DEL-C1005X7R1H331K050BA
    TDK(东电化)
    TDK - DEL-C1005X7R1H331K050BA - CERAMIC CAPACITOR, 330PF, 50V, X7R, 10%,
DEL-C1005X7R1H331K050BA 数据手册
August 2016 MULTILAYER CERAMIC CHIP CAPACITORS C Series Commercial Grade General (Up to 50V) Type: C0402 [EIA CC01005] C0603 [EIA CC0201] C1005 [EIA CC0402] C1608 [EIA CC0603] C2012 [EIA CC0805] C3216 [EIA CC1206] C3225 [EIA CC1210] C4532 [EIA CC1812] C5750 [EIA CC2220] (1/1) MULTILAYER CERAMIC CHIP CAPACITORS REMINDERS Please read before using this product SAFETY REMINDERS REMINDERS 1. If you intend to use a product listed in this catalog for a purpose that may cause loss of life or other damage, you must contact our company’s sales window. 2. We may modify products or discontinue production of a product listed in this catalog without prior notification. 3. We provide “Delivery Specification” that explain precautions for the specifications and safety of each product listed in this catalog. We strongly recommend that you exchange these delivery specifications with customers that use one of these products. 4. If you plan to export a product listed in this catalog, keep in mind that it may be a restricted item accordingto the “Foreign Exchange and Foreign Trade Control Law”. In such cases, it is necessary to acquire exportpermission in harmony with this law. 5. Any reproduction or transferring of the contents of this catalog is prohibited without prior permission from our company. 6. We are not responsible for problems that occur related to the intellectual property rights or other rights of our company or a third party when you use a product listed in this catalog. We do not grant license of these rights. 7. This catalog only applies to products purchased through our company or one of our company’s official agencies. This catalog does not apply to products that are purchased through other third parties. Notice: Effective January 2013, TDK will use a new catalog number which adds product thickness and packaging specification detail. This new catalog number should be referenced on all catalog orders going forward, and is not applicable for OEM part number orders. Please be aware the last five digits of the catalog number will differ from the item description (internal control number) on the product label. Contact your local TDK Sales representative for more information. (Example) Catalog Issued date Prior to January 2013 January 2013 and Later Catalog Number C1608C0G1E103J(080AA) C1608C0G1E103J080AA Item Description (On Delivery Label) C1608C0G1E103JT000N C1608C0G1E103JT000N 20160803 / mlcc_reminders.fm (1/53) MULTILAYER CERAMIC CHIP CAPACITORS Pb Lead Free C Series RoHS COMPLIANT Ecological General (Up to 50V) Type: C0402 [EIA CC01005], C0603 [EIA CC0201], C1005 [EIA CC0402], C1608 [EIACC0603], C2012 [EIA CC0805], C3216 [EIA CC1206], C3225 [EIA CC1210], C4532 [EIA CC1812], C5750 [EIA CC2220] Features • High capacitance has been achieved through precision technologies that enable the use of multiple thinner ceramic dielectric layers. • A monolithic structure ensures superior mechanical strength and reliability. • Low ESL and excellent frequency characteristics allow for a circuit design that closely conforms to theoretical values. • Low self-heating and high ripple resistance due to low ESR. • • • • • • Applications Shape & Dimensions General electronic equipment Mobile communication equipment Power supply circuit Office automation equipment TV, LED displays Servers, PCs, Notebooks, Tablets W L T G B L W T Body Length Body Width Body Height B Terminal Width G Terminal Spacing C • 3225 • X7R • 1H • 106 • M • 250 • A • C Catalog Number Construction Series Name Dimensions L x W (mm) Code C0402 C0603 C1005 C1608 C2012 C3216 C3225 C4532 C5750 Length 0.40 ± 0.02 0.60 ± 0.03 1.00 ± 0.05 1.60 ± 0.10 2.00 ± 0.20 3.20 ± 0.20 3.20 ± 0.40 4.50 ± 0.40 5.70 ± 0.40 Width 0.20 ± 0.02 0.30 ± 0.03 0.50 ± 0.05 0.80 ± 0.10 1.25 ± 0.20 1.60 ± 0.20 2.50 ± 0.30 3.20 ± 0.40 5.00 ± 0.40 Terminal 0.07 min. 0.10 min. 0.10 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. 0.20 min. *Dimension tolerance are typical values Temperature Characteristics Temperature Temperature Coefficient or Characteristics Capacitance Change 0±60 ppm/°C CH 0±30 ppm/°C C0G ±10% JB ±15% X5R ±22% X6S ±15% X7R ±22% X7S Temperature Range Rated Voltage (DC) -25 to +85°C -55 to +125°C -25 to +85°C -55 to +85°C -55 to +105°C -55 to +125°C -55 to +125°C Code 0G 0J 1A 1C 1E 1V 1H Voltage (DC) 4V 6.3V 10V 16V 25V 35V 50V Nominal Capacitance (pF) The capacitance is expressed in three digit codes and in units of pico Farads (pF). The first and second digits identify the first and second significant figures of the capacitance. The third digit identifies the multiplier. R designates a decimal point. Capacitance Tolerance Code B C D F G J K M Tolerance ± 0.10pF ± 0.25pF ± 0.50pF ± 1% ± 2% ± 5% ± 10% ± 20% Nominal Thickness Code 020 030 050 060 080 085 115 125 Thickness 0.20 mm 0.30 mm 0.50 mm 0.60 mm 0.80 mm 0.85 mm 1.15 mm 1.25 mm Code 130 160 200 230 250 280 320 Thickness 1.30 mm 1.60 mm 2.00 mm 2.30 mm 2.50 mm 2.80 mm 3.20 mm Packaging Style Code A B K Style 178 mm Reel, 4 mm Pitch 178 mm Reel, 2 mm Pitch 178 mm Reel, 8 mm Pitch Special Reserved Code Code Description A, B, C TDK Internal Code Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (2/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC01005 [C0402] Capacitance Range Chart   Temperature Characteristics:C0G (0±30ppm/℃), CH (0±60ppm/℃), JB (±10%)   Rated Voltage:16V (1C), 10V (1A), 6.3V (0J), 4.0V (0G) Capacitance Tolerance (pF) Code 0.5 0.75 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 0R5 R75 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 151 221 331 471 681 102 152 222 332 472 682 103 C0G CH 1C (16V) 1C (16V) JB 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) C:±0.25pF D:±0.50pF J:±5% K:±10% M:±20% K:±10% M:±20% Standard Thickness 0.20 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■ Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (3/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC01005 [C0402] Capacitance Range Chart   Temperature Characteristics:X5R (±15%), X6S (±22%), X7R (±15%)   Rated Voltage:16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X5R Tolerance (pF) Code 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 22,000 47,000 100,000 220,000 101 151 221 331 471 681 102 152 222 332 472 682 103 223 473 104 224 1C (16V) 1A (10V) 0J (6.3V) X6S 0G (4V) 1A (10V) 0J (6.3V) X7R 0G (4V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% M:±20% Standard Thickness 0 .20 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (4/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0201 [C0603] Capacitance Range Chart   Temperature Characteristics:C0G (0±30ppm/℃), CH (0±60ppm/℃), JB (±10%), X5R (±15%)   Rated Voltage:50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance C0G Tolerance (pF) Code 0.5 0.75 1 1.5 2 2.2 3 3.3 4 4.7 5 6 6.8 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 1,000,000 2,200,000 0R5 R75 010 1R5 020 2R2 030 3R3 040 4R7 050 060 6R8 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 151 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 105 225 Standard Thickness   1H (50V) 1E (25V) CH 1H (50V) 1E (25V) JB 1E (25V) 1C (16V) X5R 1A 0J 1E (10V) (6.3V) (25V) 1C (16V) 1A 0J (10V) (6.3V) 0G (4V) C:±0.25pF D:±0.50pF J:±5% K:±10% M:±20% K:±10% M:±20% M:±20% 0.30 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (5/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0201 [C0603] Capacitance Range Chart   Temperature Characteristics:X6S (±22%), X7R (±15%), X7S (±22%)   Rated Voltage:25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X6S Tolerance (pF) Code 100 150 220 330 470 680 1,000 1,500 2,200 3,300 4,700 10,000 22,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 101 151 221 331 471 681 102 152 222 332 472 103 223 473 683 104 154 224 334 474 Standard Thickness   1E (25V) 1C (16V) 1A (10V) X7R 0J (6.3V) 0G (4V) 1E (25V) 1C (16V) 1A (10V) X7S 0J (6.3V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% M:±20% 0.30 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (6/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0402 [C1005] Capacitance Range Chart   Temperature Characteristics:C0G (0±30ppm/℃), CH (0±60ppm/℃)   Rated Voltage:50V (1H), 25V (1E) Capacitance C0G Tolerance (pF) Code 0.5 0.75 1 1.5 2 3 4 5 6 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 0R5 R75 010 1R5 020 030 040 050 060 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 1H (50V) 1E (25V) CH 1H (50V) B:±0.10pF C:±0.25pF C:±0.25pF D:±0.50pF F:±1% G:±2% J:±5% F:±1% G:±2% J:±5% K:±10% Standard Thickness 0.50 mm Background gray: The product which is not recommended to a new design ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (7/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0402 [C1005] Capacitance Range Chart   Temperature Characteristics:JB (±10%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance JB Tolerance (pF) Code 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness 0.50 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (8/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0402 [C1005] Capacitance Range Chart   Temperature Characteristics:X5R (±15%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V(0J), 4V (0G) Capacitance X5R Tolerance (pF) Code 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 10,000,000 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 106 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness 0.50 mm M:±20% Capacitance Range Chart   Temperature Characteristics:X6S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V(0J), 4V (0G) Capacitance X6S Tolerance (pF) Code 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness M:±20% 0.50 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (9/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0402 [C1005] Capacitance Range Chart   Temperature Characteristics: X7R(±15%), X7S(±22%)   Rated Voltage: 50V(1H), 35V(1V), 25V(1E), 16V(1C), 10V (1A), 6.3V(0J), 4V (0G) Capacitance X7R Tolerance (pF) Code 220 330 470 680 1,000 1,500 2,200 3,300 4,700 6,800 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 221 331 471 681 102 152 222 332 472 682 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 1H (50V) 1V (35V) 1E (25V) X7S 1C (16V) 1A (10V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness 0.50 mm Background gray: The product which is not recommended to a new design ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (10/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0603 [C1608] Capacitance Range Chart   Temperature Characteristics:C0G (0±30ppm/℃), CH(0±60ppm/℃)   Rated Voltage:50V (1H), 35V(1V), 25V (1E) Capacitance C0G Tolerance (pF) Code 0.5 0.75 1 1.5 2 3 4 5 6 7 8 9 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 18,000 0R5 R75 010 1R5 020 030 040 050 060 070 080 090 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 153 183 1H (50V) 1V (35V) CH 1E (25V) 1H (50V) 1V (35V) C:±0.25pF C:±0.25pF D:±0.50pF F:±1% G:±2% J:±5% K:±10% J:±5% K:±10% Standard Thickness 0.80 mm Background gray: The product which is not recommended to a new design ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (11/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0603 [C1608] Capacitance Range Chart   Temperature Characteristics:JB(±10%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance JB Tolerance (pF) Code 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 685 106 156 226 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness M:±20% 0.80 mm Capacitance Range Chart   Temperature Characteristics:X5R (±15%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X5R Tolerance (pF) Code 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 685 106 156 226 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% M:±20% Standard Thickness 0.80 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (12/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0603 [C1608] Capacitance Range Chart   Temperature Characteristics:X6S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X6S Tolerance (pF) Code 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 154 224 334 474 684 105 155 225 335 475 685 106 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness 0.80 mm Capacitance Range Chart   Temperature Characteristics:X7R (±15%), X7S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X7R Tolerance (pF) Code 10,000 15,000 22,000 33,000 47,000 68,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 103 153 223 333 473 683 104 154 224 334 474 684 105 155 225 335 475 685 106 1H (50V) 1V (35V) 1E (25V) 1C (16V) X7S 1A (10V) 0J (6.3V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness 0.80 mm M:±20% Background gray: The product which is not recommended to a new design ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (13/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0805 [C2012] Capacitance Range Chart   Temperature Characteristics:C0G (0±30ppm/℃), CH (0±60ppm/℃), JB (±10%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance C0G Tolerance (pF) Code 1,000 1,200 1,500 1,800 2,200 2,700 3,300 3,900 4,700 5,600 6,800 8,200 10,000 15,000 18,000 22,000 27,000 30,000 33,000 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 102 122 152 182 222 272 332 392 472 562 682 822 103 153 183 223 273 303 333 104 154 224 334 474 684 105 155 225 335 475 685 106 156 226 336 476 Standard Thickness   1H (50V) 1V (35V) CH 1E (25V) 1H (50V) 1V (35V) JB 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) J:±5% K:±10% K:±10% M:±20% M:±20% 0.60 mm  0.85 mm  1.25 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (14/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0805 [C2012] Capacitance Range Chart   Temperature Characteristics:X5R (±15%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X5R Tolerance (pF) Code 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 104 154 224 334 474 684 105 155 225 335 475 685 106 156 226 336 476 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness 0.85 mm M:±20% 1.25 mm Capacitance Range Chart   Temperature Characteristics:X6S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X6S Tolerance (pF) Code 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 474 684 105 155 225 335 475 685 106 156 226 336 476 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% M:±20% Standard Thickness 0.85 mm 1.25 mm Background gray: The product which is not recommended to a new design Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (15/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC0805 [C2012] Capacitance Range Chart   Temperature Characteristics:X7R (±15%), X7S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X7R Tolerance (pF) Code 100,000 150,000 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 104 154 224 334 474 684 105 155 225 335 475 685 106 156 226 1H (50V) 1V (35V) 1E (25V) 1C (16V) X7S 1A (10V) 0J (6.3V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness 0.85 mm M:±20% 1.25 mm Background gray: The product which is not recommended to a new design ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (16/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1206 [C3216] Capacitance Range Chart   Temperature Characteristics:C0G (0±30ppm/℃), CH (0±60ppm/℃), JB (±10%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance Tolerance (pF) Code 3,900 4,700 5,600 6,800 8,200 10,000 15,000 22,000 33,000 47,000 68,000 100,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 392 472 562 682 822 103 153 223 333 473 683 104 105 155 225 335 475 685 106 156 226 336 476 686 107 C0G CH 1H (50V) 1H (50V) JB 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) J:±5% K:±10% K:±10% M:±20% Standard Thickness 0.60 mm M:±20% 0.85 mm 1.15 mm  1.30 mm  1.60 mm Capacitance Range Chart   Temperature Characteristics:X5R (±15%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X5R Tolerance (pF) Code 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 105 155 225 335 475 685 106 156 226 336 476 686 107 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% M:±20% Standard Thickness 0.85 mm 1.15 mm  1.30 mm  1.60 mm Background red: The product which is planning to stop production * Please confirm the schedule on product details information. ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (17/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1206 [C3216] Capacitance Range Chart   Temperature Characteristics: X6S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X6S Tolerance (pF) 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 Code 155 225 335 475 685 106 156 226 336 476 686 107 1H (50V) 1V (35V) 1E (25V) 1C (16V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% M:±20% Standard Thickness 0.85 mm 1.60 mm Capacitance Range Chart   Temperature Characteristics: X7R (±15%), X7S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X7R Tolerance (pF) 220,000 330,000 470,000 680,000 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 Code 224 334 474 684 105 155 225 335 475 685 106 156 226 336 476 1H (50V) 1V (35V) 1E (25V) 1C (16V) X7S 1A (10V) 0J (6.3V) 1A (10V) 0J (6.3V) 0G (4V) K:±10% M:±20% Standard Thickness M:±20% 0.85 mm 1.15 mm 1.60 mm ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (18/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1210 [C3225] Capacitance Range Chart   Temperature Characteristics: C0G (0±30ppm/℃), CH (0±60ppm/℃), JB (±10%), X5R (±15%)   Rated Voltage:50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance Tolerance (pF) 22,000 33,000 47,000 68,000 100,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 Code 223 333 473 683 104 225 335 475 685 106 156 226 336 476 686 107 C0G CH 1H (50V) 1H (50V) JB 1H (50V) 1E (25V) 1C (16V) X5R 1A 0J 1H (10V) (6.3V) (50V) 1E (25V) 1C (16V) 1A 0J (10V) (6.3V) J:±5% K:±10% K:±10% M:±20% M:±20% Standard Thickness   1.25 mm  1.60 mm  2.00 mm  2.30 mm  2.50 mm Capacitance Range Chart   Temperature Characteristics: X6S (±22%), X7R (±15%), X7S (±22%)   Rated Voltage:50V (1H), 35V (1V), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J), 4V (0G) Capacitance X6S Tolerance (pF) 1,000,000 1,500,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 47,000,000 100,000,000 Code 105 155 225 335 475 685 106 156 226 476 107 Standard Thickness   1H (50V) 1V (35V) 1E (25V) X7R 1C 0J (16V) (6.3V) 0G (4V) 1H (50V) 1E (25V) 1C (16V) X7S 1A (10V) 1H 0J (50V) (6.3V) K:±10% M:±20% M:±20% 1.60 mm  2.00 mm  2.30 mm  2.50 mm ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (19/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC1812 [C4532] Capacitance Range Chart   Temperature Characteristics:C0G (0±30ppm/℃), CH (0±60ppm/℃), JB (±10%)   Rated Voltage:50V (1H), 25V (1E), 16V (1C) Capacitance Tolerance (pF) 47,000 68,000 100,000 150,000 220,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 Code 473 683 104 154 224 685 106 156 226 336 C0G CH 1H (50V) 1H (50V) JB 1H (50V) 1E (25V) 1C (16V) J:±5% K:±10% Standard Thickness 1.60 mm  K:±10% M:±20% M:±20% 2.00 mm 2.50 mm 3.20 mm Capacitance Range Chart   Temperature Characteristics: X5R (±15%), X6S (±22%), X7R (±15%)   Rated Voltage:50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance X5R Tolerance (pF) 1,000,000 2,200,000 3,300,000 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 Code 105 225 335 475 685 106 156 226 336 476 686 107 1H (50V) 1E (25V) 1C (16V) X6S 1A (10V) 0J 0J (6.3V) (6.3V) X7R 1H (50V) 1E (25V) 1C (16V) K:±10% M:±20% Standard Thickness 1.60 mm  M:±20% 2.00 mm 2.30 mm 2.50 mm 2.80 mm ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (20/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Chart EIA CC2220 [C5750] Capacitance Range Chart   Temperature Characteristics: JB (±10%), X5R (±15%), X7R (±15%)   Rated Voltage:50V (1H), 25V (1E), 16V (1C), 10V (1A), 6.3V (0J) Capacitance JB Tolerance (pF) 4,700,000 6,800,000 10,000,000 15,000,000 22,000,000 33,000,000 47,000,000 68,000,000 100,000,000 Code 475 685 106 156 226 336 476 686 107 1E (25V) X5R 1H (50V) 1E (25V) 1C (16V) X7R 1A (10V) 0J (6.3V) 1H (50V) 1E (25V) 1C (16V) K:±10% M:±20% Standard Thickness M:±20% 2.00 mm 2.30 mm 2.50 mm 2.80 mm ■Please refer to a capacitance range table after P-21 for the details such as product thickness, a capacitance tolerance. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (21/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:C0G(-55 to +125℃, 0±30 ppm/℃) Capacitance 0.5 pF 0.75 pF 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF Size Thickness (mm) Capacitance Tolerance 0402 0603 0.20±0.02 0.30±0.03 ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0402 0603 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc:25V C0603C0G1H0R5C030BA C0603C0G1E0R5C030BA Rated Voltage Edc:16V C0402C0G1C0R5C020BC C1005C0G1H0R5B050BA C1005C0G1H0R5C050BA C1608C0G1H0R5C080AA C0402C0G1CR75C020BC C0603C0G1HR75C030BA C0603C0G1ER75C030BA C1005C0G1HR75B050BA C1005C0G1HR75C050BA C1608C0G1HR75C080AA C0402C0G1C010C020BC C0603C0G1H010C030BA C0603C0G1E010C030BA C1005C0G1H010B050BA C1005C0G1H010C050BA C1608C0G1H010C080AA C0402C0G1C1R5C020BC C0603C0G1H1R5C030BA C0603C0G1E1R5C030BA C1005C0G1H1R5B050BA C1005C0G1H1R5C050BA C1608C0G1H1R5C080AA C0402C0G1C020C020BC C0603C0G1H020C030BA C0603C0G1E020C030BA C1005C0G1H020B050BA C1005C0G1H020C050BA C1608C0G1H020C080AA C0402C0G1C2R2C020BC C0603C0G1H2R2C030BA C0603C0G1E2R2C030BA C0603C0G1H030C030BA C0603C0G1E030C030BA C0402C0G1C030C020BC C1005C0G1H030B050BA C1005C0G1H030C050BA C1608C0G1H030C080AA C0402C0G1C3R3C020BC C0603C0G1H3R3C030BA C0603C0G1E3R3C030BA C0603C0G1H040C030BA C0603C0G1E040C030BA C0402C0G1C040C020BC C1005C0G1H040B050BA C1005C0G1H040C050BA C1608C0G1H040C080AA C0402C0G1C4R7C020BC C0603C0G1H4R7C030BA C0603C0G1E4R7C030BA C0603C0G1H050C030BA C0603C0G1E050C030BA C0402C0G1C050C020BC C1005C0G1H050B050BA C1005C0G1H050C050BA C1608C0G1H050C080AA C0402C0G1C060D020BC C0603C0G1H060D030BA C0603C0G1E060D030BA C1005C0G1H060C050BA C1005C0G1H060D050BA C1608C0G1H060C080AA C1608C0G1H060D080AA C0402C0G1C6R8D020BC C0603C0G1H6R8D030BA C0603C0G1E6R8D030BA C0603C0G1H070D030BA C0603C0G1E070D030BA C0402C0G1C070D020BC C1005C0G1H070C050BA C1005C0G1H070D050BA C1608C0G1H070C080AA C1608C0G1H070D080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (22/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:C0G(-55 to +125℃, 0±30 ppm/℃) Capacitance 8 pF 9 pF 10 pF 12 pF Size Thickness (mm) Capacitance Tolerance 0402 0603 0.20±0.02 0.30±0.03 ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±1% ±2% ±5% ±1% ±2% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±1% ±2% ±5% ±1% ±2% ±5% ±10% ±5% ±10% ±5% ±5% ±5% 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 15 pF 18 pF 1005 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 1005 1608 0402 27 pF 0.50±0.05 1608 0603 22 pF 0.30±0.03 0.30±0.03 0.50±0.05 0.80±0.10 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc:25V C0603C0G1H080D030BA C0603C0G1E080D030BA Rated Voltage Edc:16V C0402C0G1C080D020BC C1005C0G1H080C050BA C1005C0G1H080D050BA C1608C0G1H080C080AA C1608C0G1H080D080AA C0402C0G1C090D020BC C0603C0G1H090D030BA C0603C0G1E090D030BA C1005C0G1H090C050BA C1005C0G1H090D050BA C1608C0G1H090C080AA C1608C0G1H090D080AA C0402C0G1C100D020BC C0603C0G1H100D030BA C0603C0G1E100D030BA C1005C0G1H100C050BA C1005C0G1H100D050BA C1608C0G1H100C080AA C1608C0G1H100D080AA C0402C0G1C120K020BC C0402C0G1C120J020BC C0603C0G1H120K030BA C0603C0G1E120K030BA C0603C0G1H120J030BA C0603C0G1E120J030BA C1005C0G1H120J050BA C1608C0G1H120J080AA C0402C0G1C150K020BC C0402C0G1C150J020BC C0603C0G1H150K030BA C0603C0G1E150K030BA C0603C0G1H150J030BA C0603C0G1E150J030BA C1005C0G1H150F050BA C1005C0G1H150G050BA C1005C0G1H150J050BA C1608C0G1H150F080AA C1608C0G1H150G080AA C1608C0G1H150J080AA C0402C0G1C180K020BC C0402C0G1C180J020BC C0603C0G1H180K030BA C0603C0G1E180K030BA C0603C0G1H180J030BA C0603C0G1E180J030BA C1005C0G1H180J050BA C1608C0G1H180J080AA C0402C0G1C220K020BC C0402C0G1C220J020BC C0603C0G1H220K030BA C0603C0G1E220K030BA C0603C0G1H220J030BA C0603C0G1E220J030BA C1005C0G1H220F050BA C1005C0G1H220G050BA C1005C0G1H220J050BA C1608C0G1H220F080AA C1608C0G1H220G080AA C1608C0G1H220J080AA C0402C0G1C270K020BC C0402C0G1C270J020BC C0603C0G1H270K030BA C0603C0G1E270K030BA C0603C0G1H270J030BA C0603C0G1E270J030BA C1005C0G1H270J050BA C1608C0G1H270J080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (23/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:C0G(-55 to +125℃, 0±30 ppm/℃) Capacitance Size Thickness (mm) 0402 0.20±0.02 0603 33 pF 1005 1608 0402 39 pF 47 pF 68 pF 0.20±0.02 0.30±0.03 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 100 pF 0.80±0.10 1005 1608 1608 82 pF 0.50±0.05 0603 1608 56 pF 0.30±0.03 1005 1608 0.30±0.03 0.50±0.05 0.80±0.10 Capacitance Tolerance ±10% ±5% ±10% ±5% ±1% ±2% ±5% ±1% ±2% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±1% ±2% ±5% ±1% ±2% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±1% ±2% ±5% ±1% ±2% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±1% ±10% ±2% ±5% ±1% ±10% ±2% ±5% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc:25V C0603C0G1H330K030BA C0603C0G1E330K030BA C0603C0G1H330J030BA C0603C0G1E330J030BA Rated Voltage Edc:16V C0402C0G1C330K020BC C0402C0G1C330J020BC C1005C0G1H330F050BA C1005C0G1H330G050BA C1005C0G1H330J050BA C1608C0G1H330F080AA C1608C0G1H330G080AA C1608C0G1H330J080AA C0402C0G1C390K020BC C0402C0G1C390J020BC C0603C0G1H390K030BA C0603C0G1E390K030BA C0603C0G1H390J030BA C0603C0G1E390J030BA C1005C0G1H390J050BA C1608C0G1H390J080AA C0402C0G1C470K020BC C0402C0G1C470J020BC C0603C0G1H470K030BA C0603C0G1E470K030BA C0603C0G1H470J030BA C0603C0G1E470J030BA C1005C0G1H470F050BA C1005C0G1H470G050BA C1005C0G1H470J050BA C1608C0G1H470F080AA C1608C0G1H470G080AA C1608C0G1H470J080AA C0402C0G1C560K020BC C0402C0G1C560J020BC C0603C0G1H560K030BA C0603C0G1E560K030BA C0603C0G1H560J030BA C0603C0G1E560J030BA C1005C0G1H560J050BA C1608C0G1H560J080AA C0402C0G1C680K020BC C0402C0G1C680J020BC C0603C0G1H680K030BA C0603C0G1E680K030BA C0603C0G1H680J030BA C0603C0G1E680J030BA C1005C0G1H680F050BA C1005C0G1H680G050BA C1005C0G1H680J050BA C1608C0G1H680F080AA C1608C0G1H680G080AA C1608C0G1H680J080AA C0402C0G1C820K020BC C0402C0G1C820J020BC C0603C0G1H820K030BA C0603C0G1E820K030BA C0603C0G1H820J030BA C0603C0G1E820J030BA C1005C0G1H820J050BA C1608C0G1H820J080AA C0402C0G1C101K020BC C0402C0G1C101J020BC C0603C0G1H101K030BA C0603C0G1E101K030BA C0603C0G1H101J030BA C0603C0G1E101J030BA C1005C0G1H101F050BA C1005C0G1H101K050BA C1005C0G1H101G050BA C1005C0G1H101J050BA C1608C0G1H101F080AA C1608C0G1H101K080AA C1608C0G1H101G080AA C1608C0G1H101J080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (24/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:C0G(-55 to +125℃, 0±30 ppm/℃) Capacitance Size Thickness (mm) 1005 0.50±0.05 120 pF 1608 1005 0.80±0.10 0.50±0.05 150 pF 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 180 pF 1005 0.50±0.05 220 pF 1608 0.80±0.10 1005 0.50±0.05 270 pF 1608 1005 0.80±0.10 0.50±0.05 330 pF 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 390 