MESSRS :
PRODUCT DRAWING
CUSTOMER'S PRODUCT NAME:
TDK PRODUCT NAME:
DC/AC INVERTER UNIT
CXA-L0612A-VxL
R
TDK Corporation
Corporate Headquarters
13-1,Nihonbashi 1-chome,Chuo-ku,
Tokyo 103, JAPAN
Telephone : 03-3278-5 111
2-15-7,Higashi-Ohwada,Ichika wa-shi,
Chiba,272-8558 JAPAN
Telephone : 047-378-9 671
Fax : 047-378-9673
PREPARED BY
Sep.11.2005
H.Mitsumoto
APPROVED BY AUTHORIZED BY
Sep.11.2005
E.Takahashi
Sep.11.2005
K.Hanabusa
DWG.No.
CTR-0734-C
Precautionary Notes Regarding the Use of This Inverter
When using this product, give due consideration to the precautionary notes described below and ensure
a safe design. Inappropriate use may result in electric shock, injury or fire.
Warning
● This product is subject to high voltage. Do not touch it while the power is on.
Failing to do so may result in electric shock.
Caution
● This product is designed for the lighting of a Cold Cathode Fluorescent Lamp.
Do not use it with any other load.
● Store this product under the conditions defined in the specification document.
● Do not store this product in an environment where dust, dirt or corrosive gas(salt,acid,base, etc.) is present.
● This product is subject to high voltage. If there is a possibility thatthe user may touch the product,
provide a proper indication in order to draw the user's attention.
● This product is designed for use with general electronic equipment.
If it is to be used with medical equipment that directly affects human life or for the control of
transportation equipment to which passengers entrust their lives, provide thorough fail-safe measures.
● Avoid using this product under high temperatures or high humidity or in an environment in which
dust, dirt or any corrosive gas (salt,acid,base, etc.) is present.
Also,be careful not to allow the formation of dew condensation. It may result in damage or electric shock.
● If the product does not have a built-in protective circuit (cir cuit breaker, fuse, etc.),
it is recommended that a fuse be used at the input stage to prevent the generation of
smoke or fire in the event of a malfunction.
Even when the product has a built-in protective circuit (circuit breaker, fuse, etc.),
the circuit may not function properly due to inappropriate operating conditions or power-supply capacity.
It is recommended that an appropriate protective circuit (circuit breaker, fuse, etc.)
be provided separately from the built-in circuit.
● Use the product only within the specified input voltage, output power, output voltage
and operating temperature ranges. Exceeding these values may result in damage, etc.
● Provide a measure for the prevention of surge voltage due to lightning, etc.
Abnormal voltage may result in damage, etc.
● To prevent problems arising from short-circuiting of the high-voltage section,
provide appropriate measures to prevent the entry of foreign substances following installation.
● This product is not designed to provide resistance to radiation.
● Ripples could be superimposed on the voltage and the current in the input source connected to the inverter ,
depending on the impedance in the input source, wiring, etc.
When you select an input source, please check waveforms, etc on the final set.
Handling Precautions
● This product uses thin wires. Observe the following precautions and handle it with care so
as not to cause wire breakage. Broken wire may result in damage, etc.
・Do not stack multiple products on top of one another.
・Do not allow the product to come in contact with tools, etc.
● Do not apply excessive stress during installation.
It may cause chipping and cracking,resulting in damage, etc.
● Provide a clearance of 2 mm or more between the high-voltage section of this product and
the frame body on which the product is installed and also the conductor section (pattern , pad etc. ).
● Please do not use the product, when dropping it, since there is a possibility of the parts damage.
Please confirm abnormality is not found in the product enough when using it by any chance.
PRODUCT NAME or MODEL,TITLE
DC-AC INVERTER CXA-L0612A-VxL
TDK CORPORATION
NAME OF DRAWING
DRAWING No.
PAGE
Product Drawing
CTR-0734-C
1/6
・The specifications may be changed without any notice.
・When placing orders,
please confirm "Specifications" or Product Drawing" throug h TDK sales or distributors.
●Features●
・This inverter is for one lamp. It has Dimming function and Remote function.
・The high-voltage area is coated with silicone so as to avoid the defects caused by dust.
・This product is conformity to RoH S directive.*
* : Conformity to RoHS Directive:This means that, in conformity with EU Directive 2002/95/EC,
lead, cadmium, hexavalent chromium, and specific bromine-based f lame retardants, PBB
and PBDE, have not been used,except for exempted applications.
[1] Outline
1-1. Outline
Label (Examlpe)
TDK part No, Date code, Country of origin
TOP VIEW
95.5MAX
2-φ2.2±0.1
(I)
1
6
SILICONE
1
1
SM02B-BHSS-1TB(LF)(SN)
1
CN1
(II)
CN2
CXA-L0612A-VJL
5805 R
MADE IN JAPAN
1
12.8±0.2
20MAX
T1
1
QZ-19-A3MYLA-#02TP
82±0.2
SM02(8.0)B-BHS1-TB(LF)(SN)
(4.5)
(4)
(III)
SIDE VIEW
(1)
8MAX
a:60
a:High Voltage generation area※
(All side 45mm from PCB edge.)
