• Low Cost
• 3 Year Warranty
• Semi F47 Compliant (DLP180&240 only)
• Convection Cooled
• Conducted and Radiated EMI, Class B
• Input Transient Protection, IEC61000-4
DLP Series
Key Market Segments & Applications
Industrial Controls:
Factory Automation:
Chemical Processing
Test & Measurement:
Measurement
75 to 240W, 24V Output
DIN Rail Mount Power Supply
DLP Features and Benefits
Features
Output Voltage
Output Current
Output Power
Output Voltage Adjustment
Load Regulation
Line Regulation
Ripple/Noise (0-600C)
AC Input Voltage & Frequency
Input Current 100/230VAC
Efficiency 100/230VAC
Power Factor
Inrush Current(Typ)100/230VAC
Leakage Current
Hold-up Time 100/230VAC
Overcurrent Protection
Overvoltage Protection
LED Indicators
Operating Temperature
(2)
Storage Temperature
Humidity (Non-Condensing)
Withstand Voltage
Vibration
Shock
Safety Agency Approvals
Conducted EMI
Radiated EMI
ESD
Radiated RFI
Fast Transient Burst
Lightning Surge
Conducted RFI
Magnetic Field
Voltage Dips
Size
Weight
Warranty
Burn in & Test, Instrumentation
Benefits
• PFC Compliant to EN61000-3-2
• UL508 Approvals
• 3 Year Warranty
Specifications
Motor Control Systems
Process Control, Automotive,
• Supports Global Use
• Enables System Certification
• Fit & Forget
MODELS
V
A
W
V
mV
mV
mV
A
A
mA
ms
°C
°C
%RH
mm
g
yrs
DLP75-24-1/E
24
3.1
75
DLP100-24-1/E
24
4.1
98.4
DLP120-24-1/E
24
5.0
120
21.6 - 28
192
120
240
DLP180-24-1/E
24
7.5
180
DLP240-24-1/E
24
10
240
85-265VAC (47-63Hz)
or 120-370VDC(1)
1.7/0.8
2.3/1.2
2.4/1.3
2.3/1.0
3.0/1.3
81/83
82/85
83/85
84/87
82/86
Meets EN61000-3-2 (DLP180, 240: >0.95)
20/45
Less than 0.75
20/30 (Semi F47 Compliance, DLP 180 & 240 only)
>105%,Fold Back
>105%, Constant Current
30-35V, latching, cycle AC line to reset
Green LED = DC ok Red LED = overcurrent
Convection cooled, -10°C to 60°C, derate linearly to 60% load from 50°C to 60°C
-30°C ~ +85°C
30-90% operating 10-95% non operating
Input - Ground 2kVAC, Input to Output 3kVAC, Output - Ground 500VAC
9.8m/s2 (1.0G) at DIN rail; (10-55Hz: 9.8m/s2 Constant, X,Y, Z each 1 hour)
196m/s2 (20G)
UL508, IEC/UL/CSA/EN62368-1, 60950-1, EN50178 Cat III (Pri), CE Mark
FCC-B, EN55011/EN55022-B, VCCI-B; Meets IEC61000-4-1
EN55011/EN55022-B, FCC-Class B, VCCI-B
IEC61000-4-2 ±10kV (Air), ±5kV (Contact)
IEC61000-4-3 80-1000MHz,12V/m 80% AM 1kHz
IEC61000-4-4 2.4kV 5kHz
IEC61000-4-5 4.4kV, 1.2x50µs (Common Mode) 2.4kV 1.2x50µs (Normal)
IEC61000-4-6 150kHz-80MHz, 12V, 80% AM 1kHz
IEC61000-4-8 36A/m
IEC61000-4-11 70% 10ms, 40% 100ms, 0% 5s
50 x 97 x 110
60 x 97 x 110
60 x 97 x 110
80 x 97 x 110
120 x 97 x 110
470
540
540
780
1000
3
85-132/170-265VAC, 47-63Hz Auto select
DLP Series
1
Outline Drawing DLP75 Series
DLP75-24-1/E
DLP75-24-1/E
Outline Drawing DLP100/120 Series
DLP100-24-1/E
DLP100-24-1/E
Also available
DLP-PU
parallel unit
for redundancy
2
Notes: (1)
(2)
DC input is not safety approved
DLP240-24-1/E: 170-265VAC: -10°C~+70°C, derated linearly to
60% load from 50° to 70°C.
DLP Series
Outline Drawing DLP180 Series
DLP180-24-1/E
DLP180-24-1/E
Outline Drawing DLP240 Series
DLP240-24-1/E
DLP240-24-1/E
Derating Curve DLP
DLP75, 120 & 180 Derating Curve
DLP100 Derating Graph Curve
DLP Series
DLP 240 Derating Curve
3
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr.powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it.powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl.powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at.powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Switzerland Sales Office
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
Tel: +41 44 850 53 53
tlg.ch.powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/at
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk.powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
www.emea.lambda.tdk.com/uk
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
DLP Oct20 v5
4
DLP Series
For Additional Information, please visit
https://product.tdk.com/en/power/
很抱歉,暂时无法提供与“DLP75241/E”相匹配的价格&库存,您可以联系我们找货