pF 1005 0.50±0.05 470 pF 1608 0.80±0.10 1005 0.50±0.05 560 pF 1608 1005 0.80±0.10 0.50±0.05 680 pF 1608 0.80±0.10 Capacitance Tolerance ±10% ±5% ±10% ±5% ±1% ±10% ±2% ±5% ±1% ±10% ±2% ±5% ±10% ±5% ±10% ±5% ±1% ±10% ±2% ±5% ±1% ±10% ±2% ±5% ±10% ±5% ±10% ±5% ±1% ±10% ±2% ±5% ±1% ±10% ±2% ±5% ±10% ±5% ±10% ±5% ±1% ±10% ±2% ±5% ±1% ±10% ±2% ±5% ±10% ±5% ±10% ±5% ±1% ±10% ±2% ±5% ±1% ±10% ±2% ±5% Catalog Number Rated Voltage Edc: 50V C1005C0G1H121K050BA C1005C0G1H121J050BA C1608C0G1H121K080AA C1608C0G1H121J080AA C1005C0G1H151F050BA C1005C0G1H151K050BA C1005C0G1H151G050BA C1005C0G1H151J050BA C1608C0G1H151F080AA C1608C0G1H151K080AA C1608C0G1H151G080AA C1608C0G1H151J080AA C1005C0G1H181K050BA C1005C0G1H181J050BA C1608C0G1H181K080AA C1608C0G1H181J080AA C1005C0G1H221F050BA C1005C0G1H221K050BA C1005C0G1H221G050BA C1005C0G1H221J050BA C1608C0G1H221F080AA C1608C0G1H221K080AA C1608C0G1H221G080AA C1608C0G1H221J080AA C1005C0G1H271K050BA C1005C0G1H271J050BA C1608C0G1H271K080AA C1608C0G1H271J080AA C1005C0G1H331F050BA C1005C0G1H331K050BA C1005C0G1H331G050BA C1005C0G1H331J050BA C1608C0G1H331F080AA C1608C0G1H331K080AA C1608C0G1H331G080AA C1608C0G1H331J080AA C1005C0G1H391K050BA C1005C0G1H391J050BA C1608C0G1H391K080AA C1608C0G1H391J080AA C1005C0G1H471F050BA C1005C0G1H471K050BA C1005C0G1H471G050BA C1005C0G1H471J050BA C1608C0G1H471F080AA C1608C0G1H471K080AA C1608C0G1H471G080AA C1608C0G1H471J080AA C1005C0G1H561K050BA C1005C0G1H561J050BA C1608C0G1H561K080AA C1608C0G1H561J080AA C1005C0G1H681F050BA C1005C0G1H681K050BA C1005C0G1H681G050BA C1005C0G1H681J050BA C1608C0G1H681F080AA C1608C0G1H681K080AA C1608C0G1H681G080AA C1608C0G1H681J080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (25/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:C0G(-55 to +125℃, 0±30 ppm/℃) Capacitance Size Thickness (mm) 1005 0.50±0.05 820 pF 1608 1005 0.80±0.10 0.50±0.05 1 nF 1608 0.80±0.10 2012 0.60±0.15 1608 0.80±0.10 1.2 nF 2012 0.60±0.15 1608 0.80±0.10 1.5 nF 2012 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 1.8 nF 1608 2.2 nF 2012 0.80±0.10 0.60±0.15 0.85±0.15 1608 0.80±0.10 2.7 nF 2012 0.60±0.15 1608 0.80±0.10 3.3 nF 2012 0.60±0.15 1.25±0.20 1608 3.9 nF 4.7 nF 2012 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 5.6 nF 0.80±0.10 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 Capacitance Tolerance ±10% ±5% ±10% ±5% ±1% ±10% ±2% ±5% ±1% ±10% ±2% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% Catalog Number Rated Voltage Edc: 50V C1005C0G1H821K050BA Rated Voltage Edc:25V C1005C0G1H821J050BA C1608C0G1H821K080AA C1608C0G1H821J080AA C1005C0G1H102F050BA C1005C0G1H102K050BA C1005C0G1H102G050BA C1005C0G1H102J050BA C1005C0G1E102J050BA C1608C0G1H102F080AA C1608C0G1H102K080AA C1608C0G1H102G080AA C1608C0G1H102J080AA C2012C0G1H102K060AA C2012C0G1H102J060AA C1608C0G1H122K080AA C1608C0G1H122J080AA C2012C0G1H122K060AA C2012C0G1H122J060AA C1608C0G1H152K080AA C1608C0G1H152J080AA C2012C0G1H152K060AA C2012C0G1H152J060AA C1608C0G1H182K080AA C1608C0G1H182J080AA C2012C0G1H182K060AA C2012C0G1H182J060AA C1608C0G1H222K080AA C1608C0G1H222J080AA C2012C0G1H222K060AA C2012C0G1H222J060AA C2012C0G1H222J085AA C1608C0G1H272K080AA C1608C0G1H272J080AA C2012C0G1H272K060AA C2012C0G1H272J060AA C1608C0G1H332K080AA C1608C0G1H332J080AA C2012C0G1H332K060AA C2012C0G1H332J060AA C2012C0G1H332J125AA C1608C0G1H392K080AA C1608C0G1H392J080AA C1608C0G1E392J080AA C2012C0G1H392K060AA C2012C0G1H392J060AA C3216C0G1H392K060AA C3216C0G1H392J060AA C1608C0G1H472K080AA C1608C0G1H472J080AA C1608C0G1E472J080AA C2012C0G1H472K060AA C2012C0G1H472J060AA C3216C0G1H472K060AA C3216C0G1H472J060AA C1608C0G1H562K080AA C1608C0G1H562J080AA C1608C0G1E562J080AA C2012C0G1H562K060AA C2012C0G1H562J060AA C3216C0G1H562K060AA C3216C0G1H562J060AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (26/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:C0G(-55 to +125℃, 0±30 ppm/℃) Capacitance 6.8 nF 8.2 nF 10 nF 15 nF Size Thickness (mm) 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.85±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 18 nF 0.60±0.15 2012 1.25±0.20 22 nF 3216 0.60±0.15 3225 1.25±0.20 27 nF 2012 0.60±0.15 30 nF 2012 0.60±0.15 2012 1.25±0.20 3216 0.85±0.15 3225 1.60±0.20 3216 1.15±0.15 3225 2.00±0.20 4532 1.60±0.20 3216 1.60±0.20 3225 2.00±0.20 4532 1.60±0.20 3216 1.60±0.20 3225 2.50±0.30 4532 2.00±0.20 150 nF 4532 2.50±0.30 220 nF 4532 3.20±0.30 33 nF 47 nF 68 nF 100 nF Capacitance Tolerance ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% Catalog Number Rated Voltage Edc: 50V C1608C0G1H682K080AA C1608C0G1H682J080AA C2012C0G1H682K060AA C2012C0G1H682J060AA C3216C0G1H682K060AA C3216C0G1H682J060AA C1608C0G1H822K080AA C1608C0G1H822J080AA C2012C0G1H822K060AA C2012C0G1H822J060AA C3216C0G1H822K060AA C3216C0G1H822J060AA C1608C0G1H103K080AA C1608C0G1H103J080AA C2012C0G1H103K060AA C2012C0G1H103J060AA C3216C0G1H103K060AA C3216C0G1H103J060AA Rated Voltage Edc:35V Rated Voltage Edc:25V C1608C0G1E682J080AA C1608C0G1E822J080AA C1608C0G1V103K080AC C1608C0G1V103J080AC C1608C0G1E103J080AA C2012C0G1E103J060AA C1608C0G1V153K080AC C1608C0G1V153J080AC C2012C0G1H153K085AA C2012C0G1H153J085AA C3216C0G1H153K060AA C3216C0G1H153J060AA C2012C0G1E153J085AA C1608C0G1V183K080AC C1608C0G1V183J080AC C2012C0G1V183K060AC C2012C0G1V183J060AC C2012C0G1V223K060AC C2012C0G1V223J060AC C2012C0G1H223K125AA C2012C0G1H223J125AA C3216C0G1H223K060AA C3216C0G1H223J060AA C3225C0G1H223K125AA C3225C0G1H223J125AA C2012C0G1E223J125AA C2012C0G1V273K060AC C2012C0G1V273J060AC C2012C0G1V303K060AC C2012C0G1V303J060AC C2012C0G1H333K125AA C2012C0G1H333J125AA C3216C0G1H333K085AA C3216C0G1H333J085AA C3225C0G1H333K160AA C3225C0G1H333J160AA C3216C0G1H473K115AA C3216C0G1H473J115AA C3225C0G1H473K200AA C3225C0G1H473J200AA C4532C0G1H473K160KA C4532C0G1H473J160KA C3216C0G1H683K160AA C3216C0G1H683J160AA C3225C0G1H683K200AA C3225C0G1H683J200AA C4532C0G1H683K160KA C4532C0G1H683J160KA C3216C0G1H104K160AA C3216C0G1H104J160AA C3225C0G1H104K250AA C3225C0G1H104J250AA C4532C0G1H104K200KA C4532C0G1H104J200KA C4532C0G1H154K250KA C4532C0G1H154J250KA C4532C0G1H224K320KA C4532C0G1H224J320KA C2012C0G1E333J125AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (27/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:CH(-25 to +85℃, 0±60 ppm/℃) Capacitance 0.5 pF 0.75 pF 1 pF 1.5 pF 2 pF 2.2 pF 3 pF 3.3 pF 4 pF 4.7 pF 5 pF 6 pF 6.8 pF 7 pF Size Thickness (mm) Capacitance Tolerance 0402 0603 0.20±0.02 0.30±0.03 ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.25pF ±0.10pF ±0.25pF ±0.25pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0402 0603 0.80±0.10 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0402 0603 0.20±0.02 0.30±0.03 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc:25V C0603CH1H0R5C030BA C0603CH1E0R5C030BA Rated Voltage Edc:16V C0402CH1C0R5C020BC C1005CH1H0R5B050BA C1005CH1H0R5C050BA C1608CH1H0R5C080AA C0402CH1CR75C020BC C0603CH1HR75C030BA C0603CH1ER75C030BA C1005CH1HR75B050BA C1005CH1HR75C050BA C1608CH1HR75C080AA C0402CH1C010C020BC C0603CH1H010C030BA C0603CH1E010C030BA C1005CH1H010B050BA C1005CH1H010C050BA C1608CH1H010C080AA C0402CH1C1R5C020BC C0603CH1H1R5C030BA C0603CH1E1R5C030BA C1005CH1H1R5B050BA C1005CH1H1R5C050BA C1608CH1H1R5C080AA C0402CH1C020C020BC C0603CH1H020C030BA C0603CH1E020C030BA C1005CH1H020B050BA C1005CH1H020C050BA C1608CH1H020C080AA C0402CH1C2R2C020BC C0603CH1H2R2C030BA C0603CH1E2R2C030BA C0603CH1H030C030BA C0603CH1E030C030BA C0402CH1C030C020BC C1005CH1H030B050BA C1005CH1H030C050BA C1608CH1H030C080AA C0402CH1C3R3C020BC C0603CH1H3R3C030BA C0603CH1E3R3C030BA C0603CH1H040C030BA C0603CH1E040C030BA C0402CH1C040C020BC C1005CH1H040B050BA C1005CH1H040C050BA C1608CH1H040C080AA C0402CH1C4R7C020BC C0603CH1H4R7C030BA C0603CH1E4R7C030BA C0603CH1H050C030BA C0603CH1E050C030BA C0402CH1C050C020BC C1005CH1H050B050BA C1005CH1H050C050BA C1608CH1H050C080AA C0402CH1C060D020BC C0603CH1H060D030BA C0603CH1E060D030BA C1005CH1H060C050BA C1005CH1H060D050BA C1608CH1H060C080AA C1608CH1H060D080AA C0402CH1C6R8D020BC C0603CH1H6R8D030BA C0603CH1E6R8D030BA C0603CH1H070D030BA C0603CH1E070D030BA C0402CH1C070D020BC C1005CH1H070C050BA C1005CH1H070D050BA C1608CH1H070C080AA C1608CH1H070D080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (28/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:CH(-25 to +85℃, 0±60 ppm/℃) Capacitance 8 pF 9 pF 10 pF 12 pF 15 pF 18 pF 22 pF 27 pF 33 pF 39 pF Size Thickness (mm) Capacitance Tolerance 0402 0603 0.20±0.02 0.30±0.03 ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±0.50pF ±0.50pF ±0.25pF ±0.50pF ±0.25pF ±0.50pF ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0603 0.20±0.02 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc:25V C0603CH1H080D030BA C0603CH1E080D030BA Rated Voltage Edc:16V C0402CH1C080D020BC C1005CH1H080C050BA C1005CH1H080D050BA C1608CH1H080C080AA C1608CH1H080D080AA C0402CH1C090D020BC C0603CH1H090D030BA C0603CH1E090D030BA C1005CH1H090C050BA C1005CH1H090D050BA C1608CH1H090C080AA C1608CH1H090D080AA C0402CH1C100D020BC C0603CH1H100D030BA C0603CH1E100D030BA C1005CH1H100C050BA C1005CH1H100D050BA C1608CH1H100C080AA C1608CH1H100D080AA C0402CH1C120K020BC C0402CH1C120J020BC C0603CH1H120K030BA C0603CH1E120K030BA C0603CH1H120J030BA C0603CH1E120J030BA C1005CH1H120J050BA C1608CH1H120J080AA C0402CH1C150K020BC C0402CH1C150J020BC C0603CH1H150K030BA C0603CH1E150K030BA C0603CH1H150J030BA C0603CH1E150J030BA C1005CH1H150J050BA C1608CH1H150J080AA C0402CH1C180K020BC C0402CH1C180J020BC C0603CH1H180K030BA C0603CH1E180K030BA C0603CH1H180J030BA C0603CH1E180J030BA C1005CH1H180J050BA C1608CH1H180J080AA C0402CH1C220K020BC C0402CH1C220J020BC C0603CH1H220K030BA C0603CH1E220K030BA C0603CH1H220J030BA C0603CH1E220J030BA C1005CH1H220J050BA C1608CH1H220J080AA C0402CH1C270K020BC C0402CH1C270J020BC C0603CH1H270K030BA C0603CH1E270K030BA C0603CH1H270J030BA C0603CH1E270J030BA C1005CH1H270J050BA C1608CH1H270J080AA C0402CH1C330K020BC C0402CH1C330J020BC C0603CH1H330K030BA C0603CH1E330K030BA C0603CH1H330J030BA C0603CH1E330J030BA C1005CH1H330J050BA C1608CH1H330J080AA C0402CH1C390K020BC C0402CH1C390J020BC C0603CH1H390K030BA C0603CH1E390K030BA C0603CH1H390J030BA C0603CH1E390J030BA C1005CH1H390J050BA C1608CH1H390J080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (29/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:CH(-25 to +85℃, 0±60 ppm/℃) Capacitance 47 pF 56 pF 68 pF 82 pF Size Thickness (mm) 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 1608 0.50±0.05 0.80±0.10 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 100 pF 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 120 pF 1005 0.50±0.05 1608 0.80±0.10 150 pF 1005 0.50±0.05 180 pF 1608 0.80±0.10 1005 0.50±0.05 220 pF 1608 0.80±0.10 1005 0.50±0.05 270 pF 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 330 pF 1005 0.50±0.05 1608 0.80±0.10 390 pF Capacitance Tolerance ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±5% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc:25V C0603CH1H470K030BA C0603CH1E470K030BA C0603CH1H470J030BA C0603CH1E470J030BA Rated Voltage Edc:16V C0402CH1C470K020BC C0402CH1C470J020BC C1005CH1H470J050BA C1608CH1H470J080AA C0402CH1C560K020BC C0402CH1C560J020BC C0603CH1H560K030BA C0603CH1E560K030BA C0603CH1H560J030BA C0603CH1E560J030BA C1005CH1H560J050BA C1608CH1H560J080AA C0402CH1C680K020BC C0402CH1C680J020BC C0603CH1H680K030BA C0603CH1E680K030BA C0603CH1H680J030BA C0603CH1E680J030BA C1005CH1H680J050BA C1608CH1H680J080AA C0402CH1C820K020BC C0402CH1C820J020BC C0603CH1H820K030BA C0603CH1E820K030BA C0603CH1H820J030BA C0603CH1E820J030BA C1005CH1H820J050BA C1608CH1H820J080AA C0402CH1C101K020BC C0402CH1C101J020BC C0603CH1H101K030BA C0603CH1E101K030BA C0603CH1H101J030BA C0603CH1E101J030BA C1005CH1H101K050BA C1005CH1H101J050BA C1608CH1H101K080AA C1608CH1H101J080AA C1005CH1H121K050BA C1005CH1H121J050BA C1608CH1H121K080AA C1608CH1H121J080AA C1005CH1H151K050BA C1005CH1H151J050BA C1608CH1H151K080AA C1608CH1H151J080AA C1005CH1H181K050BA C1005CH1H181J050BA C1608CH1H181K080AA C1608CH1H181J080AA C1005CH1H221K050BA C1005CH1H221J050BA C1608CH1H221K080AA C1608CH1H221J080AA C1005CH1H271K050BA C1005CH1H271J050BA C1608CH1H271K080AA C1608CH1H271J080AA C1005CH1H331K050BA C1005CH1H331J050BA C1608CH1H331K080AA C1608CH1H331J080AA C1005CH1H391K050BA C1005CH1H391J050BA C1608CH1H391K080AA C1608CH1H391J080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (30/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:CH(-25 to +85℃, 0±60 ppm/℃) Capacitance Size Thickness (mm) 1005 0.50±0.05 470 pF 1608 0.80±0.10 1005 0.50±0.05 560 pF 1608 0.80±0.10 1005 0.50±0.05 680 pF 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 820 pF 1 nF 1005 0.50±0.05 1608 0.80±0.10 2012 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 1.2 nF 1608 0.80±0.10 2012 0.60±0.15 1.5 nF 1608 0.80±0.10 1.8 nF 2012 0.60±0.15 1608 0.80±0.10 2.2 nF 2012 0.60±0.15 0.85±0.15 1608 0.80±0.10 2012 0.60±0.15 2.7 nF 1608 3.3 nF 2012 0.80±0.10 0.60±0.15 1.25±0.20 1608 3.9 nF 4.7 nF 2012 0.80±0.10 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 Capacitance Tolerance ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% Catalog Number Rated Voltage Edc: 50V C1005CH1H471K050BA C1005CH1H471J050BA C1608CH1H471K080AA C1608CH1H471J080AA C1005CH1H561K050BA C1005CH1H561J050BA C1608CH1H561K080AA C1608CH1H561J080AA C1005CH1H681K050BA C1005CH1H681J050BA C1608CH1H681K080AA C1608CH1H681J080AA C1005CH1H821K050BA C1005CH1H821J050BA C1608CH1H821K080AA C1608CH1H821J080AA C1005CH1H102K050BA C1005CH1H102J050BA C1608CH1H102K080AA C1608CH1H102J080AA C2012CH1H102K060AA C2012CH1H102J060AA C1608CH1H122K080AA C1608CH1H122J080AA C2012CH1H122K060AA