DP-1900
DP-1900
    TDK(东电化)
    TDK高精度偶极子天线是半波长固定长度的精密偶极子,设计用于生成可追溯的校准场或测量特定频率下的电场。
DP-1900 数据手册
P Data Sheet PRODUCTS DP-Series Precision Dipole Antennas Product Overview TDK Precision Dipole Antennas are half-wave, fixed length precision dipoles designed to generate traceable calibrated fields or to measure electric fields at their respective frequency. The DPseries antennas offer low gain and essentially perfect cross-polarization rejection, and are typically used as a reference or standard gain antenna, or as a polarization standard. Dipole Test Sets The DP-Series Dipole Antennas are designed with operating frequencies matched the operating frequencies of common mobile radio devices, and are available in sets that correspond to communication systems used in Europe, North America, and Asia, including GSM, TDMA, PCS, Bluetooth, and others. Custom frequencies are available. Applications  Calibration  Communications testing  Antenna pattern measurements TDK Dipole Antennas are specifically designed as calibration reference sources for transmitting and receiving the optimum field strength within each antenna’s respective frequency range. Communication Applications Communication System Frequency Range Model GSM - NMT 453 MHz – 458 MHz DP-450 GSM - 900 880 MHz – 925 MHz DP-900 GSM - 1800 1710 MHz – 1785 MHz DP-1800 GSM 1900/TDMS PCS/CDMA PCS 1850 MHz – 1910 MHz DP-1900 TDMA (NADC)/AMPS 824 MHz – 849 MHz DP-800 W-CDMA 1920 MHz – 1980 MHz DP-2000 Korean CDMA 1715 MHz – 1780 MHz DP-1700 1101 Cypress Creek Road  Cedar Park, Texas 78613, USA  1-512-258-9478  FAX 1-512-258-0740 P PRODUCTS DP-Series Precision Dipole Antennas Communications Applications, continued ISM (Bluetooth) 2400 – 2483.5 MHz DP2400 Japan - Low Band 898 MHz – 901 MHz DP-900-J1 915 MHz – 940 MHz DP-900-J2 940 MHz – 960 MHz DP-900-J3 1429 MHz – 1453 MHz DP-1400 Japan - High Band Representative Data Ordering Information Product: Dipole Antenna Model Number: DP-Series Warranty: 1 year limited To place an order or to learn more about the TDK products that best meet your needs, contact your TDK sales representative: Mechanical Specifications Dimensions: Dependent on operating frequency; approx. onehalf wavelength Weight: Varies by model Construction: Available in aluminum, stainless steel or brass RF Connector: SMA (female) TDK RF Solutions Inc. 1101 Cypress Creek Rd. Cedar Park, Texas 78613 USA Phone: 1-512-258-9478 Fax: 1-512-258-0740 info@tdkrf.com E-mail: World Wide Web: www.tdkrfsolutions.com Electrical Specifications T O T A L I R F Gain: See data graph Impedance 50 Ω S SYSTEMS C CHAMBERS E X P E R T I S E ™ P PRODUCTS SW TS SOFTWARE TEST SERVICES www.tdkrfsolutions.com To learn more about TDK’s wide range of innovative test products, solutions and services visit www.tdkrfsolutions.com Copyright © TDK RF Solutions Inc. All rights reserved. Specifications subject to change without notice. Rev. 2011-08-02
DP-1900 价格&库存
很抱歉,暂时无法提供与“DP-1900”相匹配的价格&库存,您可以联系我们找货
