500-12 - 500W AC-DC Medical or Industrial Power Supplies - TDK Electronics
CSS500-12 数据手册
CSS500 Series 500W AC-DC Medical or Industrial Power Supplies 360W Convection rating High Efficiency IEC60601-1 or IEC60950-1 certifications ORing FET & Current Share Key Market Segments & Applications Medical Test and Measurement Features and Benefits Feature High Efficiency Current Share and ORing FET Dual input fuses Benefit Uses less energy Use in redundant applications Easier system compliance Specifications CSS500 ITEMS Input Voltage range Inrush Current Input Current (115/230VAC) Power Factor Correction Leakage Current Hold Up Time (Typ) Temperature Coefficient Voltage Accuracy Adjustment Range Total Regulation Ripple & Noise Overcurrent Protection Overvoltage Protection Overtemperature Protection Remote On/Off Efficiency Standby Voltage Fan Output Current Share DC Good & Fan Fail Signals ORing FET Operating Temperature Storage Temperature Humidity (non condensing) Cooling Withstand Voltage (1) Isolation Resistance Vibration (non operating) Shock Safety Agency Approvals Conducted & Radiated EMI Immunity MTBF Weight (Typ) Size (WxLxH) Warranty Note (1) Industrial version (I suffix): 3kVAC A A µA ms % % % V % °C °C % g in yr 90 - 264VAC (47 - 63Hz) 0.9 68,695 (MIL-217F-HDBK) 340g (U channel) U Channel: 8 x 4.7 x 1.51", End Fan (/S) 9 x 4.7 x 1.63", Top Fan (/T) 8 x 4.7 x 2.85" Two Years 29 3055 Del Sol Blvd • San Diego, CA 92154 • 1-800-526-2324 CSS500 Series Model Selector Model CSS500-12 CSS500-24 CSS500-30 CSS500-36 CSS500-48 CSS500-54 CSS500-57 Output Voltage (V) 12V 24V 30V 36V 48V 54V 57V Maximum Curr. Conv. (A) 30A 15A 12A 10A 7.5A 6.67A 6.32A Maximum Power Conv. (W) 360W 360W 360W 360W 360W 360W 360W Maximum Curr. Forced Air 41.67A 20.84A 16.67A 13.89A 10.42A 9.26A 8.78A Maximum Pwr Forced Air 500W 500W 500W 500W 500W 500W 500W Options Suffix Blank /S /T I /SI /TI U channel Yes Yes - Mechanical End Fan Yes Yes - Top Fan Yes Yes Safety Certifications Medical Industrial Yes Yes Yes Yes Yes Yes Outline Drawings CN5 P2.54-2*3P Molex P/N:90122-0123 OR Equivalent CN4 FAN FULL SPEED 50.85 CN1 118.5 38.5 12.7 12.7 19.0 19.0 12V FAN + N.C 12V FAN - V+ V+ V+ V- V- V- FAN + PIN1 -Sensor PIN5 8.9 8.4 8.9 CN3 FAN2 CN4 PIN1 PIN2 PIN1 CN2 PIN2 185.4 185.4 203.2 Current Share CN2 P2.5-2P Molex P/N:48152-0210 OR Equivalent 4-M3P0.5 Q2 PIN1 PIN2 PIN3 PIN4 2-M3P0.5 Recommended direction for force airflow Other Medical AC-DC Products KM CSS65, 150 NV175 NV300 30 15 - 40W pcb mount medical 40 - 150W open frame 175 - 200W 1-4 outputs 300W 1-4 outputs For Additional Information, please visit us.tdk-lambda.com/lp/products/css-series.htm 3055 Del Sol Blvd • San Diego, CA 92154 • 1-800-526-2324 Revision A3: Apr 2011 CN3 P2.5-6P (OPTION) Molex P/N:48152-0610 OR Equivalent 8.9 8.9 CN1 8.9 ACN ACL 93.1 12.7 12.7 19.0 FC 12.0 PIN6 +Sensor Inhibit 5Vsb GND FAN2 P2.5-2P (With speed control) Molex P/N:48152-0210 OR Equivalent Q7 FAN1 P2.5-2P Molex P/N:48153-0210 OR Equivalent T2 Q6 PIN2 FAN - 5Vsb GND POWER GOOD GND 26.75 8.25 8.25 1 FAN FAULT CN5 FAN1 GND
CSS500-12 价格&库存
很抱歉,暂时无法提供与“CSS500-12”相匹配的价格&库存,您可以联系我们找货
