CXA-P1212D-WJL
CXA-P1212D-WJL
    TDK(东电化)
    INVERTER 12V-INPUT 1700V-OUTPUT
CXA-P1212D-WJL 数据手册
MESSRS : Comparison with the Specifications CUSTOMER'S PRODUCT NAME: TDK PRODUCT NAME: DC/AC INVERTER UNIT CXA-P1212D-WJL TDK-Lambda Corporation PREPARED BY APPROVED BY AUTHORIZED BY Apr. 28 ,2010 N.Suzuki Apr. 28 ,2010 K.Yamaishi Apr. 28 ,2010 H.Masuoka DWG.No. CTR-3917-X The difference between CXA-P1212C-WJL and CXA-P1212D-WJL Compared with CXA-P1212C-WJL to CXA-P1212D-WJL , we will expand the operating temperature range. We have changed the fuse rating for lamp impedance at the low temperature . 1. Outline , Connector 1-1. Outline Product name Depth[mm] Wide[mm] Height[mm] Mounting hole diameter[mm] Mounting hole location[mm] CXA-P1212C-WJL 22MAX 153.5MAX 8.5MAX 3.5±0.2 14±0.3, 107±0.3 CXA-P1212D-WJL ↑ ↑ ↑ ↑ ↑ 1-2. Connector Product name Input Connector Output Connector CXA-P1212C-WJL 53261-0771 SM07(7-D1)B-BHS-1-TB(LF)(SN) CXA-P1212D-WJL ↑ ↑ 2. Absolute maximum rating Strage Humidity Operation Temperature range Temperature range range Unit [V] [V] [V] [KΩ] [℃] [℃] [℃] CXA-P1212C-WJL 0~ 15 -1~ Vin+1 0~Vin 100 -10 ~ 70 -30 ~ 85 95 CXA-P1212D-WJL ↑ ↑ ↑ ↑ -30 ~ 80 ↑ ↑ Product name Vin Vrmt Vbr Load 3. Electrical characteristics Item Output current (Dimming max) Output current (Dimming min) Input current 1 Input current 2 Frequency (Dimming max) Frequency (Dimming min) Open circuit voltage Alarm output Condition CXACXAsymbol P1212C P1212D Vbr(V) RL(kΩ) Vin(V) Vrmt(V) -WJL -WJL /Rbr(kΩ) Unit Io1 12±1.2 5±0.25 0/0 90 6.0(typ) ← mArms Io2 12±1.2 5±0.25 2.5/50 90 2.0(typ) ← mArms Iin1 Iin2 12±0.6 5±0.25 12±0.6 0±0.25 0/0 0/0 90 90 1.0(typ) 1(max) ← ← A mA F1 12±0.6 5±0.25 0/0 90 43(typ) ← kHz F2 12±0.6 5±0.25 2.5/50 90 250(typ) ← Hz 0/0 0/0 0/0 ∞ ∞ 90 1.5(min) 5.0(typ) 0.5(max) ← ← ← kVrms V V Vopen 10.8min 5±0.25 12±1.2 5±0.25 Vst 12±1.2 5±0.25 No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212D-WJL TDK-Lambda NAME OF DRAWING DRAWING No. PAGE Comparison with the Specifications CTR-3917-X 1
CXA-P1212D-WJL 价格&库存
很抱歉,暂时无法提供与“CXA-P1212D-WJL”相匹配的价格&库存,您可以联系我们找货
