CXA-P1212E-WJL
CXA-P1212E-WJL
    TDK(东电化)
    INVERTER 12V-INPUT 1700V-OUTPUT
CXA-P1212E-WJL 数据手册
MESSRS : Product Drawing CUSTOMER'S PRODUCT NAME: TDK PRODUCT NAME: DC/AC INVERTER UNIT CXA- P1212E-WJL TENTATIVE *Notice Product Drawing is not contract. This is only technical data. This technical data may change internal description without any notice. When you design final product please request us specification through our sales or distributors. After you receive the specification, the contract is effective on signature of the specification. TDK-Lambda Corporation PREPARED BY APPROVED BY AUTHORIZED BY April 20, 2010 April 20, 2010 April 20, 2010 N.Suzuki Y.Kimura H.Masuoka DWG.No. CTR-3859-X Precautionary Notes Regarding the Use of This Inverter When using this product, give due consideration to the precautionary notes described below and ensure a safe design. Inappropriate use may result in electric shock, injury or fire. Warning This product is subject to high voltage. Do not touch it while the power is on. Failing to do so may result in electric shock. Caution This product is designed for lighting Cold Cathode Fluorescent Lamps. Do not use it with any other load. Store this product under the conditions defined in the specification document. Do not store this product in an environment where dust, dirt or corrosive gas(salt,acid,base, etc.) is present. This product is subject to high voltage. If there is a possibility that the user may touch the product, provide a proper warning indication in order to draw the user's attention. This product is designed for use with general electronic equipment. If it is to be used with medical equipment that directly affects human life or for the control of transportation equipment to which passengers entrust their lives, provide thorough fail-safe measures. Consult us before using if this product is to be installed in a habitual vibration environment (vehicle, etc.). Avoid using this product under high temperatures or high humidity or in an environment in which dust, dirt or any corrosive gas (salt,acid,base, etc.) is present. Also,be careful not to allow the formation of dew condensation. It may result in damage or electric shock. If the product does not have a built-in protective circuit (circuit breaker, fuse, etc.), it is recommended that a fuse be used at the input stage to prevent the generation of smoke or fire in the event of a malfunction. Even when the product has a built-in protective circuit (circuit breaker, fuse, etc.), the circuit may not function properly due to inappropriate operating conditions or power-supply capacity. It is recommended that an appropriate protective circuit (circuit breaker, fuse, etc.) be provided separately from the built-in circuit. Use the product only within the specified input voltage, output power, output voltage and operating temperature ranges. Exceeding these values may result in damage, etc. Provide a measure for the prevention of surge voltage due to lightning, etc. Abnormal voltage may result in damage, etc. To prevent problems from occurring as a result of a short circuit in the high voltage section, be sure to take appropriate measures to prevent the entry of foreign substances into the inverter after it is installed. This product is not designed to provide resistance to radiation. In order to protect the inverter from vibration and shock, be sure to use all the mounting holes when installing the inverter. Ripples could be superimposed on the voltage and the current in the input source connected to the inverter , depending on the impedance