CU4S0506AT-2593-00
CU4S0506AT-2593-00
    TDK(东电化)
    SMD,5x5mm
    RF隔离器
CU4S0506AT-2593-00 数据手册
R F C o m p o n e n t s March 2020 Isolator SMD CU4S0506 Series 5x5mm* * Dimensions Code JIS RF Components Product compatible with RoHS directive Isolator SMD Overview of CU4S0506 Series PART NUMBER CONSTRUCTION CU4S0506 □ Series name Direction A B CW CCW T - ○○○○ Center Frequency (MHz) △△ Control Number cut off after the decimal point DIRECTION OF CIRCULATION ClockWise(CW): A CounterClockWise(CCW): B Marking OUT - Marking IN IN OUT TEMPERATURE RANGE Operating temperature (°C) –40 to +105 Storage temperature (°C) –40 to +105 RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm RF Components CU4S0506 Series (Under 1GHz) SHAPES AND DIMENSIONS 2.0±0.2 (3) (4) (2) (5) (1) (6) 5.0±0.3 5.0±0.3 [Top view] Terminal (Au plating) Metal parts other than a terminal. (GND electric potential) Tolerance unless otherwise specified: ±0.2 Coplanarity : 0.1max. [Bottom view] 5.2±0.3 3.0 IN GROUND GROUND GROUND GROUND OUT Counter Clockwise 0.5 1.9 0.5 1.9 0.5 Terminal functions 1 OUT 2 GROUND 3 GROUND 4 GROUND 5 GROUND 6 IN Rotation Clockwise Dimensions in mm 0.4 [Marking] 0.4 ClockWise(CW): A CounterClockWise(CCW): B (3) (4) (3) (4) (2) (5) (2) (5) (1) (6) (1) (6) Marking RECOMMENDED LAND PATTERN Marking RECOMMENDED PC BOARD PATTERN Isolator Outline GND 0.7 1.9 1.9 0.7 1.9 0.75min. 0.7 4.2 0.8 Dimensions in mm I/O 0.75min. 4.2 (0.7) 0.8 Connect to 50Ω Stripline With I/O land. (0.8) I/O 1min. Dimensions in mm • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm RF Components CU4S0506 Series (Under 1GHz) ELECTRICAL CHARACTERISTICS Frequency range Center frequency Isolation Insertion loss V.S.W.R. Zo=50 Handling power Reflection power (MHz) (MHz) (dB) min. 9 9 11 12 11 11 (dB) max. 1.30 1.30 1.00 0.85 0.95 0.95 max. 1.8 1.8 1.8 1.7 1.8 1.8 (W) max. 5 5 5 5 5 5 (W) 4 max. 2 2 2 2 2 2 703 to 748 758 to 803 859 to 894 869 to 894 880 to 915 925 to 960 725.5 780.5 876.5 881.5 897.5 942.5 Part Number ClockWise CU4S0506AT-725-00 CU4S0506AT-780-00 CU4S0506AT-876-00 CU4S0506AT-881-00 CU4S0506AT-897-00 CU4S0506AT-942-00 CounterClockWise CU4S0506BT-725-00 CU4S0506BT-780-00 CU4S0506BT-876-00 CU4S0506BT-881-00 CU4S0506BT-897-00 CU4S0506BT-942-00 Characteristic Impedance () : 50(Nominal) 4 To be kept below +105deg.C at the bottom surface • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm RF Components CU4S0506 Series (Over 1GHz) SHAPES AND DIMENSIONS 2.0±0.2 (3) (4) (2) (5) (1) (6) 5.0±0.3 5.0±0.3 [Top view] Terminal (Au plating) Metal parts other than a terminal. (GND electric potential) [Bottom view] Tolerance unless otherwise specified: ±0.2 Coplanarity : 0.1max. 5.2±0.3 3.0 IN GROUND GROUND GROUND GROUND OUT Counter Clockwise 0.8 1.6 0.8 1.6 0.8 Terminal functions 1 OUT 2 GROUND 3 GROUND 4 GROUND 5 GROUND 6 IN Rotation Clockwise Dimensions in mm 0.4 [Marking] 0.4 ClockWise(CW): A CounterClockWise(CCW): B (3) (4) (3) (4) (2) (5) (2) (5) (1) (6) (1) (6) Marking