DEA162450BT-7219A1
DEA162450BT-7219A1
    TDK(东电化)
    SMD-6P,0.8x1.6mm
DEA162450BT-7219A1 数据手册
R F C o m p o n e n t s August 2018 Multilayer Band Pass Filter (Balance Output Type) For 2400-2500MHz DEA162450BT-7219A1 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] RF Components Multilayer Band Pass Filter (Balance Output Type) Conformity to RoHS Directive For 2400-2500MHz DEA162450BT-7219A1 SHAPES AND DIMENSIONS [Top view] 1.60±0.15 (5) (1) (2) 0.60±0.10 (4) 0.80±0.15 (6) (3) Marking [Bottom view] 0.25±0.10 0.15±0.10 0.55±0.10 0.10 +0.15 –0.10 Terminal functions 1 Unbalanced port 2 GND 3 Balanced port1 4 Balanced port2 5 GND 6 GND Dimensions in mm 0.30±0.10 RECOMMENDED LAND PATTERN 0.625 1.7 0.45 1.45 0.35 0.20 Dimensions in mm RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180806 / rf_bpf_dea162450bt-7219a1_en.fm RF Components DEA162450BT-7219A1 ELECTRICAL CHARACTERISTICS Frequency Range (MHz) Item Min. Unbalanced Port Characteristic Impedance () Balanced Port Characteristic Impedance () Insertion Loss (dB) Attenuation (dB) Return Loss at Unbalanced Port (dB) Phase Balance (deg.) Amplitude Balance (dB) 2400 to 2500 4800 to 5000 7200 to 7500 2400 to 2500 2400 to 2500 2400 to 2500 — 20 20 10 165 –2 Typ. 50 (Nominal) Matched to TICC253x series 40+j26 1.36 26 35 22 175 –0.9 Max. 1.75 — — — 195 2 ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180806 / rf_bpf_dea162450bt-7219a1_en.fm RF Components DEA162450BT-7219A1 FREQUENCY CHARACTERISTICS SDS21 ATTENUATION 0 0 1 10 SDS21 Attenuation(dB) SDS21 Insertion Loss(dB) SDS21 INSETION LOSS 2 3 50 2200 2400 2600 Frequency (MHz) 2800 3000 SSS11 RETURN LOSS at UNBALANCE PORT 1000 2000 3000 4000 5000 Frequency (MHz) 6000 7000 8000 0 SDD22 Return Loss at Balanced Port(dB) SSS11 Return Loss at Unbalanced Port(dB) 0 SDD22 RETURN LOSS at BALANCE PORT 0 10 20 30 40 50 2000 30 40 4 5 2000 20 2200 2400 2600 Frequency (MHz) 2800 10 20 30 40 50 2000 3000 AMPLITUDE BALANCE 2200 2400 2600 Frequency (MHz) 2800 3000 2400 2600 Frequency (MHz) 2800 3000 PHASE BALANCE 200 3 195 2 1 Phase Balance(deg) Amplitude Balance(dB) 190 0 –1 185 180 175 170 –2 –3 2000 165 2200 2400 2600 Frequency (MHz) 2800 3000 160 2000 2200 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180806 / rf_bpf_dea162450bt-7219a1_en.fm RF Components DEA162450BT-7219A1 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180806 / rf_bpf_dea162450bt-7219a1_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20180806 / rf_bpf_dea162450bt-7219a1_en.fm
DEA162450BT-7219A1 价格&库存
很抱歉,暂时无法提供与“DEA162450BT-7219A1”相匹配的价格&库存,您可以联系我们找货
DEA162450BT-7219A1
  • 1+2.608411+0.32710
  • 10+2.0867310+0.26168
  • 25+1.9249025+0.24139
  • 50+1.8094950+0.22692
  • 100+1.70164100+0.21339
  • 250+1.56892250+0.19675
  • 500+1.47572500+0.18506
  • 1000+1.388121000+0.17408
库存:11996
DEA162450BT-7219A1
  • 4000+1.228244000+0.15403
  • 8000+1.155378000+0.14489
  • 12000+1.1147612000+0.13980
  • 20000+1.0656220000+0.13363
  • 28000+1.0344128000+0.12972
  • 40000+1.0023340000+0.12570
库存:11996
DEA162450BT-7219A1
  • 4000+0.938274000+0.11766
  • 8000+0.929428000+0.11655
  • 12000+0.9205612000+0.11544
  • 16000+0.9162216000+0.11490
  • 20000+0.9028620000+0.11322
库存:16000
