DEA202450BT-3201B2
DEA202450BT-3201B2
    TDK(东电化)
    2400-2500MHZ多层带通滤波器
DEA202450BT-3201B2 数据手册
R F C o m p o n e n t s June 2015 Multilayer Band Pass Filter For 2400-2500MHz DEA202450BT-3201B2 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] Caution The products in this catalog will be or have been stopped production Discontinue Issue Date Jun. 3, 2022 Last Purchase Order Date Mar. 31, 2023 Last Shipment Date Mar. 31, 2024 Please refer to our Web site about replacement information. RF Components Multilayer Band Pass Filter Conformity to RoHS Directive For 2400-2500MHz pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en DEA202450BT-3201B2 SHAPES AND DIMENSIONS [Top view] 2.00±0.20 0.80max. (5) (4) (1) (2) (3) 1.25±0.20 (6) Marking 0.40±0.20 0.40±0.20 Terminal functions 1 GND 2 IN 3 GND 4 GND 5 OUT 6 GND 0.20±0.10 [Bottom view] Dimensions in mm 0.30±0.20 RECOMMENDED LAND PATTERN EVALUATION BOARD 1.60 0.30 0.65 1.55 1.35 0.45 ø0.30 0.50 1.00 2.20 Dimensions in mm Th e 0.35 0.95 1.65 Line width be designed to match 50Ω characteristic impedance depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea202450bt-3201b2_en.fm RF Components DEA202450BT-3201B2 ELECTRICAL CHARACTERISTICS Insertion Loss (dB) Return Loss (dB) Attenuation (dB) Frequency Range (MHz) Min. Typ. Max. 2400 to 2500 2400 to 2500 880 to 915 1710 to 1850 1850 to 1910 1920 to 1990 2110 to 2170 4800 to 5000 7200 to 7500 — 10 40 40 40 40 26 30 30 — — — — — — — — — 50 (Nominal) 2.5 — — — — — — — — pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Item Characteristic Impedance (:) ・Ta: +25±5°C TEMPERATURE RANGE Storage temperature (°C) –40 to +85 Th e Operating temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea202450bt-3201b2_en.fm RF Components DEA202450BT-3201B2 FREQUENCY CHARACTERISTICS ATTENUATION pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en INSERTION LOSS 0 0 0.5 10 1.0 20 Attenuation(dB) Insertion Loss (dB) 1.5 2.0 2.5 3.0 3.5 30 40 50 4.0 60 4.5 5.0 2200 2300 2400 2500 Frequency (MHz) 2600 2700 70 500 1500 2500 3500 4500 5500 Frequency (MHz) 6500 7500 RETURN LOSS 0 5 10 Return Loss(dB) 15 20 25 30 35 40 45 2200 2300 2400 2500 Frequency (MHz) 2600 2700 2800 Th e 50 2100 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea202450bt-3201b2_en.fm RF Components pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T1 t1 T3 t3 t2 t: Time Preheating Temp. T1 150°C t3 T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Th e : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Th e When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea202450bt-3201b2_en.fm
DEA202450BT-3201B2 价格&库存
很抱歉,暂时无法提供与“DEA202450BT-3201B2”相匹配的价格&库存,您可以联系我们找货
