CU4S0508AC-3500-00
CU4S0508AC-3500-00
    TDK(东电化)
    SMD6
    CU4S0508AC-3500-00
CU4S0508AC-3500-00 数据手册
RF Components Circulator SMD Pb RoHS Lead Free CU4S0508 Series PART NUMBER CONSTRUCTION CU4S0508 □ Series name Direction A B C - - ○○○○ Center Frequency (MHz) CW CCW △△ Control Number cut off after the decimal point DIRECTION OF CIRCULATION ClockWise(CW): A CounterClockWise(CCW): B 50Ω Load 50Ω Load OUT IN IN OUT ELECTRICAL CHARACTERISTICS Frequency range Center frequency Isolation Insertion loss V.S.W.R. Zo=50 Handling power (MHz) (MHz) (dB) min. 10 10 9 10 (dB) max. 1.20 1.20 1.30 1.20 max. 2.0 2.0 2.0 2.0 (W) max. 5 5 5 5 3300 to 3600 3400 to 3600 3400 to 3800 3500 to 3800 3450 3500 3600 3650 Part Number ClockWise CU4S0508AC-3450-00 CU4S0508AC-3500-00 CU4S0508AC-3600-00 CU4S0508AC-3650-00 CounterClockWise CU4S0508BC-3450-00 CU4S0508BC-3500-00 CU4S0508BC-3600-00 CU4S0508BC-3650-00 Characteristic Impedance () : 50(Nominal) TEMPERATURE RANGE Operating temperature (°C) –40 to +105 Storage temperature (°C) –40 to +105 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20200416 rf_circulator_cu4s0508_en.fm RF Components CU4S0508 Series RECOMMENDED REFLOW PROFILE SHAPES AND DIMENSIONS 5.0±0.3 [Top view] 2.5±0.2 Soaking (2) (5) (1) (6) 260°C max. 250°C 250°C Terminal (Au plating) Metal parts other than a terminal. (GND electric potential) T: Temperature (4) 5.0±0.3 (3) Working Soldering Peak 230°C 230°C 180°C within 10s 150°C Tolerance unless otherwise specified: ±0.2 Coplanarity : 0.1max. 60 to 120s 5.2±0.3 [Bottom view] 30 to 60s 3.0 0.8 1.6 0.8 1.6 0.8 Terminal functions 1 OUT 2 GROUND 3 50Ω Load 4 GROUND 5 GROUND 6 IN Rotation Clockwise IN GROUND 50Ω Load GROUND GROUND OUT Counter Clockwise t: Time PACKAGING STYLE REEL DIMENSIONS Dimensions in mm 0.4 0.4 [Marking] ClockWise(CW): A CounterClockWise(CCW): B (3) (4) (3) (4) (2) (5) (2) (5) (1) (6) (1) (6) Marking Marking 330 Dimensions in mm RECOMMENDED LAND PATTERN Pulling side 1.1 4.2 1.1 Dimensions in mm RECOMMENDED PC BOARD PATTERN GND 5.6±0.1 50Ω Load GND I/O Circulator Outline GND GND I/O 3.2±0.1 5.6±0.1 12.0±0.1 1.0 1.6 1.5+0.1/–0 2.0±0.1 4.0±0.1 7.5±0.1 1.75±0.1 1.0 1.6 Reel side 16.0+0.3/–0.1 1.0 TAPE DIMENSIONS 0.3±0.05 Dimensions in mm 4.2 Standard package quantity 1.6 0.6min. PACKAGE QUANTITY I/O 1000 pieces/reel I/O 0.6min. (1.0) Connect to 50Ω Stripline With I/O land. I/O (1.1) 1min. Dimensions in mm Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20200416 rf_circulator_cu4s0508_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS Please do not bring the magnet close to the product (Recommending is separating to 50cm or more). An electric characteristic might be deteriorated. The magnetic field of 5mT or more must not go into the product when you make the magnet approach. Moreover, please do not touch a soft magnetic material such as iron (Recommending is separating to 10mm or more). An electric characteristic might be deteriorated. An electric characteristic changes when bringing it close within 10mm(reversible change). There is a leakage of some magnetism (0.3T or less) from the product. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20200416 rf_circulator_cu4s0508_en.fm
CU4S0508AC-3500-00 价格&库存
很抱歉,暂时无法提供与“CU4S0508AC-3500-00”相匹配的价格&库存,您可以联系我们找货
