DEA204480BT-3019B2
DEA204480BT-3019B2
    TDK(东电化)
DEA204480BT-3019B2 数据手册
The products in this catalog are not recommended for new design R F C o m p o n e n t s June 2015 Multilayer Band Pass Filter For 4200-4760MHz DEA204480BT-3019B2 2.0x1.25mm [EIA 0805]* * Dimensions Code JIS[EIA] The products in this catalog are not recommended for new design RF Components Multilayer Band Pass Filter Conformity to RoHS Directive For 4200-4760MHz DEA204480BT-3019B2 SHAPES AND DIMENSIONS [Top view] (1) 1.25±0.15 0.50±0.05 2.00±0.15 (4) (3) (2) Marking [Bottom view] 0.35±0.15 0.25±0.15 1.60±0.15 Terminal functions 1 IN/(OUT) 2 GND 3 OUT/(IN) 4 GND 0.25±0.15 Dimensions in mm RECOMMENDED LAND PATTERN 2.60 1.50 0.75 0.35 0.55 1.70 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea204480bt-3019b2_en.fm The products in this catalog are not recommended for new design RF Components DEA204480BT-3019B2 ELECTRICAL CHARACTERISTICS Item Insertion Loss (dB) Return Loss (dB) Ripple (dB) Attenuation (dB) Group Delay Ripple (ns) Characteristic Impedance (:) Frequency Range (MHz) Min. Typ. Max. 4200 to 4760 4200 to 4760 4200 to 4760 4200 to 4760 DC to 2000 2400 to 2500 3200 to 3800 5150 5160 to 5170 5170 to 5850 8960 4200 to 4760 — — 9.54 — 40 40 20 18 22.5 28 30 — 2.52 — 16.5 0.65 53.5 63.1 29.1 46.3 56.5 35.8 41.6 0.26 50 (Nominal) 3.3 3.6 (–40 to +85°C) — 2.2 — — — — — — — 0.60 ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea204480bt-3019b2_en.fm The products in this catalog are not recommended for new design RF Components DEA204480BT-3019B2 FREQUENCY CHARACTERISTICS INSERTION LOSS ATTENUATION 0 0.0 0.5 10 1.0 20 Attenuation(dB) Insertion Loss (dB) 1.5 2.0 2.5 3.0 3.5 30 40 50 4.0 60 4.5 5.0 3500 4000 4500 Frequency (MHz) 5000 70 500 5500 VSWR 1500 2500 3500 4500 5500 6500 Frequency (MHz) 7500 8500 9500 GROUP DELAY 5.0 2.0 1.8 1.6 4.0 Group Delay(ns) VSWR 1.4 3.0 1.2 1.0 0.8 0.6 2.0 0.4 0.2 1.0 3000 3500 4000 4500 Frequency (MHz) 5000 5500 6000 0.0 4000 4200 4400 4600 Frequency (MHz) 4800 5000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea204480bt-3019b2_en.fm The products in this catalog are not recommended for new design RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. The products in this catalog are not recommended for new design RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20150601 / rf_bpf_dea204480bt-3019b2_en.fm
DEA204480BT-3019B2 价格&库存
很抱歉,暂时无法提供与“DEA204480BT-3019B2”相匹配的价格&库存,您可以联系我们找货