C2012CH1H122J060AA C1608CH1H152K080AA C1608CH1H152J080AA C2012CH1H152K060AA C2012CH1H152J060AA C1608CH1H182K080AA C1608CH1H182J080AA C2012CH1H182K060AA C2012CH1H182J060AA C1608CH1H222K080AA C1608CH1H222J080AA C2012CH1H222K060AA C2012CH1H222J060AA C2012CH1H222J085AA C1608CH1H272K080AA C1608CH1H272J080AA C2012CH1H272K060AA C2012CH1H272J060AA C1608CH1H332K080AA C1608CH1H332J080AA C2012CH1H332K060AA C2012CH1H332J060AA C2012CH1H332J125AA C1608CH1H392K080AA C1608CH1H392J080AA C2012CH1H392K060AA C2012CH1H392J060AA C3216CH1H392K060AA C3216CH1H392J060AA C1608CH1H472K080AA C1608CH1H472J080AA C2012CH1H472K060AA C2012CH1H472J060AA C3216CH1H472K060AA C3216CH1H472J060AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (31/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:CH(-25 to +85℃, 0±60 ppm/℃) Capacitance 5.6 nF 6.8 nF Size Thickness (mm) 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 8.2 nF 10 nF 15 nF 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.60±0.15 3216 0.60±0.15 1608 0.80±0.10 2012 0.85±0.15 3216 0.60±0.15 1608 0.80±0.10 18 nF 2012 0.60±0.15 0.60±0.15 2012 1.25±0.20 22 nF 3216 0.60±0.15 3225 1.25±0.20 27 nF 2012 0.60±0.15 30 nF 2012 0.60±0.15 33 nF 2012 1.25±0.20 3216 0.85±0.15 3225 47 nF 68 nF 1.60±0.20 3216 1.15±0.15 3225 2.00±0.20 4532 1.60±0.20 3216 1.60±0.20 3225 4532 2.00±0.20 1.60±0.20 Capacitance Tolerance ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% Catalog Number Rated Voltage Edc: 50V C1608CH1H562K080AA Rated Voltage Edc:35V C1608CH1H562J080AA C2012CH1H562K060AA C2012CH1H562J060AA C3216CH1H562K060AA C3216CH1H562J060AA C1608CH1H682K080AA C1608CH1H682J080AA C2012CH1H682K060AA C2012CH1H682J060AA C3216CH1H682K060AA C3216CH1H682J060AA C1608CH1H822K080AA C1608CH1H822J080AA C2012CH1H822K060AA C2012CH1H822J060AA C3216CH1H822K060AA C3216CH1H822J060AA C1608CH1H103K080AA C1608CH1V103K080AC C1608CH1H103J080AA C1608CH1V103J080AC C2012CH1H103K060AA C2012CH1H103J060AA C3216CH1H103K060AA C3216CH1H103J060AA C1608CH1V153K080AC C1608CH1V153J080AC C2012CH1H153K085AA C2012CH1H153J085AA C3216CH1H153K060AA C3216CH1H153J060AA C1608CH1V183K080AC C1608CH1V183J080AC C2012CH1V183K060AC C2012CH1V183J060AC C2012CH1V223K060AC C2012CH1V223J060AC C2012CH1H223K125AA C2012CH1H223J125AA C3216CH1H223K060AA C3216CH1H223J060AA C3225CH1H223K125AA C3225CH1H223J125AA C2012CH1V273K060AC C2012CH1V273J060AC C2012CH1V303K060AC C2012CH1V303J060AC C2012CH1H333K125AA C2012CH1H333J125AA C3216CH1H333K085AA C3216CH1H333J085AA C3225CH1H333K160AA C3225CH1H333J160AA C3216CH1H473K115AA C3216CH1H473J115AA C3225CH1H473K200AA C3225CH1H473J200AA C4532CH1H473K160KA C4532CH1H473J160KA C3216CH1H683K160AA C3216CH1H683J160AA C3225CH1H683K200AA C3225CH1H683J200AA C4532CH1H683K160KA C4532CH1H683J160KA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (32/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 1 (Temperature Compensating)  Temperature Characteristics:CH(-25 to +85℃, 0±60 ppm/℃) Size Thickness (mm) 3216 1.60±0.20 3225 2.50±0.30 4532 2.00±0.20 150 nF 4532 2.50±0.30 220 nF 4532 3.20±0.30 Capacitance 100 nF Capacitance Tolerance ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% ±10% ±5% Catalog Number Rated Voltage Edc: 50V C3216CH1H104K160AA C3216CH1H104J160AA C3225CH1H104K250AA C3225CH1H104J250AA C4532CH1H104K200KA C4532CH1H104J200KA C4532CH1H154K250KA C4532CH1H154J250KA C4532CH1H224K320KA C4532CH1H224J320KA Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance Size Thickness (mm) 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C0402JB1C101K020BC C0402JB1C101M020BC C0603JB1E101K030BA C0603JB1E101M030BA C0402JB1C151K020BC C0402JB1C151M020BC C0603JB1E151K030BA C0603JB1E151M030BA C0402JB1C221K020BC C0402JB1C221M020BC C0603JB1E221K030BA C0603JB1E221M030BA C1005JB1H221K050BA C1005JB1H221M050BA C0402JB1C331K020BC C0402JB1C331M020BC C0603JB1E331K030BA C0603JB1E331M030BA C1005JB1H331K050BA C1005JB1H331M050BA C0402JB1C471K020BC C0402JB1C471M020BC C0603JB1E471K030BA C0603JB1E471M030BA C1005JB1H471K050BA C1005JB1H471M050BA C0402JB1C681K020BC C0402JB1C681M020BC C0603JB1E681K030BA C0603JB1E681M030BA C1005JB1H681K050BA C1005JB1H681M050BA C0603JB1E102K030BA C0603JB1E102M030BA C1005JB1H102K050BA C1005JB1H102M050BA C0603JB1E152K030BA C0603JB1E152M030BA C1005JB1H152K050BA C1005JB1H152M050BA C0603JB1E222K030BA C0603JB1E222M030BA C1005JB1H222K050BA C1005JB1H222M050BA C0603JB1E332K030BA C0603JB1E332M030BA C1005JB1H332K050BA C1005JB1H332M050BA C0603JB1C472K030BA C0603JB1C472M030BA C1005JB1H472K050BA C1005JB1H472M050BA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (33/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance Size Thickness (mm) 6.8 nF 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 10 nF 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 0.30±0.03 0603 0.30±0.05 150 nF 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 0.30±0.03 0603 0.30±0.05 220 nF 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 330 nF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V C1005JB1H682K050BA Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C1005JB1H682M050BA C1005JB1H103K050BB C1005JB1E103K050BA C1005JB1H103M050BB C1005JB1E103M050BA C1608JB1H103K080AA C1608JB1H103M080AA C1005JB1H153K050BB C1005JB1E153K050BA C1005JB1C153K050BA C1005JB1H153M050BB C1005JB1E153M050BA C1005JB1C153M050BA C1608JB1H153K080AA C1608JB1H153M080AA C0603JB1E223K030BB C0603JB1E223M030BB C1005JB1H223K050BB C1005JB1E223K050BA C1005JB1C223K050BA C1005JB1H223M050BB C1005JB1E223M050BA C1005JB1C223M050BA C1608JB1H223K080AA C1608JB1H223M080AA C1005JB1H333K050BB C1005JB1E333K050BA C1005JB1C333K050BA C1005JB1H333M050BB C1005JB1E333M050BA C1005JB1C333M050BA C1608JB1H333K080AA C1608JB1H333M080AA C0603JB1E473K030BB C0603JB1E473M030BB C1005JB1H473K050BB C1005JB1E473K050BA C1005JB1C473K050BA C1005JB1H473M050BB C1005JB1E473M050BA C1005JB1C473M050BA C1608JB1H473K080AA C1608JB1H473M080AA C1005JB1H683K050BB C1005JB1V683K050BB C1005JB1E683K050BC C1005JB1C683K050BA C1005JB1H683M050BB C1005JB1V683M050BB C1005JB1E683M050BC C1005JB1C683M050BA C1608JB1H683K080AA C1608JB1H683M080AA C0603JB1E104K030BB C0603JB1C104K030BC C0603JB1E104M030BB C0603JB1C104M030BC C1005JB1H104K050BB C1005JB1V104K050BB C1005JB1E104K050BC C1005JB1C104K050BA C1005JB1H104M050BB C1005JB1V104M050BB C1005JB1E104M050BC C1005JB1C104M050BA C1608JB1H104K080AA C1608JB1H104M080AA C2012JB1H104K085AA C2012JB1H104M085AA C0603JB1C154K030BC C0603JB1C154M030BC C0603JB1E154K030BC C0603JB1E154M030BC C1005JB1E154K050BC C1005JB1C154K050BB C1005JB1E154M050BC C1005JB1C154M050BB C1608JB1H154K080AB C1608JB1V154K080AB C1608JB1E154K080AA C1608JB1H154M080AB C1608JB1V154M080AB C1608JB1E154M080AA C2012JB1H154K085AA C2012JB1H154M085AA C0603JB1C224K030BC C0603JB1C224M030BC C0603JB1E224K030BC C0603JB1E224M030BC C1005JB1E224K050BC C1005JB1C224K050BB C1005JB1E224M050BC C1005JB1C224M050BB C1608JB1H224K080AB C1608JB1V224K080AB C1608JB1E224K080AA C1608JB1H224M080AB C1608JB1V224M080AB C1608JB1E224M080AA C2012JB1H224K125AA C2012JB1H224M125AA C1005JB1V334K050BC C1005JB1E334K050BB C1005JB1C334K050BC C1005JB1V334M050BC C1005JB1E334M050BB C1005JB1C334M050BC C1608JB1H334K080AB C1608JB1V334K080AB C1608JB1E334K080AC C1608JB1C334K080AA C1608JB1H334M080AB C1608JB1V334M080AB C1608JB1E334M080AC C1608JB1C334M080AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (34/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance Size Thickness (mm) 330 nF 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 470 nF 680 nF 0.85±0.15 1 µF 2012 1.25±0.20 3216 1.60±0.20 0.50±0.05 1005 0.50±0.10 0.50+0.15/-0.10 1.5 µF 1608 0.80±0.10 0.85±0.15 2012 1.25±0.20 3216 1.60±0.20 0.50±0.05 1005 0.50±0.10 0.50+0.15/-0.10 1608 0.80±0.10 2.2 µF 0.85±0.15 2012 1.25±0.20 3216 1.60±0.20 3225 2.00±0.20 0.80±0.10 1608 0.80+0.20, -0.10 0.60±0.15 3.3 µF 2012 0.85±0.15 1.25±0.20 3216 1.60±0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V C2012JB1H334K125AA Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C2012JB1H334M125AA C1005JB1V474K050BC C1005JB1E474K050BB C1005JB1C474K050BC C1005JB1V474M050BC C1005JB1E474M050BB C1005JB1C474M050BC C1608JB1H474K080AB C1608JB1V474K080AB C1608JB1E474K080AC C1608JB1C474K080AA C1608JB1H474M080AB C1608JB1V474M080AB C1608JB1E474M080AC C1608JB1C474M080AA C2012JB1H474K125AB C2012JB1H474M125AB C1005JB1V684K050BC C1005JB1E684K050BC C1005JB1C684K050BC C1005JB1V684M050BC C1005JB1E684M050BC C1005JB1C684M050BC C1608JB1H684K080AB C1608JB1V684K080AB C1608JB1E684K080AC C1608JB1C684K080AA C1608JB1H684M080AB C1608JB1V684M080AB C1608JB1E684M080AC C1608JB1C684M080AA C2012JB1H684K125AB C2012JB1E684K125AA C2012JB1H684M125AB C2012JB1E684M125AA C1005JB1V105K050BC C1005JB1E105K050BC C1005JB1C105K050BC C1005JB1V105M050BC C1005JB1E105M050BC C1005JB1C105M050BC C1608JB1H105K080AB C1608JB1V105K080AB C1608JB1E105K080AC C1608JB1C105K080AA C1608JB1H105M080AB C1608JB1V105M080AB C1608JB1E105M080AC C1608JB1C105M080AA C2012JB1H105K085AB C2012JB1V105K085AB C2012JB1E105K085AC C2012JB1C105K085AA C2012JB1H105M085AB C2012JB1V105M085AB C2012JB1E105M085AC C2012JB1C105M085AA C2012JB1H105K125AB C2012JB1E105K125AA C2012JB1H105M125AB C2012JB1E105M125AA C3216JB1H105K160AA C3216JB1H105M160AA C1005JB1C155K050BC C1005JB1C155M050BC C1005JB1E155K050BC C1005JB1E155M050BC C1005JB1V155K050BC C1005JB1V155M050BC C1608JB1V155K080AC C1608JB1E155K080AB C1608JB1C155K080AB C1608JB1V155M080AC C1608JB1E155M080AB C1608JB1C155M080AB C2012JB1E155K085AC C2012JB1E155M085AC C2012JB1H155K125AB C2012JB1V155K125AB C2012JB1E155K125AB C2012JB1C155K125AA C2012JB1H155M125AB C2012JB1V155M125AB C2012JB1E155M125AB C2012JB1C155M125AA C3216JB1H155K160AB C3216JB1E155K160AA C3216JB1H155M160AB C3216JB1E155M160AA C1005JB1C225K050BC C1005JB1C225M050BC C1005JB1E225K050BC C1005JB1E225M050BC C1005JB1V225K050BC C1005JB1V225M050BC C1608JB1V225K080AC C1608JB1E225K080AB C1608JB1C225K080AB C1608JB1V225M080AC C1608JB1E225M080AB C1608JB1C225M080AB C2012JB1H225K085AB C2012JB1V225K085AB C2012JB1E225K085AB C2012JB1C225K085AC C2012JB1H225M085AB C2012JB1V225M085AB C2012JB1E225M085AB C2012JB1C225M085AC C2012JB1H225K125AB C2012JB1V225K125AB C2012JB1E225K125AC C2012JB1C225K125AA C2012JB1H225M125AB C2012JB1V225M125AB C2012JB1E225M125AC C2012JB1C225M125AA C3216JB1H225K160AB C3216JB1E225K160AA C3216JB1H225M160AB C3216JB1E225M160AA C3225JB1H225K200AA C3225JB1H225M200AA C1608JB1E335K080AC C1608JB1C335K080AC C1608JB1E335M080AC C1608JB1C335M080AC C1608JB1V335K080AC C1608JB1V335M080AC C2012JB1C335K060AC C2012JB1C335M060AC C2012JB1E335K085AC C2012JB1C335K085AB C2012JB1E335M085AC C2012JB1C335M085AB C2012JB1H335K125AB C2012JB1V335K125AC C2012JB1E335K125AB C2012JB1C335K125AC C2012JB1H335M125AB C2012JB1V335M125AC C2012JB1E335M125AB C2012JB1C335M125AC C3216JB1H335K160AB C3216JB1V335K160AB C3216JB1E335K160AA C3216JB1H335M160AB C3216JB1V335M160AB C3216JB1E335M160AA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (35/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance Size Thickness (mm) 3.3 µF 3225 2.50±0.30 0.80±0.10 1608 0.80+0.20, -0.10 0.60±0.15 2012 4.7 µF 0.85±0.15 1.25±0.20 0.85±0.10 3216 1.15±0.10 1.60±0.20 3225 2.50±0.30 1608 0.80+0.20, -0.10 0.85±0.15 2012 1.25±0.20 6.8 µF 3216 1.60±0.20 2.00±0.20 3225 2.50±0.30 4532 2.50±0.30 1608 0.80+0.20, -0.10 0.85±0.15 2012 1.25±0.20 0.85±0.10 10 µF 3216 1.60±0.20 2.00±0.20 3225 2.50±0.30 15 µF 4532 2.50±0.30 2012 3216 3225 4532 1.25±0.20 1.60±0.20 2.50±0.30 2.50±0.30 0.85±0.15 1.25±0.20 1.60±0.20 2.50±0.30 2.00±0.20 2.50±0.30 2.50±0.30 2012 22 µF 3216 3225 4532 5750 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 50V C3225JB1H335K250AA Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C3225JB1H335M250AA C1608JB1E475K080AC C1608JB1C475K080AC C1608JB1E475M080AC C1608JB1C475M080AC C1608JB1V475K080AC C1608JB1V475M080AC C2012JB1C475K060AC C2012JB1C475M060AC C2012JB1E475K085AC C2012JB1C475K085AB C2012JB1E475M085AC C2012JB1C475M085AB C2012JB1H475K125AB C2012JB1V475K125AC C2012JB1E475K125AB C2012JB1C475K125AC C2012JB1H475M125AB C2012JB1V475M125AC C2012JB1E475M125AB C2012JB1C475M125AC C3216JB1H475K085AB C3216JB1V475K085AB C3216JB1E475K085AB C3216JB1H475M085AB C3216JB1V475M085AB C3216JB1E475M085AB C3216JB1E475K115AB C3216JB1E475M115AB C3216JB1H475K160AB C3216JB1V475K160AB C3216JB1E475K160AA C3216JB1H475M160AB C3216JB1V475M160AB C3216JB1E475M160AA C3225JB1H475K250AB C3225JB1H475M250AB C1608JB1E685K080AC C1608JB1C685K080AB C1608JB1E685M080AC C1608JB1C685M080AB C2012JB1C685K085AC C2012JB1C685M085AC C2012JB1V685K125AC C2012JB1E685K125AC C2012JB1C685K125AC C2012JB1V685M125AC C2012JB1E685M125AC C2012JB1C685M125AB C3216JB1H685K160AB C3216JB1V685K160AB C3216JB1E685K160AB C3216JB1C685K160AA C3216JB1H685M160AB C3216JB1V685M160AB C3216JB1E685M160AB C3216JB1C685M160AA C3225JB1E685K200AA C3225JB1C685K200AA C3225JB1E685M200AA C3225JB1C685M200AA C1608JB1E106M080AC C1608JB1C106M080AB C3225JB1H685K250AB C3225JB1H685M250AB C4532JB1H685K250KA C4532JB1H685M250KA C2012JB1V106K085AC C2012JB1E106K085AC C2012JB1C106K085AC C2012JB1V106M085AC C2012JB1E106M085AC C2012JB1C106M085AC C2012JB1V106K125AC C2012JB1E106K125AB C2012JB1C106K125AB C2012JB1V106M125AC C2012JB1E106M125AB C2012JB1C106M125AB C3216JB1E106K085AC C3216JB1C106K085AB C3216JB1E106M085AC C3216JB1C106M085AB C3216JB1H106K160AB C3216JB1V106K160AB C3216JB1E106K160AB C3216JB1C106K160AA C3216JB1H106M160AB C3216JB1V106M160AB C3216JB1E106M160AB C3216JB1C106M160AA C3225JB1C106K200AA C3225JB1C106M200AA C3225JB1H106K250AB C3225JB1E106K250AA C3225JB1H106M250AB C3225JB1E106M250AA C4532JB1E106K250KA C4532JB1E106M250KA C2012JB1V156M125AC C2012JB1E156M125AC C3216JB1V156M160AC C3216JB1E156M160AB