R F
C o m p o n e n t s
May 2015
Multilayer Phase Shifter (Delay Line)
For 1710-1910MHz
DEA101910DT-6016A1
1.0x0.5mm [EIA 0402]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 1710-1910MHz
DEA101910DT-6016A1
SHAPES AND DIMENSIONS
[Top view]
1.00±0.05
0.52max.
(1)
(3)
(2)
0.50±0.05
(4)
Marking
[Bottom view]
0.30±0.10
0.30±0.10
0.12±0.07
0.12±0.07
Terminal functions
1 IN
2 GND
3 OUT
4 GND
0.35±0.10
Dimensions in mm
RECOMMENDED LAND PATTERN
0.45
0.30
0.45
0.20
0.70
0.30
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150508 / rf_phase-shifter_dea101910dt-6016a1_en.fm
RF Components
DEA101910DT-6016A1
ELECTRICAL CHARACTERISTICS
Item
Insertion Loss (dB)
Phase Shift (deg.)
VSWR
Characteristic Impedance (:)
Frequency Range
(MHz)
Min.
Typ.
Max.
1710 to 1910
1710 to 1910
1710 to 1910
–85
50 (Nominal)
0.40
–65
1.7
・Ta=25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DEA101910DT-6016A1
FREQUENCY CHARACTERISTICS
INSERTION LOSS
ATTENUATION
5
0.5
10
Attenuation(dB)
Insertion Loss (dB)
15
1.0
1.5
2.0
30
35
40
2.5
45
3.0
500
1000
1500
2000
Frequency (MHz)
2500
50
3000
3000
VSWR
4000
5000
6000
Frequency (MHz)
7000
8000
1500
2000
Frequency (MHz)
2500
3000
PHASE SHIFT
2.0
200
1.9
150
1.8
100
Phase Shift(deg.)
1.7
VSWR
1.6
1.5
1.4
50
–50
1.3
–100
1.2
–150
1.1
1.0
500
1000
1500
2000
Frequency (MHz)
2500
3000
–200
500
1000
RF Components
DEA101910DT-6016A1
RECOMMENDED REFLOW PROFILE
Soaking
Working
Soldering
Peak
T: Temperature
T4
T5
T3
T2
T4
T3
t3
T1
t1
t2
t: Time
Soaking
Temp.
T1
150°C
T2
180°C
Time
t1
60 to 120s
Working
Temp.
T3
230°C
Time
t2
more than 30s
Soldering Peak
Temp.
T4
247 to 253°C
Time
t3
within 10s
Temp.
T5
260°C max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA101910DT-6016A1”相匹配的价格&库存,您可以联系我们找货