in the input source, wiring, etc. When you select an input source, please check waveforms, etc on the final set. Please use all the mounting holes, because to defend the converter from vibration and impact. E V I T A T N E T Handling Precautions This product uses thin wires. Observe the following precautions and handle it with care so as not to cause wire breakage. Broken wire may result in damage, etc. Do not stack multiple products on top of one another. Do not allow the product to come in contact with tools, etc. Do not apply excessive stress during installation. It may cause chipping and cracking,resulting in damage, etc. Provide clearance between the high-voltage section of this product and the frame body on which the product is installed and also the conductor section as on page 2 , [1] ”Outline” . Do not use the product after it has been dropped because there is the possibility that components have been damaged. No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 1 TSB-08-01-05(00) form-6(A4) 1. Part Name The part name is CXA-P1212E-WJL. 2. Contents Item Attched view Page 1.Appearance,Structure and Dimensions Outline refer to [1] 3 Pin configration refer to [1] 4 2.Characteristics Absolute Maximum Ratings 3.Electrical Characteristics 4.Test circuit 5.Reliability Test 6.Packing and Marking 7.Others Test Cond Std Warranty Others E V I T A T N E T No. MATERIALS NAME QU refer to [2] 5 refer to [3] 5 refer to [4] 6 refer to [5] 7 refer to [6] 8 refer to [7] 8 MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 2 TSB-08-01-05(00) form-6(A4) Listed description are subject to change without notice. **Features** This is the double output (two CCFL) inverter. It has Dimming function and Remote function. This product has shutdown function. It prevents from keeping generating the high voltage when the lamps open.(Refer Note.4-4.) With lamp failure detector. Normal Operation : CN1-6=0V Some Lamps Open : CN1-6=5V The high-voltage area (terminals and patterns) is coated with silicone so as to avoid the defects caused by dust. This product is conformity to RoHS directive.*1 *1Conformity to RoHS Directive:This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used,except for exempted applications. [1] Outline 1-1. Outline Label (Examlpe) TDK part No, Date code, Country of origin TDK-Lambda logo TOP VIEW E V I T A T N E T (10) CXA-P1212E-WJL 0419 MADE IN MALAYSIA 3 7,8 (10) 10.25 ±0.3 CN2 CN3 1 3 1 CAUTION HIGH VOLTAGE 21.5±0.5 1 14±0.2 7 CN1 1 T1 (4.0) 2- 3.5±0.2 (3.5) (iii) (i) (ii) SILICONE 107±0.2 153±0.5 No parts and pattern area.(Except GND) 8.5MAX (1.0) SIDE VIEW 75mm (a:High Voltage generation area) **Please secure 3mm or longer space distance from the h igh voltage generating area in all directions. Please see Note 1-3 for the details. BOTTOM VIEW Unit:mm Weight:21.2g.typ. No. Part Description Material QU REMARK MATES WITH (i) PCB Composite (CEM-3) 1 UL94V-0 t=1.0 - (ii) Input Connector CN1 53261-0771 1 MOLEX 51021-0700 (iii) Output Connector CN2,CN3 SM02(8.0)B-BHS-1-TB(LF)(SN) 2 JST BHR-03VS-1 No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 3 TSB-08-01-05(00) form-6(A4) 1-2. Connector Configuration Output side CN2 Input side CN1 Pin No. CN1-1 CN1-2 CN1-3 CN1-4 CN1-5 Symbols Ratings Notes Vin 10.8-13.2V Input Voltage GND 0V GND Vrmt 0V/2.5V-Vin 0-0.4V:OFF 2.5-Vin V:ON Remote terminal CN1-6 (Output) Vst CN1-7 Vbr/Rbr Pin No. Symbols Ratings Notes CN2-1 VHIGH1 600Vrms Output1 CN2-2 NC - - CN2-3 VLOW1 (2V) Output1 Return Output side CN3 Pin No. Symbols Ratings Notes CN3-1 VHIGH2 600Vrms Output2 CN3-2 NC - - CN3-3 VLOW2 (2V) Output2 Return The warning output 5V in abnormal circumstances 0V/5V E V I T A T N E T 0-2.5V/0-50k Brightness terminal Note1-1. Marking of TDK part No, Date code, Country of origin. 