Preliminary
Jul. / 2009 Ver. 2
Multilayer Band Pass Filter
DEA162450BT-1260B3
P/N:
For Bluetooth / W-LAN 2.4GHz
MECHANICAL DIMENSIONS
0.6 ± 0.1
1.6 ± 0.1
Top view
(4)
(1)
(3)
0.8 ± 0.1
(2)
Bottom view
0.25 ± 0.15
0.30 ± 0.15
(1)
(2)
(3)
(4)
IN
GND
OUT
GND
0.20 ± 0.15
0.45 ± 0.15 0.70 ± 0.15
0.20 ± 0.15
Unit : mm
Note: All specifications are subject to change and are not guaranteed.
Preliminary
Jul. / 2009 Ver. 2
ELECTRICAL CHARACTERISTICS (Ta=+25oC)
Parameter
Specification
Typical Value
Unit
2400-2500
MHz
50 (Nominal)
ohm
2.2 max
1.7
dB
2.1 max
1.4
DC – 746 MHz
20 min
28
dB
746 – 764 MHz
22 min
30
dB
776 – 794 MHz
22 min
31
dB
824 – 849 MHz
24 min
32
dB
869 – 894 MHz
24 min
33
dB
894 – 915 MHz
24 min
33
dB
925 – 960 MHz
25 min
34
dB
1570 – 1580 MHz
15 min
28
dB
1710 – 1785 MHz
10 min
21
dB
1805 – 1850 MHz
10 min
19
dB
1850 – 1910 MHz
8 min
17
dB
1920 – 1980 MHz
6 min
15
dB
2110 – 2170 MHz
3 min
8
dB
4000 – 4800 MHz
21 min
31
dB
4800 – 5000 MHz
28 min
33
dB
5000 – 7200 MHz
21 min
34
dB
7200 – 7500 MHz
25 min
40
dB
7500 – 8000 MHz
21 min
41
dB
9600 – 12415 MHz
6 min
22
dB
Frequency Range (Pass Band)
Characteristics Impedance (Pass Band)
Insertion Loss (Pass Band)
o
+25 C
VSWR (Pass Band)
Attenuation
TEMPERATURE RANGE
Storage Temperature
-40 ~ +85 °C
Operating Temperature
-40 ~ +85 °C
Preliminary
Jul. / 2009 Ver. 2
FREQUENCY RESPONSE
DEA162450BT-1260B3
22/Jun/2007
Bluetooth / W-LAN 2.45GHz 1608BPF
TDK Corporation
S11
POLA
REF 1.0 U
VSWR
1
SCALE 1.0U FS
S21
MARKER 1
2400 MHz
1.14
jV
0.8
MARKER 2
2450 MHz
1.15
0.6
0.4
MARKER 3
2500 MHz
1.31
0.2
Log MAG
REF 0.0dB
SCALE 5.0dB/
MARKER 1
2400 MHz
1.69 dB
5
3
2
MARKER 2
2450 MHz
1.58 dB
10
MARKER 3
2500 MHz
1.66 dB
15
-0.2
U
MARKER 4
MHz
MARKER 5
MHz
-0.4
-0.6
35
REF 0.0dB
SCALE 5.0dB/
S22
ATTENUATION
5
10
15
MARKER 6
MHz
dB
INSERTION LOSS
40
1900
-1
Log MAG
MARKER 5
MHz
dB
30
MARKER 6
MHz
-0.8
S12
MARKER 4
MHz
dB
25
MARKER 1
960 MHz
34.8 dB
-10
MARKER 2
1500 MHz
30.9 dB
Log MAG
2300
2500
REF 0.0dB
2700
2900
3100
SCALE 5.0dB/
MARKER 1
2400 MHz
16.1 dB
RETURN LOSS
-5
MARKER 2
2450 MHz
18.8 dB
5
MARKER 3
1600 MHz
27.2 dB
25
3
30
2
MARKER 4
3200 MHz
41.4 dB
5
35
1
6
40
MARKER 5
3500 MHz
31.7 dB
50
55
60
500
MARKER 6
4900 MHz
33.7 dB
1500
2500
3500
15
MARKER 4
MHz
dB
1
3
25
4
45
MARKER 3
2500 MHz
20.1 dB
10
4500
5500
6500
7500
8500
9500 10500
MARKER 5
MHz
dB
30
35
40
1900
MARKER 6
MHz
dB
2100
2300
2500
2700
RECOMMENDED PCB PATTERN
0.30
0.05 0.50
0.80
0.50
0.20
Unit:mm
2900
3100
很抱歉,暂时无法提供与“DEA162450BT-1260B3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.80960
- 200+0.55770
- 2000+0.50710
- 4000+0.47520
- 国内价格 香港价格
- 1+5.178901+0.67196
- 10+4.2338910+0.54935
- 25+3.9065025+0.50687
- 50+3.6730750+0.47658
- 100+3.45385100+0.44814
- 250+3.18529250+0.41329
- 500+2.99621500+0.38876
- 1000+2.818381000+0.36569
- 国内价格 香港价格
- 4000+2.422624000+0.31434
- 8000+2.278848000+0.29568
- 12000+2.1987012000+0.28528
- 20000+2.1016820000+0.27269
- 28000+2.0400628000+0.26470
- 40000+1.9767140000+0.25648
- 国内价格
- 1+1.40249
- 10+1.11456
- 30+0.99123
- 100+0.83722
- 400+0.76875
- 800+0.72760