C2012JB1C156M125AC C3216JB1C156M160AB C3225JB1C156M250AA C4532JB1E156M250KA C2012JB1C226M085AC C2012JB1V226M125AC C2012JB1E226M125AC C3216JB1V226M160AC C3216JB1E226M160AB C2012JB1C226M125AC C3216JB1C226M160AB C3225JB1C226M250AA C4532JB1C226M200KA C4532JB1E226M250KA C5750JB1E226M250KA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (36/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance 33 µF 47 µF Size Thickness (mm) Capacitance Tolerance 3216 4532 3216 1.60±0.20 2.50±0.30 1.60±0.20 ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 25V C3216JB1E336M160AC Rated Voltage Edc: 16V C3216JB1C336M160AB C4532JB1C336M250KA C3216JB1E476M160AC C3216JB1C476M160AB Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance Size Thickness (mm) 1 nF 0402 0.20±0.02 1.5 nF 0402 0.20±0.02 2.2 nF 0402 0.20±0.02 3.3 nF 0402 0.20±0.02 4.7 nF 0402 0.20±0.02 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 15 nF 0603 0.30±0.03 22 nF 0603 0.30±0.03 33 nF 0603 0.30±0.03 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 6.8 nF 10 nF 47 nF 68 nF 100 nF 150 nF 220 nF 0.30±0.03 0603 330 nF 0.30±0.05 1005 0.50±0.05 0603 0.30±0.03 0.30±0.05 1005 0.50±0.05 470 nF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 10V C0402JB1A102K020BC Rated Voltage Edc:6.3V C0402JB0J102K020BC Rated Voltage Edc:4V C0402JB0G102K020BC C0402JB1A102M020BC C0402JB0J102M020BC C0402JB0G102M020BC C0402JB1A152K020BC C0402JB0J152K020BC C0402JB0G152K020BC C0402JB1A152M020BC C0402JB0J152M020BC C0402JB0G152M020BC C0402JB1A222K020BC C0402JB0J222K020BC C0402JB0G222K020BC C0402JB1A222M020BC C0402JB0J222M020BC C0402JB0G222M020BC C0402JB1A332K020BC C0402JB0J332K020BC C0402JB0G332K020BC C0402JB1A332M020BC C0402JB0J332M020BC C0402JB0G332M020BC C0402JB1A472K020BC C0402JB0J472K020BC C0402JB0G472K020BC C0402JB1A472M020BC C0402JB0J472M020BC C0402JB0G472M020BC C0402JB1A682K020BC C0402JB0J682K020BC C0402JB0G682K020BC C0402JB1A682M020BC C0402JB0J682M020BC C0402JB0G682M020BC C0603JB1A682K030BA C0603JB1A682M030BA C0402JB1A103K020BC C0402JB0J103K020BC C0402JB0G103K020BC C0402JB1A103M020BC C0402JB0J103M020BC C0402JB0G103M020BC C0603JB1A103K030BA C0603JB1A103M030BA C0603JB1A153K030BC C0603JB0J153K030BA C0603JB1A153M030BC C0603JB0J153M030BA C0603JB1A223K030BC C0603JB0J223K030BC C0603JB1A223M030BC C0603JB0J223M030BC C0603JB1A333K030BC C0603JB0J333K030BC C0603JB1A333M030BC C0603JB0J333M030BC C0603JB1A473K030BC C0603JB0J473K030BC C0603JB1A473M030BC C0603JB0J473M030BC C1005JB1A473K050BA C1005JB1A473M050BA C0603JB1A683K030BC C0603JB0J683K030BC C0603JB1A683M030BC C0603JB0J683M030BC C1005JB1A683K050BA C1005JB1A683M050BA C0603JB1A104K030BC C0603JB0J104K030BC C0603JB1A104M030BC C0603JB0J104M030BC C1005JB1A104K050BA C1005JB1A104M050BA C0603JB1A154K030BB C0603JB0J154K030BB C0603JB1A154M030BB C0603JB0J154M030BB C1005JB1A154K050BC C1005JB0J154K050BB C1005JB1A154M050BC C1005JB0J154M050BB C0603JB1A224K030BB C0603JB0J224K030BB C0603JB1A224M030BB C0603JB0J224M030BB C1005JB1A224K050BC C1005JB0J224K050BB C1005JB1A224M050BC C1005JB0J224M050BB C0603JB0J334M030BC C0603JB1A334K030BC C0603JB1A334M030BC C1005JB1A334K050BC C1005JB0J334K050BB C1005JB1A334M050BC C1005JB0J334M050BB C0603JB0J474M030BC C0603JB1A474M030BC C1005JB1A474K050BC C1005JB0J474K050BB C1005JB1A474M050BC C1005JB0J474M050BB ■ The gray items are non-recommended products in the new design. ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (37/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance Size Thickness (mm) 1005 0.50±0.05 680 nF 1608 0.80+0.15/-0.10 1005 0.50±0.05 1608 0.80+0.15/-0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 1005 0.50±0.10 1 µF 1.5 µF 2.2 µF 0.80+0.15, -0.10 3.3 µF 1608 0.80±0.10 2012 1.25±0.20 1005 0.50+0.15/-0.10 0.80+0.15, -0.10 1608 0.80±0.10 4.7 µF 0.60±0.15 2012 0.85±0.15 1.25±0.20 1608 0.80±0.10 0.60±0.15 6.8 µF 2012 0.85±0.15 1.25±0.20 1608 0.80±0.10 0.85±0.15 10 µF 2012 1.25±0.20 15 µF 3216 1.60±0.20 1608 0.80+0.20, -0.10 0.85±0.15 1.25±0.20 1.60±0.20 2.30±0.20 2012 3216 3225 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 10V C1005JB1A684K050BC Rated Voltage Edc:6.3V C1005JB0J684K050BB C1005JB1A684M050BC C1005JB0J684M050BB Rated Voltage Edc:4V C1608JB1A684K080AC C1608JB1A684M080AC C1005JB1A105K050BB C1005JB0J105K050BB C1005JB1A105M050BB C1005JB0J105M050BB C1608JB1A105K080AC C1608JB1A105M080AC C1005JB1A155K050BC C1005JB0J155K050BB C1005JB1A155M050BC C1005JB0J155M050BB C1608JB1A155K080AC C1608JB0J155K080AB C1608JB1A155M080AC C1608JB0J155M080AB C1005JB1A225K050BC C1005JB0J225K050BC C1005JB0G225K050BB C1005JB1A225M050BC C1005JB0J225M050BC C1005JB0G225M050BB C1608JB1A225K080AC C1608JB0J225K080AB C1608JB1A225M080AC C1608JB0J225M080AB C2012JB1A225K085AA C2012JB1A225M085AA C1005JB1A335K050BC C1005JB0J335K050BC C1005JB0G335K050BB C1005JB1A335M050BC C1005JB0J335M050BC C1005JB0G335M050BB C1608JB0J335K080AB C1608JB0J335M080AB C1608JB1A335K080AB C1608JB1A335M080AB C2012JB1A335K125AA C2012JB1A335M125AA C1005JB1A475K050BC C1005JB0J475K050BC C1005JB0G475K050BB C1005JB1A475M050BC C1005JB0J475M050BC C1005JB0G475M050BB C1608JB0J475K080AB C1608JB0J475M080AB C1608JB1A475K080AB C1608JB1A475M080AB C2012JB1A475K060AB C2012JB1A475M060AB C2012JB0J475K085AB C2012JB0J475M085AB C2012JB1A475K125AA C2012JB1A475M125AA C1608JB1A685K080AC C1608JB0J685K080AB C1608JB1A685M080AC C1608JB0J685M080AB C2012JB1A685K060AC C2012JB1A685M060AC C2012JB1A685K085AC C2012JB0J685K085AB C2012JB1A685M085AC C2012JB0J685M085AB C2012JB1A685K125AC C2012JB0J685K125AB C2012JB1A685M125AC C2012JB0J685M125AB C1608JB1A106K080AC C1608JB0J106K080AB C1608JB1A106M080AC C1608JB0J106M080AB C2012JB1A106K085AC C2012JB0J106K085AB C2012JB1A106M085AC C2012JB0J106M085AB C2012JB1A106K125AC C2012JB0J106K125AB C2012JB1A106M125AC C2012JB0J106M125AB C3216JB1A106K160AA C3216JB1A106M160AA C1608JB1A156M080AC C1608JB0J156M080AC C2012JB1A156M085AC C2012JB0J156M085AB C2012JB1A156M125AB C2012JB0J156M125AC C1608JB0G156M080AA C3216JB1A156M160AC C3225JB1A156M230AA ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (38/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable)  Temperature Characteristics:JB(-25 to +85℃, ±10%) Capacitance Size 1608 22 µF 2012 3216 3225 2012 33 µF 47 µF 68 µF 100 µF 3216 2012 3216 3216 3225 3216 3225 Thickness (mm) Capacitance Tolerance 0.80+0.20, -0.10 0.85±0.15 1.25±0.20 1.60±0.20 2.50±0.30 1.25±0.20 1.30±0.20 1.60±0.20 1.25±0.20 1.60±0.20 1.60+0.30/-0.10 2.00±0.20 1.60+0.30/-0.10 2.50±0.30 ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 10V C1608JB1A226M080AC Rated Voltage Edc:6.3V C1608JB0J226M080AC C2012JB1A226M085AC C2012JB0J226M085AB C2012JB1A226M125AB C2012JB0J226M125AC Rated Voltage Edc:4V C1608JB0G226M080AA C3216JB1A226M160AC C3225JB1A226M250AA C2012JB1A336M125AC C2012JB0J336M125AC C3216JB0J336M130AC C3216JB1A336M160AB C2012JB1A476M125AC C2012JB0J476M125AC C3216JB1A476M160AB C3216JB0J476M160AC C3216JB1A686M160AC C3216JB0J686M160AB C3225JB0J686M200AC C3216JB1A107M160AC C3216JB0J107M160AB C3225JB0J107M250AC Class 2 (Temperature Stable)  Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance Size Thickness (mm) 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 100 pF 150 pF 220 pF 330 pF 470 pF 680 pF 1 nF 1.5 nF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C0402X5R1C101K020BC C0402X5R1C101M020BC C0603X5R1E101K030BA C0603X5R1E101M030BA C0402X5R1C151K020BC C0402X5R1C151M020BC C0603X5R1E151K030BA C0603X5R1E151M030BA C0402X5R1C221K020BC C0402X5R1C221M020BC C0603X5R1E221K030BA C0603X5R1E221M030BA C1005X5R1H221K050BA C1005X5R1H221M050BA C0402X5R1C331K020BC C0402X5R1C331M020BC C0603X5R1E331K030BA C0603X5R1E331M030BA C1005X5R1H331K050BA C1005X5R1H331M050BA C0402X5R1C471K020BC C0402X5R1C471M020BC C0603X5R1E471K030BA C0603X5R1E471M030BA C1005X5R1H471K050BA C1005X5R1H471M050BA C0402X5R1C681K020BC C0402X5R1C681M020BC C0603X5R1E681K030BA C0603X5R1E681M030BA C1005X5R1H681K050BA C1005X5R1H681M050BA C0603X5R1E102K030BA C0603X5R1E102M030BA C1005X5R1H102K050BA C1005X5R1H102M050BA C0603X5R1E152K030BA C0603X5R1E152M030BA C1005X5R1H152K050BA C1005X5R1H152M050BA ■ The gray items are non-recommended products in the new design. ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (39/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance Size Thickness (mm) 0603 0.30±0.03 2.2 nF 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 0603 0.30±0.03 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 0.30±0.03 0603 0.30±0.05 150 nF 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 35V Rated Voltage Edc: 25V C0603X5R1E222K030BA Rated Voltage Edc: 16V C0603X5R1E222M030BA C1005X5R1H222K050BA C1005X5R1H222M050BA C0603X5R1E332K030BA C0603X5R1E332M030BA C1005X5R1H332K050BA C1005X5R1H332M050BA C0603X5R1C472K030BA C0603X5R1C472M030BA C1005X5R1H472K050BA C1005X5R1H472M050BA C1005X5R1H682K050BA C1005X5R1H682M050BA C0603X5R1C103K030BA C0603X5R1C103M030BA C1005X5R1H103K050BB C1005X5R1E103K050BA C1005X5R1H103M050BB C1005X5R1E103M050BA C1608X5R1H103K080AA C1608X5R1H103M080AA C1005X5R1H153K050BB C1005X5R1E153K050BA C1005X5R1C153K050BA C1005X5R1H153M050BB C1005X5R1E153M050BA C1005X5R1C153M050BA C1608X5R1H153K080AA C1608X5R1H153M080AA C0603X5R1E223K030BB C0603X5R1E223M030BB C1005X5R1H223K050BB C1005X5R1E223K050BA C1005X5R1C223K050BA C1005X5R1H223M050BB C1005X5R1E223M050BA C1005X5R1C223M050BA C1608X5R1H223K080AA C1608X5R1H223M080AA C1005X5R1H333K050BB C1005X5R1E333K050BA C1005X5R1C333K050BA C1005X5R1H333M050BB C1005X5R1E333M050BA C1005X5R1C333M050BA C1608X5R1H333K080AA C1608X5R1H333M080AA C0603X5R1E473K030BB C0603X5R1E473M030BB C1005X5R1H473K050BB C1005X5R1E473K050BA C1005X5R1C473K050BA C1005X5R1H473M050BB C1005X5R1E473M050BA C1005X5R1C473M050BA C1608X5R1H473K080AA C1608X5R1H473M080AA C1005X5R1H683K050BB C1005X5R1V683K050BB C1005X5R1E683K050BC C1005X5R1C683K050BA C1005X5R1H683M050BB C1005X5R1V683M050BB C1005X5R1E683M050BC C1005X5R1C683M050BA C1608X5R1H683K080AA C1608X5R1H683M080AA C0603X5R1E104K030BB C0603X5R1C104K030BC C0603X5R1E104M030BB C0603X5R1C104M030BC C1005X5R1H104K050BB C1005X5R1V104K050BB C1005X5R1E104K050BC C1005X5R1C104K050BA C1005X5R1H104M050BB C1005X5R1V104M050BB C1005X5R1E104M050BC C1005X5R1C104M050BA C1608X5R1H104K080AA C1608X5R1H104M080AA C2012X5R1H104K085AA C2012X5R1H104M085AA C0603X5R1C154K030BC C0603X5R1C154M030BC C0603X5R1E154K030BC C0603X5R1E154M030BC C1005X5R1E154K050BC C1005X5R1C154K050BB C1005X5R1E154M050BC C1005X5R1C154M050BB C1608X5R1H154K080AB C1608X5R1V154K080AB C1608X5R1E154K080AA C1608X5R1H154M080AB C1608X5R1V154M080AB C1608X5R1E154M080AA C2012X5R1H154K085AA C2012X5R1H154M085AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (40/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance Size Thickness (mm) 0.30±0.03 0603 0.30±0.05 220 nF 330 nF 470 nF 680 nF 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 0.85±0.15 1 µF 2012 1.25±0.20 3216 1.60±0.20 0.50+0.15/-0.10 1005 0.50±0.05 0.50±0.10 1.5 µF 1608 0.80±0.10 0.85±0.15 2012 1.25±0.20 3216 1.60±0.20 0.50+0.15/-0.10 1005 0.50±0.10 0.50±0.05 2.2 µF 1608 0.80±0.10 0.85±0.15 2012 1.25±0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C0603X5R1C224K030BC C0603X5R1C224M030BC C0603X5R1E224K030BC C0603X5R1E224M030BC C1005X5R1E224K050BC C1005X5R1C224K050BB C1005X5R1E224M050BC C1005X5R1C224M050BB C1608X5R1H224K080AB C1608X5R1V224K080AB C1608X5R1E224K080AA C1608X5R1H224M080AB C1608X5R1V224M080AB C1608X5R1E224M080AA C2012X5R1H224K125AA C2012X5R1H224M125AA C1005X5R1V334K050BC C1005X5R1E334K050BB C1005X5R1C334K050BC C1005X5R1V334M050BC C1005X5R1E334M050BB C1005X5R1C334M050BC C1608X5R1H334K080AB C1608X5R1V334K080AB C1608X5R1E334K080AC C1608X5R1C334K080AA C1608X5R1H334M080AB C1608X5R1V334M080AB C1608X5R1E334M080AC C1608X5R1C334M080AA C2012X5R1H334K125AA C2012X5R1H334M125AA C1005X5R1V474K050BC C1005X5R1E474K050BB C1005X5R1C474K050BC C1005X5R1V474M050BC C1005X5R1E474M050BB C1005X5R1C474M050BC C1608X5R1H474K080AB C1608X5R1V474K080AB C1608X5R1E474K080AC C1608X5R1C474K080AA C1608X5R1H474M080AB C1608X5R1V474M080AB C1608X5R1E474M080AC C1608X5R1C474M080AA C2012X5R1H474K125AB C2012X5R1H474M125AB C1005X5R1V684K050BC C1005X5R1E684K050BC C1005X5R1C684K050BC C1005X5R1V684M050BC C1005X5R1E684M050BC C1005X5R1C684M050BC C1608X5R1H684K080AB C1608X5R1V684K080AB C1608X5R1E684K080AC C1608X5R1C684K080AA C1608X5R1H684M080AB C1608X5R1V684M080AB C1608X5R1E684M080AC C1608X5R1C684M080AA C2012X5R1H684K125AB C2012X5R1E684K125AA C2012X5R1H684M125AB C2012X5R1E684M125AA C1005X5R1V105K050BC C1005X5R1E105K050BC C1005X5R1C105K050BC C1005X5R1V105M050BC C1005X5R1E105M050BC C1005X5R1C105M050BC C1608X5R1H105K080AB C1608X5R1V105K080AB C1608X5R1E105K080AC C1608X5R1C105K080AA C1608X5R1H105M080AB C1608X5R1V105M080AB C1608X5R1E105M080AC C1608X5R1C105M080AA C2012X5R1H105K085AB C2012X5R1V105K085AB C2012X5R1E105K085AC C2012X5R1C105K085AA C2012X5R1H105M085AB C2012X5R1V105M085AB C2012X5R1E105M085AC C2012X5R1C105M085AA C2012X5R1H105K125AB C2012X5R1E105K125AA C2012X5R1H105M125AB C2012X5R1E105M125AA C3216X5R1H105K160AA C3216X5R1H105M160AA C1005X5R1V155K050BC C1005X5R1V155M050BC C1005X5R1C155K050BC C1005X5R1C155M050BC C1005X5R1E155K050BC C1005X5R1E155M050BC C1608X5R1V155K080AC C1608X5R1E155K080AB C1608X5R1C155K080AB C1608X5R1V155M080AC C1608X5R1E155M080AB C1608X5R1C155M080AB C2012X5R1E155K085AC C2012X5R1E155M085AC C2012X5R1H155K125AB C2012X5R1V155K125AB C2012X5R1E155K125AA C2012X5R1C155K125AA C2012X5R1H155M125AB C2012X5R1V155M125AB C2012X5R1E155M125AA C2012X5R1C155M125AA C3216X5R1H155K160AB C3216X5R1E155K160AA C3216X5R1H155M160AB C3216X5R1E155M160AA C1005X5R1V225K050BC C1005X5R1V225M050BC C1005X5R1E225K050BC C1005X5R1E225M050BC C1005X5R1C225K050BC C1005X5R1C225M050BC