1)TDK part No., Date code, Country of origin, is marked on the transformer. 2)Date code example. (ex. April 19. 2010) 0 4 1 9 R RoHS Directive compliant product Identification sign*2 Blank Manufacturing date (marked in 2 digits) Manufacturing month (marked in 1 digit except October, November and December that are represetned by X, Y and Z respectively.) Manufacturing year (last digit in Christian year) 3) Country of origin code example. (ex. MADE IN JAPAN. MADE IN CHINA. MADEIN MALAYSIA). Note1-2. For circuit connection, please prefer to test circuit diagram [4]. Note1-3. Please use minimum of 3mm clearance (all directions) between inverter high voltage area and any conductors. Please refer to mechanical drawing for marking of high voltage area. Note1-4. Open voltage (strike voltage) is measured across the transformer secondary winding at no load as the reading at the output connector would be less than the actual value. Note1-5. If the start up voltage falls below Cold Cathode Tube strike voltage, the CCFL will not light up easily specially at lower ambient temperature. Please review mounting instruction to avoid any abnormal operation due to coupling/leakage capacitance of inverter high voltage area to any surrounding conductor. Fig1.High Voltage Code NG OK LCD MODULE CN3 CN3 LCD MODULE No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 4 TSB-08-01-05(00) form-6(A4) Note1-6. Please check your lamp characteristic for minimum operational current and set the limit point in your design to avoid flickering and/or abnormal operation. Note1-7. For proper operation of circuit protection (fuse or IC PROTECTOR),Please use minimum of 4.0A capacity for input power supply. Note1-8. Impedence from the wire connection can cause a ripple in the input. The product has an internal fuse of 2.0A. Please check that input current peak wave form does not exceed 2.0A. [2] Absolute maximum ratings Item Symbol Specification Vin 0~15 Input Voltage Vrmt 0~Vin Vbr 0~16 Unit V E V I T A T N E T Load Resistance RL1//CL1 RL2//CL2 100//5 k //pF Operating Temp. range Ta -30~80 °C Storage Temp. range Ts -30~85 °C Humidity range RH 95 %RH [3] Electrical specifications Notes A maximum wet ball temperature is 38°C No dew Conditions Item Symbol Output Current (Brightness max.) Iout1/ Iout2 Output Current (Brightness min.) Iout1/ Iout2 Specifications Vin(V) Vrmt(V) Rbr(k )/ Vbr(V) 12±1.2 5±0.25 0/0 -30~80 90//5±0.25 90//5±0.25 5.3 6.0 6.7 12±0.6 5±0.25 0/0 23±5 90//5±0.25 90//5±0.25 5.5 6.0 6.5 12±1.2 5±0.25 50 / 2.5 -30~80 90//5±0.25 90//5±0.25 1.0 2.0 3.0 12±1.2 5±0.25 50 / 2.5 -10~70 90//5±0.25 90//5±0.25 1.1 2.0 2.9 12±0.6 5±0.25 50 / 2.5 23±5 90//5±0.25 90//5±0.25 1.2 2.0 2.8 Ta(°C) RL1(k )//CL1(pF) RL2(k )//CL2(pF) MIN. TYP. MAX. Unit mArms Input Current1 lin1 12±0.6 5±0.25 0/0 -30~80 90//5±0.25 90//5±0.25 - 0.8 1.0 A Input Current2 lin2 12±0.6 0±0.25 0/0 -30~80 90//5±0.25 90//5±0.25 - - 1 mA F1 12±0.6 5±0.25 0/0 -30~80 90//5±0.25 90//5±0.25 35 40 45 kHz F2 12±0.6 5±0.25 50 / 2.5 -30~80 90//5±0.25 90//5±0.25 210 250 290 kHz Vopen 12±1.2 5±0.25 0/0 -30~80 1500 1700 - Vrms 12±1.2 5±0.25 0/0 -30~80 4.5 5.0 5.5 12±1.2 5±0.25 0/0 -30~80 4.5 5.0 5.5 12±1.2 5±0.25 0/0 -30~80 - 0 0.5 Frequency Open Circuit Voltage Warning Output Vst No. MATERIALS NAME QU 90//5±0.25 90//5±0.25 90//5±0.25 90//5±0.25 MATERIAL V REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 5 