P
Data Sheet
PRODUCTS
DP-Series Precision Dipole Antennas
Product Overview
TDK Precision Dipole Antennas are half-wave,
fixed length precision dipoles designed to generate traceable calibrated fields or to measure electric fields at their respective frequency. The DPseries antennas offer low gain and essentially perfect cross-polarization rejection, and are typically
used as a reference or standard gain antenna, or
as a polarization standard.
Dipole Test Sets The DP-Series Dipole Antennas
are designed with operating frequencies matched
the operating frequencies of common mobile radio
devices, and are available in sets that correspond
to communication systems used in Europe, North
America, and Asia, including GSM, TDMA, PCS,
Bluetooth, and others. Custom frequencies are
available.
Applications
Calibration
Communications testing
Antenna pattern measurements
TDK Dipole Antennas are specifically designed as calibration reference sources for transmitting and
receiving the optimum field
strength within each antenna’s
respective frequency range.
Communication Applications
Communication System
Frequency Range
Model
GSM - NMT
453 MHz – 458 MHz
DP-450
GSM - 900
880 MHz – 925 MHz
DP-900
GSM - 1800
1710 MHz – 1785 MHz
DP-1800
GSM 1900/TDMS PCS/CDMA PCS
1850 MHz – 1910 MHz
DP-1900
TDMA (NADC)/AMPS 824 MHz – 849 MHz
DP-800
W-CDMA
1920 MHz – 1980 MHz
DP-2000
Korean CDMA
1715 MHz – 1780 MHz
DP-1700
1101 Cypress Creek Road Cedar Park, Texas 78613, USA 1-512-258-9478 FAX 1-512-258-0740
P
PRODUCTS
Communications Applications, continued
ISM (Bluetooth)
2400 – 2483.5 MHz
DP2400
Japan - Low Band
898 MHz – 901 MHz
DP-900-J1
915 MHz – 940 MHz
DP-900-J2
940 MHz – 960 MHz
DP-900-J3
1429 MHz – 1453 MHz
DP-1400
Japan - High Band
Representative Data
Ordering Information
Product:
Dipole Antenna
Model Number:
DP-Series
Warranty:
1 year limited
To place an order or to learn more about the
TDK products that best meet your needs, contact your TDK sales representative:
Mechanical Specifications
Dimensions:
Dependent on operating
frequency; approx. onehalf wavelength
Weight:
Varies by model
Construction:
Available in aluminum,
stainless steel or brass
RF Connector:
SMA (female)
TDK RF Solutions Inc.
1101 Cypress Creek Rd.
Cedar Park, Texas 78613 USA
Phone:
1-512-258-9478
Fax:
1-512-258-0740
info@tdkrf.com
E-mail:
World Wide Web: www.tdkrfsolutions.com
Electrical Specifications
T O T A L I R F
Gain:
See data graph
Impedance
50 Ω
S
SYSTEMS
C
CHAMBERS
E X P E R T I S E ™
P
PRODUCTS
SW TS
SOFTWARE
TEST SERVICES
To learn more about TDK’s wide range of innovative test products, solutions and services visit www.tdkrfsolutions.com
Copyright © TDK RF Solutions Inc. All rights reserved. Specifications subject to change without notice.
Rev. 2011-08-02
很抱歉,暂时无法提供与“DP-2000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6367.62600
- 200+5980.47840
- 500+5780.62440
- 1000+5681.88000
