CXA-L0612A-VJL
CXA-L0612A-VJL
    TDK(东电化)
    Ceramic
    INVERTER 12V-INPUT 1800V-OUTPUT
CXA-L0612A-VJL 数据手册
1 Dimming/Connector Type CXA-L0612A-VJL ■ Features ■ Applications ●1 output ●Applicable panel size*: 3 to 15 inches ●With brightness control function (A current system). ●In the high-voltage generator(a terminal and a pattern), an anti-dust measure by silicone application is taken. (Notice) Applicable panel size becomes a standard. CXA-L0612A-VJL Specifications(Please refer to each specification before use) Electrical Characteristics Item Unit Output Current mArms Input Current A Frequency kHz Open Circuit Voltage Vrms Symbol Iout (Maximum dimmer) Iout (Minimum dimmer) Iin Freq Vopen min 5.4 5.3 Specification typ 6.0 6.0 max 6.6 6.7 Vin(V) 12 2.4 12 2.4 Vrmt(V) 5 5 Condition Vbr(V) 0 0 Ta(℃ ) 23 5 0 to +70 RL(kΩ) 100 90 to 130 Remark (*1) (*1) 1.3 1.6 1.9 12 2.4 5 4 23 5 520 (*1) 48 1500 0.40 58 1800 0.65 68 - 12 12 2.4 9.6min. 5 5 5 0 0 0 to 3 0 to +70 0 to +70 0 to +70 90 to 130 90 to 130 ∞ Open load (*1) Please refer to the connection diagram for details of a dimming method. Other Specifications Dimming Function Operating Temperature Storage Temperature Operating Humidity Ratio Safety Standard Weight Dimensions(WxDxH) Fused Input Remote ON / OFF Alarm Signal Function Shutdown Function ℃ ℃ RH% g mm Yes 0 to +70 -30 to +85 95Max ー 14 95.5x20x8 (*2) Yes Yes No No Silicone Coating on High Voltage Area ■ Conformity to RoHs Directive This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. Yes (*2) These dimensions are indicated the maximum. ・All specifications are subject to change without notice. 001-01/20080228/etl_cxa_l0612a_vjl 2 CXA-L0612A-VJL Outline Drawing Example of label marking Product name, Lot No., Country of origin, TDK-Lambda logotype Silicone High-voltage generator ※ (The entire surface within a range of 45mm away from the end of the basein) ※From high-voltage generator, please secure space distance more than 3mm in top and bottom right and left. Connector Connector number Part number Model Quantity Remarks ① Printed circuit board PCB Composite(CEM-3) 1 UL94V-0 t=1.0 ー ② Input connector CN1 53261-0571 1 Molex Inc. 51021-0500 ③ Output connector CN2 SM02(8.0)B-BHS-1-TB(LF) (SN) 1 JST Mfg. Co., Ltd. BHR-03VS-1 Recommended applicable connector Terminal Numbers And Functions Input side CN1 Terminal number Symbol Output side CN2 Rated voltage Remarks Terminal number Symbol Rated voltage VHIGH 600Vrms CN1-1 Vin 12 2.4V Power input CN2-1 CN1-2 GND 0V Ground CN2-2 N.C. ー CN2-3 VLOW (2V) CN1-3 Vrmt CN1-4 Vbr CN1-5 N.C. 0 to 0.4V:OFF 0V/2.5V to Vin Remote terminal 2.5V to Vin :ON 0 to 4V Dimmer terminal ー Because it uses for internal circuit, please do not connected. All specifications are subject to change without notice. unit:mm 3 CXA-L0612A-VJL Connections ± Maximum brightness RL:Load resistance(7W minimum) Operate as follows by switching a SW. SW Unit operation a Operation b Operation stopped ・All specifications are subject to change without notice.
CXA-L0612A-VJL 价格&库存
很抱歉,暂时无法提供与“CXA-L0612A-VJL”相匹配的价格&库存,您可以联系我们找货
