DPP100-24
DPP100-24
    TDK(东电化)
    DPP100-24
DPP100-24 数据手册
• Low Cost • 5V to 48V Outputs • Universal Input • Compact Size • NEC Class 2 Compliant • UL508 Listed • -10°C to +71°C Operation Key Market Segments & Applications DPP15-100 Series Industrial Controls: Factory Automation: Motor Control Systems Process Control, Automotive, Chemical Processing Test & Measurement: Burn in & Test, Instrumentation Measurement 15-100W, 5-48V Output DIN Rail Mount Power Supplies DPP15-100 Features and Benefits Features Benefits • PFC Compliant to EN61000-3-2 • UL508 Approvals • TS35/7.5 or TS35/15 DIN Rail Mounting Specifications ITEMS AC Input Voltage range MODELS (1) Input Frequency Inrush Current (115 / 230VAC) Power Factor Max Input Current (230VAC) Output Voltage Accuracy Line Regulation Load Regulation Ripple/Noise Overcurrent Protection (Typ) Overvoltage Protection Hold Up Time (115VAC input) Parallel switch LED Indicator Operating Temperature Storage Temperature Operating Humidity Cooling (2) Withstand Voltage Shock Vibration Isolation Resistance Safety Agency Approvals Emissions Immunity Weight (Typ) Size (WxHxD) Case material MTBF (MIL-HDBK-217F, GF25) Warranty VAC Hz A A % % % mV V ms Ω - • Supports Global Use • Easier System Configuration • Easy System Integration DPP15 DPP25/30 85 - 264VAC DPP50 DPP100 85 - 132VAC 176 - 264VAC 47 - 63Hz 35 / 45A 35 / 50A 35 / 55A Meets EN61000-3-2 Class A 0.25 0.4 0.7 1.2 ±1% (24V outputs preset at 24.5V) < 0.5% < 0.5% 120% 125 - 137.5% > 20ms No Yes Green LED = On -10°C to +71°C (Derate linearly 5%/°C from 61°C to 71°C) -25°C to +85°C 20 - 90% RH (non condensing) Convection Input to Output 3kVAC for 1 min. Half sine wave, 4G, 22ms, 3 times per face, X, Y, Z 10-500Hz (20 min sweep) 0.002G2/Hz, 1Grms acceleration X, Y, Z, 1 hour >100MΩ at 25°C & 70%RH, Output to Ground 500VDC IEC/UL/CSA/EN60950-1, 60950-1, UL508, UL1310(3) (Class 2), CE Mark EN55011, EN55032 Class B Radiated & Conducted, EN61000-6-3 EN61000-6-2, EN61000-4-2 Level 4, EN61000-4-3, EN61000-4-6 Level 3 EN61000-4-4 Level 4 (I/P) Level 3 (O/P), EN61000-4-5 Level 3 L-N, Level 4 L/N-PE, EN61000-4-8, EN61000-4-11 g 130 260 390 mm 23 x 75 x 97 45 x 75 x 91 73 x 75 x 97 Plastic Hours 287,000 >288,000 273,000 239,000 yrs 3
DPP100-24 价格&库存
很抱歉,暂时无法提供与“DPP100-24”相匹配的价格&库存,您可以联系我们找货
DPP100-24
    • 1+932.48730
    库存:10