Marking RECOMMENDED LAND PATTERN RECOMMENDED PC BOARD PATTERN GND Isolator Outline 4.2 1.1 Dimensions in mm I/O 0.6min. 1.1 Connect to 50Ω Stripline With I/O land. (1.0) 1.0 1.6 1.6 1.0 0.6min. 1.6 1.0 4.2 I/O (1.1) 1min. Dimensions in mm • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm RF Components CU4S0506 Series (Over 1GHz) ELECTRICAL CHARACTERISTICS Frequency range Center frequency Isolation Insertion loss V.S.W.R. Zo=50 Handling power Reflection power (MHz) (MHz) (dB) min. 14 12 15 14 14 12 15 15 (dB) max. 0.70 1.00 0.70 0.80 0.80 0.90 0.70 0.75 max. 1.5 1.7 1.5 1.5 1.5 1.7 1.5 1.6 (W) max. 5 5 5 5 5 5 5 5 (W) 4 max. 2 2 2 2 2 2 2 2 1805 1880 1930 2110 2300 2496 2570 2620 to 1880 to 2025 to 1995 to 2200 to 2400 to 2690 to 2620 to 2690 1842.5 1952.5 1962.5 2155 2350 2593 2595 2655 Part Number ClockWise CU4S0506AT-1842-00 CU4S0506AT-1952-00 CU4S0506AT-1962-00 CU4S0506AT-2155-00 CU4S0506AT-2350-00 CU4S0506AT-2593-00 CU4S0506AT-2595-00 CU4S0506AT-2655-00 CounterClockWise CU4S0506BT-1842-00 CU4S0506BT-1952-00 CU4S0506BT-1962-00 CU4S0506BT-2155-00 CU4S0506BT-2350-00 CU4S0506BT-2593-00 CU4S0506BT-2595-00 CU4S0506BT-2655-00 Characteristic Impedance () : 50(Nominal) 4 To be kept below +105deg.C at the bottom surface • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm RF Components CU4S0506 Series PACKAGING STYLE REEL DIMENSIONS 330 Dimensions in mm TAPE DIMENSIONS Reel side Pulling side P2 P0 K0 P1 T A0 GND GND I/O A0 5.6±0.1 GND GND I/O B0 5.6±0.1 D0 1.5+0.1/–0 B0 W F E D0 Dimensions in mm E 1.75±0.1 F 7.5±0.1 P0 4.0±0.1 P1 12.0±0.1 P2 2.0±0.1 W 16.0+0.3/–0.1 K0 2.6±0.1 T 0.3±0.05 PACKAGE QUANTITY Standard package quantity (pieces/reel) 1000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm RF Components CU4S0506 Series RECOMMENDED REFLOW PROFILE Soaking Working Soldering Peak T: Temperature T4 T5 T3 T2 T4 T3 t3 T1 t1 t2 t: Time Soaking Temp. T1 150°C T2 180°C Time t1 60 to 120s Working Temp. T3 230°C Time t2 30 to 60s Soldering Peak Temp. Time T4 t3 250°C within 10s Temp. T5 260°C max. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS Please do not bring the magnet close to the product (Recommending is separating to 50cm or more). An electric characteristic might be deteriorated. The magnetic field of 5mT or more must not go into the product when you make the magnet approach. Moreover, please do not touch a soft magnetic material such as iron (Recommending is separating to 10mm or more). An electric characteristic might be deteriorated. An electric characteristic changes when bringing it close within 10mm(reversible change). There is a leakage of some magnetism (0.3T or less) from the product. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20200316 / rf_isolator_cu4s0506_en.fm
CU4S0506AT-2593-00 价格&库存
很抱歉,暂时无法提供与“CU4S0506AT-2593-00”相匹配的价格&库存,您可以联系我们找货
CU4S0506AT-2593-00
    • 1+16.79400
    • 10+15.94080
    • 30+15.43320
    • 100+14.14800
    • 500+13.91040
    库存:882