※Please secure the air clearance of 2mm or more from the hi gh voltage generation area up and down and right and left.
Please refer to Note1-4. for details.
TAPE
BOTTOM VIEW
Unit:mm
Weight:13.7g.typ.
No.
Part Description
Material
QU.
REMARK
MATES WITH
(I)
PCB
Conposite (CEM-3)
1
UL94V-0 t=1.0
(II)
Input Connector CN1
(III)
Output Connector CN2
53261-0571
1
MOLEX
51021-0500
SM02(8.0)B-BHS-1-TB(LF)(SN)
1
JST
BHR-03VS-1
QZ-19-A3MYLA-#02TP
1
HONDA
QZ-19-3F01
SM02B-BHSS-1-TB(LF)(SN)
1
JST
BHSR-02VS-1
TDK CORPORATION
NAME OF DRAWING
DRAWING No.
PAGE
Product Drawing
CTR-0734-C
2
*Example of naming product
CXA- L0612A-VxL
CN2 high voltage output side terminal position :
L-Leftside sees from insert terminal.
Inverter.
Output power : 4~5W.
Output connector : J-JST SM02(8.0)B-BHS-1-TB(LF)(SN)
HOND A QZ-19-A3MYLA-#02TP
S-JST SM 02B-BHSS-1-TB(LF)(SN)
Output current : 6mArms type.
Input voltage :12V type.
Adjustment of brightness method : Voltag e amplitude
control method to put current feedback.
Power improvement goods of CXA-L0612.
Output side CN2
(CXA-L0612A-VJL)
Pin No. Symbol
1-2. Connector Configuration
Input side CN1
Pin No. Symbol
Rating
CN1-1
Vin
9.6~14.4V
CN2-1
VHIGH
600Vrms 6mArms
CN1-2
GND
0V
CN2-2
N.C.
CN1-3
Vrmt
0V / 2.5V~Vin
0~0.4V : OFF
2.5V~Vin : ON
CN2-3
VLOW
(2V)
CN1-4
Vbr
0~4V
Power supply for
adjustment of brightness.
CN1-5
N.C.
For an internal circuit use.
Don't connect.
Notes
Rating
Output side CN2
(CXA-L0612A-VHL)
Pin No. Symbol
Rating
CN2-1
VLOW
(2V)
CN2-2
N.C.
CN2-3
VHIGH
600Vrms 6mArms
Output side CN2
(CXA-L0612A-VSL)
Pin No. Symbol
Rating
CN2-1
VHIGH
600Vrms 6mArms
CN2-2
VLOW
(2V)
Note1-1. Marking of TDK part No, Date code, Country of origin.
1) TDK part No., Date code, Country of origin, is marked o n the transformer.
2) Date code example. (ex. Augest. 05. 2005)
5
8
R
Product Conforming to RoHS Directive* Identification sign
Blank
Two digits of production day.
One digit of production month. (Oct. :X , Nov. :Y, Dec. :Z)
Last digit of producti on year.
3) Country of origin code example. (ex. MADE IN JAPAN. MADE IN CHINA).
lead, cadmium, hexavalent chromium, and specific bromi ne-based flame retardants, PBB
Note1-1.For connector pins assignment, please refer to inverter mechanical specification as it may differ from
manufacturer pi ns assignment.
Note1-2.For circuit connection, please refer to test circuit diagram [5].
TDK CORPORATION
NAME OF DRAWING
DRAWING No.
PAGE
Product Drawing
CTR-0734-C
3
Note1-4. Please use minimum of 2mm clearance (all directions) between inverter high voltage area a nd any conductors.
Please refer to mechanical drawing for marking of high voltage area.
Note1-5. Open voltage (strike voltage) is measured across the transformer secondary winding at no load as the reading at the
output connector would be less than the actual value.
Note1-6. If the start up voltage falls below Cold Cathode Tube strike voltage, the CCFL will not light up ea sily specially at lower
ambient temperature. Please review mounting instruction to avoid any abnormal operation due t o coupling/leakage
capacitance of inverter high voltage area to any surrounding conductor.
Note1-7. Please check your lamp characteristic for minimum operational current and set the limit po int in your design to avoid
flickering and/or abnormal o peration.
Note1-8. For proper operation of circuit protection (FUSE or IC PROTECTOR),Please use minimu m of 2A capacity for input
power supply.
[2] Absolute maximum ratings
Item
Symbol
Specification
Unit
Input Voltage
Vin
0~16
VDC
Load Resistance
RL
130max.
kΩ
Operating Temp. range
Ta
0~70
°C
Storage Temp. range
Ts
-30~85
°C
Humidity range
RH
95
%RH
Notes
110MAX at output voltage 10.8V or less
A maximum wet ball temperatu re is 38 °C.
