DEA211898BT-9033B1
DEA211898BT-9033B1
    TDK(东电化)
    多层带通滤波器(平衡输出型)(2合1),适用于869-960MHz / 1805-2025MHz。尺寸:2.0x1.5毫米,尺寸代码JIS。
DEA211898BT-9033B1 数据手册
R F C o m p o n e n t s October 2015 Multilayer Band Pass Filter (Balance Output Type) (2in1) For 869-960MHz / 1805-2025MHz DEA211898BT-9033B1 2.0x1.5mm * Dimensions Code JIS Caution The products in this catalog will be or have been stopped production Discontinue Issue Date Apr. 28, 2021 Last Purchase Order Date Dec. 31, 2022 Last Shipment Date Mar. 31, 2023 Please refer to our Web site about replacement information. RF Components Multilayer Band Pass Filter (Balance Output Type) (2in1) Conformity to RoHS Directive For 869-960MHz / 1805-2025MHz pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en DEA211898BT-9033B1 SHAPES AND DIMENSIONS 2.00±0.15 (5) (3) 0.30±0.15 0.76±0.15 1.10±0.10 (1) (10) (6) [Bottom view] (2) (7) (8) 1.50±0.15 (4) (9) 1.00±0.15 Marking 0.40±0.15 0.27±0.15 [Top view] 0.50±0.15 0.30±0.15 Terminal functions 1 GSM850/900(Unbalanced port) 2 GND 3 GND 4 GSM1800/1900(Unbalanced port) 5 GND 6 GSM1800/1900(Balanced port) 7 GSM1800/1900(Balanced port) 8 GSM850/900(Balanced port) 9 GSM850/900(Balanced port) 10 GND Dimensions in mm RECOMMENDED LAND PATTERN 0.40 1.00 0.27 0.30 Th e 0.76 0.20 Dimensions in mm RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151007 / rf_bpf_dea211898bt-9033b1_en.fm RF Components DEA211898BT-9033B1 ELECTRICAL CHARACTERISTICS pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en Band1 Frequency Range (MHz) Item Unbalanced Port Characteristic Impedance () Balanced Port Characteristic Impedance () Insertion Loss (dB) Attenuation (dB) Amplitude Balance (dB) Phase Balance (deg.) ・Ta: +25±5°C Band2 Item Unbalanced Port Characteristic Impedance () Balanced Port Characteristic Impedance () Insertion Loss (dB) Attenuation (dB) Amplitude Balance (dB) Phase Balance (deg.) ・Ta: +25±5°C Min. Typ. Max. 869 to 960 434.5 to 480 1738 to 1920 2607 to 2880 869 to 960 869 to 960 — 15 20 20 –1.0 170 50 (Nominal) 200 (Nominal) 1.35 17.6 21.6 25.6 0.51 176.4 1.5 — — — 1.0 190 Frequency Range (MHz) Min. Typ. Max. — 16.5 15 20 13 –1.5 170 50 (Nominal) 200 (Nominal) 1.60 18.3 21.0 22.5 19.7 0.96 176.4 1.9 — — — — 1.5 190 1805 to 2025 902.5 to 1012.5 2400 to 2500 3610 to 4050 5415 to 6000 1805 to 2025 1805 to 2025 TEMPERATURE RANGE Storage temperature (°C) –40 to +85 Th e Operating temperature (°C) –40 to +85 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151007 / rf_bpf_dea211898bt-9033b1_en.fm RF Components DEA211898BT-9033B1 FREQUENCY CHARACTERISTICS (Band1) 0 0 10 SDS21 Attenuation(dB) SDS21 Insertion Loss(dB) 1 2 3 4 5 600 SDS21 ATTENUATION pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SDS21 INSERTION LOSS 700 0 800 1000 900 Frequency(MHz) 1100 1200 50 1300 0 1000 2000 3000 Frequency(MHz) 4000 5000 6000 SDD22 RETURN LOSS at BALANCE PORT 0 SDD22 Return Loss at Balanced Port(dB) SSS11 Return Loss at Unbalanced Port(dB) 30 40 SSS11 RETURN LOSS at UNBALANCE PORT 10 20 30 40 50 600 20 700 800 1000 900 Frequency(MHz) 1100 1200 20 30 40 50 600 1300 PHASE BALANCE 200 10 700 800 1000 900 Frequency(MHz) 1100 1200 1300 1000 900 Frequency(MHz) 1100 1200 1300 AMPLITUDE BALANCE 3 195 180 Th e Phase Balance(deg) 185 Amplitude Balance(dB) 2 190 175 1 0 –1 170 –2 165 160 600 700 800 900 1000 Frequency(MHz) 1100 1200 1300 –3 600 700 800 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151007 / rf_bpf_dea211898bt-9033b1_en.fm RF Components DEA211898BT-9033B1 FREQUENCY CHARACTERISTICS (Band2) SDS21 Insertion Loss(dB) 1 2 3 4 5 1400 SDS21 ATTENUATION 0 10 SDS21 Attenuation(dB) 0 pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SDS21 INSERTION LOSS 1600 1800 2000 Frequency(MHz) 2200 50 2400 20 30 40 50 1400 195 1000 2000 3000 Frequency(MHz) 4000 5000 6000 0 1600 1800 2000 Frequency(MHz) 2200 10 20 30 40 50 1400 2400 PHASE BALANCE 200 0 SDD22 RETURN LOSS at BALANCE PORT SDD22 Return Loss at Balanced Port(dB) SSS11 Return Loss at Unbalanced Port(dB) 10 30 40 SSS11 RETURN LOSS at UNBALANCE PORT 0 20 1600 1800 2000 Frequency(MHz) 2200 2400 1800 2000 Frequency(MHz) 2200 2400 AMPLITUDE BALANCE 3 180 Th e Phase Balance(deg) 185 Amplitude Balance(dB) 2 190 175 1 0 –1 170 –2 165 160 1400 1600 1800 2000 Frequency(MHz) 2200 2400 –3 1400 1600 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151007 / rf_bpf_dea211898bt-9033b1_en.fm RF Components pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T1 t1 T3 t3 t2 t: Time Preheating Temp. T1 150°C t3 T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Th e : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. pr od u st cts op w pe il d lb pr e od or uc ha tio ve n be en SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications Th e When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20151007 / rf_bpf_dea211898bt-9033b1_en.fm
DEA211898BT-9033B1 价格&库存
很抱歉,暂时无法提供与“DEA211898BT-9033B1”相匹配的价格&库存,您可以联系我们找货
