The products in this catalog are not recommended for new design
R F
C o m p o n e n t s
June 2015
Multilayer Low Pass Filter
For 2300-2690MHz
DEA162690LT-1217A2
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 2300-2690MHz
DEA162690LT-1217A2
SHAPES AND DIMENSIONS
[Top view]
1.60±0.10
(2)
(4)
(5)
(1)
0.80±0.10
(3)
0.60±0.10
(6)
Marking
[Bottom view]
0.55±0.10
0.15±0.10
Terminal functions
1 GND
2 IN
3 GND
4 GND
5 OUT
6 GND
0.10±0.10
Dimensions in mm
0.30±0.10
RECOMMENDED LAND PATTERN
EVALUATION BOARD
2.60
0.70
0.65
0.20
0.35
Dimensions in mm
0.25
1.00
0.65
0.25
4-ø0.30 Through-hole
0.25
0.30
Land
Solder resist
Line width be designed to match 50Ω
characteristic impedance depending
on PCB material and thickness.
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150601 / rf_lpf_dea162690lt-1217a2_en.fm
RF Components
DEA162690LT-1217A2
ELECTRICAL CHARACTERISTICS
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
2300 to 2690
2300 to 2690
4600 to 5400
6900 to 8070
10
25
25
0.32
22
45
33
50 (Nominal)
0.8
Characteristic Impedance (:)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DEA162690LT-1217A2
FREQUENCY CHARACTERISTICS
ATTENUATION
0.0
10
1.0
Attenuation(dB)
Insertion Loss (dB)
INSERTION LOSS
1.5
30
2.0
40
2.5
50
3.0
2000
2200
2400
2600
Frequency (MHz)
2800
3000
60
2000
3000
4000
5000
6000
7000
Frequency (MHz)
8000
9000
10000
RETURN LOSS
–40
–30
Return Loss(dB)
–20
–10
40
2000
3000
4000
5000
6000
7000
Frequency (MHz)
8000
9000
10000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA162690LT-1217A2”相匹配的价格&库存,您可以联系我们找货
