DEA160915LT-1169
DEA160915LT-1169
    TDK(东电化)
DEA160915LT-1169 数据手册
Multilayer Low Pass Filters For GSM850/GSM900 Tx DEA Series Type: DEA160915LT-1169 (1.6×0.8×0.8mm) Issue date: November 2010 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/2) Multilayer Chip Low Pass Filters For AGSM-EGSM/Tx Conformity to RoHS Directive DEA Series DEA160915LT-1169 SHAPES AND DIMENSIONS Marking 0.8±0.1 3 4 Terminal functions 1 IN 2 GND 3 OUT 4 GND 0.8±0.1 1.6±0.15 0.5±0.1 0.15min. 1 0.8±0.1 2 0.2±0.1 0.2min. Dimensions in mm RECOMMENDED PC BOARD PATTERNS 0.5 0.3 0.6 0.3 0.5 0.6 OUT/IN IN/OUT 0.4 GND 0.5 1.0 0.8 0.5 1.0 This width is 50Ω. Micro-strip line for 0.4mm thick glass-epoxy substrate. GND Solder resist ø0.3 Through-hole Dimensions in mm ELECTRICAL CHARACTERISTICS Item Insertion loss Attenuation Temperature range [880 to 915MHz] [1760 to 1830MHz] [2640 to 2745MHz] Operating Storage (dB) (dB) (dB) (°C) (°C) Minimum value — 30 25 –40 –40 Typical value — — — — — Maximum value 0.7 — — +85 +85 • Ta: 25±5°C • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-02 / 20101012 / e731_multilpf_dea04.fm (2/2) 0 –0.5 –1.0 –1.5 –2.0 –2.5 –3.0 –3.5 –4.0 –4.5 –5.0 500 ATTENUATION 1: 880.0MHz –0.28dB 2: 915.0MHz –0.30dB 12 1000 1500 2000 Frequency (MHz) 2500 Return loss(dB) –20 –30 34 –40 –60 500 3000 12 1000 1500 2000 Frequency (MHz) 2500 3000 VSWR jV 1 1: 880.0MHz –25.2dB 2: 915.0MHz –29.2dB –1 12 1000 1: 1760.0MHz –42.1dB 2: 1830.0MHz –40.2dB 3: 2640.0MHz –33.7dB 4: 2745.0MHz –33.1dB –10 –50 RETURN LOSS 50 40 30 20 10 0 –10 –20 –30 –40 –50 500 0 Attenuation(dB) Insertion loss (dB) FREQUENCY CHARACTERISTICS INSERTION LOSS 1500 2000 Frequency (MHz) 2500 3000 0.8 0.6 0.4 0.2 0 12 1: 880.0MHz 1.18dB 2: 915.0MHz 1.12dB 1 U –0.4 –0.6 –0.8 –1 • All specifications are subject to change without notice. 001-02 / 20101012 / e731_multilpf_dea04.fm
DEA160915LT-1169 价格&库存
很抱歉,暂时无法提供与“DEA160915LT-1169”相匹配的价格&库存,您可以联系我们找货
