CU4S0506BT-785-XN
CU4S0506BT-785-XN
    TDK(东电化)
CU4S0506BT-785-XN 数据手册
R F C o m p o n e n t s January 2024 Isolator SMD CU4S0506 Series 5x5mm* * Dimensions Code JIS Caution ࡘٛ൰಼௽፩ܿٛ൰ਖ࿮ٛডᇲ࿮ٛ 停产发布日期 Dec.22, 2023 最后订单日期 Sep.30, 2024 最后出货日期 Dec.31, 2024 关于替换产品信息,请参考本公司 Web 网站。 RF Components Product compatible with RoHS directive Isolator SMD 品 Overview of CU4S0506 Series PART NUMBER CONSTRUCTION □ Series name Direction ○○○○ - Center Frequency (MHz) CW CCW cut off after the decimal point DIRECTION OF CIRCULATION ClockWise(CW): A 已 Marking IN OUT 或 IN TEMPERATURE RANGE 产 Storage temperature (°C) –40 to +85 包 含 将 停 Operating temperature (°C) –35 to +85 Control Number CounterClockWise(CCW): B Marking OUT △△ - 停 产 A B T 产 CU4S0506 RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm RF Components CU4S0506 Series (Under 1GHz) SHAPES AND DIMENSIONS 2.0±0.2 (2) (5) (1) (6) 产 (4) 5.0±0.3 (3) 品 5.0±0.3 [Top view] 停 产 Terminal (Au plating) Metal parts other than a terminal. (GND electric potential) Tolerance unless otherwise specified: ±0.2 Coplanarity : 0.1max. [Bottom view] 5.2±0.3 3.0 IN GROUND GROUND GROUND GROUND OUT Counter Clockwise 或 0.5 1.9 0.5 已 1.9 0.5 Terminal functions 1 OUT 2 GROUND 3 GROUND 4 GROUND 5 GROUND 6 IN Rotation Clockwise Dimensions in mm 0.4 CounterClockWise(CCW): B (4) (2) (5) 将 停 (3) (1) (3) (4) (2) (5) (1) (6) 产 ClockWise(CW): A (6) Marking 4.2 Isolator Outline GND 1.9 0.7 0.75min. 0.7 4.2 0.8 Dimensions in mm Connect to 50Ω Stripline With I/O land. I/O 0.75min. 0.8 RECOMMENDED PC BOARD PATTERN 0.7 含 包 1.9 1.9 RECOMMENDED LAND PATTERN Marking (0.7) [Marking] 0.4 (0.8) I/O 1min. Dimensions in mm • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm RF Components CU4S0506 Series (Under 1GHz) ELECTRICAL CHARACTERISTICS Insertion loss V.S.W.R. Zo=50 Handling power Reflection power (MHz) (MHz) (dB) min. 13 14 14 12 13 14 15 15 15 12 15 12 14 14 13 12 13 14 13 14 14 13 14 14 14 (dB) max. 0.90 0.90 0.90 0.90 0.80 0.80 0.80 0.80 0.80 0.90 0.80 0.85 0.75 0.75 0.80 0.90 0.80 0.75 0.80 0.75 0.75 0.75 0.75 0.70 0.70 max. 1.6 1.6 1.6 1.7 1.6 1.5 1.5 1.5 1.5 1.7 1.5 1.7 1.6 1.6 1.6 1.7 1.6 1.6 1.6 1.6 1.6 1.6 1.6 1.5 1.5 (W) max. 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 (W) 4 max. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 ClockWise CU4S0506AT-707-00 CU4S0506AT-710-00 CU4S0506AT-722-00 CU4S0506AT-733-00 CU4S0506AT-737-00 CU4S0506AT-740-00 CU4S0506AT-751-00 CU4S0506AT-763-00 CU4S0506AT-782-00 CU4S0506AT-788-00 CU4S0506AT-793-00 CU4S0506AT-806-00 CU4S0506AT-815-00 CU4S0506AT-822-00 CU4S0506AT-830-00 CU4S0506AT-831-00 CU4S0506AT-836-00 CU4S0506AT-837-00 CU4S0506AT-847-00 CU4S0506AT-860-00 CU4S0506AT-867-00 CU4S0506AT-875-00 CU4S0506AT-882-00 CU4S0506AT-907-00 CU4S0506AT-952-00 CounterClockWise CU4S0506BT-707-00 CU4S0506BT-710-00 CU4S0506BT-722-00 CU4S0506BT-733-00 