No dew.
[3] Electrical specifications
Condition
Item
Symbol
Output Current
(Brightness max.)
Iout1/
Iout2
Output Current
(Brightness min.)
Iout1/
Iout2
9.6~
14.4
9.6~
14.4
9.6~
14.4
Input Current
lin
12
Frequency
F
Open Circuit
Voltage
Vopen
Vin(V)
9.6~
14.4
9.6~
14.4
Specification
MAX
MIN. TYP.
Unit
Ta(°C)
RL(kΩ)
Vbr (V)
18~28
100
6.0
6.6
0~70
90~130
6.0
6.7
18~28
520
4
1.3
1.6
1.9
0~70
90~130
0.65
A
0~70
90~130
58
68
kHz
0~70
0~3
1.5
1.8
kVrms
mArms
TDK CORPORATION
NAME OF DRAWING
DRAWING No.
PAGE
Product Drawing
CTR-0734-C
4
Vin
9.6~14.4V
CN1-1
(Vin)
T1-1
T1-6
CN1-2
(GND)
a SW
CN1-3
(Vrmt)
Vrmt 5V
b
CN1-4
(Vbr)
Vbr
04V
Vbr=0V:Brightness max.
NC
CN2-3
(VHIGH )
CXA-L0612A-VJL
SM02(8.0)B-BHS-1TB(LF)(SN)
(JST)
V Vin
CN2-1
(V HIGH)
CN1-5
(NC)
CN2-3
(V LOW )
F
1000:1
CN2-1
(V HIGH)
CXA-L0612A-VSL
(JST)
lin
A
CXA-L0612A-VHL
QZ-19-A3MYLA-#02TP
(HONDA)
[4] Test circuit
CN2-1
(VLOW )
CN2-2
(V LOW )
RL
Iout
A
V
*For the number of the component's positon, please refer to Outline diagram [1].
Note4-2.Test Equipments
Note4-1.SW(ON/OFF) Operation is as following;
SW
Operation of unit
V
Digital Multiple Meter(ADVANTEST R6451A or equivalent)
A
DC Current Meter(ADVANTEST R6451A or equivalent)
a
Operation
F
Frequency Countor(ADVANTEST R6452A or equivalent)
b
Non operation
V
True RMS Meter(KEITHLEY 2001 or equivalent.)
A
High Frequency Current Meter(KEITHLEY 2001 or equivalent)
1000:1
High Voltage Probe(Tektronix P3000 or equivalent)
Remote terminal circuit (Reference)
Connection diagram of LCD module (Reference)
LCD module
DC-AC inverter
CN1-1
Vin
10kΩ
47kΩ
CN1-3
Vrmt
VLOW
10kΩ
A
22kΩ
VHIGH
IC1
Lamp
*Connect the High Frequency Current Meter to the Low-Voltage (VLOW ) side.
[5] Reliability test
Following test items are assured.
Item
Condition
Judgement
Low Temp.Non
operational
-40°C 500h
Low Temp.operational
-10°C 500h Load cond.:TYP
High Temp.Non
operational
85°C 500h
High Temp.operational
70°C 500h Load cond.:TYP
Heat shock
-20°C to 75°C 30min.Each 100 Cycles
Humidity
(Non operational)
40°C 90~95%RH 500h
Vibration
10~55Hz Amplitude 0.35mm or 5G
Sweep:1min
30min each axis X,Y,Z
Shock
100G 6ms Harf-sine pulse
1 time each axis ±X,Y,Z
Electrical and apperrance should be in the
spec.
TDK CORPORATION
NAME OF DRAWING
DRAWING No.
PAGE
Product Drawing
CTR-0734-C
5
[6] Packing and Marking
A shipping box is packaged to avoid from damage. Follo wing items are printed on the box.
6-1. TDK part No.
(ex) CXA-L0612A-VJL
6-2. Manufacture
TDK
6-3. Customer part No.
6-4. QTY.
6-5. Inspection No.
6-6. Country of origin
Packing style as under Fig. (200 going in with a standard.)
8 trays and one cover tray
* Put the tray (No product tray) on the top.
25pcs in one tray (Anti static tray)
X 8trays = 200pcs/one box
Corrugated cardboard
Packing box.
(400mm:L)X(333mm:W)X(149mm:H)
LABEL
TDK part No.
Manufacture
Customer part No.
QTY.
Inspection No.
Countory of origin
[7] Others
7-1. Test cond.
A normal test condition :Temperature (20±15°C), Humidity (65±20%RH).
7-2. Std warrantry
One year after shipment.This covers any defects in material or workmanshi p. Defective units will be replaces
at no charge.
7-3. Others
TDK and customer are to discuss changes,problems, and modifica tions and etc, when needed.
TDK CORPORATION
NAME OF DRAWING
DRAWING No.
PAGE
Product Drawing
CTR-0734-C
6
