DEA202400HT-8037A1
DEA202400HT-8037A1
    TDK(东电化)
DEA202400HT-8037A1 数据手册
Jan. 2017 Ver.2.0.a TDK Corporation Multilayer High Pass Filter For 2.4GHz W-LAN & Bluetooth DEA Series P/N: 2.0x1.25mm [EIA 0805] TYPE DEA202400HT-8037A1 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   Jan. 2017 Ver.2.0.a TDK Corporation DEA202400HT-8037A1 ■ SHAPES AND DIMENSIONS Dimensions (mm) L W T a b c d 2.00 1.25 0.90 0.275 0.25 0.60 0.95 +/-0.15 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 Terminal functions Input Port (1) GND (2) Output Port (3)             ■ TEMPERATURE RANGE Operating temperature –40 to +85 °C Storage temperature –40 to +85 °C All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   Jan. 2017 Ver.2.0.a TDK Corporation DEA202400HT-8037A1 ■ ELECTRICAL CHARACTERISTICS Parameter Insertion Loss (dB) Attenuation (dB) Characteristic Impedance (ohm) Ta = +25+/-5°C ( Measurement ) TDK Spec Min. Typ. Max. 2400 to 5850 0.35 0.50 1610 30 47 50 (Nominal) Frequency (MHz) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   Jan. 2017 Ver.2.0.a TDK Corporation DEA202400HT-8037A1 ■ FREQUENCY CHARACTERISTICS S11 POLA REF 1.0 U 1 VSWR SCALE 1.0U FS S21 Log MAG REF 0.0dB 0 jV 1 MARKER 1 2400 MHz 1.07 0.8 SCALE 1dB/ MARKER 1 2400 MHz 0.30 dB 2 3 MARKER 2 4125 MHz 0.18 dB 1 0.6 MARKER 2 4125 MHz 1.19 0.4 0.2 0 1 -0.2 -0.4 -0.8 3 MARKER 6 0 MHz #N/A -1 Log MAG MARKER 4 0 MHz #N/A MARKER 5 0 MHz #N/A -0.6 S21 2 MARKER 2 5850 MHz 0.35 dB U 0 -1 MARKER 3 5850 MHz 1.22 REF 0.0dB SCALE 5.0dB/ #N/A dB MARKER 5 0 MHz #N/A dB 4 5 2000 2500 S11 0 MARKER 1 1510 MHz 46.8 dB 3 5 10 MARKER 2 1610 MHz 47.7 dB 15 20 MARKER 6 0 MHz #N/A dB INSERTION LOSS 3000 Log MAG 3500 4000 4500 REF -10.0dB 5000 5500 6000 6500 SCALE 5.0dB/ 0 MARKER 1 2400 MHz 30.0 dB 5 10 MARKER 2 4125 MHz 21.4 dB 15 20 MARKER 3 0 MHz #N/A dB 25 30 MARKER 2 5850 MHz 20.3 dB 3 2 25 30 MARKER 4 0 MHz 0.0 dB 35 40 45 1 50 2 55 ATTENUATION 60 500 S21 1000 Log MAG 1500 2000 REF 0.0dB 2500 3000 3500 4000 1 35 0 MHz #N/A dB 40 MARKER 5 0 MHz 0.0 dB 45 MARKER 6 0 MHz 0.0 dB 55 MARKER 5 0 MHz #N/A dB 50 RETURN LOSS 60 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 MARKER 6 0 MHz #N/A dB SCALE 5.0dB/ 0 3 MARKER 7 1510 MHz 46.8 dB 5 4 5 ATTENUATION 10 MARKER 8 1610 MHz 47.7 dB 15 20 MARKER 9 2400 MHz 0.30 dB 25 30 MARKER 10 4125 MHz 0.18 dB 35 40 MARKER 11 5850 MHz 0.35 dB 45 1 50 2 MARKER 12 0 MHz #N/A dB 55 60 500 1500 2500 3500 4500 5500 6500 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   Jan. 2017 Ver.2.0.a TDK Corporation DEA202400HT-8037A1 ■ RECOMMENDED LAND PATTERN ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies TDK Corporation ■ RECOMMENDED REFLOW PROFILE Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   Jan. 2017 Ver.2.0.a TDK Corporation DEA202400HT-8037A1 ■ PACKAGING STYLE Reel Dimensions 13+/-0.2 13.0+/-1.0 2.0+/-0.5 60+1.0/-0.0 Label 21+/-0.8 Unit: mm 180+0/-1.5 9+1.0/-0.0 Carrier Tape STANDARD PACKAGE QUANTITY ( pieces/reel ) 2,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DEA202400HT-8037A1
物料型号:DEA202400HT-8037A1
器件简介:这是TDK公司生产的一款用于2.4GHz无线局域网和蓝牙的多层高通滤波器。产品尺寸为2.0x1.25mm(EIA 0805)。
引脚分配: - (1) 输入端口 - (2) 地线(GND) - (3) 输出端口
参数特性: - 工作温度范围:-40到+85°C - 存储温度范围:-40到+85°C - 插入损耗:在2400到5850MHz频率范围内最小值为0.35dB,典型值为0.50dB - 衰减:在1610MHz频率下为30dB到47dB - 特性阻抗:50欧姆(标称值)
功能详解: - 该滤波器在2400MHz频率下具有30dB的衰减,用于抑制较低频率的信号,同时允许较高频率的信号通过。 - 插入损耗和衰减特性在数据表中通过图表展示,显示了频率与插入损耗和衰减的关系。
应用信息: - 该滤波器适用于一般电子设备,如音视频设备、电信设备、家用电器、娱乐设备、计算机设备、个人设备、办公设备、测量设备和工业机器人。 - 明确指出不适用于需要更高安全或可靠性水平的应用程序,如航空/航空设备、交通设备、医疗设备、发电控制设备、核能相关设备、海底设备、交通控制设备、公共信息处理设备、军事设备、电加热设备、燃烧设备、防灾/防盗设备、安全设备等。
封装信息: - 推荐回流焊温度曲线,包括预热、焊接和峰值温度。 - 包装风格:卷轴尺寸和载体带尺寸。 - 标准包装数量:每卷2000件。
环境信息: - RoHS声明:符合RoHS标准。
使用提醒: - 在使用这些产品之前,确保请求交付规格。 - 安全提醒:在使用这些产品时,请注意安全设计警告。
DEA202400HT-8037A1 价格&库存
很抱歉,暂时无法提供与“DEA202400HT-8037A1”相匹配的价格&库存,您可以联系我们找货
DEA202400HT-8037A1
  • 1+3.106201+0.40236
  • 10+2.5297910+0.32770
  • 25+2.3325325+0.30215
  • 50+2.1933450+0.28412
  • 100+2.06247100+0.26717
  • 250+1.90206250+0.24639
  • 500+1.78900500+0.23174
  • 1000+1.682821000+0.21799
库存:3102
DEA202400HT-8037A1
  • 2000+1.537712000+0.19919
  • 4000+1.446494000+0.18737
  • 6000+1.395646000+0.18079
  • 10000+1.3341410000+0.17282
  • 14000+1.2951014000+0.16776
  • 20000+1.2549620000+0.16256
库存:3102