TSB-08-01-05(00) form-6(A4) [4] Test circuit F1 F Vin 10.8~13.2V Vrmt 5V A 1000:1 PROBE F2 CN1-1 CN1-2 Iin V CN1-3 CN1-4 T1-2 a V b CN1-5 SW1 V ~ T1-7,8 CN2-1 V Vst IC2 b SW2 V Rbr 0~50k (0.025W~) A ~ IC2-1 a Vbr 0~2.5V RL 1 RL2 CN1-6 A ~ Io2 CN3-3 CN1-7 Vopn CL1 CL2 CN3-1 Io1 CN2-3 E V I T A T N E T RL1,2:Load resistance (7W min.) CL1,2:Stray capacitor (3kV min.) *About the number of the component's positon, please refer to Outline [1]. Note4-1. SW1(ON/OFF) Operation is as following; Note4-2. SW2(ON/OFF) Operation is as following; SW1 Operation of unit SW2 Operation of unit a Operation a *Voltage dimming Vbr=0~2.5V b Non operation b *Variable resistance dimming VR=0~50k *Vbr=0V : Brightness max. Rbr=0 : Brightness max. Note 4-3.Measuring apparatus Note4-4.Safety Function V - Digital Multiple Meter(ADVANTEST R6452A or equivalent) A V ~ DC Current Meter(ADVANTEST R6452A or equivalent) F Frequency Countor(ADVANTEST R6452A or equivalent) A ~ High Frequency Current Meter(FLUKE187or equivalent) Load Condition Alarm Signal (CN1-6)*1 Shutdown Operation*2 Normal Operation 0.5V max. Normal 1 Lamp Open 4.75~5.25V Normal 2 Lamps Open 4.75~5.25V Shutdown True RMS Meter(NF Circuit M2170or equivalent) *1. When any of the load is opened, the alarm output becomes 5V. 1000:1 High Voltage Probe(Tektronix P6015A or equivalent) *2. When all of the load is opened, inverter will shut down about 3 seconds. Connection diagram of LCD module (Reference) DC-AC inverter VLOW A VHIGH VHIGH VLOW LCD module Lamp Lamp A *Connect the High Frequency Current Meter to the Low-Voltage (V LOW) side. No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 6 TSB-08-01-05(00) form-6(A4) Vrmt terminal circuit (Reference) CN1-1,2 Vin CN1-5 Vrmt 10k 20k 10k 10k IC1 [5] Reliability test Following test items are assured. Item Condition Low Temp.Non operational -40°C 500h Low Temp.operational High Temp.Non operational High Temp.operational Humidity (Non operational) Shock E V I T A T N E T -30°C 500h Load cond.:TYP 85°C 500h 80°C 500h Load cond.:TYP -30°C 85°C 30min.Each 100 Cycles Heat shock Vibration Judgement Electrical and apperrance should be in the spec. 60°C 90~95%RH 500h 10~57Hz Amplitude0.75mm 58~500Hz 9.8m/s2 Sweep:11min 60min each axis X,Y,Z 980m/s2 6ms Harf-sine pulse 1 time each axis ±X,Y,Z No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 7 TSB-08-01-05(00) form-6(A4) [6] Packing and Marking A shipping box is packaged to avoid from damage. Following items are printed on the box. 6-1. TDK part No. CXA-P1212E-WJL 6-2. Manufacture 6-3. QTY. Packing style as under Fig. (100 going in with a standard.) Styrofoam E V I T A T N E T Corrugated cardboard Product Styrofoam 20pcs in one tray X 5trays =100pcs/one box Packing box. TDKa part No. Manufacture QTY. (210mm) (340mm) (480mm) [7] Others 7-1.Test conditions Unless otherwise specified, the temperature to be (25±15)℃ and humidity to be (65±20) %RH. 7-2. Warranty Warranty shall be for one year after delivery, and those products causing failure during the warranty period and which failures are attributed to the manufacturer's responsibility shall be replaced at no charge. 7-3.Oters When any doubt arises about this specification, it shall be discussed and decided upon between both parties. Shipment inspection result sheet are subject to change without notice. No. MATERIALS NAME QU MATERIAL REMARK PRODUCT NAME or MODEL,TITLE DC-AC INVERTER UNIT CXA-P1212E-WJL NAME OF DRAWING DRAWING No. PAGE Product Drawing CTR-3859-X 8 TSB-08-01-05(00) form-6(A4)
CXA-P1212E-WJL 价格&库存
很抱歉,暂时无法提供与“CXA-P1212E-WJL”相匹配的价格&库存,您可以联系我们找货
