DEA162495BT-1289A1
DEA162495BT-1289A1
    TDK(东电化)
DEA162495BT-1289A1 数据手册
R F C o m p o n e n t s June 2015 Multilayer Band Pass Filter For 2300-2690MHz DEA162495BT-1289A1 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] RF Components Multilayer Band Pass Filter Conformity to RoHS Directive For 2300-2690MHz DEA162495BT-1289A1 SHAPES AND DIMENSIONS [Top view] 0.60±0.10 (1) (3) Marking 0.25±0.15 (2) [Bottom view] 0.70±0.15 0.30±0.15 0.20±0.15 0.80±0.15 1.60±0.10 (4) 0.20±0.15 Terminal functions 1 IN 2 GND 3 OUT 4 GND 0.45±0.15 Dimensions in mm RECOMMENDED LAND PATTERN 0.80 0.20 0.05 0.30 0.50 0.50 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea162495bt-1289a1_en.fm RF Components DEA162495BT-1289A1 ELECTRICAL CHARACTERISTICS Item Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 2300 to 2690 2300 to 2690 100 to 1800 3600 to 4000 — 10 12 25 1.4 23.8 17 33 50 (Nominal) 2.0 — — — Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea162495bt-1289a1_en.fm RF Components DEA162495BT-1289A1 FREQUENCY CHARACTERISTICS INSERTION LOSS ATTENUATION 0 0 5 10 1 20 Attenuation(dB) Insertion Loss (dB) 15 2 3 25 30 35 40 45 4 50 55 5 2000 2200 2400 2600 Frequency (MHz) 2800 3000 2400 2600 Frequency (MHz) 2800 3000 60 500 1500 2500 3500 4500 5500 Frequency (MHz) 6500 7500 RETURN LOSS –10 –5 0 Return Loss(dB) 5 10 15 20 25 30 35 40 2000 2200 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea162495bt-1289a1_en.fm RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea162495bt-1289a1_en.fm
DEA162495BT-1289A1
1. 物料型号:DEA162495BT-1289A1 2. 器件简介:这是一个多层带通滤波器,尺寸为1.6x0.8mm,符合EIA 0603标准。 3. 引脚分配:IN(输入)、GND(地)、OUT(输出),其中GND有两个引脚。 4. 参数特性: - 插入损耗:在2300至2690MHz频率范围内,最小值为1.4dB,典型值为2.0dB。 - 回波损耗:在2300至2690MHz频率范围内,最小值为10dB,典型值为23.8dB。 - 衰减:在100至1800MHz频率范围内,最小值为12dB,典型值为17dB;在3600至4000MHz,最小值为25dB,典型值为33dB。 - 特性阻抗:标称值为50欧姆。 5. 功能详解:文档提供了插入损耗、衰减和回波损耗的频率特性图。 6. 应用信息:适用于一般电子设备,如音视频设备、通信设备、家用电器等,但不适合用于需要更高安全或可靠性水平的特定应用,如航空、医疗设备等。 7. 封装信息:符合RoHS指令,详细信息可在TDK官网查询。 8. 推荐回流焊接曲线:提供了预热、焊接和峰值温度的具体参数。
DEA162495BT-1289A1 价格&库存
很抱歉,暂时无法提供与“DEA162495BT-1289A1”相匹配的价格&库存,您可以联系我们找货
DEA162495BT-1289A1
    • 1+0.72930
    • 200+0.50380
    • 2000+0.45760
    • 4000+0.42790
    库存:6306
    DEA162495BT-1289A1
    • 4000+1.228244000+0.15403
    • 8000+1.155378000+0.14489
    • 12000+1.1147612000+0.13980
    • 20000+1.0656220000+0.13363
    • 28000+1.0344128000+0.12972
    • 40000+1.0023340000+0.12570
    库存:2784
    DEA162495BT-1289A1
    • 1+2.523241+0.31642
    • 10+2.0505310+0.25714
    • 25+1.8887025+0.23685
    • 50+1.7735150+0.22240
    • 100+1.66842100+0.20923
    • 250+1.53835250+0.19291
    • 500+1.44676500+0.18143
    • 1000+1.360881000+0.17066
    库存:2784
