DEA202450BT-7116E1
DEA202450BT-7116E1
    TDK(东电化)
DEA202450BT-7116E1 数据手册
R F C o m p o n e n t s June 2015 Multilayer Band Pass Filter (Balance Output Type) For 2400-2500MHz DEA202450BT-7116E1 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] Caution The products in this catalog will be or have been stopped production Discontinue Issue Date Jun. 3, 2022 Last Purchase Order Date Mar. 31, 2023 Last Shipment Date Mar. 31, 2027 Please refer to our Web site about replacement information. RF Components Multilayer Band Pass Filter (Balance Output Type) Conformity to RoHS Directive For 2400-2500MHz pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en DEA202450BT-7116E1 SHAPES AND DIMENSIONS [Top view] 2.00±0.15 (8) (5) (4) (1) (2) 0.65±0.15 (3) Marking 0.30±0.20 Terminal functions 1 Unbalanced port 2 DC feed + RF GND or GND 3 N.C. 4 GND 5 Balanced port 6 GND 7 Balanced port 8 GND 0.30±0.20 0.25±0.20 [Bottom view] (6) 1.25±0.15 (7) 0.95±0.10 0.20±0.20 0.25±0.20 Dimensions in mm 0.35±0.15 RECOMMENDED LAND PATTERN EVALUATION BOARD 0.35 0.60 Port extension value is 139.56ps for all port. 0. 0.40 0. 35 35 65 0. 0.20 75 0. 1. 00 0.35 60 1. 1.95 40 0. 0.65 0.70 Dimensions in mm 25 35 35 0. Line width be designed to match 50Ω characteristic impedance depending on PCB material and thickness. 2. 0. 30 30 0. ø0.30 0. 0 0.6 30 0 0.7 Th e 2.60 0. 0.55 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150605 / rf_bpf_dea202450bt-7116e1_en.fm RF Components DEA202450BT-7116E1 ELECTRICAL CHARACTERISTICS Min. Typ. Max. — — 40 25 25 15 9 9 165 –1.5 50 (Nominal) 50 (Nominal) — — — — — — — — — — 2.0 2.3 (–40 to +85°C) — — — — — — 195 1.5 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Frequency Range (MHz) Item Unbalanced Port Characteristic Impedance (:) Balanced Port Characteristic Impedance (:) Insertion Loss (dB) Attenuation (dB) Return Loss at Unbalanced Port (dB) Return Loss at Balanced Port (dB) Phase Balance (deg.) Amplitude Balance (dB) ・Ta: +25±5°C 2400 to 2500 2400 to 2500 10 to 960 1710 to 1910 4800 to 5000 7200 to 7500 2400 to 2500 2400 to 2500 2400 to 2500 2400 to 2500 TEMPERATURE RANGE Storage temperature (°C) –40 to +85 Th e Operating temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150605 / rf_bpf_dea202450bt-7116e1_en.fm RF Components DEA202450BT-7116E1 FREQUENCY CHARACTERISTICS 0.0 SDS21 ATTENUATION pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SDS21 INSERTION LOSS 0 0.5 10 1.0 20 Attenuation(dB) Insertion Loss (dB) 1.5 2.0 2.5 3.0 3.5 30 40 50 4.0 60 4.5 5.0 2000 2100 2200 2300 2400 2500 2600 Frequency (MHz) 2700 2800 2900 70 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000 Frequency (MHz) 3000 SSS11 RETURN LOSS at UNBALANCE PORT 0 0 5 5 10 Return Loss (dB) Return Loss (dB) 10 15 20 25 30 2000 SDD22 RETURN LOSS at BALANCE PORT 15 20 25 2100 2200 2300 2400 2500 2600 Frequency (MHz) 2700 2800 2900 30 2000 3000 PHASE BALANCE 200 2100 2200 2300 2400 2500 2600 Frequency (MHz) 2700 2800 2900 3000 2400 2500 2600 Frequency (MHz) 2700 2800 2900 3000 AMPLITUDE BALANCE 3.0 2.5 195 2.0 185 180 Amplitude Balance (dB) 1.5 Th e Phase Balance (deg.) 190 175 170 1.0 0.5 0 –0.5 –1.0 –1.5 –2.0 165 160 2000 2100 2200 2300 –2.5 2400 2500 2600 Frequency (MHz) 2700 2800 2900 3000 –3.0 2000 2100 2200 2300 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150605 / rf_bpf_dea202450bt-7116e1_en.fm RF Components pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T1 t1 T3 t3 t2 t: Time Preheating Temp. T1 150°C t3 T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Th e : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Th e When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150605 / rf_bpf_dea202450bt-7116e1_en.fm
DEA202450BT-7116E1
1. 物料型号:DEA202450BT-7116E1 2. 器件简介:这是一个多层带通滤波器,具有平衡输出,适用于2400-2500MHz的频段。 3. 引脚分配:文档中提到了未平衡端口、平衡端口和GND,但具体的引脚分配图没有直接提供。 4. 参数特性: - 尺寸:2.0x1.25mm [EIA 0805] - 工作温度范围:-40°C 至 +85°C - 存储温度范围:-40°C 至 +85°C 5. 功能详解: - 插入损耗:在2400至2500MHz范围内,典型值为2.0dB。 - 衰减:在不同频段有不同的衰减值,例如在10至960MHz为40dB,在1710至1910MHz为25dB。 - 回波损耗:在2400至2500MHz范围内,未平衡端口和平衡端口的回波损耗均为9dB。 - 相位平衡和幅度平衡:在2400至2500MHz范围内,相位平衡的典型值为195度,幅度平衡的典型值为1.5dB。 6. 应用信息:适用于一般电子设备,如AV设备、通信设备、家用电器等,但不适合用于需要更高安全或可靠性等级的特定应用,例如航空、医疗设备、核能相关设备等。 7. 封装信息:封装尺寸为2.0x1.25mm [EIA 0805],符合RoHS指令。
DEA202450BT-7116E1 价格&库存
很抱歉,暂时无法提供与“DEA202450BT-7116E1”相匹配的价格&库存,您可以联系我们找货
DEA202450BT-7116E1
    • 1+1.25324
    • 10+1.00116
    • 30+0.89306
    库存:2