C1608X5R1V225K080AC C1608X5R1E225K080AB C1608X5R1C225K080AB C1608X5R1V225M080AC C1608X5R1E225M080AB C1608X5R1C225M080AB C2012X5R1H225K085AB C2012X5R1V225K085AB C2012X5R1E225K085AC C2012X5R1C225K085AC C2012X5R1H225M085AB C2012X5R1V225M085AB C2012X5R1E225M085AC C2012X5R1C225M085AC C2012X5R1H225K125AB C2012X5R1V225K125AB C2012X5R1E225K125AC C2012X5R1C225K125AA C2012X5R1H225M125AB C2012X5R1V225M125AB C2012X5R1E225M125AC C2012X5R1C225M125AA ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (41/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance Size Thickness (mm) 3216 1.60±0.20 2.2 µF 3225 2.50±0.30 0.80±0.10 1608 0.80+0.20, -0.10 0.60±0.15 3.3 µF 2012 0.85±0.15 1.25±0.20 3216 1.60±0.20 3225 2.50±0.30 0.80±0.10 1608 0.80+0.20, -0.10 0.60±0.15 2012 4.7 µF 0.85±0.15 1.25±0.20 0.85±0.15 3216 1.15±0.15 1.60±0.20 3225 2.50±0.30 1608 0.80+0.20, -0.10 0.85±0.15 2012 1.25±0.20 6.8 µF 3216 1.60±0.20 2.00±0.20 3225 2.50±0.30 4532 2.50±0.30 1608 0.80+0.20, -0.10 0.85±0.15 2012 1.25±0.20 10 µF 0.85±0.15 3216 1.60±0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V C3216X5R1H225K160AB Rated Voltage Edc: 35V C3216X5R1H225M160AB Rated Voltage Edc: 25V C3216X5R1E225K160AA Rated Voltage Edc: 16V C3216X5R1E225M160AA C3225X5R1H225K250AB C3225X5R1H225M250AB C1608X5R1E335K080AC C1608X5R1C335K080AC C1608X5R1E335M080AC C1608X5R1C335M080AC C1608X5R1V335K080AC C1608X5R1V335M080AC C2012X5R1C335K060AC C2012X5R1C335M060AC C2012X5R1E335K085AC C2012X5R1C335K085AB C2012X5R1E335M085AC C2012X5R1C335M085AB C2012X5R1H335K125AB C2012X5R1V335K125AC C2012X5R1E335K125AB C2012X5R1C335K125AC C2012X5R1H335M125AB C2012X5R1V335M125AC C2012X5R1E335M125AB C2012X5R1C335M125AC C3216X5R1H335K160AB C3216X5R1V335K160AB C3216X5R1E335K160AA C3216X5R1H335M160AB C3216X5R1V335M160AB C3216X5R1E335M160AA C3225X5R1H335K250AB C3225X5R1H335M250AB C1608X5R1E475K080AC C1608X5R1C475K080AC C1608X5R1E475M080AC C1608X5R1C475M080AC C1608X5R1V475K080AC C1608X5R1V475M080AC C2012X5R1C475K060AC C2012X5R1C475M060AC C2012X5R1E475K085AC C2012X5R1C475K085AB C2012X5R1E475M085AC C2012X5R1C475M085AB C2012X5R1H475K125AB C2012X5R1V475K125AC C2012X5R1E475K125AB C2012X5R1C475K125AC C2012X5R1H475M125AB C2012X5R1V475M125AC C2012X5R1E475M125AB C2012X5R1C475M125AC C3216X5R1H475K085AB C3216X5R1V475K085AB C3216X5R1E475K085AB C3216X5R1H475M085AB C3216X5R1V475M085AB C3216X5R1E475M085AB C3216X5R1E475K115AB C3216X5R1C475K115AA C3216X5R1E475M115AB C3216X5R1C475M115AA C3216X5R1H475K160AB C3216X5R1V475K160AB C3216X5R1E475K160AA C3216X5R1H475M160AB C3216X5R1V475M160AB C3216X5R1E475M160AA C3225X5R1H475K250AB C3225X5R1H475M250AB C1608X5R1E685K080AC C1608X5R1C685K080AB C1608X5R1E685M080AC C1608X5R1C685M080AB C2012X5R1C685K085AC C2012X5R1C685M085AC C2012X5R1V685K125AC C2012X5R1E685K125AC C2012X5R1C685K125AC C2012X5R1V685M125AC C2012X5R1E685M125AC C2012X5R1C685M125AC C3216X5R1H685K160AB C3216X5R1V685K160AB C3216X5R1E685K160AB C3216X5R1C685K160AA C3216X5R1H685M160AB C3216X5R1V685M160AB C3216X5R1E685M160AB C3216X5R1C685M160AA C3225X5R1C685K200AA C3225X5R1C685M200AA C3225X5R1H685K250AB C3225X5R1E685K250AA C3225X5R1H685M250AB C3225X5R1E685M250AA C4532X5R1H685K250KA C4532X5R1H685M250KA C1608X5R1E106M080AC C1608X5R1C106M080AB C2012X5R1V106K085AC C2012X5R1E106K085AC C2012X5R1C106K085AC C2012X5R1V106M085AC C2012X5R1E106M085AC C2012X5R1C106M085AC C2012X5R1V106K125AC C2012X5R1E106K125AB C2012X5R1C106K125AC C2012X5R1V106M125AC C2012X5R1E106M125AB C2012X5R1C106M125AC C3216X5R1E106K085AC C3216X5R1C106K085AC C3216X5R1E106M085AC C3216X5R1C106M085AC C3216X5R1H106K160AB C3216X5R1V106K160AB C3216X5R1E106K160AB C3216X5R1C106K160AA C3216X5R1H106M160AB C3216X5R1V106M160AB C3216X5R1E106M160AB C3216X5R1C106M160AA ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (42/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance Size Thickness (mm) 2.00±0.20 3225 2.50±0.30 10 µF 15 µF 4532 2.50±0.30 5750 2.30±0.20 2012 3216 3225 1.25±0.20 1.60±0.20 2.50±0.30 2.50±0.30 2.80±0.30 0.85±0.15 4532 2012 22 µF 3216 1.60±0.20 3225 2.50±0.30 4532 5750 33 µF 47 µF 1.25±0.20 3216 4532 5750 3216 5750 2.00±0.20 2.30±0.20 2.50±0.30 2.30±0.20 2.50±0.30 1.60±0.20 2.50±0.30 2.00±0.20 1.60±0.20 2.30±0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±20% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C3225X5R1C106K200AA C3225X5R1C106M200AA C3225X5R1H106K250AB C3225X5R1E106K250AA C3225X5R1H106M250AB C3225X5R1E106M250AA C4532X5R1E106K250KA C4532X5R1E106M250KA C5750X5R1H106K230KA C5750X5R1H106M230KA C2012X5R1V156M125AC C2012X5R1E156M125AC C3216X5R1V156M160AC C3216X5R1E156M160AB C2012X5R1C156M125AC C3216X5R1C156M160AB C3225X5R1C156M250AA C4532X5R1E156M250KA C4532X5R1E156M280KA C2012X5R1C226M085AC C2012X5R1C226K125AC C2012X5R1V226M125AC C2012X5R1E226M125AC C2012X5R1C226M125AC C3216X5R1V226M160AC C3216X5R1E226M160AB C3216X5R1C226M160AB C3225X5R1C226K250AA C3225X5R1C226M250AA C4532X5R1C226M200KA C4532X5R1C226M230KA C4532X5R1E226M250KA C5750X5R1E226M230KA C5750X5R1E226M250KA C3216X5R1E336M160AC C3216X5R1C336M160AB C4532X5R1C336M250KA C5750X5R1C336M200KA C3216X5R1E476M160AC C3216X5R1C476M160AB C5750X5R1C476M230KA Class 2 (Temperature Stable) Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance Size Thickness (mm) 1 nF 0402 0.20±0.02 1.5 nF 0402 0.20±0.02 2.2 nF 0402 0.20±0.02 3.3 nF 0402 0.20±0.02 4.7 nF 0402 0.20±0.02 0402 0.20±0.02 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 0603 0.30±0.03 0402 0.20±0.02 0603 0.30±0.03 0603 0.30±0.03 6.8 nF 10 nF 15 nF 22 nF 33 nF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 10V C0402X5R1A102K020BC Rated Voltage Edc:6.3V C0402X5R0J102K020BC Rated Voltage Edc:4V C0402X5R0G102K020BC C0402X5R1A102M020BC C0402X5R0J102M020BC C0402X5R0G102M020BC C0402X5R1A152K020BC C0402X5R0J152K020BC C0402X5R0G152K020BC C0402X5R1A152M020BC C0402X5R0J152M020BC C0402X5R0G152M020BC C0402X5R1A222K020BC C0402X5R0J222K020BC C0402X5R0G222K020BC C0402X5R1A222M020BC C0402X5R0J222M020BC C0402X5R0G222M020BC C0402X5R1A332K020BC C0402X5R0J332K020BC C0402X5R0G332K020BC C0402X5R1A332M020BC C0402X5R0J332M020BC C0402X5R0G332M020BC C0402X5R1A472K020BC C0402X5R0J472K020BC C0402X5R0G472K020BC C0402X5R1A472M020BC C0402X5R0J472M020BC C0402X5R0G472M020BC C0402X5R1A682K020BC C0402X5R0J682K020BC C0402X5R0G682K020BC C0402X5R1A682M020BC C0402X5R0J682M020BC C0402X5R0G682M020BC C0603X5R1A682K030BA C0603X5R1A682M030BA C0402X5R1A103K020BC C0402X5R0J103K020BC C0402X5R0G103K020BC C0402X5R1A103M020BC C0402X5R0J103M020BC C0402X5R0G103M020BC C0603X5R1A103K030BA C0603X5R1A103M030BA C0603X5R1A153K030BC C0603X5R0J153K030BA C0603X5R1A153M030BC C0603X5R0J153M030BA C0402X5R0J223M020BC C0603X5R1A223K030BC C0603X5R0J223K030BC C0603X5R1A223M030BC C0603X5R0J223M030BC C0603X5R1A333K030BC C0603X5R0J333K030BC C0603X5R1A333M030BC C0603X5R0J333M030BC C0402X5R0G223M020BC ■ The gray items are non-recommended products in the new design. ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (43/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance 47 nF Size Thickness (mm) Capacitance Tolerance 0402 0.20±0.02 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.02 ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% 68 nF 100 nF 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0402 0.20±0.03 150 nF 220 nF 0603 0.30±0.03 1005 0.50±0.05 0.30±0.03 0603 330 nF 1005 0603 0.30±0.05 0.50±0.05 0.30±0.03 0.30±0.05 470 nF 1005 0.50±0.05 1608 0.80+0.15/-0.10 1005 0.50±0.05 1608 0.80+0.15/-0.10 0603 0.30±0.05 680 nF 1 µF 1005 0.50±0.05 1608 0.80+0.15/-0.10 1005 0.50±0.05 1608 0.80±0.10 1.5 µF 2.2 µF 3.3 µF 4.7 µF 0603 0.30±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 1005 0.50±0.10 1608 0.80±0.10 2012 1.25±0.20 1005 0.50+0.15/-0.10 Catalog Number Rated Voltage Edc: 10V Rated Voltage Edc:6.3V C0402X5R0J473M020BC C0603X5R1A473K030BC C0603X5R0J473K030BC C0603X5R1A473M030BC C0603X5R0J473M030BC Rated Voltage Edc:4V C0402X5R0G473M020BC C1005X5R1A473K050BA C1005X5R1A473M050BA C0603X5R1A683K030BC C0603X5R0J683K030BC C0603X5R1A683M030BC C0603X5R0J683M030BC C1005X5R1A683K050BA C1005X5R1A683M050BA C0402X5R0J104M020BC C0603X5R1A104K030BC C0603X5R0J104K030BC C0603X5R1A104M030BC C0603X5R0J104M030BC C1005X5R1A104K050BA C1005X5R0J104K050BA C0402X5R0G104M020BC C1005X5R1A104M050BA C0603X5R1A154K030BB C0603X5R0J154K030BB C0603X5R1A154M030BB C0603X5R0J154M030BB C1005X5R1A154K050BC C1005X5R0J154K050BB C1005X5R1A154M050BC C1005X5R0J154M050BB C0603X5R1A224K030BB C0603X5R0J224K030BB C0603X5R1A224M030BB C0603X5R0J224M030BB C0402X5R0G224M020BC C1005X5R1A224K050BC C1005X5R0J224K050BB C1005X5R1A224M050BC C1005X5R0J224M050BB C0603X5R0J334M030BC C0603X5R1A334K030BC C0603X5R1A334M030BC C1005X5R1A334K050BB C1005X5R0J334K050BB C1005X5R1A334M050BB C1005X5R0J334M050BB C0603X5R0J474K030BC C0603X5R0J474M030BC C0603X5R1A474M030BC C1005X5R1A474K050BB C1005X5R0J474K050BB C1005X5R1A474M050BB C1005X5R0J474M050BB C1608X5R1A474K080AA C1005X5R1A684K050BB C1005X5R0J684K050BB C1005X5R1A684M050BB C1005X5R0J684M050BB C1608X5R1A684K080AC C1608X5R1A684M080AC C0603X5R0J105M030BC C1005X5R1A105K050BB C1005X5R0J105K050BB C1005X5R1A105M050BB C1005X5R0J105M050BB C0603X5R0G105M030BC C1608X5R1A105K080AC C1608X5R1A105M080AC C1005X5R1A155K050BC C1005X5R0J155K050BB C1005X5R1A155M050BC C1005X5R0J155M050BB C1608X5R1A155K080AB C1608X5R0J155K080AB C1608X5R1A155M080AB C1608X5R0J155M080AB C0603X5R0J225M030BC C0603X5R0G225M030BC C1005X5R1A225K050BC C1005X5R0J225K050BC C1005X5R0G225K050BB C1005X5R1A225M050BC C1005X5R0J225M050BC C1005X5R0G225M050BB C1608X5R1A225K080AC C1608X5R0J225K080AB C1608X5R1A225M080AC C1608X5R0J225M080AB C2012X5R1A225K085AA C2012X5R0J225K085AA C2012X5R1A225M085AA C2012X5R0J225M085AA C1005X5R1A335K050BC C1005X5R0J335K050BC C1005X5R0G335K050BB C1005X5R1A335M050BC C1005X5R0J335M050BC C1005X5R0G335M050BB C1608X5R1A335K080AC C1608X5R0J335K080AB C1608X5R1A335M080AC C1608X5R0J335M080AB C2012X5R1A335K125AA C2012X5R1A335M125AA C1005X5R1A475K050BC C1005X5R0J475K050BC C1005X5R0G475K050BB C1005X5R1A475M050BC C1005X5R0J475M050BC C1005X5R0G475M050BB ■ The gray items are non-recommended products in the new design. ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (44/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X5R(-55 to +85℃, ±15%) Capacitance Size Thickness (mm) 1608 0.80±0.10 0.60±0.15 4.7 µF 2012 0.85±0.15 1.25±0.20 1608 0.80±0.10 0.60±0.15 6.8 µF 2012 0.85±0.15 1.25±0.20 10 µF 1005 0.50+0.20/-0.10 1608 0.80±0.10 0.85±0.15 2012 1.25±0.20 15 µF 3216 1.60±0.20 1608 0.80+0.20, -0.10 0.85±0.15 1.25±0.20 1.60±0.20 2.30±0.20 0.80+0.20, -0.10 0.85±0.15 2012 3216 3225 1608 2012 22 µF 3216 3225 4532 2012 3216 33 µF 3225 47 µF 4532 2012 3216 3225 4532 68 µF 100 µF 3216 3225 4532 5750 3216 3225 4532 5750 1.25±0.20 0.85±0.15 1.60±0.20 2.00±0.20 2.30±0.20 2.30±0.20 1.25±0.20 1.30±0.20 1.60±0.20 2.00±0.20 2.50±0.30 2.30±0.20 1.25±0.20 1.60±0.20 2.50±0.30 2.50±0.30 2.80±0.30 1.60+0.30, -0.10 2.00±0.20 2.80±0.30 2.30±0.20 1.60+0.30, -0.10 2.50±0.30 2.80±0.30 2.80±0.30 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±10% ±20% ±20% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 10V C1608X5R1A475K080AC Rated Voltage Edc:6.3V C1608X5R0J475K080AB C1608X5R1A475M080AC C1608X5R0J475M080AB Rated Voltage Edc:4V C2012X5R1A475K060AB C2012X5R1A475M060AB C2012X5R1A475K085AC C2012X5R0J475K085AB C2012X5R1A475M085AC C2012X5R0J475M085AB C2012X5R1A475K125AA C2012X5R0J475K125AA C2012X5R1A475M125AA C2012X5R0J475M125AA C1608X5R1A685K080AC C1608X5R0J685K080AB C1608X5R1A685M080AC C1608X5R0J685M080AB C2012X5R1A685K060AC C2012X5R1A685M060AC C2012X5R1A685K085AB C2012X5R0J685K085AB C2012X5R1A685M085AB C2012X5R0J685M085AB C2012X5R1A685K125AB C2012X5R0J685K125AB C2012X5R1A685M125AB C2012X5R0J685M125AB C1005X5R0J106M050BC C1608X5R1A106K080AC C1608X5R0J106K080AB C1608X5R1A106M080AC C1608X5R0J106M080AB C2012X5R1A106K085AB C2012X5R0J106K085AB C2012X5R1A106M085AB C2012X5R0J106M085AB C2012X5R1A106K125AB C2012X5R0J106K125AB C2012X5R1A106M125AB C2012X5R0J106M125AB C1005X5R0G106M050BB C3216X5R1A106K160AB C3216X5R1A106M160AB C1608X5R1A156M080AC C1608X5R0J156M080AC C2012X5R1A156M085AC C2012X5R0J156M085AB C2012X5R1A156M125AB C2012X5R0J156M125AC C1608X5R0G156M080AA C3216X5R1A156M160AB C3225X5R1A156M230AA C1608X5R1A226M080AC C1608X5R0J226M080AC C2012X5R1A226M085AC C2012X5R0J226M085AB C2012X5R1A226K125AB C2012X5R0J226K125AB C2012X5R1A226M125AB C2012X5R0J226M125AC C1608X5R0G226M080AA C3216X5R0J226M085AC C3216X5R1A226M160AC C3216X5R0J226M160AA C3225X5R0J226K200AA C3225X5R0J226M200AA C3225X5R1A226M230AA C4532X5R1A226M230KA C2012X5R1A336M125AC C2012X5R0J336M125AC C3216X5R0J336M130AC C3216X5R1A336M160AB C3225X5R1A336M200AC C3225X5R0J336M200AA C3225X5R0J336M250AA C4532X5R1A336M230KA C2012X5R1A476M125AC C2012X5R0J476M125AC C3216X5R1A476M160AB C3216X5R0J476M160AC C3225X5R1A476M250AC C2012X5R0G476M125AB C3225X5R0J476M250AA C4532X5R0J476M250KA C4532X5R1A476M280KA C3216X5R1A686M160AC C3216X5R0J686M160AB C3225X5R0J686M200AC C4532X5R0J686M280KA C5750X5R1A686M230KA C3216X5R1A107M160AC C3216X5R0J107M160AB C3216X5R0G107M160AB C3225X5R0J107M250AC C4532X5R1A107M280KC C4532X5R0J107M280KA C5750X5R1A107M280KC C5750X5R0J107M280KA ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (45/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X6S(-55 to +105℃, ±22%) Capacitance Size Thickness (mm) 2.2 nF 0603 0.30±0.03 4.7 nF 0603 0.30±0.03 10 nF 1005 0.50±0.05 15 nF 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF 220 nF 330 nF 470 nF 680 nF 1 µF 0.85±0.15 2012 1.25±0.20 1005 0.50+0.15/-0.10 1608 0.80±0.10 2012 1.25±0.20 3216 1.60±0.20 1.5 µF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 35V Rated Voltage Edc: 25V