CU4S0506BT-737-00 CU4S0506BT-740-00 CU4S0506BT-751-00 CU4S0506BT-763-00 CU4S0506BT-782-00 CU4S0506BT-788-00 CU4S0506BT-793-00 CU4S0506BT-806-00 CU4S0506BT-815-00 CU4S0506BT-822-00 CU4S0506BT-830-00 CU4S0506BT-831-00 CU4S0506BT-836-00 CU4S0506BT-837-00 CU4S0506BT-847-00 CU4S0506BT-860-00 CU4S0506BT-867-00 CU4S0506BT-875-00 CU4S0506BT-882-00 CU4S0506BT-907-00 CU4S0506BT-952-00 包 含 将 停 产 Characteristic Impedance () : 50(Nominal) 4 To be kept below +85deg.C at the bottom surface 已 707.5 710 722 733 737.5 740 751 763 782 788 793 806 815.5 822.5 830 831.5 836.5 837.5 847 860.5 867.5 875 882.5 907.5 952.5 或 699 to 716 704 to 716 716 to 728 718 to 748 729 to 746 734 to 746 746 to 756 758 to 768 777 to 787 773 to 803 788 to 798 791 to 821 807 to 824 815 to 830 815 to 845 814 to 849 824 to 849 830 to 845 832 to 862 852 to 869 860 to 875 860 to 890 875 to 890 900 to 915 945 to 960 Part Number 品 Isolation 产 Center frequency 停 产 Frequency range • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm RF Components CU4S0506 Series (Over 1GHz) SHAPES AND DIMENSIONS 2.0±0.2 (2) (5) (1) (6) 产 (4) 5.0±0.3 (3) 品 5.0±0.3 [Top view] [Bottom view] 停 产 Terminal (Au plating) Metal parts other than a terminal. (GND electric potential) Tolerance unless otherwise specified: ±0.2 Coplanarity : 0.1max. 5.2±0.3 3.0 IN GROUND GROUND GROUND GROUND OUT Counter Clockwise 或 0.8 1.6 0.8 已 1.6 0.8 Terminal functions 1 OUT 2 GROUND 3 GROUND 4 GROUND 5 GROUND 6 IN Rotation Clockwise Dimensions in mm 0.4 CounterClockWise(CCW): B (3) (4) (2) (5) (4) (2) (5) (6) (1) (6) Marking Marking 含 GND 0.6min. 1.0 1.6 1.0 1.0 4.2 Isolator Outline 1.1 Dimensions in mm Connect to 50Ω Stripline With I/O land. I/O 0.6min. 1.1 RECOMMENDED PC BOARD PATTERN 4.2 包 1.6 1.6 RECOMMENDED LAND PATTERN (1.0) (1) (3) 产 ClockWise(CW): A 将 停 [Marking] 0.4 I/O (1.1) 1min. Dimensions in mm • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm RF Components CU4S0506 Series (Over 1GHz) ELECTRICAL CHARACTERISTICS Insertion loss V.S.W.R. Zo=50 Handling power Reflection power (MHz) (MHz) (dB) min. 15 15 15 15 13 15 15 15 14 15 15 15 15 15 15 15 15 10 10 (dB) max. 0.60 0.60 0.60 0.60 0.80 0.60 0.60 0.60 0.70 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 1.00 1.00 max. 1.5 1.5 1.5 1.5 1.6 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.6 1.8 1.8 (W) max. 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 (W) 4 max. 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 1 1 1445.4 1493.4 1542 1643.5 1747.5 1767.4 1862.4 1880 1882.5 1900 1950 1960 2017.5 2140 2310 2355 2535 3500 3540 ClockWise CU4S0506AT-1445-00 CU4S0506AT-1493-00 CU4S0506AT-1542-00 CU4S0506AT-1643-00 CU4S0506AT-1747-00 CU4S0506AT-1767-00 CU4S0506AT-1862-00 CU4S0506AT-1880-00 CU4S0506AT-1882-00 CU4S0506AT-1900-00 CU4S0506AT-1950-00 CU4S0506AT-1960-00 CU4S0506AT-2017-00 CU4S0506AT-2140-00 