R F
C o m p o n e n t s
January 2016
Multilayer Low Pass Filter (2in1)
For 824-915MHz / 1710-1910MHz
DEA161910LT-9031A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Jun. 4, 2020
Last Purchase Order Date
Dec. 31, 2021
Last Shipment Date
Mar. 31, 2022
Please refer to our Web site about replacement information.
RF Components
Conformity to RoHS Directive
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
DEA161910LT-9031A1
SHAPES AND DIMENSIONS
[Top view]
1.60±0.10
0.60±0.10
(5)
(4)
(1)
(2)
(3)
Marking
0.80±0.10
(6)
0.25±0.10
0.15±0.10
0.55±0.10
0.10±0.10
Terminal functions
1 High Band Input port
2 GND
3 Low Band Input port
4 Low Band Output port
5 GND
6 High Band Output port
Dimensions in mm
0.30±0.10
RECOMMENDED LAND PATTERN
EVALUATION BOARD
Dimensions in mm
Th
e
0.25
Low Band Input port
0.90
THRU HOLE
Metal Pattern (Cu)
Filter
LAND PATTERN
0.63
0.05
0.30
0.60
0.30
0.35
[Bottom view]
Dimensions in mm
Line width to be designed to match 50: characteristic impedance, depending on
PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20160107 / rf_lpf_dea161910lt-9031a1_en.fm
RF Components
DEA161910LT-9031A1
ELECTRICAL CHARACTERISTICS
Item
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
824 to 915
824 to 915
824 to 915
1648 to 1830
2472 to 2745
3296 to 3660
4120 to 4575
4944 to 6405
6500 to 12750
10.03
30
25
7
3
0.47
29.2
40.8
34.8
28.3
19.5
15.0
6.7
50 (Nominal)
0.60
0.80 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
1710 to 1910
1710 to 1910
1710 to 1910
3420 to 3820
5130 to 5730
6840 to 9550
10260 to 12750
10.03
30
3
0.43
17.0
40.3
26.1
12.0
8.3
50 (Nominal)
0.60
0.80 (–40 to +85°C)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Storage temperature
(°C)
–40 to +85
Th
e
Operating temperature
(°C)
–40 to +85
RF Components
DEA161910LT-9031A1
FREQUENCY CHARACTERISTICS
0.0
0.0
0.5
Insertion Loss(dB)
1.0
1.5
2.0
2.5
3.0
500
600
Return Loss
2.0
800
900
1000
Frequency(MHz)
1100
1200
1300
3.0
1400
1400
1600
1800
2000
2200
2400
Frequency(MHz)
2600
2800
3000
1800
2000
2200
2400
Frequency(MHz)
2600
2800
3000
Return Loss
Return Loss(dB)
40
50
500
700
10
10
Return Loss(dB)
1.5
40
600
Attenuation
700
800
900
1000
Frequency(MHz)
1100
1200
1300
50
1400
1400
1600
Attenuation
10
Th
e
30
40
4000
30
40
50
50
60
1.0
2.5
Attenuation(dB)
Insertion Loss(dB)
0.5
Attenuation(dB)
HIGH-BAND
Insertion Loss
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
LOW-BAND
Insertion Loss
6000
8000
Frequency(MHz)
10000
12000
14000
60
4000
6000
8000
Frequency(MHz)
10000
12000
14000
RF Components
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA161910LT-9031A1”相匹配的价格&库存,您可以联系我们找货
