R F
C o m p o n e n t s
June 2015
Multilayer Band Pass Filter
For 2400-2500MHz
DEA252450BT-2027A1
2.5x2.0mm [EIA 1008]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 2400-2500MHz
DEA252450BT-2027A1
SHAPES AND DIMENSIONS
[Top view]
2.50±0.20
0.90±0.10
(1)
2.00±0.20
(3)
(2)
(4)
Marking
[Bottom view]
Terminal functions
1 IN
2 OUT
3 GND
4 GND
0.20±0.10
0.50±0.20
0.35±0.15
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
2.30
2.00
1.10
0.40
0.30
0.60
2.30
0.60
0.80
0.30
0.40
0.60
1.40
0.30 0.55
1.90
Dimensions in mm
0.30
0.60
Line width should be designed to match 50Ω
characteristic impedance, depending on PCB
material and thickness.
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150601 / rf_bpf_dea252450bt-2027a1_zh.fm
RF Components
DEA252450BT-2027A1
ELECTRICAL CHARACTERISTICS
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Power Handling (W)
Characteristic Impedance (:)
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
2400 to 2500
2400 to 2500
880 to 915
1710 to 1790
1850 to 1910
4800 to 5000
7200 to 7500
2400 to 2500
10
35
35
35
30
25
1.00
19.5
48.6
42.7
40.2
42.7
50 (Nominal)
1.2
1.5 (–40 to +85°C)
0.5
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
˄°C˅
–40 to +85
Storage temperature
˄°C˅
–40 to +85
RF Components
DEA252450BT-2027A1
FREQUENCY CHARACTERISTICS
INSERTION LOSS
ATTENUATION
0.0
10
1.0
Attenuation(dB)
Insertion Loss (dB)
1.5
2.0
2.5
3.0
30
40
50
3.5
60
4.0
70
4.5
5.0
1500
1700
1900
2100
2300
2500
Frequency (MHz)
2700
2900
1900
2100
2300
2500
Frequency (MHz)
2700
2900
80
500
1500
2500
3500
Frequency (MHz)
4500
5500
RETURN LOSS
Return Loss(dB)
30
40
50
60
70
80
90
100
1500
1700
RF Components
DEA252450BT-2027A1
RECOMMENDED REFLOW PROFILE
Soaking
Working
Soldering
Peak
T: Temperature
T4
T5
T3
T2
T4
T3
t3
T1
t1
t2
t: Time
Soaking
Temp.
T1
150°C
T2
180°C
Time
t1
60 to 120s
Working
Temp.
T3
230°C
Time
t2
more than 30s
Soldering Peak
Temp.
T4
247 to 253°C
Time
t3
within 10s
Temp.
T5
260°C max.
RF Components
ቂ᎙ሃჵ
ቂׁٛ൰ˈขႚࢆࣙࢭتࡒཱུכ༚ȃ
ภ᎙ሃჵ
ቂׁٛ൰ˈข᎙ሃภჵȃ
᎙ ሃ
ׁٛ൰಼፩ኵܿٛ൰ፑቂᎳቂဉሃሆຢቂᇜֈݢᏊົֻ ˄AV ົֻˈᄪົֻˈয়ݢٛ൰ˈቨົֻˈིົֻˈࢋ
เົֻˈ֑࢞ົֻˈˈֻົكᇖධเ˅ˈ෩ࡘᇜֈݢᏊົֻᇋ٢ܿغᏮञቂߴߟቂȃ
ޭᅍᇋࡴޡภᄹञ૰૦ᄹܿˈডጚົֻܿࢽጊˈႜވᏮˈከᎡட૰ঐࢍเܿໍಛˈເ࿒ঽاٛ݃ዉڈཿࣷˈᇵঽ૰ٛໍಧܐ
຺ঐሯჳܿᇵቂဉ ˄ᇵ ‘ څ࿅ށቂဉ ’˅፩ܿቂᄹˈᄹߙংˈ൰፣ˈׁ࢞ཌྷቧ֦ጽȃ
ٛ൰־ׁٛ൰಼ܿ߭ၐȂፇိˈডጚ࿅ށቂဉ፩ቂˈׁ࢞ཌྷޭྋዉܿڈཿࣷञᄪᄹܞڏใटውใȃ
(1) ऎ࿙ऎૼົֻ
(2) ਦከ༕ົֻ ˄පވݢˈٴট˅݃ؑۉˈٴ
(3) ᇞனົֻ
(4) ߙ૿ݢ፟ົֻ
(5) ኊᏊኑყ࣋ົֻ
(6) ֻࣴົݒ
(7) ਦ૿፟ົֻ
(8) ࢞ࢥᄪႩֻົ୲ۃ
(9) ૅົֻ
(10) ݢৠົֻȂัຨົֻ
(11) ߷ኳ / ኁ߷߯Ꮶົֻ
(12) ภົֻ
(13) ඝྊ־༄ၓ٢ࣙቂဉܿቂဉ
ၓமࢮภݓቂٛ൰ˈޭቂׁٛ൰಼፩ྈኵٛ൰ܿົֻᄵົˈขฬ֦࠲ठࡘົֻܿቂቂဉঽᎫྙ֦ܿ॓ই௸ञᎧ
ˈົֻቂই௸݃ȃ
很抱歉,暂时无法提供与“DEA252450BT-2027A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.46344
- 30+0.44712
- 100+0.41448
- 500+0.38184
- 1000+0.36553