CU4S0506AT-2310-00 CU4S0506AT-2355-00 CU4S0506AT-2535-00 CU4S0506AT-3500-00 CU4S0506AT-3540-00 CounterClockWise CU4S0506BT-1445-00 CU4S0506BT-1493-00 CU4S0506BT-1542-00 CU4S0506BT-1643-00 CU4S0506BT-1747-00 CU4S0506BT-1767-00 CU4S0506BT-1862-00 CU4S0506BT-1880-00 CU4S0506BT-1882-00 CU4S0506BT-1900-00 CU4S0506BT-1950-00 CU4S0506BT-1960-00 CU4S0506BT-2017-00 CU4S0506BT-2140-00 CU4S0506BT-2310-00 CU4S0506BT-2355-00 CU4S0506BT-2535-00 CU4S0506BT-3500-00 CU4S0506BT-3540-00 已 1427.9 to 1462.9 1475.9 to 1510.9 1525 to 1559 1626.5 to 1660.5 1710 to 1785 1749.9 to 1784.9 1844.9 to 1879.9 1850 to 1910 1850 to 1915 1880 to 1920 1920 to 1980 1930 to 1990 2010 to 2025 2110 to 2170 2305 to 2315 2350 to 2360 2500 to 2570 3400 to 3600 3480 to 3600 Part Number 品 Isolation 产 Center frequency 停 产 Frequency range 包 含 将 停 产 或 Characteristic Impedance () : 50(Nominal) 4 To be kept below +85deg.C at the bottom surface • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm RF Components CU4S0506 Series PACKAGING STYLE 330 停 产 产 品 REEL DIMENSIONS Dimensions in mm TAPE DIMENSIONS Reel side Pulling side P2 P0 K0 P1 或 T B0 5.6±0.1 D0 1.5+0.1/–0 E 1.75±0.1 F 7.5±0.1 P0 4.0±0.1 Dimensions in mm P1 12.0±0.1 P2 2.0±0.1 W 16.0+0.3/–0.1 K0 2.6±0.1 T 0.3±0.05 将 停 A0 5.6±0.1 GND GND I/O 产 A0 GND GND I/O B0 W F 已 E D0 PACKAGE QUANTITY Standard package quantity 包 含 (pieces/reel) 1000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm RF Components CU4S0506 Series RECOMMENDED REFLOW PROFILE T: Temperature T4 T5 T4 T3 T3 T2 t3 t1 停 产 T1 t2 Working Temp. T3 230°C Time t2 30 to 60s Soldering Peak Temp. Time T4 t3 250°C within 10s Temp. T5 260°C max. 包 含 将 停 产 或 T2 180°C Time t1 60 to 120s 已 t: Time Soaking Temp. T1 150°C 品 Working Soldering Peak 产 Soaking • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm RF Components 使用注意事项 在使用本产品前,请务必随附采购规格书。 安全注意事项 品 使用本产品时,请注意安全事项。 产 注 意 停 产 建议磁铁与制品保持50cm以上距离,有可能影响制品静特性;若磁铁必须靠近制品时,禁止在制品上加5mT以上磁力。 建议磁性材料与制品保持10mm以上距离,有可能影响制品静特性 (若在10mm以内静特性会产生可逆变化)。 制品本身会产生0.3T以下的漏磁现象。 本产品目录中记载的产品是指在通用标准用途意义上使用于一般电子设备 (AV 设备,通信设备,家电产品,娱乐设备,计算机设备,个 人设备,办公设备,计测设备,工业机器人),并且该一般电子设备要在通常的操作和使用方法下使用。 对于需要高度安全性和可靠性的,或者设备的故障,误动作,运转不良可能会给人的生命,身体及财产等造成损害,以及有可能产生莫大 社会影响的以下用途 (以下称 ‘ 特定用途 ’)中的适用性,性能发挥,品质,本公司不予保证。 产品被在本产品目录的范围、条件之外,或者在特定用途中使用时,本公司对它造成的损害和信赖性不承担任何责任。 (8) 公共信息处理设备 (9) 军事设备 (10) 电加热设备、燃烧设备 (11) 防灾 / 预防犯罪设备 (12) 安全设备 (13) 其他不被视为常规用途的用途 已 或 (1) 航天航空设备 (2) 交通运输设备 (汽车,电动火车,船舶等) (3) 医疗设备 (4) 发电控制设备 (5) 原子能源相关设备 (6) 海底设备 (7) 交通控制设备 包 含 将 停 产 为了能够更安全地使用产品,对使用本产品目录中所记载产品的设备进行设计时,请确保符合该设备的使用用途及状态的保护回路和装 置,并设置备用回路等。 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20240115 / withdraw_rf_isolator_cu4s0506_zh.fm
CU4S0506BT-785-XN 价格&库存
很抱歉,暂时无法提供与“CU4S0506BT-785-XN”相匹配的价格&库存,您可以联系我们找货
CU4S0506BT-785-XN
    • 1+15.91920
    • 10+15.08760
    • 30+14.59080
    • 100+14.08320
    • 500+13.85640
    库存:515
