DPP240-24-1
DPP240-24-1
    TDK(东电化)
    DIN导轨式电源
DPP240-24-1 数据手册
DPP120-240 Series 120W & 240W DIN Rail Mount Power Supplies Features  Low Cost  12V, 24V or 48V Outputs  Auto-ranging input (no manual switching)  Parallel Function Switch  -40(2) to +71°C Operation Key Market Segments & Applications Specifications Model DPP120-xx-1 DPP240-xx-1 AC Input Voltage range VAC 93 - 132 / 186 - 264VAC, single phase. Auto select Input Frequency Hz 47 - 63Hz DC Input Voltage range VDC 210 - 370VDC* Inrush Current (115 / 230VAC) A 24 / 48A 30 / 60A Power Factor Meets EN61000-3-2 Input Current (115 / 230VAC) A 2.8 / 1.4A 5.4 / 2.2A Leakage Current mA 3.5mA Output Voltage Accuracy % -0, +1% of Nominal Line Regulation % ±0.5% Load Regulation % ±1% (±5% when set in parallel mode) Ripple and Noise (20MHz BW) mV 50mV 100mV Overcurrent Protection (Typ) 110 - 145% Overvoltage Protection V See model selector Overtemperature Protection Hold Up Time (230VAC input) ms > 30ms Parallel operation Set in parallel (droop) mode - maximum of 3 units LED Indicators Green LED = On, Red LED = DC Output Low DC Good Relay (24V model only) 0.3A rated normally open relay contacts, closes when output is above 17.6 - 19.4V Operating Temperature °C -40(2) to +71°C (Derate linearly 2.5%/°C from 61 to 71°C) Storage Temperature °C -40 to +85°C Operating Humidity 20 - 95% RH (non condensing) Cooling (1) Convection Withstand Voltage Input to Output 3kVAC for 1 min. Isolation Resistance >100M at 25C & 70%RH, Output to Ground 500VDC Vibration (Operating) - IEC 60068-2-6 (Mounting by rail: Random wave, 10-500 Hz, 2G, ea. along X, Y, Z axes 10 min/cycle, 60 min) Shock (Operating) IEC 60068-2-27 (Half sine wave, 4G, 22ms, 3 axes, 6 Faces, 3 times for each face) Safety Agency Approvals UL508 Listed, IEC/UL/CSA/EN62368-1, 60950-1, CE Mark Conducted & Radiated EMI EN55022 class B EN55022 class A Immunity IEC 61000-4-2, -3, 4, -5, -6. -8, -11 Weight (Typ) g 920 1000 Size (LxWxH) mm 116.6 x 63.5 x 125mm 116 x 83 x 125mm Size (LxWxH) (1) in 4.59 x 2.5 x 4.92” 4.57 x 3.27 x 4.92” Case material Metal Warranty yrs Three years (1) Recommend 1” clearance on all sides (2) DPP120 -35°C *Safety certified for AC input only DPP120-240 Series Outline Drawing (DPP120) Outline Drawing (DPP240) Model Selector Terminal Assignments Model Voltage DPP120-12-1 12V DPP120-24-1 24V DPP120-48-1 48V DPP240-24-1 24V DPP240-48-1 48V Adjust. Range 11.4 - 14.5V 22.5 - 28.5V 45 - 55V 22.5 - 28.5V 47 - 56V Output Curr. 10A 5A 2.5A 10A 5A Overvoltage 15 - 17.4V 30 - 34.8V 60 - 69.6V 30 - 34.8V 60 - 69.6V Other DIN Rail Products DPP DPP480 DSP DLP 15W to 100W 480W single and three phase 10W to 100W low profile 75W to 240W single phase For Additional Information, please visit https://product.tdk.com/info/en/products/power/index.html Eff. 84% 86% 87% 89% 90% # Function 1 2 3 4 5 6 7 8 9 DC Good relay DC Good relay +V +V -V -V Chassis ground L N Snap-on Mounting: snap onto DIN Rail TS35/7.5 or TS35/15. (no tools required) Options Suffix Description Blank B Non detachable connectors Detachable input and output connectors Revision B2: Oct 2020
DPP240-24-1 价格&库存
很抱歉,暂时无法提供与“DPP240-24-1”相匹配的价格&库存,您可以联系我们找货
