DLP-PU/E
DLP-PU/E
    TDK(东电化)
    REDUNDANCY MODULE FOR DLP POWER
DLP-PU/E 数据手册
DLP-PU Series Power Supply Parallel or Redundancy Module Features u OR-ing Diodes Included u Alarm Signals u LED Indicators u DIN Rail Mounting u Can connect two units in parallel u Output voltage monitoring (via relays) Key Market Segments & Applications Specifications Model Input Voltage Range Number of inputs Maximum Input Current Maximum Output Current Overcurrent protection Voltage Drop Maximum Reverse Voltage LED Indicators Input Voltage Alarm Relay contact rating (max) Cooling Operating Temperature Storage Temperature Humidity Withstand Voltage Isolation Resistance Vibration Shock Safety Agency Approval Size Weight Warranty DLP-PU/E 21 - 28VDC Two 20A per input 20A None 0.5V 35VDC Two green LEDs indicating each input is “good” Relay off when input is 30V (±5%). NO and NC contacts 28VDC, 1A or 120VAC, 0.5A (5mA minimum recommended) Convection -10 to +70°C, derate linearly to 60% from 60 to 70°C -30 to +90°C Operating: 30 - 90%RH, Storage: 10 - 95%RH (non condensing) Input or Output - Chassis, Input or Output - Relay Contacts, Relay Contacts to Chassis; 500VAC for 1 min. Input or Output - Chassis, Input or Output - Relay Contacts, Relay Contacts to Chassis; >10M Ohms at 25°C, 70%RH and 500VDC Non operating, mounted on DIN Rail,10-55Hz (sweep for 1 min), 9.8m/s2 constant X, Y, Z each for 1 hour 196m/s2 UL60950-1, CSA60950-1, EN60950-1, UL508, CSA22.2 No.14, EN60529 IP20, EN50178 Cat 1 mm/in 50 x 97 x 110mm, 1.97x 3.81 x 4.33” g 470g yrs Three Years VDC A A VDC VDC - Note: See Installation Manual for full details, test methods of parameters and application notes 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 1 DLP-PU Series Outline Drawings Block Diagram DLP-PU Block Diagram Power Supply A+ +V Power Supply B+ +V + Output + Relay A Alarm A NC F OK Relay B + Alarm B NC F OK -V Other Industrial Products DLP DPP/DSP R Series 75W to 240W power supplies 10W to 480W low cost power supplies 3A to 30A single & three phase EMI Filters Snap-on Mounting: snap onto DIN Rail TS35/7.5 or TS35/15. (no tools required) For Additional Information, please visit us.tdk-lambda.com/lp/products/dlp-series.htm 1-800-526-2324 • www.us.tdk-lambda.com/lp/ 2 Revision A8: Nov 2011
DLP-PU/E 价格&库存
很抱歉,暂时无法提供与“DLP-PU/E”相匹配的价格&库存,您可以联系我们找货
DLP-PU/E
  • 1+929.566591+120.20586
