Oct. 2020 Ver.1.4
TDK Corporation
Multilayer Band Pass Filter
For 5G-H
DEA Series
P/N:
2.0x1.25mm [EIA 0805] TYPE
DEA204700BT-2307A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Oct. 2020 Ver.1.4
TDK Corporation
DEA204700BT-2307A1
■ SHAPES AND DIMENSIONS
(6) (5)
(1)
(5) (6)
(4)
(4)
(1)
(3) (2)
(2) (3)
Dimensions (mm)
L
W
T
a
b
c
d
2.00 1.25 0.65 0.275 0.25 0.60 0.95
+/-0.15 +/-0.10
Max
+/-0.10 +/-0.10 +/-0.10 +/-0.15
Terminal functions
Input Port
(1)
GND
(2)
GND
(3)
(4)
(5)
(6)
Output Port
GND
GND
■ TERMINATION FINISH
Material
Ag
Oct. 2020 Ver.1.4
TDK Corporation
DEA204700BT-2307A1
■ ELECTRICAL CHARACTERISTICS
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
( Input / Output Port )
Attenuation (dB)
( Measurement )
TDK
Spec.
Min. Typ. Max.
5000 0.64 0.85
5000 1.08
5000 10 21.0
1606 20 22.6
2400 23 27.2
2500 23 37.2
2690 21 27.0
3150 5 24.5
3800 13 17.0
4200 0.7 1.5
10000 15 23.4
15000 15 18.0
50 (Nominal)
Frequency (MHz)
4400 to
4400 to
to
4400 to
to
500 to
1606 to
2400 to
2500 to
2700 to
3300 to
3800 to
8800 to
13200 to
Characteristic Impedance (ohm)
Ta = +25+/-5°C
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W)
TDK Spec
Min. Max.
Conditions
–40 to +90 °C
–40 to +90 °C
2 CW
Human Body Model : HBM
@Each Port (V) -1000 1000 100pF / 1500ohm
Machine Model : MM
@Each Port (V) -150 150 200pF / 0ohm
Charged Device Model : CDM @Each Port (V) -500 500 Relative humidity : 60%RH max
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
Oct. 2020 Ver.1.4
TDK Corporation
DEA204700BT-2307A1
■ FREQUENCY CHARACTERISTICS
Oct. 2020 Ver.1.4
TDK Corporation
DEA204700BT-2307A1
■ RECOMMENDED LAND PATTERN
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Oct. 2020 Ver.1.4
TDK Corporation
DEA204700BT-2307A1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
Oct. 2020 Ver.1.4
TDK Corporation
DEA204700BT-2307A1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Dimensions (mm)
A
B
C
D
1.45 2.2 8.0 3.5
+/-0.05
+/-0.05 +0.3/-0.1 +/-0.05
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
Max.
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
2,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA204700BT-2307A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.14902
- 50+0.91217
- 150+0.81065
- 500+0.68408
- 国内价格 香港价格
- 1+2.853121+0.35793
- 10+2.2856710+0.28674
- 25+2.1104725+0.26476
- 50+1.9834550+0.24883
- 100+1.86478100+0.23394
- 250+1.71931250+0.21569
- 500+1.61719500+0.20288
- 1000+1.521221000+0.19084
- 国内价格 香港价格
- 2000+1.459542000+0.18310
- 4000+1.372944000+0.17224
- 6000+1.324706000+0.16619
- 10000+1.2663110000+0.15886
- 14000+1.2292614000+0.15421
- 20000+1.1911620000+0.14943
- 50000+1.0985350000+0.13781
- 国内价格
- 1+0.93363
- 10+0.79080
- 100+0.72459
- 500+0.61163
- 1000+0.55006
- 2000+0.49855
