Nov. 2014 Ver.3.0
TDK-EPC Corporation
Multilayer Low Pass Filter
For LTE
DEA Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DEA162690LT-5051B1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Nov. 2014 Ver.3.0
TDK-EPC Corporation
DEA162690LT-5051B1
■ SHAPES AND DIMENSIONS
[Top View]
[Bottom View]
4
3
(W)
1
(a)
(b)
2
(c)
(L)
(d)
(e)
[Side View]
(T)
Dimensions (mm)
L
W
T
a
b
c
d
e
f
1.60 0.80 0.60 0.21 0.22 0.40 0.30 0.225 0.65
+/-0.10 +/-0.10 +/-0.10 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05
Terminal functions
In/Out Port
(1)
GND
(2)
Out/In Port
(3)
GND
(4)
■ TEMPERATURE RANGE
Operating temperature
–40 to +85 °C
Storage temperature
–40 to +85 °C
(f)
Nov. 2014 Ver.3.0
TDK-EPC Corporation
DEA162690LT-5051B1
■ ELECTRICAL CHARACTERISTICS
Parameter
Frequency (MHz)
( Measurement )
TDK Spec
Typ.
0.37
Max.
0.50
Insertion Loss (dB)
673 to
2690
Min.
Insertion Loss (dB)
( –40 to +85 °C )
Ripple (dB)
(Over any 200 MHz range)
G.D.Ripple (ns)
(Over any 20 MHz range)
VSWR
673 to
2690
0.60
673 to
2690
0.07
0.20
673 to
2690
0.01
673 to
2690
1.5
2.0
35
45
42
49
50 (Nominal)
35
Attenuation (dB)
Power Handling (dBm)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
4950 to 6000
6000 to 12750
Nov. 2014 Ver.3.0
TDK-EPC Corporation
DEA162690LT-5051B1
■ FREQUENCY CHARACTERISTICS
S11
POLA
REF 1.0 U
SCALE 1.0U FS
S21
REF 0.0dB
SCALE 0.5dB/
INSERTION LOSS
VSWR
0.8
0.6
0.4
0.2
Log MAG
0.0
1 jV
U
1
MARKER 1
673 MHz
1.15
MARKER 2
960 MHz
1.28
MARKER 3
1710 MHz
1.46
MARKER 4
2170 MHz
1.19
MARKER 5
MHz
0.5
1.0
1.5
2.0
MARKER 6
MHz
-0.4
MARKER 1
673 MHz
0.096 dB
MARKER 2
960 MHz
0.160 dB
MARKER 3
1710 MHz
0.305 dB
MARKER 4
2170 MHz
0.263 dB
MARKER 5
2300 MHz
0.264 dB
MARKER 6
2690 MHz
0.368 dB
2.5
-0.6
-0.8
3.0
500
-1
S21
Log MAG
REF 0.0dB
SCALE 10.0dB/
S11
1500
Log MAG
2000
2500
REF 0.0dB
3000
3500
4000
SCALE 5.0dB/
ATTENUATION
10
40
50
60
70
80
500
2000
3500
5000
6500
8000
9500
11000
12500
14000
MARKER 1
4950 MHz
42.3 dB
MARKER 2
6000 MHz
49.0 dB
MARKER 3
8500 MHz
61.5 dB
MARKER 4
12750 MHz
60.0 dB
MARKER 5
0.0 MHz
#N/A dB
MARKER 6
0.0 MHz
#N/A dB
MARKER 7
0.0 MHz
#N/A dB
MARKER 8
0.0 MHz
#N/A dB
RETURN LOSS
5
10
15
30
35
40
45
50
500
1000
1500
2000
2500
3000
3500
4000
MARKER 1
673 MHz
23.1 dB
MARKER 2
960 MHz
18.3 dB
MARKER 3
1710 MHz
14.6 dB
MARKER 4
2170 MHz
21.2 dB
MARKER 5
2300 MHz
26.3 dB
MARKER 6
2690 MHz
20.9 dB
Nov. 2014 Ver.3.0
TDK-EPC Corporation
DEA162690LT-5051B1
■ RECOMMENDED LAND PATTERN
Unit : [mm]
■ EVALUATION BOARD
Thru hole
Resist
Surface Pattern
DUT (LPF)
Material, Layer
Thickness
Top Resist
Resist
Cupper Surface Pattern
0.035mm
FR-4
0.10mm
Cupper Inner GND
0.018mm
FR-4
0.30mm
Cupper Bottom GND
0.035mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Nov. 2014 Ver.3.0
TDK-EPC Corporation
DEA162690LT-5051B1
■ RECOMMENDED REFLOW PROFILE
Pb free solder
Soaking
Temp.
Time
t1
T1
T2
150°C 180°C 60 to 120sec
Temp.
T3
230°C
Working
Time
t2
more than 30sec
Soldering
Temp.
Time
T4
t3
Peak
Temp.
T5
247 to 253°C within 10sec 260°C Max.
Nov. 2014 Ver.3.0
TDK-EPC Corporation
DEA162690LT-5051B1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA162690LT-5051B1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.27894
- 100+0.25956
- 300+0.24019
- 500+0.22082
- 2000+0.21114
- 5000+0.20533
- 国内价格
- 4000+1.09978
- 8000+1.03136
- 12000+0.96195
- 28000+0.91377
