DEA160710LT-5023B1
DEA160710LT-5023B1
    TDK(东电化)
    SMD-4P,0.8x1.6mm
    470-770MHZ多层低通滤波器
DEA160710LT-5023B1 数据手册
R F C o m p o n e n t s June 2015 Multilayer Low Pass Filter For 470-770MHz DEA160710LT-5023B1 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] RF Components Multilayer Low Pass Filter Conformity to RoHS Directive For 470-770MHz DEA160710LT-5023B1 SHAPES AND DIMENSIONS [Top view] 0.45max. (1) 0.8±0.10 1.60±0.15 (4) (3) (2) Marking [Bottom view] 0.70±0.10 0.30±0.10 0.15±0.10 0.15±0.10 Terminal functions 1 IN 2 GND 3 OUT 4 GND 0.45±0.10 Dimensions in mm RECOMMENDED LAND PATTERN 2.20 0.50 0.30 0.40 0.60 0.50 1.40 0.50 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_lpf_dea160710lt-5023b1_en.fm RF Components DEA160710LT-5023B1 ELECTRICAL CHARACTERISTICS Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 470 to 600 600 to 710 710 to 770 470 to 710 710 to 770 880 to 915 940 to 960 1429 to 1453 1920 to 1980 2400 to 2500 — — — 11.73 7.36 25 25 27 26 26 0.76 1.49 3.09 13.6 11.0 33.4 29.9 33.6 30.7 33.0 50 (Nominal) 1.0 2.0 4.0 — — — — — — — Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_lpf_dea160710lt-5023b1_en.fm RF Components DEA160710LT-5023B1 FREQUENCY CHARACTERISTICS INSERTION LOSS ATTENUATION 0.0 0 1.0 10 20 3.0 Attenuation(dB) Insertion Loss (dB) 2.0 4.0 5.0 30 40 6.0 50 7.0 8.0 300 500 700 Frequency (MHz) 900 500 700 Frequency (MHz) 900 60 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 Frequency (MHz) RETURN LOSS –10 –5 Return Loss(dB) 0 5 10 15 20 25 30 300 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_lpf_dea160710lt-5023b1_en.fm RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_lpf_dea160710lt-5023b1_en.fm
DEA160710LT-5023B1
物料型号:DEA160710LT-5023B1
器件简介:这是TDK公司生产的多层低通滤波器,适用于470-770MHz的频率范围。
引脚分配:该器件有3个引脚,其中1号引脚为输入(IN),2号和3号引脚为地(GND)。
参数特性: - 尺寸:1.6x0.8mm(EIA 0603标准) - 推荐焊盘图案尺寸 - 符合RoHS指令的产品
功能详解: - 插入损耗:在470-600MHz范围内最小为0.76dB,典型值为1.0dB;在600-710MHz范围内典型值为1.49dB,最大为2.0dB;在710-770MHz范围内典型值为3.09dB,最大为4.0dB。 - 回波损耗:在470-710MHz范围内为11.73dB至13.6dB,在710-770MHz范围内为7.36dB至11.0dB。 - 特定频率范围内的衰减值和特性阻抗(50欧姆,标称值)。
应用信息:该产品适用于一般电子设备,如音视频设备、通信设备、家用电器、娱乐设备、计算机设备、个人设备、办公设备、测量设备和工业机器人等。不适用于需要更高安全或可靠性级别的应用,如航空、汽车、医疗设备等。
封装信息:封装尺寸为1.60±0.15mm x 0.8±0.10mm,标记方式遵循JIS[EIA]标准。
DEA160710LT-5023B1 价格&库存
很抱歉,暂时无法提供与“DEA160710LT-5023B1”相匹配的价格&库存,您可以联系我们找货
DEA160710LT-5023B1
  • 4000+1.281584000+0.16637
  • 8000+1.205558000+0.15650
  • 12000+1.1631812000+0.15100
  • 20000+1.1118920000+0.14434
  • 28000+1.0793428000+0.14012
  • 40000+1.0458640000+0.13577
库存:7786
DEA160710LT-5023B1
    DEA160710LT-5023B1
    • 1+2.726681+0.35397
    • 10+2.2431210+0.29120
    • 25+2.0684425+0.26852
    • 50+1.9444650+0.25243
    • 100+1.82815100+0.23733
    • 250+1.68547250+0.21881
    • 500+1.58505500+0.20577
    • 1000+1.491021000+0.19356
    库存:7786
