CXA-0535
CXA-0535
    TDK(东电化)
    INVERTER 12V-INPUT 2000V-OUTPUT
CXA-0535 数据手册
MESSRS : Comparison with the Specifications CUSTOMER'S PRODUCT NAME: TDK PRODUCT NAME: DC/AC INVERTER UNIT CXA-0535 TDK-Lambda Corporation PREPARED BY APPROVED BY AUTHORIZED BY Apr. 28 ,2010 N.Suzuki Apr. 28 ,2010 K.Yamaishi Apr. 28 ,2010 H.Masuoka DWG.No. CTR-3912-X The difference between CXA-0384 and CXA-0535 Compared with CXA-0384 to CXA-0535 , we will expand the operating temperature range , improve the start up characteristic at low temperature and protect circuit. We have changed the fuse rating for lamp impedance at the low temperature . 1. Outline , Connector Outline Input Conector (mm) Output Conector Mounting hole location Mounting hole diameter CXA-0384 CXA-0535 50X150X8.5 S7B-PH-SM4-TB(LF)(SN) SM02B-BHSS-1-TB(LF)(SN) SM02(4.0)B-BHS-1-TB(LF)(SN) ← ← ← --- 2.5 (mm) ← ← 2. Absolute maximum rating Vin (V) Vrmt (V) Vbr (V) Load (KΩ) Operation Temperature range (℃) Strage Temperature range (℃) Humidity range (%RH) CXA-0384 CXA-0535 0~15 0~Vin 0~16 100max 0~70 -30~85 95max ← ← ← ← -30~80 ← ← 3. Electrical characteristics Vin Output current (mArms) 12±1.2 (Dimming max) Output current (mArms) 12±1.2 (Dimming min) Input current (A) 12±1.2 Frequency (KHz) 12±1.2 (Dimming max) Frequency (Hz) 12±1.2 (Dimming min) Open circuit voltage (Vrms) 10.8 Alarm output Protect circuit (V) Vrmt Vbr(V) Load CXA-0384 CXA-0535 5 0/0 TYP 6.5typ ← 5 2.5/50 TYP 2.0typ ← 5 0/0 TYP 0.9typ ← 5 0/0 TYP 50typ ← 5 2.5/50 TYP 270typ 150typ 5 0/0 0~2.5 /0~50 0~2.5 /0~50 ∞ 1500min 1700min ∞ 5.0typ ← 12±1.2 5 12±1.2 5 - Shutdown at all Shutdown at road open one road open ※CXA-0384:0~70℃、CXA-0535:-30~80℃ No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-0535 TDK-Lambda NAME OF DRAWING DRAWING No. PAGE Comparison with the Specifications CTR-3912-X 1
CXA-0535 价格&库存
很抱歉,暂时无法提供与“CXA-0535”相匹配的价格&库存,您可以联系我们找货