C0603X6S1E222K030BA Rated Voltage Edc: 16V C0603X6S1C222K030BA C0603X6S1E222M030BA C0603X6S1C222M030BA C0603X6S1C472K030BA C0603X6S1C472M030BA C1005X6S1H103K050BB C1005X6S1H103M050BB C1005X6S1H153K050BB C1005X6S1H153M050BB C0603X6S1C223K030BC C0603X6S1C223M030BC C1005X6S1H223K050BB C1005X6S1H223M050BB C1005X6S1H333K050BB C1005X6S1H333M050BB C0603X6S1C473K030BC C0603X6S1C473M030BC C1005X6S1H473K050BB C1005X6S1H473M050BB C1005X6S1H683K050BB C1005X6S1V683K050BB C1005X6S1E683K050BC C1005X6S1H683M050BB C1005X6S1V683M050BB C1005X6S1E683M050BC C0603X6S1C104K030BC C0603X6S1C104M030BC C1005X6S1H104K050BB C1005X6S1V104K050BB C1005X6S1E104K050BB C1005X6S1H104M050BB C1005X6S1V104M050BB C1005X6S1E104M050BB C1608X6S1H154K080AB C1608X6S1V154K080AB C1608X6S1H154M080AB C1608X6S1V154M080AB C1608X6S1H224K080AB C1608X6S1V224K080AB C1608X6S1H224M080AB C1608X6S1V224M080AB C1005X6S1E154K050BC C1005X6S1C154K050BB C1005X6S1E154M050BC C1005X6S1C154M050BB C1005X6S1E224K050BC C1005X6S1C224K050BB C1005X6S1E224M050BC C1005X6S1C224M050BB C1005X6S1C334K050BC C1005X6S1C334M050BC C1608X6S1H334K080AB C1608X6S1V334K080AB C1608X6S1E334K080AB C1608X6S1H334M080AB C1608X6S1V334M080AB C1608X6S1E334M080AB C1005X6S1C474K050BC C1005X6S1C474M050BC C1608X6S1H474K080AB C1608X6S1V474K080AB C1608X6S1E474K080AB C1608X6S1H474M080AB C1608X6S1V474M080AB C1608X6S1E474M080AB C2012X6S1H474K125AB C2012X6S1H474M125AB C1005X6S1C684K050BC C1005X6S1C684M050BC C1608X6S1H684K080AC C1608X6S1V684K080AB C1608X6S1E684K080AB C1608X6S1C684K080AC C1608X6S1H684M080AC C1608X6S1V684M080AB C1608X6S1E684M080AB C1608X6S1C684M080AC C2012X6S1H684K125AB C2012X6S1H684M125AB C1005X6S1C105K050BC C1005X6S1C105M050BC C1608X6S1H105K080AC C1608X6S1V105K080AB C1608X6S1E105K080AB C1608X6S1C105K080AC C1608X6S1H105M080AC C1608X6S1V105M080AB C1608X6S1E105M080AB C1608X6S1C105M080AC C2012X6S1H105K085AB C2012X6S1V105K085AB C2012X6S1E105K085AB C2012X6S1H105M085AB C2012X6S1V105M085AB C2012X6S1E105M085AB C2012X6S1H105K125AB C2012X6S1H105M125AB C1005X6S1C155K050BC C1005X6S1C155M050BC C1608X6S1C155K080AC C1608X6S1C155M080AC C2012X6S1H155K125AB C2012X6S1V155K125AB C2012X6S1E155K125AB C2012X6S1H155M125AB C2012X6S1V155M125AB C2012X6S1E155M125AB C3216X6S1H155K160AB C3216X6S1V155K160AB C3216X6S1H155M160AB C3216X6S1V155M160AB ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (46/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X6S(-55 to +105℃, ±22%) Capacitance Size Thickness (mm) 1005 0.50+0.15, -0.10 1608 0.80±0.10 0.85±0.15 2.2 µF 2012 1.25±0.20 3.3 µF 3216 1.60±0.20 1608 0.80+0.20, -0.10 2012 1.25±0.20 3216 1.60±0.20 1608 0.80+0.20, -0.10 0.85±0.15 2012 1.25±0.20 4.7 µF 0.85±0.15 3216 1.60±0.20 6.8 µF 3225 2.50±0.30 2012 1.25±0.20 3216 1.60±0.20 3225 2.50±0.30 0.85±0.15 2012 1.25±0.20 0.85±0.15 10 µF 3216 1.60±0.20 15 µF 22 µF 3225 2.50±0.30 2012 3216 2012 3216 3225 1.25±0.20 1.60±0.20 1.25±0.20 1.60±0.20 2.50±0.30 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C1005X6S1C225K050BC C1005X6S1C225M050BC C1608X6S1C225K080AC C1608X6S1C225M080AC C2012X6S1H225K085AC C2012X6S1V225K085AB C2012X6S1E225K085AB C2012X6S1C225K085AB C2012X6S1H225M085AC C2012X6S1V225M085AB C2012X6S1E225M085AB C2012X6S1C225M085AB C2012X6S1H225K125AB C2012X6S1V225K125AB C2012X6S1E225K125AC C2012X6S1H225M125AB C2012X6S1V225M125AB C2012X6S1E225M125AC C3216X6S1H225K160AB C3216X6S1V225K160AB C3216X6S1H225M160AB C3216X6S1V225M160AB C1608X6S1C335K080AC C1608X6S1C335M080AC C2012X6S1H335K125AC C2012X6S1V335K125AB C2012X6S1E335K125AC C2012X6S1C335K125AC C2012X6S1H335M125AC C2012X6S1V335M125AB C2012X6S1E335M125AC C2012X6S1C335M125AC C3216X6S1H335K160AB C3216X6S1V335K160AB C3216X6S1H335M160AB C3216X6S1V335M160AB C1608X6S1C475K080AC C1608X6S1C475M080AC C2012X6S1C475K085AC C2012X6S1C475M085AC C2012X6S1H475K125AC C2012X6S1V475K125AB C2012X6S1E475K125AC C2012X6S1C475K125AC C2012X6S1H475M125AC C2012X6S1V475M125AB C2012X6S1E475M125AC C2012X6S1C475M125AC C3216X6S1V475K085AC C3216X6S1E475K085AB C3216X6S1V475M085AC C3216X6S1E475M085AB C3216X6S1H475K160AB C3216X6S1V475K160AB C3216X6S1E475K160AB C3216X6S1H475M160AB C3216X6S1V475M160AB C3216X6S1E475M160AB C3225X6S1H475K250AB C3225X6S1H475M250AB C2012X6S1C685K125AC C2012X6S1C685M125AC C3216X6S1V685K160AC C3216X6S1E685K160AB C3216X6S1C685K160AC C3216X6S1V685M160AC C3216X6S1E685M160AB C3216X6S1C685M160AC C3225X6S1H685K250AC C3225X6S1V685K250AC C3225X6S1E685K250AB C3225X6S1H685M250AC C3225X6S1V685M250AC C3225X6S1E685M250AB C2012X6S1C106K085AC C2012X6S1C106M085AC C2012X6S1C106K125AC C2012X6S1C106M125AC C3216X6S1C106K085AC C3216X6S1C106M085AC C3216X6S1V106K160AC C3216X6S1E106K160AB C3216X6S1C106K160AB C3216X6S1V106M160AC C3216X6S1E106M160AB C3216X6S1C106M160AB C3225X6S1H106K250AC C3225X6S1V106K250AC C3225X6S1E106K250AC C3225X6S1H106M250AC C3225X6S1V106M250AC C3225X6S1E106M250AC C2012X6S1C156M125AC C3216X6S1C156M160AC C2012X6S1C226M125AC C3216X6S1C226M160AC C3225X6S1C226M250AC Class 2 (Temperature Stable) Temperature Characteristics:X6S(-55 to +105℃, ±22%) Capacitance Size Thickness (mm) 100 pF 0402 0.20±0.02 150 pF 0402 0.20±0.02 220 pF 0402 0.20±0.02 330 pF 0402 0.20±0.02 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 10V C0402X6S1A101K020BC Rated Voltage Edc:6.3V C0402X6S0J101K020BC Rated Voltage Edc:4V C0402X6S0G101K020BC C0402X6S1A101M020BC C0402X6S0J101M020BC C0402X6S0G101M020BC C0402X6S1A151K020BC C0402X6S0J151K020BC C0402X6S0G151K020BC C0402X6S1A151M020BC C0402X6S0J151M020BC C0402X6S0G151M020BC C0402X6S1A221K020BC C0402X6S0J221K020BC C0402X6S0G221K020BC C0402X6S1A221M020BC C0402X6S0J221M020BC C0402X6S0G221M020BC C0402X6S1A331K020BC C0402X6S0J331K020BC C0402X6S0G331K020BC C0402X6S1A331M020BC C0402X6S0J331M020BC C0402X6S0G331M020BC ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (47/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X6S(-55 to +105℃, ±22%) Capacitance Size Thickness (mm) 470 pF 0402 0.20±0.02 680 pF 0402 0.20±0.02 2.2 nF 0603 0.30±0.03 4.7 nF 0603 0.30±0.03 10 nF 0603 0.30±0.03 22 nF 0603 0.30±0.03 47 nF 0603 0.30±0.03 68 nF 0603 0.30±0.03 0603 0.30±0.03 1005 0.50±0.05 100 nF 0.30±0.03 0603 150 nF 0.30±0.05 1005 0.50±0.05 0.30±0.03 0603 220 nF 0.30±0.05 1005 0.50±0.05 0603 0.30±0.05 1005 0.50±0.05 330 nF 470 nF 680 nF 0603 0.30±0.05 1005 0.50±0.05 1005 0.50±0.05 1005 0.50±0.05 1608 0.80+0.15/-0.10 1 µF 0.50±0.05 1005 1.5 µF 0.50±0.10 1608 0.80±0.10 0.50±0.05 1005 2.2 µF 0.50±0.10 1608 0.80±0.10 1005 0.50±0.10 1608 0.80±0.10 1005 0.50+0.15/-0.10 3.3 µF 4.7 µF 1608 0.80±0.10 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 10V C0402X6S1A471K020BC Rated Voltage Edc:6.3V C0402X6S0J471K020BC Rated Voltage Edc:4V C0402X6S0G471K020BC C0402X6S1A471M020BC C0402X6S0J471M020BC C0402X6S0G471M020BC C0402X6S1A681K020BC C0402X6S0J681K020BC C0402X6S0G681K020BC C0402X6S1A681M020BC C0402X6S0J681M020BC C0402X6S0G681M020BC C0603X6S1A222K030BA C0603X6S0J222K030BA C0603X6S1A222M030BA C0603X6S0J222M030BA C0603X6S1A472K030BA C0603X6S0J472K030BA C0603X6S1A472M030BA C0603X6S0J472M030BA C0603X6S1A103K030BA C0603X6S0J103K030BA C0603X6S1A103M030BA C0603X6S0J103M030BA C0603X6S1A223K030BB C0603X6S0G223K030BC C0603X6S1A223M030BB C0603X6S0G223M030BC C0603X6S1A473K030BB C0603X6S0G473K030BC C0603X6S1A473M030BB C0603X6S0G473M030BC C0603X6S0G683K030BC C0603X6S0G683M030BC C0603X6S0J104K030BC C0603X6S0G104K030BC C0603X6S0J104M030BC C0603X6S0G104M030BC C1005X6S0J104K050BA C1005X6S0G104K050BA C1005X6S0J104M050BA C1005X6S0G104M050BA C0603X6S0J154K030BC C0603X6S0G154K030BB C0603X6S0J154M030BC C0603X6S0G154M030BB C0603X6S1A154K030BC C0603X6S1A154M030BC C1005X6S0J154K050BC C1005X6S0G154K050BB C1005X6S0J154M050BC C1005X6S0G154M050BB C0603X6S0J224K030BC C0603X6S0G224K030BB C0603X6S0J224M030BC C0603X6S0G224M030BB C0603X6S1A224K030BC C0603X6S1A224M030BC C1005X6S0J224K050BC C1005X6S0G224K050BB C1005X6S0J224M050BC C1005X6S0G224M050BB C0603X6S0G334K030BC C0603X6S0G334M030BC C1005X6S1A334K050BC C1005X6S0J334K050BC C1005X6S0G334K050BB C1005X6S1A334M050BC C1005X6S0J334M050BC C1005X6S0G334M050BB C1005X6S1A474K050BC C1005X6S0J474K050BC C1005X6S0G474K050BB C1005X6S1A474M050BC C1005X6S0J474M050BC C1005X6S0G474M050BB C0603X6S0G474M030BC C1005X6S1A684K050BC C1005X6S0J684K050BC C1005X6S0G684K050BB C1005X6S1A684M050BC C1005X6S0J684M050BC C1005X6S0G684M050BB C1005X6S1A105K050BC C1005X6S0J105K050BC C1005X6S0G105K050BB C1005X6S1A105M050BC C1005X6S0J105M050BC C1005X6S0G105M050BB C1608X6S1A105K080AC C1608X6S0J105K080AC C1608X6S1A105M080AC C1608X6S0J105M080AC C1005X6S0J155K050BC C1005X6S0G155K050BC C1005X6S0J155M050BC C1005X6S0G155M050BC C1005X6S1A155K050BC C1005X6S1A155M050BC C1608X6S1A155K080AB C1608X6S0J155K080AB C1608X6S1A155M080AB C1608X6S0J155M080AB C1005X6S0J225K050BC C1005X6S0G225K050BC C1005X6S0J225M050BC C1005X6S0G225M050BC C1005X6S1A225K050BC C1005X6S1A225M050BC C1608X6S1A225K080AB C1608X6S0J225K080AB C1608X6S1A225M080AB C1608X6S0J225M080AB C1005X6S0G335K050BC C1005X6S0G335M050BC C1608X6S1A335K080AC C1608X6S0J335K080AB C1608X6S1A335M080AC C1608X6S0J335M080AB C1608X6S1A475K080AC C1608X6S0J475K080AB C1608X6S1A475M080AC C1608X6S0J475M080AB C1005X6S0G475M050BC ■ The gray items are non-recommended products in the new design. ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (48/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X6S(-55 to +105℃, ±22%) Capacitance Size Thickness (mm) 0.85±0.15 4.7 µF 2012 1.25±0.20 0.80±0.10 1608 0.80+0.20, -0.10 0.85±0.15 6.8 µF 2012 1.25±0.20 3216 1608 0.85±0.15 0.80±0.10 0.80+0.20, -0.10 0.85±0.15 10 µF 2012 1.25±0.20 0.85±0.15 3216 1.60±0.20 15 µF 2012 3216 22 µF 33 µF 47 µF 68 µF 100 µF 2012 3216 2012 3216 2012 3216 3225 3216 3216 3225 4532 0.85±0.15 1.25±0.20 1.60±0.20 0.85±0.15 1.25±0.20 1.60±0.20 1.25±0.20 1.60±0.20 1.25±0.20 1.60±0.20 2.50±0.30 1.60+0.30, -0.10 1.60+0.30, -0.10 2.50±0.30 2.80±0.30 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 10V C2012X6S1A475K085AB Rated Voltage Edc:6.3V Rated Voltage Edc:4V C2012X6S1A475M085AB C2012X6S0J475K125AB C2012X6S0J475M125AB C1608X6S0G685K080AC C1608X6S0G685M080AC C1608X6S1A685K080AC C1608X6S0J685K080AB C1608X6S1A685M080AC C1608X6S0J685M080AB C2012X6S1A685K085AC C2012X6S0J685K085AB C2012X6S1A685M085AC C2012X6S0J685M085AB C2012X6S1A685K125AB C2012X6S1A685M125AB C3216X6S1A685K085AB C3216X6S1A685M085AB C1608X6S0G106K080AB C1608X6S0G106M080AC C1608X6S1A106M080AC C1608X6S0J106M080AC C2012X6S1A106K085AC C2012X6S0J106K085AC C2012X6S1A106M085AC C2012X6S0J106M085AC C2012X6S1A106K125AB C2012X6S0J106K125AB C2012X6S0G106K125AC C2012X6S1A106M125AB C2012X6S0J106M125AB C2012X6S0G106M125AC C3216X6S1A106K085AB C3216X6S1A106M085AB C3216X6S0J106K160AC C3216X6S0J106M160AC C2012X6S0G156M085AC C2012X6S1A156M125AC C3216X6S1A156M160AB C2012X6S0J156M125AB C3216X6S0J156M160AB C2012X6S0J226M085AC C2012X6S0G226M085AC C2012X6S1A226M125AC C2012X6S0J226M125AB C2012X6S0G226M125AC C3216X6S1A226M160AB C3216X6S0J226M160AB C3216X6S1A336M160AC C3216X6S0J336M160AB C3216X6S1A476M160AC C3216X6S0J476M160AB C2012X6S0G336M125AC C2012X6S0G476M125AC C3216X6S0G476M160AC C3225X6S0J476M250AC C3216X6S0G686M160AC C3216X6S0G107M160AC C3225X6S0J107M250AC C3225X6S0G107M250AC C4532X6S0J107M280KC Class 2 (Temperature Stable) Temperature Characteristics:X7R(-55 to +125℃, ±15%) Capacitance Size Thickness (mm) 100 pF 0603 0.30±0.03 150 pF 0603 0.30±0.03 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 220 pF 330 pF 470 pF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 25V C0603X7R1E101K030BA C0603X7R1E101M030BA C0603X7R1E151K030BA C0603X7R1E151M030BA C0603X7R1E221K030BA C0603X7R1E221M030BA C1005X7R1H221K050BA C1005X7R1H221M050BA C0603X7R1E331K030BA C0603X7R1E331M030BA C1005X7R1H331K050BA C1005X7R1H331M050BA C0603X7R1E471K030BA C0603X7R1E471M030BA C1005X7R1H471K050BA C1005X7R1H471M050BA ■ The gray items are non-recommended products in the new design. ■ The red items are products of the production will be stopped. Please confirm the schedule on product details information. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (49/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X7R(-55 to +125℃, ±15%) Capacitance Size Thickness (mm) 0603 0.30±0.03 680 pF 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 0603 0.30±0.03 1005 0.50±0.05 1005 0.50±0.05 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 1005 0.50±0.05 1608 0.80±0.10 2012 0.85±0.15 1 nF 1.5 nF 2.2 nF 3.3 nF 4.7 nF 6.8 nF 10 nF 15 nF 22 nF 33 nF 47 nF 68 nF 100 nF 150 nF Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 35V Rated Voltage Edc: 25V C0603X7R1E681K030BA Rated Voltage Edc: 16V C0603X7R1E681M030BA C1005X7R1H681K050BA C1005X7R1H681M050BA C0603X7R1E102K030BA C0603X7R1E102M030BA C1005X7R1H102K050BA C1005X7R1E102K050BA C1005X7R1H102M050BA C0603X7R1E152K030BA C0603X7R1E152M030BA C1005X7R1H152K050BA C1005X7R1H152M050BA C0603X7R1E222K030BA C0603X7R1C222K030BA C0603X7R1E222M030BA C0603X7R1C222M030BA C1005X7R1H222K050BA C1005X7R1H222M050BA C0603X7R1E332K030BA C0603X7R1E332M030BA C1005X7R1H332K050BA C1005X7R1H332M050BA C0603X7R1C472K030BA C0603X7R1C472M030BA C1005X7R1H472K050BA C1005X7R1H472M050BA C1005X7R1H682K050BA C1005X7R1H682M050BA C1005X7R1H103K050BB C1005X7R1V103K050BB C1005X7R1E103K050BB C1005X7R1H103M050BB C1005X7R1V103M050BB C1005X7R1E103M050BB C1608X7R1H103K080AA C1005X7R1C103K050BA C1608X7R1E103K080AA C1608X7R1H103M080AA C1005X7R1H153K050BB C1005X7R1V153K050BB C1005X7R1H153M050BB C1005X7R1V153M050BB C1608X7R1H153K080AA C1608X7R1H153M080AA C1005X7R1H223K050BB C1005X7R1V223K050BB C1005X7R1E223K050BB C1005X7R1H223M050BB C1005X7R1V223M050BB C1005X7R1E223M050BB C1608X7R1H223K080AA C1608X7R1H223M080AA C1005X7R1H333K050BB C1005X7R1V333K050BB C1005X7R1H333M050BB C1005X7R1V333M050BB C1608X7R1H333K080AA C1608X7R1H333M080AA C1005X7R1H473K050BB C1005X7R1V473K050BB C1005X7R1E473K050BC C1005X7R1C473K050BC C1005X7R1H473M050BB C1005X7R1V473M050BB C1005X7R1E473M050BC C1005X7R1C473M050BC C1608X7R1H473K080AA C1608X7R1H473M080AA C1005X7R1H683K050BB C1005X7R1V683K050BB C1005X7R1E683K050BB C1005X7R1C683K050BC C1005X7R1H683M050BB C1005X7R1V683M050BB C1005X7R1E683M050BB C1005X7R1C683M050BC C1608X7R1H683K080AA C1608X7R1H683M080AA C1005X7R1H104K050BB C1005X7R1V104K050BB C1005X7R1E104K050BB C1005X7R1C104K050BC C1005X7R1H104M050BB C1005X7R1V104M050BB C1005X7R1E104M050BB C1005X7R1C104M050BC C1608X7R1H104K080AA C1608X7R1E104K080AA C1608X7R1H104M080AA C1608X7R1E104M080AA C2012X7R1H104K085AA C2012X7R1H104M085AA C1005X7R1V154K050BC C1005X7R1E154K050BB C1005X7R1C154K050BC C1005X7R1V154M050BC C1005X7R1E154M050BB C1005X7R1C154M050BC C1608X7R1H154K080AB C1608X7R1V154K080AB C1608X7R1E154K080AA C1608X7R1H154M080AB C1608X7R1V154M080AB C1608X7R1E154M080AA C2012X7R1H154K085AA C2012X7R1H154M085AA ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (50/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X7R(-55 to +125℃, ±15%) Capacitance Size Thickness (mm) 150 nF 2012 1.25±0.20 1005 0.50±0.05 1608 0.80±0.10 2012 1.25±0.20 3216 1.15±0.15 1608 0.80±0.10 2012 1.25±0.20 3216 1.60±0.20 1608 0.80±0.10 2012 1.25±0.20 3216 1.60±0.20 1608 0.80±0.10 2012 1.25±0.20 3216 1.60±0.20 1608 0.80±0.10 220 nF 330 nF 470 nF 680 nF 0.85±0.15 2012 1.25±0.20 0.85±0.15 1 µF 3216 1.60±0.20 1.5 µF 3225 1.60±0.20 4532 1.60±0.20 2012 1.25±0.20 3216 1.60±0.20 3225 2.00±0.20 0.85±0.15 2012 1.25±0.20 2.2 µF 3216 3225 1.60±0.20 2.00±0.20 2.50±0.30 4532 1.60±0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±10% ±20% Catalog Number Rated Voltage Edc: 50V C2012X7R1H154K125AA Rated Voltage Edc: 35V Rated Voltage Edc: 25V Rated Voltage Edc: 16V C2012X7R1H154M125AA C1005X7R1V224K050BC C1005X7R1E224K050BB C1005X7R1C224K050BC C1005X7R1V224M050BC C1005X7R1E224M050BB C1005X7R1C224M050BC C1608X7R1H224K080AB C1608X7R1V224K080AB C1608X7R1E224K080AC C1608X7R1C224K080AC C1608X7R1H224M080AB C1608X7R1V224M080AB C1608X7R1E224M080AC C1608X7R1C224M080AC C2012X7R1H224K125AA C2012X7R1H224M125AA C3216X7R1H224K115AA C3216X7R1H224M115AA C1608X7R1H334K080AC C1608X7R1V334K080AB C1608X7R1E334K080AC C1608X7R1C334K080AC C1608X7R1H334M080AC C1608X7R1V334M080AB C1608X7R1E334M080AC C1608X7R1C334M080AC C2012X7R1H334K125AA C2012X7R1H334M125AA C3216X7R1H334K160AA C3216X7R1H334M160AA C1608X7R1H474K080AC C1608X7R1V474K080AB C1608X7R1E474K080AB C1608X7R1C474K080AC C1608X7R1H474M080AC C1608X7R1V474M080AB C1608X7R1E474M080AB C1608X7R1C474M080AC C2012X7R1H474K125AB C2012X7R1V474K125AB C2012X7R1E474K125AA C2012X7R1H474M125AB C2012X7R1V474M125AB C2012X7R1E474M125AA C3216X7R1H474K160AA C3216X7R1H474M160AA C1608X7R1V684K080AC C1608X7R1E684K080AB C1608X7R1C684K080AC C1608X7R1V684M080AC C1608X7R1E684M080AB C1608X7R1C684M080AC C2012X7R1H684K125AB C2012X7R1V684K125AB C2012X7R1E684K125AB C2012X7R1C684K125AA C2012X7R1H684M125AB C2012X7R1V684M125AB C2012X7R1E684M125AB C2012X7R1C684M125AA C3216X7R1H684K160AA C3216X7R1H684M160AA C1608X7R1V105K080AC C1608X7R1E105K080AB C1608X7R1C105K080AC C1608X7R1V105M080AC C1608X7R1E105M080AB C1608X7R1C105M080AC C2012X7R1H105K085AC C2012X7R1V105K085AB C2012X7R1E105K085AB C2012X7R1C105K085AC C2012X7R1H105M085AC C2012X7R1V105M085AB C2012X7R1E105M085AB C2012X7R1C105M085AC C2012X7R1H105K125AB C2012X7R1V105K125AB C2012X7R1E105K125AB C2012X7R1C105K125AA C2012X7R1H105M125AB C2012X7R1V105M125AB C2012X7R1E105M125AB C2012X7R1C105M125AA C3216X7R1E105K085AA C3216X7R1E105M085AA C3216X7R1H105K160AB C3216X7R1E105K160AA C3216X7R1H105M160AB C3216X7R1E105M160AA C3225X7R1H105K160AA C3225X7R1H105M160AA C4532X7R1H105K160KA C4532X7R1H105M160KA C2012X7R1H155K125AC C2012X7R1V155K125AB C2012X7R1E155K125AC C2012X7R1C155K125AB C2012X7R1H155M125AC C2012X7R1V155M125AB C2012X7R1E155M125AC C2012X7R1C155M125AB C3216X7R1H155K160AB C3216X7R1V155K160AB C3216X7R1E155K160AA C3216X7R1H155M160AB C3216X7R1V155M160AB C3216X7R1E155M160AA C3225X7R1H155K200AA C3225X7R1H155M200AA C2012X7R1V225K085AC C2012X7R1E225K085AB C2012X7R1C225K085AB C2012X7R1V225M085AC C2012X7R1E225M085AB C2012X7R1C225M085AB C2012X7R1H225K125AC C2012X7R1V225K125AB C2012X7R1E225K125AB C2012X7R1C225K125AB C2012X7R1H225M125AC C2012X7R1V225M125AB C2012X7R1E225M125AB C2012X7R1C225M125AB C3216X7R1H225K160AB C3216X7R1V225K160AB C3216X7R1E225K160AA C3216X7R1H225M160AB C3216X7R1V225M160AB C3216X7R1E225M160AA C3225X7R1H225K200AB C3225X7R1H225M200AB C3225X7R1H225K250AB C4532X7R1H225K160KA C4532X7R1H225M160KA Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (51/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X7R(-55 to +125℃, ±15%) Capacitance Size Thickness (mm) 2012 1.25±0.20 3216 1.60±0.20 1.60±0.20 3.3 µF 3225 2.50±0.30 4532 2.00±0.20 2012 1.25±0.20 0.85±0.15 3216 1.60±0.20 4.7 µF 2.00±0.20 3225 2.50±0.30 4532 5750 2.00±0.20 2.00±0.20 2.80±0.30 3216 1.60±0.20 3225 2.50±0.30 4532 2.50±0.30 5750 2.50±0.30 3216 1.60±0.20 6.8 µF 2.00±0.20 3225 2.50±0.30 10 µF 2.30±0.20 4532 2.50±0.30 2.00±0.20 5750 3225 15 µF 22 µF 5750 2.50±0.30 2.50±0.30 2.80±0.30 2.30±0.20 3225 2.50±0.30 4532 4532 5750 33 µF 47 µF 2.30±0.20 4532 5750 5750 2.00±0.20 2.30±0.20 2.50±0.30 2.50±0.30 2.80±0.30 2.50±0.30 2.00±0.20 2.30±0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 35V C2012X7R1V335K125AC Rated Voltage Edc: 25V C2012X7R1E335K125AB Rated Voltage Edc: 16V C2012X7R1C335K125AB C2012X7R1C335M125AB C2012X7R1V335M125AC C2012X7R1E335M125AB C3216X7R1H335K160AC C3216X7R1V335K160AB C3216X7R1E335K160AC C3216X7R1H335M160AC C3216X7R1V335M160AB C3216X7R1E335M160AC C3225X7R1E335K160AA C3225X7R1E335M160AA C3225X7R1H335K250AB C3225X7R1H335M250AB C4532X7R1H335K200KA C4532X7R1H335M200KA C2012X7R1V475K125AC C2012X7R1E475K125AB C2012X7R1C475K125AB C2012X7R1V475M125AC C2012X7R1E475M125AB C2012X7R1C475M125AB C3216X7R1V475K085AC C3216X7R1E475K085AB C3216X7R1C475K085AB C3216X7R1V475M085AC C3216X7R1E475M085AB C3216X7R1C475M085AB C3216X7R1H475K160AC C3216X7R1V475K160AB C3216X7R1E475K160AC C3216X7R1C475K160AB C3216X7R1H475M160AC C3216X7R1V475M160AB C3216X7R1E475M160AC C3216X7R1C475M160AB C3225X7R1E475K200AA C3225X7R1E475M200AA C3225X7R1H475K250AB C3225X7R1H475M250AB C4532X7R1H475K200KB C4532X7R1H475M200KB C4532X7R1E475M200KA C5750X7R1H475K200KA C5750X7R1H475M200KA C5750X7R1H475M280KA C3216X7R1V685K160AC C3216X7R1E685K160AB C3216X7R1C685K160AC C3216X7R1V685M160AC C3216X7R1E685M160AB C3216X7R1C685M160AC C3225X7R1E685K250AB C3225X7R1E685M250AB C4532X7R1H685K250KB C4532X7R1H685M250KB C5750X7R1H685K250KA C5750X7R1H685M250KA C3216X7R1V106K160AC C3216X7R1E106K160AB C3216X7R1C106K160AC C3216X7R1V106M160AC C3216X7R1E106M160AB C3216X7R1C106M160AC C3225X7R1C106K200AB C3225X7R1C106M200AB C3225X7R1E106K250AC C3225X7R1H106M250AC C3225X7R1E106M250AC C4532X7R1C106K230KA C4532X7R1C106M230KA C4532X7R1E106K250KA C4532X7R1E106M250KA C5750X7R1E106M200KA C5750X7R1H106K230KB C5750X7R1H106M230KB C3225X7R1C156M250AB C4532X7R1E156M250KC C4532X7R1E156M280KB C5750X7R1E156M230KA C3225X7R1C226K250AC C3225X7R1C226M250AC C4532X7R1C226M200KC C4532X7R1C226M230KB C4532X7R1E226M250KC C5750X7R1E226M250KA C5750X7R1C226M280KA C4532X7R1C336M250KC C5750X7R1C336M200KB C5750X7R1C476M230KB Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (52/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X7R(-55 to +125℃, ±15%) Capacitance Size Thickness (mm) 100 pF 0402 0.20±0.02 150 pF 0402 0.20±0.02 220 pF 0402 0.20±0.02 330 pF 0402 0.20±0.02 470 pF 0402 0.20±0.02 680 pF 0402 0.20±0.02 1 nF 0402 0.20±0.02 1.5 nF 0402 0.20±0.02 2.2 nF 0603 0.30±0.03 4.7 nF 0603 0.30±0.03 10 nF 0603 0.30±0.03 100 nF 1005 0.50±0.05 150 nF 1005 0.50±0.05 220 nF 1005 0.50±0.05 680 nF 1608 0.80+0.15/-0.10 1 µF 1608 0.80+0.15/-0.10 1.5 µF 1608 0.80±0.10 2.2 µF 1608 0.80±0.10 3.3 µF 2012 1.25±0.20 4.7 µF 2012 0.85±0.15 1.25±0.20 6.8 µF 2012 1.25±0.20 2012 1.25±0.20 0.85±0.15 10 µF 3216 1.60±0.20 22 µF 3225 2.30±0.20 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% Catalog Number Rated Voltage Edc: 10V C0402X7R1A101K020BC Rated Voltage Edc: 6.3V C0402X7R0J101K020BC Rated Voltage Edc: 4V C0402X7R0G101K020BC C0402X7R1A101M020BC C0402X7R0J101M020BC C0402X7R0G101M020BC C0402X7R1A151K020BC C0402X7R0J151K020BC C0402X7R0G151K020BC C0402X7R1A151M020BC C0402X7R0J151M020BC C0402X7R0G151M020BC C0402X7R1A221K020BC C0402X7R0J221K020BC C0402X7R0G221K020BC C0402X7R1A221M020BC C0402X7R0J221M020BC C0402X7R0G221M020BC C0402X7R1A331K020BC C0402X7R0J331K020BC C0402X7R0G331K020BC C0402X7R1A331M020BC C0402X7R0J331M020BC C0402X7R0G331M020BC C0402X7R1A471K020BC C0402X7R0J471K020BC C0402X7R0G471K020BC C0402X7R1A471M020BC C0402X7R0J471M020BC C0402X7R0G471M020BC C0402X7R1A681K020BC C0402X7R0J681K020BC C0402X7R0G681K020BC C0402X7R1A681M020BC C0402X7R0J681M020BC C0402X7R0G681M020BC C0402X7R1A102K020BC C0402X7R1A102M020BC C0402X7R1A152K020BC C0402X7R1A152M020BC C0603X7R1A222K030BA C0603X7R0J222K030BA C0603X7R1A222M030BA C0603X7R0J222M030BA C0603X7R1A472K030BA C0603X7R0J472K030BA C0603X7R1A472M030BA C0603X7R0J472M030BA C0603X7R1A103K030BA C0603X7R0J103K030BA C0603X7R1A103M030BA C0603X7R0J103M030BC C1005X7R1A104K050BB C1005X7R1A154K050BB C1005X7R1A154M050BB C1005X7R1A224K050BB C1005X7R1A224M050BB C1608X7R1A684K080AC C1608X7R1A684M080AC C1608X7R1A105K080AC C1608X7R1A105M080AC C1608X7R1A155K080AC C1608X7R0J155K080AB C1608X7R1A155M080AC C1608X7R0J155M080AB C1608X7R1A225K080AC C1608X7R0J225K080AB C1608X7R1A225M080AC C1608X7R0J225M080AB C2012X7R1A335K125AC C2012X7R1A335M125AC C2012X7R1A475K085AC C2012X7R0J475K085AB C2012X7R1A475M085AC C2012X7R0J475M085AB C2012X7R1A475K125AC C2012X7R1A475M125AC C2012X7R1A685K125AC C2012X7R0J685K125AB C2012X7R1A685M125AC C2012X7R0J685M125AB C2012X7R1A106K125AC C2012X7R0J106K125AB C2012X7R1A106M125AC C2012X7R0J106M125AB C3216X7R1A106K085AC C3216X7R0J106K085AB C3216X7R1A106M085AC C3216X7R0J106M085AB C3216X7R1A106K160AC C3216X7R1A106M160AC C3225X7R1A226K230AC C3225X7R1A226M230AC ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm (53/53) MULTILAYER CERAMIC CHIP CAPACITORS Capacitance Range Table Class 2 (Temperature Stable) Temperature Characteristics:X7S(-55 to +125℃, ±22%) Capacitance Size Thickness (mm) 22 nF 0603 0.30±0.03 47 nF 0603 0.30±0.03 100 nF 0603 0.30±0.03 150 nF 0603 0.30±0.05 0.30±0.03 220 nF 0603 0.30±0.05 330 nF 1005 0.50±0.05 470 nF 1005 0.50±0.05 680 nF 1005 0.50±0.05 1 µF 1005 0.50±0.05 0.50+0.15/-0.10 1005 0.50±0.05 1.5 µF 0.50±0.10 1608 0.80±0.10 0.50±0.10 1005 0.50+0.15/-0.10 2.2 µF 0.50±0.05 1608 0.80±0.10 0.80±0.10 3.3 µF 1608 0.80+0.20, -0.10 0.80±0.10 4.7 µF 1608 0.80+0.20, -0.10 6.8 µF 1608 0.80+0.20, -0.10 2012 1.25±0.20 3225 2.50±0.30 1608 0.80+0.20, -0.10 0.85±0.15 10 µF 15 µF 22 µF 33 µF 47 µF 2012 1.25±0.20 3225 2.50±0.30 2012 3216 2012 3216 3216 3216 3225 1.25±0.20 1.60±0.20 1.25±0.20 1.60±0.20 1.60±0.20 1.60±0.20 2.50±0.30 Capacitance Tolerance ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±10% ±20% ±10% ±20% ±10% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% Catalog Number Rated Voltage Edc: 50V Rated Voltage Edc: 16V Rated Voltage Edc: 10V C0603X7S1A223K030BC Rated Voltage Edc: 6.3V C0603X7S0J223K030BB C0603X7S1A223M030BC C0603X7S0J223M030BB C0603X7S1A473K030BC C0603X7S0J473K030BB C0603X7S1A473M030BC C0603X7S0J473M030BB Rated Voltage Edc: 4V C0603X7S1A104K030BC C0603X7S0G104K030BC C0603X7S1A104M030BC C0603X7S0G104M030BC C0603X7S0J154K030BC C0603X7S0J154M030BC C0603X7S0G224K030BC C0603X7S0G224M030BC C0603X7S0J224K030BC C0603X7S0J224M030BC C1005X7S1C334K050BC C1005X7S1A334K050BC C1005X7S0J334K050BC C1005X7S1C334M050BC C1005X7S1A334M050BC C1005X7S0J334M050BC C1005X7S1C474K050BC C1005X7S1A474K050BC C1005X7S0J474K050BB C1005X7S1C474M050BC C1005X7S1A474M050BC C1005X7S0J474M050BB C1005X7S1A684K050BC C1005X7S0J684K050BC C1005X7S0G684K050BC C1005X7S1A684M050BC C1005X7S0J684M050BC C1005X7S0G684M050BC C1005X7S1A105K050BC C1005X7S0J105K050BC C1005X7S0G105K050BC C1005X7S1A105M050BC C1005X7S0J105M050BC C1005X7S0G105M050BC C1005X7S1A155K050BC C1005X7S1A155M050BC C1005X7S0G155K050BC C1005X7S0G155M050BC C1005X7S0J155K050BC C1005X7S0J155M050BC C1608X7S1C155K080AC C1608X7S1C155M080AC C1005X7S0J225K050BC C1005X7S0J225M050BC C1005X7S1A225K050BC C1005X7S1A225M050BC C1005X7S0G225K050BC C1005X7S0G225M050BC C1608X7S1C225K080AC C1608X7S1A225K080AC C1608X7S0J225K080AB C1608X7S1C225M080AC C1608X7S1A225M080AC C1608X7S0J225M080AB C1608X7S0J335K080AC C1608X7S0G335K080AC C1608X7S0J335M080AC C1608X7S0G335M080AC C1608X7S1A335K080AC C1608X7S1A335M080AC C1608X7S0J475K080AC C1608X7S0G475K080AC C1608X7S0J475M080AC C1608X7S0G475M080AC C1608X7S1A475K080AC C1608X7S1A475M080AC C1608X7S0J685K080AC C1608X7S0G685K080AB C1608X7S0J685M080AC C1608X7S0G685M080AB C1608X7S0J106M080AC C1608X7S0G106M080AB C2012X7S1C685K125AC C2012X7S1C685M125AC C3225X7S1H685K250AB C3225X7S1H685M250AB C2012X7S0J106K085AC C2012X7S0G106K085AC C2012X7S0J106M085AC C2012X7S0G106M085AC C2012X7S1A156M125AC C2012X7S0J156M125AC C2012X7S0G156M125AC C3216X7S1A156M160AC C3216X7S0J156M160AB C2012X7S1A226M125AC C2012X7S0J226M125AC C3216X7S1A226M160AC C3216X7S0J226M160AB C2012X7S1C106K125AC C2012X7S1C106M125AC C3225X7S1H106K250AB C3225X7S1H106M250AB C2012X7S0G226M125AC C3216X7S0J336M160AC C3216X7S0G336M160AB C3216X7S0J476M160AC C3216X7S0G476M160AB C3225X7S0J476M250AC ■ The gray items are non-recommended products in the new design. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20160803 / mlcc_commercial_general_en.fm
DEL-C1005X7R1H331K050BA 价格&库存
很抱歉,暂时无法提供与“DEL-C1005X7R1H331K050BA”相匹配的价格&库存,您可以联系我们找货
