Oct. 2016 Ver.1.0
TDK Corporation
Multilayer High Pass Filter
DEA Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DEA162300HT-8047A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Oct. 2016 Ver.1.0
TDK Corporation
DEA162300HT-8047A1
■ SHAPES AND DIMENSIONS
(1)
(2)
(3)
(3)
(2)
(1)
Dimensions (mm)
L
W
T
a
b
c
d
1.60 0.80 0.65 0.30 0.25 0.40 0.70
+/-0.10 +/-0.10
Max
+/-0.10 +/-0.10 +/-0.10 +/-0.10
Terminal functions
Input Port
(1)
GND
(2)
Output Port
(3)
■ TEMPERATURE RANGE
Operating temperature Storage temperature
–40 to +85 °C
–40 to +85 °C
■ TERMINATION FINISH
Material
Au plate
Oct. 2016 Ver.1.0
TDK Corporation
DEA162300HT-8047A1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Insertion Loss (dB)
2300 to
2496 to
TDK Spec
Min. Typ. Max.
2400 0.42 0.50
2690 0.40 0.50
Insertion Loss (dB)
( –40 to +85 °C )
2300 to
2496 to
2400
2690
0.70
0.70
VSWR
2300 to
2496 to
2400
2690
1.29 2.00
1.33 2.00
Attenuation (dB)
1710 to
1785
13
Parameter
Characteristic Impedance (ohm)
Ta = +25+/-5°C
Frequency (MHz)
21
50 (Nominal)
Oct. 2016 Ver.1.0
TDK Corporation
DEA162300HT-8047A1
■ FREQUENCY CHARACTERISTICS
S11
POLA
REF 1.0 U
Insertion
VSWR Loss
SCALE 1.0U FS
S21
1 jV
0.8
0.6
0.4
0.2
U
-0.2
-0.4
Log MAG
REF 0.0dB
SCALE 1dB/
0.0
MARKER 1
2300.0 MHz
0.42 dB
MARKER 2
2400.0 MHz
0.41 dB
MARKER 3
2496.0 MHz
0.40 dB
MARKER 4
2690.0 MHz
0.35 dB
MARKER 5
MHz
dB
MARKER 6
MHz
dB
INSERTION LOSS
MARKER 1
2300.0 MHz
1.19
MARKER 2
2400.0 MHz
1.29
MARKER 3
2496.0 MHz
1.33
MARKER 4
2690.0 MHz
1.32
MARKER 5
MHz
0.3
0.6
0.9
1.2
MARKER 6
MHz
1.5
-0.6
1.8
-0.8
1800
-1
S21
Log MAG
REF 0.0dB
SCALE 5.0dB/
S11
Return
Loss
10
25
30
30
S21
1500
Log MAG
2000
2500
REF 0.0dB
3000
3000
SCALE 5.0dB/
MARKER 1
2300.0 MHz
21.1 dB
MARKER 2
2400.0 MHz
18.0 dB
MARKER 3
2496.0 MHz
16.9 dB
MARKER 4
2690.0 MHz
17.2 dB
MARKER 5
MHz
dB
MARKER 6
MHz
dB
10
REF 0.0dB
2800
5
15
500
2600
RETURN LOSS
15
35
Log MAG
2400
MARKER 1
1710.0 MHz
21.0 dB
MARKER 2
1785.0 MHz
21.0 dB
ATTENUATION
2200
2000
35
3500
2000
3000
4000
5000
SCALE 5.0dB/
MARKER 1
1710.0 MHz
21.0 dB
MARKER 2
1785.0 MHz
21.0 dB
MARKER 3
2300.0 MHz
0.42 dB
MARKER 4
2690.0 MHz
0.35 dB
MARKER 5
2300.0 MHz
21.03 dB
MARKER 6
2690.0 MHz
0.35 dB
MARKER 7
0.0 MHz
0.0 dB
5
10
Attenuation
15
30
35
40
45
2000
3000
4000
5000
6000
7000
8000
9000
10000
11000
12000
13000
Oct. 2016 Ver.1.0
TDK Corporation
DEA162300HT-8047A1
■ RECOMMENDED LAND PATTERN
■ EVALUATION BOARD
Thru hole
Resist
Surface Pattern
DUT (LPF)
Material, Layer
Thickness
Top Resist
Resist
Copper Surface Pattern
0.035mm
FR-4
0.10mm
Copper Inner GND
0.018mm
FR-4
0.30mm
Copper Bottom GND
0.035mm
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Oct. 2016 Ver.1.0
TDK Corporation
DEA162300HT-8047A1
■ RECOMMENDED REFLOW PROFILE
Pb free solder
Soaking
Temp.
Time
t1
T1
T2
150°C 180°C 60 to 120sec
Temp.
T3
230°C
Working
Time
t2
more than 30sec
Soldering
Temp.
Time
T4
t3
Peak
Temp.
T5
247 to 253°C within 10sec 260°C Max.
Oct. 2016 Ver.1.0
TDK Corporation
DEA162300HT-8047A1
■ PACKAGING STYLE
Reel Dimensions
13.0+/-1.0
13+/-0.2
Label
2.0+/-0.5
60+1.0/-0
Label
21+/-0.8
180 +0/-1.5
Unit : mm
9.0 +1.0/-0
Carrier Tape
Sprocket hole
Loading Direction
J
C
A
D
E
K
B
t
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05
G
H
+/-0.05
+/-0.2
F
D
3.5
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.05
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA162300HT-8047A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.31544
- 50+1.03864
- 150+0.92006
- 500+0.77199
- 国内价格 香港价格
- 1+2.732601+0.35397
- 10+2.2479910+0.29120
- 25+2.0729325+0.26852
- 50+1.9486950+0.25243
- 100+1.83212100+0.23733
- 250+1.68913250+0.21881
- 500+1.58850500+0.20577
- 1000+1.494251000+0.19356
- 国内价格 香港价格
- 4000+1.284374000+0.16637
- 8000+1.208168000+0.15650
- 12000+1.1657012000+0.15100
- 20000+1.1143120000+0.14434
- 28000+1.0816828000+0.14012
- 40000+1.0481440000+0.13577
