CXA-0547
CXA-0547
    TDK(东电化)
    INVERTER 12V-INPUT 2100V-OUTPUT
CXA-0547 数据手册
MESSRS : Specification Comparison CUSTOMER'S PRODUCT NAME: TDK PRODUCT NAME: DC/AC INVERTER UNIT CXA-0547 TENTATIVE TDK-Lambda Corporation PREPARED BY APPROVED BY AUTHORIZED BY April 27th, 2010 April 27th, 2010 April 27th, 2010 K.Imai K.Yamaishi H.Masuoka DWG.No. CTR-3911-X The difference between CXA-0349 and CXA-0547. *Product summary CXA-0547 expands operating temperature range to -20ºC~70ºC compared with CXA-0349. At the same time, all components is mounted by machine. So human error reduces and reliability is improved. Input fuse rating is changed because the lamp impedance at low temperature is high. This product is expected stable supply to the customer by replacement of terminated components. TE NT AT IVE 1.Appearance, dimension and pin configuration 1-1.Appearance The appearance of CXA-0547 is changed as follows because several component is changed from CXA-0349. ∴CXA-0349 ∴CXA-0547 The CXA-0349 has several hand mount components indicated in All of components are mounted by machine in CXA-0547. . 1-2.Dimension and Pin configuration Dimension, Pin configuration, Mounting hole and Input Output connector are not changed. P/N CXA-0349 CXA-0547 X dimension Y dimension Z dimension diameter of mounting hole pitch of mounting hole 180.0±0.5 37.0±0.5 12max 3.0±0.2 X: 80±0.3,93±0.3 Y: 28±0.3      Unit in m m P/N CXA-0349 CXA-0547 Input Connector S7B-PH-SM4-TB(LF)(SN)  No. Output Connector SM02B-BHSS-1-TB(LF)(SN)  MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-0547 TDK-Lambda NAME OF DRAWING DRAWING No. PAGE Specification Comparison CTR-3911-X 1 TSB-08-01-05(00) form-6(A4) 2.Absolute Maximum Ratings CXA-0547 expands operating temprature range to -20ºC~70ºC compared with CXA-0349. Except operating temprature range any specification is not changed. Item Symbol CXA-0349 CXA-0547 Unit Vin 0~14.4  V Vrmt 0~Vin  V Vbr 0~Vin  V  kΩ Input Voltage RL 90 TE NT AT IVE Load Resistance Remark Operational Temperature range Ta -10~70 -20~70 ºC Storage Temperature range Ts -30~85  ºC Operational Humidity range Ha 0~95  %RH. Maximum wet bulb temperature is 38ºC. No dew. 3.Electrical Characterisitics The maximum current specification changes to 2.2A from 2A because input current is increase in low temperature operation. Condition Item Output Current (Maximim Brightness) Symbol Iout Output Current (Minimum Brightness) Input Current1 Iin1 Input Current2 Iin2 Oscillation Frequency F1 PWM Dimming Frequency F2 Open Output Voltage Vopen Warning Output Vst Specification CXA-0349 CXA-0547 Unit Vin (V) Vrmt (V) Rbr(kΩ)/ Vbr(V) Ta (ºC) RL1,2,3,4 (kΩ) MIN. TYP. MAX. MIN. TYP. MAX. 12± 1.2 5± 0.25 0/0 *1 80 6.2 6.9 7.6    12± 0.05 5± 0.25 0/0 23 ±5 80 6.4 6.9 7.4    12± 1.2 5± 0.25 50 / 2.5 *1 80 1.7 2.7 3.7    12± 1.2 5± 0.25 0/0 *1 80 - 1.6 2.0   2.2 A 12± 1.2 0± 0.25 0/0 *1 80 - 0 1    mA 12± 1.2 5± 0.25 0/0 *1 80 40 45 50    kHz 12± 1.2 5± 0.25 50 / 2.5 *1 80 120 140 160    Hz 10.8± 0.05 5± 0.25 0/0 *1 ∞ 1800 2100 2400    Vrms 12± 1.2 5± 0.25 0/0 *1 RL1=∞ RL2,3,4=80 4.5 5.1 5.5    12± 1.2 5± 0.25 0/0 *1 RL2=∞ RL1,3,4=80 4.5 5.1 5.5    12± 1.2 5± 0.25 0/0 *1 RL3=∞ RL1,2,4=80 4.5 5.1 5.5    12± 1.2 5± 0.25 0/0 *1 RL4=∞ RL1,2,3=80 4.5 5.1 5.5    12± 1.2 5± 0.25 0/0 *1 80 - 0.1 0.5    mA rms V *1 The ambient temperature of CXA-0349 is -10~70ºC and CXA-0547 is -20~70ºC. No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-0547 TDK-Lambda NAME OF DRAWING DRAWING No. PAGE Specification Comparison CTR-3911-X 2 TSB-08-01-05(00) form-6(A4)
CXA-0547 价格&库存
很抱歉,暂时无法提供与“CXA-0547”相匹配的价格&库存,您可以联系我们找货
